[DEZMEMBREZ] Citroen C5 sedan si combi 2.0 hdi si 2.2 hdi.
Tot ce este legat in mod direct de Citroen. Cititi cu atentie REGULILE publicate in header-ul sectiunii! Anunturile vor contine OBLIGATORIU o descriere cat mai detaliata a produsului, datele de contact si PRETUL. Nerespectarea acestor reguli duce la stergerea anuntului. ATENTIE: Discutiile Off-Topic vor fi sterse fara notificare prealabila.
constantadezmembrari
Localitate: constanta
Mesajde constantadezmembrari » Vin 25-Ian-2013 00:22
Dezmembrez Citroen C5 sedan si combi an fabricatie 2001-2004 2.0 HDI 66kw (90cp) tip RHY (DW10TD),2.0 HDI 80KW (109 CP) tip RHZ DW10ATED, 2.2 HDI 98 KW (133 CP) tip 4HX (DW12ATED), cutie de viteze automata si manuala 5+1 trepte, jante aliaj R15 cu cauciucuri iarna, 8 airbag-uri, suspensie reglabila 4 trepte, cutie viteze 5+1, servodirectie, ABS, ESP,comenzi volan, cruise control, geamuri electrice, oglinzi electrice heliomate, scaune reglabile, navigatie.
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capotaportbagaj/haion, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa inalta presiune, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompaservo directie, brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbagsofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
fiki
Localitate: medgidia
Masina: c 5 2004 raposata ...
2: c 5 x7 2008 exclusiv
Mesajde fiki » Dum 14-Apr-2013 12:15
sal vreun radio cd original mai este pe cele doua c5 care le dezmembrezi?si daca este un pret te rog
Înapoi la “Vanzari/Cumparari/Schimburi”
    Total mesaje 187829
    Total membri 11848
