Cine ma ajuta cu o citere vin?
doru81
Localitate: cluj-napoca
Mesajde doru81 » Mar 05-Feb-2013 17:10
Doresc sa-mi achizitionez un citroen xsara picasso, si i-as fi recunoscator celui care imi poate furniza informatii legat de vin-ul masinii.
VF7CHRHYB39330529
Multumesc
mihai ham
Localitate: Valcea
Mesajde mihai ham » Mar 05-Feb-2013 17:23
Caracteristicile vehiculului
Linie de produs XSARA PICASSO
Nr. APV/PR 09422 FV 2 0025
Data de Inceput de Garantie DDG 27.09.2002
OPB P000
NRE e2*98/14*0153*03
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT XSARA PICASSO
SILHOUETTE BERLINA FAMILIALA
FINITION MEDIE MEDIE
MOTEUR DIESEL TURBO DW10TD
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE KDD - VOPSEA SABLE BIVOUAC
TYPE D’HABILLAGE INTÉRIEUR VELUR DALICAN "HC"
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME FARA MONOGRAMA
Caracteristici vehicul
DIRECTION SISTEM DE DIRECTIE ASISTATA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X 18
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI FONTA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
REFROIDISSEMENT D’HUILE MONTARE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR 27MBA - 21 DM2 - PAS 1,1
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
AUTODIAGNOSTIC EOBD FARA SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 3 TURATII 460W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
Cutie de viteze Transmisie
COUPLE RAPPORT CP 19 X 72
STYLE ROUE ROATA DIN TABLA 15 INCI
EMBRAYAGE AMBREIAJ CU CABLU CU SISTEM DE PRELUARE A JOCULUI
JOINT COTÉ ROUE GARNITURA LATERALA DE ROATA DIAMETRU 17,5
JOINT COTÉ PONT GARNITURA LATERALA DE PUNTE JB2A
DIFFÉRENTIEL (BOITE) DEFERENTIAL SUPERIOR
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 185/65 R15 H CARE NU ESTE INTARIT
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
Suspensie Directie Franare
ANTIBLOCAGE ANTIBLOCARE ROATA
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 21
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 21
FREIN TYPE DISCURI FATA VENTILATE / TAMBURE SPATE
SUSPENSION SUSPENSIE NORMALA
CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
Caroserie Echipamente
ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
ENJOLIVEUR ROUE (STYLE) STIL HENDAYE 7 FANTE 15 INCI
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
OBTURATEUR FACE AVANT OBTURATOR MARE (INTRARE MICA AER)
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ACCESSOIRES EXTÉRIEURS MANERE EXTERIOARE + BAGHETE LATERALE + RETROVIZOARE EXTERIOARE NEUTRE
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (ASPECT) COLORATA
Echipament de interior
ASSISE ARRIÈRE 3 SCAUNE SPATE SEPARATE (1 CULISANT)
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
GRADUATION VITESSES GRADATIE IN KM/H
CONSOLE FARA CONSOLA
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
EQUIPEMENT PLANCHE DE BORD BANDOU V098 + PANOU FRONTAL COLORAT IN MASA
HAUT-PARLEUR FARA DIFUZOARE
COMMANDE D’AUTORADIO FARA COMANDA SISTEM AUDIO LA DISTANTA
ACCOUDOIR ASSISE AVANT MONTARE CU COTIERA FATA
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG DUBLU LATERAL FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
RÉFRIGÉRATION COMPLÉMENTAIRE FARA REFRIGERARE SUPLIMENTARA
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
RÉCEPTEUR RADIO FARA SISTEM AUDIO
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES FARA SISTEM DE REGULARIZARE VITEZA
RANGEMENT VOLUME CHARGEMENT CARUCIOR DE INCARCARE AMOVIBIL
ADAPTATION GARNITURE FARA ADAPTARE GARNITURA
VOLANT VOLAN IMBRACAT CU SPUMA
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE BATERIE L2 400
DÉMARREUR DEMAROR CLASA 6
ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
MULTIPLEXAGE FARA MULTIPLEXARE
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION DEPOLUARE
ATMOSPHÈRE ATMOSFERA NORMALA
BOÎTIER SERVITUDE FARA BSI (BOITIER DE SERVITUDE)
doru81
Mesajde doru81 » Sâm 09-Feb-2013 20:46
Multumesc.
Imi poti spune daca motorul 2.0 hdi ,90 cai are distributie pe lant sau curea? multumesc
marianmarian
Localitate: cernavoda
Mesajde marianmarian » Sâm 09-Feb-2013 20:59
curea .
la citirea VIN-lui sa iti spuna si cati km are masina .
sorel
Masina: Scenic
2: Xsara Picasso
Re: Cine ma ajuta cu o citere vin?
