stie cineva? ENGINE IMMOBILISER FAULT
- sandor mihai
- Localitate: cluj napoca
- 2: Citroen C5 2.0 hdi 2007
- 3: Citroen XM 2.1 TDI 1993
am schimbat un kit ambreaj la un c5 2.0 hdi.pentru acces, am scos bateria dar si calculatorul.acum, imi da mesajul din titlu si bineinteles ca nu porneste.am incercat metodele cunoscute cu lasarea cheii in contact 2 minute dar nu merge.stie cineva alte metode de remediere a situatiei? se poate anula cumva faza cu recunoasterea cheii?daca da ,cum? mersi pt.orice sfat.
- C i t r o n e l
- Localitate: psaclub.ro
Uite aici documentele referitoare la imobilizator, eventual mai verifica daca calculatorul este bine repus, eu banuiesc ca el a patit ceva, nu face contact vre-o mufa, eventual sigurante...
http://rapidshare.com/files/93772880/im ... r.zip.html
intrebare:
inchiderea/deschiderea din telecomanda merge ok ?
Luc
p.s.
un post ce-l aveam salvat de pe un forum...
Just a note of caution on any multiplexed PSA. Batteries must
not be disconnected until the BSI has been allowed to shut itself
down correctly (approximately 2 minutes after ignition switched off).
If not, the BSI will not save important data such as immobiliser
information etc and may corrupt its own software. This could cause
loss of functions, a non start or a burned out BSI. To do this follow
the 3 minute rule.
Lower the drivers window and switch off any consumers such as
interior lights, radio, vehicle lights etc including unpluging any
accessories that may be plugged into the lighter socket.
Switch off the ignition and remove the key.
Open bonnet and shut all other doors.
Leave the vehicle for 3 minutes WITHOUT operating the key remote or
opening any doors. (time allocated for BSI to shut down) and not re
awaken it.
disconnect battery in normal way (negative first).
Replace battery and reconnect (positive first).
Upon reconnecting negative wait 2 minutes and then reach through
window and switch the side lights on (soft reboot). This is the
cleanest way to wake up the BSI.
Open door.
Turn on the ignition reset clock etc and check operation of
functions.
intrebare:
Luc
p.s.
the 3 minute rule.
awaken it.
Open door.
functions.
Ultima oară modificat Joi 21-Feb-2008 22:08 de către C i t r o n e l, modificat 1 dată în total.
- sandor mihai
fault
mersi.mai verific miine. stii ceva de faza cu tinutul 10 secunde apasat pe unul din butoanele telecomenzii cu contactul pus, cum zicea cineva din oradea?
- C i t r o n e l
doar ce am salvat de pe un forum:
Before sending the unit try the BSI Reset procedure as this may cure your faults:
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items.
- sandor mihai
fault
telecomanda functioneaza,inclusiv deschiderea geamurilor.sunt curios daca merge azi,am lasat-o peste noapte cu bateria pusa.mersi de tot.
- sandor mihai
c5
a murit.nu mai porneste si gata.
- C i t r o n e l
incearca cu alta cheie. mesajul respectiv se refera la faptul ca imobilizatorul nu o lasa sa porneasca... ceea ce ar trebi sa insemne ca nu mai recunoaste cheia... sunt mai multe motive, dar daca spui ca ai demontat doar la motor este totusi dtupid, ca inelul de citire se afla in jurul contactului. totusi, incearca cu cheia de rezerva.
- sandor mihai
c5 de vinzare
luni vine un prieten de la reprezentanta cu un echipament mobil sa vedem ce are.va tin la curent.
engine immobiliser fault
Am patit si eu chestia asta. Pune contactul si lasa-l pus aprox. 1 minut. Dupa asta, daca bateria este ok, motorul va porni.
- sandor mihai
fault
masina a fost diagnosticata,a avut ceva erori dar tot nu merge.caut un calculator.
- C i t r o n e l
Calculatorul nu mai merge... Lexia il identifica ? Poate dialoga cu el ?
Pana sa cumperi unul nou incearca sa-l duci la un service de electronice care are scula de incalzit cu aer cald ptr refacerea lipiturilor; daca nu ai pus mana pe el sa sufere vre-o descarcare electrostatica sunt sanse mari sa fie doar o lipitura rece pe la vre-o mufa.
Luc.
Luc.
- sandor mihai
fault
lexia il vede dar dupa 1 secunda se intrerupe legatura cu el.nu vede turatia electromotorului si nici sincronizarea arborelui cu came,asa mi-a zis tipul care a venit, chestii pe care ar trebui sa le vada.
