http://www.autoevolution.com/news/psa-r ... 54264.html
PSA Reveals All-New EMP2 Modular Platform [Video]
PSA Peugeot-Citroen has just released a video showcasing their all-new modular platform, called the EMP2, which stands for Efficient Modular Platform 2. The French group are planning to use it on a wide range of vehicles, from SUVs to light commercial vehicles, as well as regular hatchbacks, sedans and estates.
It will also be used to underpin the next generation of the Peugeot 308 and Citroen C4, as well as other mainstream models from the C and D segments.
The platform itself is easily modifiable, and can be stretched to fit various purposes, while the use of high-strength steels, composites and aluminium help it shed some 70 kg or 154 lbs over the current platform.
However, in their quest to make one platform fit all models, they have had to compromise. First of all, the idea of having just one platform is a clear cost-cutting exercise, and therefor they could not make it overly-complex, as it would be overkill on some of the cheaper models.
What this means, basically, is that it does`t get independent rear suspension, getting the multilink alternative instead. Now, while some cars with such rear suspension setups are good to drive (some Renaults and a few others), it means that neither handling nor comfort will be class leading.
We also found a plausible-looking rendering of what the next Peugeot 308 may look like, to give you some idea of the cars this new platform will underpin.
VIDEO => http://www.youtube.com/watch?v=h4Xqa1_w ... r_embedded
Noua platforma modulara EMP2 de la grupul PSA
Vasea30
- Localitate: Iasi
- Masina: Renault Scenis 2, 1.6 b, 2006
CITROEN C5 CLUB ROMANIA - facebook.com/groups/110645719379127/
Total mesaje 187844
