euro 3 sau euro 4 ?
danilitvin
Localitate: oradea
euro 3 sau euro 4 ?
Mesajde danilitvin » Lun 13-Apr-2015 15:35
buna ziua .daca va rog sa ma ajutati cu o informatie despre un citroen c5 II an fabr 2005
am seria de sasiu VF7RCRHRG76670801
puteti sa imi spuneti ce euro este? eventual tot ce se poate despre dotarile masinii
am incercat pe service.citroen dar nu reusesc sa intruduc vin ul
multumesc frumos
danilitvin
Localitate: oradea
Mesajde danilitvin » Lun 13-Apr-2015 18:36
Scuze..motorul este de 2.0 hdi 137cp
urzica
Localitate: Medgidia
Mesajde urzica » Lun 13-Apr-2015 23:45
Caracteristicile vehiculului
Linie de produs C5 II
Nr. APV/PR 10349 CJ 1 0268
Data de Inceput de Garantie DDG 24.08.2005
OPB A03Z
NRE e2*2001/116*0306*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINA CU 5 USI
FINITION INALTA MEDIE
MOTEUR DIESEL TURBO DW10BTED4 FARA FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EFB - VOPSEA GANACHE
TYPE D’HABILLAGE INTÉRIEUR VELUR MOARA "FF"
COULEUR DE GARNISSAGE "FC"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA HUNGARO 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
JOINT COTÉ ROUE GARNITURA PE PARTEA ROTII DIAMETRU 20
JOINT COTÉ PONT GARNITURA PE PARTEA PUNTII JB3A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R16 W NERANFORSAT
ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE ML6C
Suspensie Directie Franare
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ENJOLIVEUR ROUE (STYLE) TIP HUNGARO
FEU D’ÉCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
PACK LOOK EXTÉRIEUR PACHET LOOK EXTERIOR IN CULOAREA CAROSERIEI
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA RECE
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE LAC NEGRU
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
RANGEMENT SOUS SIÈGE 1 SERTAR DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE DECORATIUNE LAC NEGRU
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 4 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ELÉMENTS DE GARNISSAGE INTÉRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN POLIPROPILENA
ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
COMPACT DISQUE MONTARE COMPACT DISCURI
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE FARA SISTEM DE REGLARE PROIECTOR
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
AMPLI-ÉQUALISEUR CU AMPLIFICATOR EGALIZATOR
FRÉQUENCE RADIO FRECVENTA RADIO ASIA
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
PACK RADIO / INFORMATION / COMMUNICATION RM4 + AMPLIFICATOR
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) FARA SPRIJIN LOMBAR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
DÉMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
Partea de sus a paginii
urzica
Mesajde urzica » Lun 13-Apr-2015 23:47
EURO 3
danilitvin
Localitate: oradea
Mesajde danilitvin » Mar 14-Apr-2015 06:08
Multumesc frumos .
mihaivls
Localitate: Romania
Mesajde mihaivls » Vin 17-Apr-2015 06:40
ca sa nu mai deschid si eu alt topic.
Am si eu aceasi intrebare. C5 II 2005 1.6 HDi 110cp .... nu stiu seria dar daca e nevoie o caut si o postez.
Din fisa tehnica intra foarte bine la euro4 (emisii CO2, particule si restu) .... insa am auzit ca ar fi euro3?
raulolariu
Localitate: timisoara
Mesajde raulolariu » Vin 17-Apr-2015 07:05
Ce tip d3 motor ai'?
mihaivls
Localitate: Romania
Mesajde mihaivls » Vin 17-Apr-2015 07:39
9HZ
mihaivls
Localitate: Romania
Mesajde mihaivls » Vin 17-Apr-2015 09:07
si am uitat sa precizez ... este cu FAP
raulolariu
Mesajde raulolariu » Vin 17-Apr-2015 09:33
iese euro 4 cu siguranta !
mihaivls
Localitate: Romania
Mesajde mihaivls » Vin 17-Apr-2015 10:31
deci cele cu FAP sunt sigur euro 4 nu?
raulolariu
Mesajde raulolariu » Lun 20-Apr-2015 07:47
Nu e obligatoriu poate sa aiba fap si sa fie euro 3 depinde de codul motorului iar 9 hz este e 4
calorifer4
Localitate: Focsani
Mesajde calorifer4 » Lun 20-Apr-2015 09:47
Nu fiti naivi 8), orice vehicul care are norma de poluare trecuta in momentul fabricarii in catalogul tehnic al acesteia nu se poate modifica in nici un fel.
Masina din semnatura cu motor 2.0hdi este euro 3 (L4 nu inseamna euro 4 :lol:... tin minte un samsar care i-a vandut unui amic o masina cu banut verde in parbriz si la pacalit ca este euro 4, culmea a fost euro 3 :roll:... la RAR niciodata o masina euro 3 veche nu va fi omologata euro 4,doar norma respectiva sau sub ia)
raulolariu
Mesajde raulolariu » Lun 20-Apr-2015 09:59
Mda,esti tu putin naiv daca cumperi o masina din strainatate iti va fi foarte simplu sa iei teapa daca nu esti informat corect ,masina mea cand am cumparato scria in brif euro3und d4 si a iesit euro 4 !
calorifer4
Localitate: Focsani
Mesajde calorifer4 » Lun 20-Apr-2015 10:16
raulolariu scrie:Mda,esti tu putin naiv daca cumperi o masina din strainatate iti va fi foarte simplu sa iei teapa daca nu esti informat corect ,masina mea cand am cumparato scria in brif euro3und d4 si a iesit euro 4 !
un gest frumos cu un scan la cartea ta de identitate, din romania te rog!... sa vada ochiu :lol:
Înapoi la “Citroen C5 I-II”
    Total mesaje 187806
    Total subiecte 18663
