[DEZMEMBREZ] 2 Citroen C4 coupe 1.4i 16V si 1.6i 16V
Tot ce este legat in mod direct de Citroen. Cititi cu atentie REGULILE publicate in header-ul sectiunii! Anunturile vor contine OBLIGATORIU o descriere cat mai detaliata a produsului, datele de contact si PRETUL. Nerespectarea acestor reguli duce la stergerea anuntului. ATENTIE: Discutiile Off-Topic vor fi sterse fara notificare prealabila.
constantadezmembrari
Localitate: constanta
Mesajde constantadezmembrari » Mie 06-Feb-2013 00:03
Dezmembrez Citroen C4 coupe 1.4i 16V si 1.6i 16V an fabricatie 2006, 1.4i 16V 65kw (88cp) tip KFU (ET3J4) si 1.6i 16V 80kw (110cp) tip NFU (TU5JP4) cutie de viteze 5+1 trepte, ABS, Servodirectie electrica, geamuri si oglinzi electrice, cruise control, comenzi volan, proiectoare ceata, jante tabla si aliaj cu cauciucuri iarna 195/65 R15, capace roti OEM, 4X Airbag, computer de bord, A/C clima, scut motor.
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capote portbagaj, haion, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa injectie, electrovalva, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompa servo directie electrica , brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate, bascule,; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa,racitor ulei, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbag sofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; pasager, ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
Cezcarino
Localitate: Radauti
Mesajde Cezcarino » Mie 06-Feb-2013 16:48
Doar mâner portierã stânga spate?
Mesajde constantadezmembrari » Joi 07-Feb-2013 23:17
Cezcarino scrie:Doar mâner portierã stânga spate?
masina este coupe !
mariuss
Localitate: Slatina,Olt
Mesajde mariuss » Mie 13-Mar-2013 22:40
Pret pt far stanga?
Înapoi la “Vanzari/Cumparari/Schimburi”
Utilizatori ce ce navighează pe acest forum: Niciun utilizator înregistrat și 13 vizitatori
    Total mesaje 187829
    Total membri 11848
