Salut ! Doresc sa imi achizitionez un C4 second-hand si am cateva nelamuriri tehnice :
1.Tipul de distributie pentru aceasta masina.
2.Are filtru de particule sau nu? Am verificat la reprezentanta telefonic si nu m-au lamurit.
3.Ce injectoare are - Siemens, Delphi sau Bosch?
VIN VF7LC9HYC74694343
Multumesc anticipat
Lucian
Achizitionare C4
Salut.nu are filtru de particule iar injectoarele sunt Bosch
Caracteristicile vehiculului
Linie de produs C4
Nr. APV/PR 11160 88 1 0601
Data de Inceput de Garantie DDG 09.10.2007
OPB I00F
NRE e2*2001/116*0302*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C4
SILHOUETTE BERLINA CU 5 USI
FINITION SX VTR
MOTEUR DIESEL TURBO DV6TED4 FARA FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EZW - VOPSEA GRI FER
TYPE D’HABILLAGE INTĂRIEUR VELUR COTTA + POINTIL "SQ"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTĂRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
MOTEUR (TYPE) MOTOR TIP EV/DV
MONOGRAMME COMPLĂMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
Caracteristici vehicul
FINITION SX VTR
Alimentare motor
ALIMENTATION INJECTIE TURBO CU SCHIMBATOR DIRECT
DĂTECTEUR D’EAU FILTRE À GAZOLE CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI ALUMINIU
CARBURANT MOTORINA
DĂPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
CYLINDRĂE 1600 CM3
CATALYSEUR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
RĂCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 2 TURATII 130W AERO
RĂCUPĂRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
VARIANTE ASSOCIĂE INJECTION SISTEM DE INJECTIE BOSCH
FILTRE RĂSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT CP 19 X 72
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
TYPE DE BOITE DE VITESSES (HOMOLOGATION) CUTIE DE VITEZE TIP BE4/5 L
DIFFĂRENTIEL (BOITE) DIFERENTIAL 84
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R16 91V FARA INTARIRE
ROUES MONTĂES ROATA 6 INCI 1/2
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA NIVEL 2
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
Suspensie Directie Franare
BARRE ANTIDĂVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 27
COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIDĂVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
SUSPENSION SUSPENSIE NORMALA
CONTRĂLE DYNAMIQUE DE STABILITĂ CU SISTEM ESP
VARIANTE ASSOCIĂE FREIN ESP BOSCH 8 1
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
PĂDALIER (TYPE) PEDALIER STANDARD
Caroserie Echipamente
AVERTISSEURS SISTEM DE AVERTIZARE STANDARD
ANTENNE ANTENA SCURTA PAVILION
DĂFLECTEUR AĂRODYNAMIQUE ARRIÈRE MONTARE CU DEFLECTOR SPATE IN PARTEA SUPERIOARA A CAPACULUI DE PORTBAGAJ
DĂCORATION (PEINTE) DECORATIUNE COLORATA IN MASA
ENJOLIVEMENT LATĂRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATĂRAL (DIMENSION) FARA ELEMENTE DE PROTECTIE LATERALE
ENJOLIVEUR ROUE (STYLE) STIL AZZANA 8 FANTE 16 INCI
FEU DE RECUL CU 1 LUMINA PENTRU MERS INAPOI
FEU D’ĂCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
ETANCHĂITĂ AĂRODYNAMIQUE FARA GARNITURA DE CAPOTA MOTOR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ENJOLIVEUR DE SORTIE D’ĂCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORISATION COTĂ MOTEUR IZOLARE FONICA LA CAPOTA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PARE-CHOCS BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI
PARE-BOUE (BAVETTE) CU APARATORI DE ROTI SPATE
PLAQUE POLICE FARA PLACUTA DE INMATRICULARE
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ROUE DE SECOURS ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
ACCESSOIRES EXTĂRIEURS MANER EXTERIOR + SUPORT + COMANDA SPATE NEUTRA RETROVIZOR IN CULOAREA CAROSERIEI
RĂTROVISEUR EXTĂRIEUR (RAYON COTĂ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (ASPECT) COLORATA
VITRE (TYPE) PARBRIZ STRATIFICAT + GEAMURI LATERALE SI SPATE SECURIZATE
ACCÈS ET DĂMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ALLUME-CIGARE BRICHETA FATA
APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
APPUI-TÊTE AVANT TETIERA FATA REGLABILA
ASSISE ARRIÈRE PERNA SEPARABILA RABATABILA + SPATAR SEPARABIL RABATABIL
ACCOUDOIR ASSISE ARRIÈRE FARA COTIERA SPATE
CEINTURE DE SĂCURITĂ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CEINTURE DE SĂCURITĂ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMAT (TEMPĂRATURE AMBIANTE) TARI CU CLIMA RECE
CONDAMNATION ENFANT SIGURANTA COPIL MANUALA USA SPATE
GRADUATION VITESSES GRADATIE IN KM/H
COMPTE-TOURS TUROMETRU DIGITAL
COTĂ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD MISTRAL FATADA INFERIOARA + SUPORT CREION NEUTRE
FEUX INT. DIVERS PLAFONIERA FATA 3 POZITII
COMBINĂ (CARACTĂRISTIQUES) TABLOU DE BORD DIGITAL CU FATADA GRI LION
GARNISSAGE DE PORTE PANOU DE USA FARA DECORATIUNE CROM SATINAT
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 6 KG
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) FARA PERDEA IMPOTRIVA SOARELUI
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RĂGLAGE ASSISE AVANT CONDUCTEUR FARA SUPORTURI LOMBARE SI LATERALE CONDUCATOR
RĂGLAGE ASSISE AVANT PASSAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATTEMENT ASSISE AVANT CONDUCTEUR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
RABATTEMENT ASSISE AVANT PASSAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT COTIERA CENTRALA
COMPACT DISQUE FARA MONTARE COMPACT DISC
BOITE DE RANGEMENT FARA CONTAINER DE DEPOZITARE
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°, CD) FARA MEMORIE
MIROIR DE COURTOISIE OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
INDICATEUR D’HUILE SENZOR DE NIVEL DE ULEI
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE 3 TETIERE SPATE
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATĂRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
LÈVE-VITRE ĂLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
PACK ĂQUIPEMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
COMMANDE INTĂRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA DE USA CU ASPECT NEUTRU
PLANCHER ARRIÈRE CHARGE FARA PLANSEU SPATE DE INCARCARE
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
PARE-SOLEIL AVANT PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
RANGEMENT (POSTE CONDUITE) COMPARTIMENT DE DEPOZITARE LATERAL, INCHIS FARA SUPORT PENTRU OCHELARI
RĂCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RĂFRIGĂRATION SISTEM DE REFRIGERARE AUTOMATA
RĂGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RĂTROVISEUR INTĂRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
TAPIS MOCHETA TESUTA DILOUR F550
TUNER-RADIO CU UN SINGUR TUNER RADIO
PROTECTION INTĂRIEURE FARA PROTECTIE INTERIOARA
DĂTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
STORES LATĂRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE BURDUF + MANER STANDARD PLACUTA CROMATA
SURTAPIS FARA COVORAS SUPLIMENTAR
AMPLI-ĂQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN SPUMA CU 2 BRATE
RĂTROVISEUR INTĂRIEUR SURVEILLANCE ENFANT FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE BATERIE L2 400
DĂMARREUR DEMAROR CLASA 6
ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
FRĂQUENCE TĂLĂCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION ECHIPAMENT IMBUNATATIT + DEPOLUARE SUPERIOARA
ATMOSPHÈRE ATMOSFERA NORMALA
PRISE D’ĂCOUTE RADIO PRIZA ACCESORII
COTĂ CIRCULATION CIRCULARE PE DREAPTA
CHOCS LATĂRAUX USA CARE NU ESTE INTARITA
JEUX DE CLĂS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
BOĂTIER SERVITUDE BSI + COMANDA VOLAN BUTUC FIX
TRIANGLE DE PRĂSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
Linie de produs C4
OPB I00F
Informatii generale
LIGNE DE PRODUIT C4
FINITION SX VTR
FINITION SX VTR
Alimentare motor
CARBURANT MOTORINA
CYLINDRĂE 1600 CM3
Electricitate
Diverse
ROULAGE DRUM CORECT
Total mesaje 187953
Total subiecte 18702
Total membri 11840
Cel mai nou membru c4coupe
