[DEZMEMBREZ] Citroen Saxo 1.5D 42kw 58cp tip VJZ an fab 2001
Tot ce este legat in mod direct de Citroen. Cititi cu atentie REGULILE publicate in header-ul sectiunii! Anunturile vor contine OBLIGATORIU o descriere cat mai detaliata a produsului, datele de contact si PRETUL. Nerespectarea acestor reguli duce la stergerea anuntului. ATENTIE: Discutiile Off-Topic vor fi sterse fara notificare prealabila.
constantadezmembrari
Localitate: constanta
Mesajde constantadezmembrari » Vin 25-Ian-2013 00:11
Dezmembrez Citroen Saxo (echivalent Peugeot 106) 1.5D 42kw (58cp) tip VJZ (TUD5/L/L3) an fabricatie 2001, cutie de viteze 5+1 trepte, 2+1 usi hatchback, servodirectie, pompa injectie Lucas, Airbag, geamuri electrice, inchidere centralizata, oglinzi manuale, jante tabla 165/70 R13 si R14 cu capace roti originale,
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capotaportbagaj/haion, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa injectie Lucas, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompaservo directie, brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbag sofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
mewtwo
Mesajde mewtwo » Lun 25-Feb-2013 12:29
Buna ziua,
Fata de usa (interiorul) si inchiderea centralizata cat costa ?
Multumesc
Înapoi la “Vanzari/Cumparari/Schimburi”
    Total mesaje 187829
    Total membri 11848
