[DEZMEMBREZ] Citroen Xsara 1.5D, 1.9D, 2.0 HDI, 1.6i, 2.0i
Tot ce este legat in mod direct de Citroen. Cititi cu atentie REGULILE publicate in header-ul sectiunii! Anunturile vor contine OBLIGATORIU o descriere cat mai detaliata a produsului, datele de contact si PRETUL. Nerespectarea acestor reguli duce la stergerea anuntului. ATENTIE: Discutiile Off-Topic vor fi sterse fara notificare prealabila.
constantadezmembrari
Localitate: constanta
Mesajde constantadezmembrari » Vin 25-Ian-2013 00:18
Dezmembrez Citroen Xsara an fab 1997-2006 1.5D, 1.9D, 2.0 HDI, 1.6i, 2.0i. 1.9 TD, 1.6i 16V 80kw (110cp) tip NFU (TU5JP4), 1.9D, 1.5 D 42kw (58cp) tip VJZ (TUD5/L3), 2.0i 16V 97kw (135cp) tip RFV,1.9TD 66kw (90cp) tip DHY (XUD9), 2.0 HDI 66kw (90CP) tip RHY si 2.0 HDI 80kw (110cp) tip RHZ, hatchback, cutie de viteze 5+1 trepte, geamuri si oglinzi electrice, ABS, 4X Airbag, clima A/C, inchidere centralizata,Radio/CD OEM, jante tabla R14 si aliaj R15.
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capotaportbagaj/haion, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa injectie, pompa benzina, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompaservo directie, brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbagsofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
th3k1d87
Localitate: tg-mures
Mesajde th3k1d87 » Joi 26-Sep-2013 17:44
Buna
Aveti sprituitoarele de far din bara ,practice suportul de diuza de sprituitor care este ascuns in bara sub ornamental de pe bara stg si dr.
Înapoi la “Vanzari/Cumparari/Schimburi”
    Total mesaje 187829
    Total membri 11848
