Citroen C4 a murit...traiasca noul C4 Cactus
Vasea30
Localitate: Iasi
Masina: Renault Scenis 2, 1.6 b, 2006
Mesajde Vasea30 » Sâm 28-Oct-2017 18:19
Citroen Axes C4 Hatchback, New C4 Cactus Takes Its Place At The Range
http://www.carscoops.com/2017/10/citroe ... actus.html
Citroen will drop the C4 hatchback from its range and doesn’t plan a direct replacement up until 2020, leaving temporarily the C4 Cactus as the sole player in the compact segment.
That’s why the French car-maker made the extra effort and significantly re-engineered the Cactus, making it the first European model to come fitted with its new hydraulic suspension, as it targets now to a much wider audience.
An all-new replacement for the C4 hatchback won’t be ready up until 2020 or 2021 while the new C4 Cactus will be launched in Europe at the start of 2018.
“The current C4 is a seven-year-old design and we had to make a decision. We will stop production and the C4 Cactus will take its place,” said Xavier Peugeot, product planning boss to Autocar.
Apart from the new hydraulic suspension, the new C4 Cactus comes with 80 percent new body panels and a more premium front end with extra bits of chrome. Citroen has also added new optional seats that are filled with high-density foam for even more comfort.
“We are talking here about 21st-century comfort in suspension and seats. But it is more than that, Citroën is about well-being and peace of mind,” said Citroën boss Linda Jackson.
Refreshed Citroen C4 Cactus Gains Hydraulic Suspension For A Smoother Ride
http://www.carscoops.com/2017/10/refres ... gains.html
Citroen has pulled the wraps of their facelifted C4 Cactus, which becomes the first European model to offer the company’s new Progressive Hydraulic Cushion (PHC) suspension.
The system debuted with the C5 Aircross and aims to give the more affordable C4 Cactus a buttery smooth and comfortable ride through a set of secondary hydraulic dampers in each corner which replace the conventional bumpstops at both ends.
Citroen has opted for a more comfortable set of the regular springs and dampers in order to further cushion the ride quality. The French company has also redesigned the seats which are now filled with high-density foam for even more comfort over longer drives.
Part of the update is of course the new exterior look of the C4 Cactus, which continues to feature the signature Airbumps, only now they’re mounted just above the sills and are smaller in size.
Other changes include new bumpers front and back along with physically larger lights all around, making the 2018 C4 Cactus look a lot cleaner. Citroen will offer 31 different exterior color combos and a range of five alloy designs to choose from.
Autonomous emergency braking, traffic sign recognition and a driver attention warning system are now part of the new model’s equipment, along with blind spot monitoring, park assist and a rear-view camera. The infotainment features a seven-inch touchscreen display.
Citroen has also added a new engine option in the C4 Cactus range with the 130PS 1.2-litre PureTech engine. The same engine is also offered in 82PS and 110PS versions while there’s also a 100PS diesel.
Noul Citroen C4 Cactus: sistem Airbumps redus, confort sporit și suspensie hidraulică
http://www.automarket.ro/stiri/noul-cit ... 80655.html
Citroen C4 Cactus a primit o actualizare care include o reducere semnificativă a sistemului Airbumps și introducerea suspensiei hidraulice PHC. Modelul este poziționat acum drept un hatchback compact care înlocuiește C4.
Citroen a anunțat joi câteva schimbări importante pentru C4 Cactus. În ciuda faptului că SUV-ul ar fi trebuit să primească doar un facelift, constructorul francez evită acest termen ca urmare a faptului că poziționează acum modelul ca hatchback compact.
Modificarea apare pentru a scoate în evidență că gama de SUV-uri Citroen este alcătuită acum din modele lansate sub brandul Aircross, în timp ce C4 Cactus este considerat doar un înlocuitor pentru C4, a cărui producție a fost întreruptă.