Mesajde sorel » Vin 22-Iun-2018 07:49
Salut, va rog daca se mai poate o citire VIN Xsara Picasso 2.0HDI 90cp 2003 VF7CHRHYB39779250. Multumesc
soctav25
Localitate: slobozia
Mesajde soctav25 » Vin 22-Iun-2018 18:39
Caracteristicile vehiculului VF7CHRHYB39779250
Nr. APV/PR 10101 FV 2 0068
Data de Inceput de Garantie DDG 07.11.2004
OPB P000
NRE e2*98/14*0153*07
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS XSARA PICASSO
TIP CAROSERIE BERLINA FAMILIALA
NIVEL DE ECHIPARE JOASA INALTA
MOTOR DIESEL TURBO DW10TD
TRANSMISIE CUTIE DE VITEZE MANUALA5
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI VOPSEA EAU LIMPIDE
TIP ECHIPARE INTERIOARA VELUR SISAL "PX"
CULOARE GARNISAJ "FD"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
EVOLUTIE DEFINITIE TEHNICA ANIMATIE DE GAMA
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA FARA MONOGRAMA
DIRECTIE SISTEM DE DIRECTIE ASISTATA
CUPLU DE TAHOMETRU RAPORT TRANSMISIE 22 X 18
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
BLOC CILINDRI (MATERIAL) BLOC CILINDRI FONTA
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE CEE 2000 (MOTOR)
RECIRE ULEI MONTARE SCHIMBATOR APA/ULEI MOTOR
MOTOR RACIRE RADIATOR 27MBA - 21 DM2 - PAS 1,1
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATE DE PUTERE (MOTOR) PUTERE STANDARD
AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL L4
FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 2 TURATII 140W AERO
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
MODUL CLAPETA (ADMISIE AER MOTOR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
CUPLU RAPORT CP 19 X 72
STIL ROATA (JANTA) ROATA DIN TABLA 15 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
GARNITURA PE PARTEA ROTII GARNITURA LATERALA DE ROATA DIAMETRU 17,5
GARNITURA PE PARTEA PUNTII GARNITURA LATERALA DE PUNTE JB2A
DIFERENTIAL (CUTIE) DIFERENTIAL 84
PNEURI (DIMENSIUNI, TIP) PNEU 185/65 R15 88H NERANFORSAT
ROATA (TIP) MONTARE ROATA CU JANTA DIN TABLA
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
ANTIBLOCARE ANTIBLOCARE ROATA
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 21
FRANA TIP DISCURI FATA VENTILATE / TAMBURE SPATE
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII FARA SISTEM ESP
VARIANTA ASOCIATA FRANA ABS BOSCH 5 3
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
ORNAMENT DE ROATA (STIL) STIL BAYONNE 16 FANTE 15 INCI
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU PLIERE MANUALA
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
OBTURATOR FATA FATA OBTURATOR MARE (INTRARE MICA AER)
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ACCESORII EXTERIOARE MANERE EXTERIOARE + BAGHETE LATERALE + RETROVIZOARE EXTERIOARE NEUTRE
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
GEAM (ASPECT) COLORATA
SCAUN SPATE 3 SCAUNE SPATE SEPARATE (1 CULISANT)
CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA FARA ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GRADARE VITEZE GRADATIE IN KM/H
CONSOLA FARA CONSOLA
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD BANDOU V098 + PANOU FRONTAL COLORAT IN MASA
DIFUZOR MONTARE 4 DIFUZOARE + 2 TWEETERE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
COTIERA DE SCAUN FATA MONTARE CU COTIERA FATA
CD FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
ACTIONARE GEAM SPATE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG DUBLU LATERAL FATA
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
REFRIGERARE COMPLEMENTARA FARA REFRIGERARE SUPLIMENTARA
RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD3"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
REGULATOR DE VITEZA FARA SISTEM DE REGULARIZARE VITEZA
DEPOZITARE VOLUM DE INCARCARE CARUCIOR DE INCARCARE AMOVIBIL
DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
ADAPTARE GARNITURA FARA ADAPTARE GARNITURA
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L2 400
DEMAROR DEMAROR CLASA 6
ILUMINAT DEOSEBIT FARA ILUMINAT SPECIAL
MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN VAN
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE DEPOLUARE
ATMOSFERA ATMOSFERA NORMALA
LICHID REFRIGERANT LICHID REFRIGERANT R134
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI COMM 2000
sorel
Masina: Scenic
2: Xsara Picasso
Mesajde sorel » Mar 26-Iun-2018 10:27
Pt. soctav25 multumesc, cine stie cit timp o sa fiu dator?
marianotelul
Localitate: Galati
Masina: Citroen Xsara Picasso
2: nu
Mesajde marianotelul » Mie 04-Iul-2018 20:52
Salutare, ma poate ajuta cineva cu citire VIN VF7CH9HXC25852958? Ma intereseaza daca a iesit din fabrica autoutilitara (2 locuri) sau autoturism (5).
Multumesc anticipat.
leo2
Masina: citroen c5 lll
Mesajde leo2 » Joi 05-Iul-2018 17:13
Nr. APV/PR 10809 FV 2 0434
Data de Inceput de Garantie DDG 19.12.2006
OPB P003
Informatii generale
MOTOR DIESEL TURBO DV6ATED4
CULOAREA CAROSERIEI EZW - VOPSEA GRI FER
TIP ECHIPARE INTERIOARA VELUR AUSTRAL + MISTECO2 "WP"
CULOARE GARNISAJ "FR"
MOTOR (TIP) MOTOR TIP DV
Alimentare motor
BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO 4 (MOTOR)
RECIRE ULEI FARA SCHIMBATOR APA/ULEI
MOTOR RACIRE RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
DIFERENTIAL (CUTIE) DIFERENTIAL 77
VARIANTA ASOCIATA FRANA ABS BOSCH 8 0
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
SCAUN SPATE FARA PERNA DE SEZUT SPATE
CENTURA DE SIGURANTA SPATE FARA CENTURA DE SIGURANTA SPATE
INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CONDUCATOR
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
REFRIGERARE SISTEM DE REFRIGERARE SIMPLA
DEPOZITARE VOLUM DE INCARCARE FARA SANIE DE INCARCARE
Electricitate
ILUMINAT DEOSEBIT LUMINA DIURNA
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE VEHICUL COMERCIAL CARE SE POATE TRANSFORMA
Utilizatori ce ce navighează pe acest forum: Niciun utilizator înregistrat și 15 vizitatori
