ARC Raiders' new flying ARC, the Vaporizer, is quickly becoming one of the Flashpoint update's most talked-about additions. Described as a drone-like aerial enemy that attacks with deadly lasers, it often appears in groups and forces players to rethink movement, spacing, and timing during surface runs ARC Raiders Items.
The game has always leaned on tension, but the Vaporizer takes that to another level by turning the sky itself into a threat. Unlike ground enemies that can be avoided or baited, this new ARC seems designed to punish players who stand still or commit too early to a fight. It's more than just another enemy—it changes the way encounters play out.
What makes the Vaporizer even more interesting is how it fits into the larger Flashpoint update. Set to arrive on March 31, 2026, the update brings not just this flying ARC, but also new weapons, a map condition called Close Scrutiny, and major crafting improvements. Together, these changes make the game's surface feel less predictable and more volatile.
Early previews suggest the Vaporizer is smaller than some of the larger ARC machines but still noticeable in a fight. Its size hints at agility rather than brute strength, which means players will have less time to react once it appears. A flying enemy with a laser naturally adds tension because it can attack from angles that are hard to defend against.
There's also a story side to its arrival. Reports tie it to unknown machines landing across the Rust Belt, with ARC activity spreading into new areas. The Shredder is also expanding into additional regions, which reinforces the idea that the world is becoming more dangerous, rather than just adding one-off boss events. The Vaporizer isn't just a new enemy; it signals that ARC forces are escalating across the map.
For players, the biggest change is in positioning. If the Vaporizer moves in groups and strikes with precise laser attacks, lone-wolf strategies become riskier buy cheap ARC Raiders Coins. Teams that communicate, stay mobile, and balance anti-air and ground tactics will have the best shot at surviving. It's exactly the kind of change that can shake up a live game without altering its core identity.
RSVSR ARC Raiders New Flying ARC: Vaporizer
Total mesaje 187849
Total subiecte 18695
Cel mai nou membru makabaka