Citroen C4 Cactus: date esențiale:
● blocurile optice, aripile față și ușile au un design ușor modificat, în timp ce stopurile beneficiază de o semnătură LED cu efect 3D;
● francezii renunță aproape complet la sistemul Airbumps. Prezent inițial pe o suprafață generoasă a ușilor din față, acesta este vizibil acum doar în partea inferioară a portierelor cu scopul de a oferi un aspect estetic mai discret și tradițional. Sistemul Airbumps este alcătuit din capsule de aer integrate în ornamentele care îmbracă portierele pentru a evita zgârieturile şi avariile caroseriei care au loc în parcări;
● modelul oferă 5 tipuri de jante din aliaj de 16 inch și 17 inch;
● volumul portbagajului este de 358 de litri și crește la 1.170 de litri în cazul rabatării banchetei din spate;
● Citroen oferă 31 de posibilități de personalizare prin intermediul a 9 culori pentru caroserie și a patru pachete speciale Color Packs;
● C4 Cactus devine primul model european al francezilor care folosește o suspensie hidraulică Progressive Hydraulic Cushions (PHC) care înlocuiește astfel suspensia pneumatică;
● utilizarea noii suspensii oferă un confort sporit pentru pasageri, care beneficiază și de noile scaune Advanced Comfort prin care postura este îmbunătățită;
● modelul include și 5 ambianțe diferite pentru interior, car se deosebesc în special prin tapițeria folosită pentru scaune și culoarea plansei de bord: Standard, Metropolitan Red, Wild Grey, Hype Grey și Hype Red;
● pe consola centrală există un spațiu de stocare generos, priză de 12 V și porturi USB, în timp ce în portiere poți depozita și sticle de 1.5 litri;
● Citroen oferă 3 tehnologii de conectivitate: Mirror Screen Function compatibil cu Android Auto și Apple CarPlay, Connect Nav (cu sistem de navigație TomTom și ecran de 7 inch) și Connect Box (cu sistem de alertare automată a serviciilor de ambulanță în cazul unui accident);
● gama de motorizări rămâne neschimbată. Fanii motoarelor pe benzină au la dispoziție unitățile PureTech de 1.2 litri și 82 CP cu cutie manuală și PureTech de 1.2 litri și 110 CP și 130 CP, în timp ce fanii diesel au la dispoziție doar motorul BlueHDi de 1.6 litri și 100 CP. În toamna anului viitor va apărea însă și o versiune de 120 CP a motorului BlueHDi;
● noul C4 Cactus este disponibil cu 12 sisteme de asitenta, printre care Active Safety Brake, Speed Sign Recognition, Lane Departure Warning System, Blind Spot Monitoring System sau Park Assist.
Via Autocar, L'Automobile, Caradisiac, L'Argus
CITROEN C5 CLUB ROMANIA - facebook.com/groups/110645719379127/
Vasea30
Localitate: Iasi
Re: Citroen C4 a murit...traiasca noul C4 Cactus
Mesajde Vasea30 » Dum 11-Feb-2018 14:58
That’s Fresh: Citroen Is Resurrecting The C4 Hatchback
https://www.carscoops.com/2018/01/thats ... hatchback/
The slow-selling C4 hatchback was dropped last year, and Citroen now has the C4 Cactus pseudo-crossover to compete in the compact segment.
However, in a surprising move, the French firm will reportedly bring the C4 hatch back, reports AutoExpress, after talking to the company’s CEO, Linda Jackson, who admitted that the regular C4 hatchback is still “extremely important” to them.
“I’m not saying we’re going to get rid of Cactus, but we will introduce a new C-segment car“, Jackson said. “It’ll be in the sector, but it will not be traditional. Nor will it necessarily be the C4 Cactus. As time evolves, we’ll move back into what we call our core model strategy, which will be to have a C-segment car.”
Introduced in 2010 and facelifted four years later, the second generation Citroen C4 shared its underpinnings with the first-gen Peugeot 308. The latter was replaced by an entirely new car in 2013, which won the 2014 European Car of the Year award.
PSA’s next logical step would be to use common platforms for the new Citroen C4 (name unconfirmed) and the third generation Peugeot 308, which would allow both cars to share the same engines and technologies and, thus, reduce costs.
At this point, however, there’s no word on when the new C4 might be launched and whether it’ll get a Cactus version as well.
Vasea30
Localitate: Iasi
Mesajde Vasea30 » Dum 10-Iun-2018 13:01
Zona de confort – Test cu noul Citroen C4 Cactus
http://voom.ro/zona-de-confort-test-cu- ... c4-cactus/
Drive-test Citroen C4 Cactus - 1.2 Benzina Turbo (PureTech) 110CP Aut6 Shine
http://www.automarket.ro/test-drive/tes ... 84783.html
Cine a fost la - https://www.lansare-noul-c4-cactus.ro/ ???
Noul Citroën C4 CACTUS HATCHBACK te aşteaptă în showroom-urile noastre din toată țara. Participă la tombolă și poți câștiga o vacanță în doi sau unul dintre celelalte 5 premii surpriză.
    Total mesaje 187856
    Total subiecte 18683
