Buna seara , nu prea ma pricep eu sa fac anunt de vinzare asa ca o sa postez tot ce scrie la Citroen ca are masina mea.
In plus , 169.000 km , intretinere la ATS apoi la Khan , in plus are cirlig remorca cu modulul CAN-BUS original , stare perfecta interior ( este masina de familie ) , exterior in stare f buna pt km ei , ne retusata , f mici si putine urme.
Revizie distributie , pompa apa , etc efectuat la 150.000 la Khan , scut metalic motor , tavita plastic portbagaj . alarma , bare portbagaj noi nefolosite ,
consum afara 6,2 , oras , 9.4 %.
Accept orice verificare la orice service ( bineintzeles din Bucuresti :) )
Taxa de drum nu a fost platita , este Euro4 , n am facut nici un demers in acest sens.
de la Citroen :
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINE 5PTES
FINITION HAUTE MOYENNE
MOTEUR DIESEL TURBO DW10BTED4 FAP
TRANSMISSION BVA 6 RAPPORTS
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE EZR - PEINTURE GRIS ALUMINIUM
TYPE D’HABILLAGE INTĂRIEUR VELOURS MOARA "FF"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTĂRISTIQUES) BVA AM6B
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLĂMENTAIRE, DIVERS SANS MONOGRAMME
COMPLEMENTAIRE
MONOGRAMME C5
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
COUPLE TACHYMÈTRE CT 22 X NO
DĂTECTEUR D’EAU FILTRE À GAZOLE AVEC DETECTEUR EAU
FILTRE GASOIL
CARBURANT GAZOLE
DĂPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
REFROIDISSEMENT D’HUILE ECHANGEUR SUR MOTEUR ET BV
MOTEUR REFROIDISSEMENT RADIATEUR EP:32 - 21 DM2 ALU BRASE
RĂCHAUFFAGE CIRCUIT GAZ CARTER RECHAUFFAGE CIRCUIT GAZ
CARTER
VARIATION PUISSANCE (MOTEUR) PUISSANCE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT
"EGR"
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLLUTION TECHNIQUE
VEHICULE EURO 4
FILTRE À PARTICULE FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 160W
VARIANTE ASSOCIĂE INJECTION SYSTEME INJECTION SIEMENS
FILTRE RĂSERVOIR FILTRE RESERVOIR INTERIEUR
COUPLE RAPPORT CP 15 X 53
STYLE ROUE ROUE HUNGARO 16 POUCES
EMBRAYAGE SANS EMBRAYAGE
JOINT COTĂ ROUE JOINT COTE ROUE AC 3300I
JOINT COTĂ PONT JOINT COTE PONT AAR 3300I
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X16 W
ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS
INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE BVA AM6
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION HYDRACTIVE 3 PLUS REGLAGE
AUTO
CONTRĂLE DYNAMIQUE DE STABILITĂ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE
ASSISTEE
ENJOLIVEMENT LATĂRAL (ASPECT) PROTECTEURS LATERAUX COULEUR
CAISSE
ENJOLIVEMENT LATĂRAL (DIMENSION) PROTECTEURS LATERAUX
PLASTIQUE + CHROME
ENJOLIVEUR ROUE (STYLE) TYPE HUNGARO
FEU D’ĂCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION
COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETRO EXT
RABATTABLE ELECTRIQUE SANS MEMOIRE
ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
ESSUIE-PROJECTEUR ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR
CAISSE
VITRE (TYPE) P-B ATHER+ACCOUS+REFL+LAT FEUILL+AR TREMPE
PACK LOOK EXTĂRIEUR PACK LOOK EXTERIEUR COULEUR CAISSE
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
CLIMAT (TEMPĂRATURE AMBIANTE) PAYS FROIDS
GRADUATION VITESSES GRADUATION EN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD DECOR LAQUE NOIRE
GARNISSAGE VOLUME CHARGEMENT SANS TAPIS
RANGEMENT SOUS SIÈGE 2 TIROIRS DE RANGEMENT SOUS SIEGE
GARNISSAGE DE PORTE DECOR LAQUE NOIRE
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) STORE
AR MANUEL
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE
AVANT
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV ELECT
CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV ELECT PASSAGER
ELĂMENTS DE GARNISSAGE INTĂRIEUR GARNISSAGE PIED
CENTRAL TISSU + CUSTODE POLYPRO
ACCOUDOIR ASSISE AVANT ACCOUDOIRS AVANT CONDUCTEUR ET
PASSAGER
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
LAMPES DE PROJECTEURS LAMPE A DECHARGE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT +
CONDAMNAT
LECTEUR D’INFORMATIONS ROUTIÈRES SANS SURVEILLANCE
TRAJECTOIRE LATERALE
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC
ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPERATURE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND +
PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION
MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE
PROJECTEURS
RĂCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD4"
RĂFRIGĂRATION REFRIGERATION AUTOMATIQUE
RĂGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
RĂTROVISEUR INTĂRIEUR RETROVISEUR INT JOUR-NUIT
ELECTROCHROME
RĂGULATION CLIMATISATION / TEMPĂRATURE REFRIGERATION
AUTOMATIQUE BI-ZONE
RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
TUNER-RADIO MONO TUNER RADIO
DĂTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AVANT
ARRIERE
AMPLI-ĂQUALISEUR SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT MOUSSE 4 BRAS
PACK RADIO / INFORMATION / COMMUNICATION RD4
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN
LOMBAIRE AUTOMATIQUE
ALTERNATEUR ALTERNATEUR CLASSE 18
BATTERIE BATTERIE L3 450
DĂMARREUR DEMARREUR CLASSE 6+
ECLAIREMENT PARTICULIER FEUX DIURNE
PASS AV
PROJECTEURS
FRĂQUENCE RADIO FREQUENCE RADIO ASIE
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
COTĂ CIRCULATION CIRCULATION A DROITE
TRIANGLE DE PRĂSIGNALISATION CONDITIONNEMENT TRIANGLE
PRESIGNALISATION
Grigore 0722786069
Pret orientativ 5.000 Euro.
[VAND] Citroen C5 2006 diesel , BVA6 , H3 ,
La Multi Ani!
VIN
VF7RCRHRJ76747955
Vine Sf. Ion , asa ca Ion si Ioana au reducere!
VF7RCRHRJ76747955
este de actualitate
Am facut din nou control tehnic si nu am avut nici o surpriza neplacuta.
Poate solutia cea mai buna pentru cine o doreste este ruta Bulgaria pentru evitarea taxei.
DONEZ Citroen C5
Adica mai exact il dau la cea mai buna oferta .
In momentul de fata masina nu merge pentru ca are ceva la turbosuflanta. Nu stiu ce , nu sint mecanic , considerati varianta cea mai rea.Masina se afla in curtea unui service iar eu nu am elan sa o repar caci nu mai imi trebuie.
Pentru a fi folosita sau dezmembrata , cum doriti , astept oferte pe mesaj privat . Revin in Bucuresti la inceputul saptaminii viitoare dar am acces la email si net .
Curaj , masina asteapta un proprietar iubitor asa cum am fost si eu.
Înapoi la “Vanzari/Cumparari Auto”
Total mesaje 187828
Total subiecte 18669
Total membri 11845
