model cutie viteze
branimir
Localitate: caras sevein
model cutie viteze
Mesajde branimir » Lun 29-Ian-2018 14:40
Am un citroen c5 din 2001 cu seria, vf7dc4hxe76108353.
as dori sa stiu,ce model de cutie de viteze am si ce ulei merge in cutie si de cat ulei am nevoie,si daca are un filtru ceva ?
masina are 180000 km cutia merge perfect dar m-am gandit ca poate este nevoie sa schimb uleiu in ea.
urzica
Localitate: Medgidia
Re: model cutie viteze
Mesajde urzica » Lun 29-Ian-2018 21:09
Caracteristicile vehiculului
Linie de produs C5
Nr. APV/PR 09017 CJ 1 0762
Data de Inceput de Garantie DDG 31.08.2001
OPB R00D
NRE e2*98/14*0221*02
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C5
TIP CAROSERIE BERLINA CU 5 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR DIESEL TURBO DW12TED4
TRANSMISIE CUTIE DE VITEZE AUTOMATA4
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EKQ - VOPSEA ROSU LUCIFER
TIP ECHIPARE INTERIOARA VELUR MOARA "FF"
CULOARE GARNISAJ "FG"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA 4HP20
MOTOR (TIP) MOTOR TIP EW/DW
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
MODUL CLAPETA (ADMISIE AER MOTOR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRU
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE CEE 2000 (MOTOR)
RACIRE ULEI SCHIMBATOR PE MOTOR SI CUTIE DE VITEZE
MOTOR RACIRE RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL L4
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 500W
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 23 X 66
STIL ROATA (JANTA) ROATA CU JANTA ALUMINIU MONZA 16 INCI
AMBREIAJ FARA AMBREIAJ
GARNITURA PE PARTEA ROTII GARNITURA LATERALA DE ROATA AC 3300I
GARNITURA PE PARTEA PUNTII GARNITURA PE PARTEA PUNTII AAR 3300I
PNEURI (DIMENSIUNI, TIP) PNEU 215X55X16 W
ROATA (TIP) MONTARE ROATA ALIAJ 2
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA HP
Suspensie Directie Franare
ANTIPATINARE FARA SISTEM ANTIPATINARE
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 148
SUSPENSIE SUSPENSIE NORMALA
SUSPENSIE ACTIVA SUSPENSIE HIDRACTIVA 3 PLUS
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
Caroserie Echipamente
PACHET LOOK EXTERIOR PACHET LOOK EXTERIOR IN CULOAREA CAROSERIEI
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN CULOAREA CAROSERIEI
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) CAPAC DE ROATA MONZA
LUMINA DE PRAG LUMINA PENTRU PRAG
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
OBTURATOR FATA FATA CALANDRU SEMIINCHIS + SCUT DESCHIS
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
ROATA DE REZERVA ROATA ALIAJ + PNEU STANDARD
ACCESORII EXTERIOARE RETROVIZOR SI MANER EXTERIOR IN CULOAREA CAROSERIEI + GUSEU VOPSIT
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
GEAM (TIP) PARBRIZ CU IZOLARE TERMICA
Echipament de interior
PACHET AMBIANTA PACHET AMBIANTA DECORATIUNE LEMN
ALARMA ANTIFURT ALARMA PENTRU VOLUM + PERMETRU - STANDARD
COTIERA DE SCAUN SPATE CU COTIERA SPATE
RADIOTELEFON PREGATIRE PRELIMINARA PENTRU RADIO TELEFON (ANTENA + CABLU)
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD PLANSA DE BORD CU DECORATIUNE DIN LEMN
GARNISAJ SPATIU DE INCARCARE COVORAS DE PORTBAGAJ CARE NU ESTE REVERSIBIL
DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
DIFUZOR MONTARE 4 DIFUZOARE + 2 TWEETERE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA ELECTRICA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR FARA SUPORT REGLARE LOMBARA CONDUCATOR
ELMENTE DE GARNITURA INTERIOARA ELEMENTE DE TAPITERIE INTERIOARA CU TESATURA
COTIERA DE SCAUN FATA MONTARE CU COTIERA FATA
CD FARA MONTARE COMPACT DISC
CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
CD PENTRU AUTO PC FARA CD ROM PENTRU AUTO-PC
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
AFISAJ AFISAJ (RADIO + CEAS + SI SAU T°,CD)
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATOR DE ULEI SENZOR TEMPERATURA
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTIE PASAGER SPATE FARA ELEMENT DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD2"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
REGULATOR DE VITEZA SISTEM DE REGULARIZARE VITEZA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
DEPOZITARE VOLUM DE INCARCARE CU PLASA IN PORTBAGAJ
DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SUPRA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 6
ILUMINAT DEOSEBIT APRINDERE AUTOMATA A LUMINILOR
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
RULARE DRUM CORECT
TRIUNGHI DE PRESEMNALIZARE PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
branimir
Mesajde branimir » Dum 01-Iul-2018 05:51
Pot achimba cutia de viteze automata,cu alta tot automata dar cu 5 trepte de la alt model ?si care ar fi varianta? Multumesc
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Dum 01-Iul-2018 20:12
Nu poti.
Nu usor.
Nu merita.
    Total mesaje 187844
