Mi-a murit claxonul
Mi-a murit claxonul
Ieri am avut masina in service iar electricianul de acolo a reusit sa imi dea foc la un releu cind umbla la alarma - aftermarket, ce functiona perfect - de ce umbla la ea nu stiu, eu am adus masina pt altceva. L-a inlocuit si totul a parut normal pina azi dimineata cind am vazut ca nu mai am claxon. Asa ca as avea si eu nevoie de o schema pentru cutia de relee de sub bord si cablajul ei - daca s-a ars cablajul de claxon s-ar putea sa se fi ars si altceva si vreau sa verific tot. Daca cineva o are m-ar face fericit.
verifica siguranta F7 (20 amperi) din interiorul masinii
schema claxon:
Datedespre sigurante:
ELECTRICAL SYSTEM
Xantia's electrical system is of 12-volt negative earth type. Power for the lights and all electrical accessories is supplied by a lead/acid type battery, which is charged by the alternator. Electrical problems usually stem from simple causes, such as loose or corroded connections, a faulty earth connection, a blown fuse, a melted fusible link, or a faulty reley.
Below is listed all fuses, number codes and ratings. At the bottom of the list are bulbs listed also.
Note that the fuses are color-coded as follows:
Color Rating (amps)
Orange 5
Red 10
Blue 15
Yellow 20
Clear or white 25
Green 30
Facia fusebox with 30 fuse locations - models up to January 1998
No Rating (amps) Circuit(s) protected
F1 10 Radio and CD player (via ignition or battery direct, depending on fuse position)
F2 5 Coded anti-theft keypad, instrument panel lighting rheostat, instruments, "lights-on" warning system, washer fluid level sensor, automatic heating relay
F3 10 Reversing light, cooling fan, diagnostic socket
F4 5 Left-hand sidelight, right-hand tail light, "lights-on" warning system
F5 15 Coolant temperature warning system
F6 10 ABS
F7 20 Horn reley, horn compressor
F8 30 Suply shunt F25/F15
F9 5 Instruments, right-hand sidelight, left-hand tail light
F10 30 Rear electric windows
F11 30 Sunroof
F12 10 Heating, air conditioning, cruise control, Hydractive suspension, alarm system, alarm siren, instruments
F13 10 Tow bar
F14 40 Electric seats (power)
F15 20 Heated seats, alarm (led), boot lighting, courtesy light delay timer
F16 20 Front cigarette lighter (via ignition or battery direct, depending on fuse position)
F17 15 Alarm (power supply)
F18 10 Rear foglights
F19 5 Cigarette lighter and switch illumination
F20 30 Heater blower (power supply)
F21 30 Central locking
F22 20 Tailgate wiper
F23 10 Heated rear window switch, heated seat switches
F24 30 Widscreen wiper, lighting, automatic gearbox
F25 5 Radio memory, clock, diagnostic socket, CD player of cooling fan, central locking remote control
F26 15 Hazard warning light switch
F27 30 Heated rear window heated mirrors (power suply)
F28 15 Sunroof control, rear window wiper isolator, direction indicators, instruments, STOP and break pad wear warning lights, ABS, cruise control
F29 30 Front electric windows
F30 15 Map reading lights, vanity mirror light, glovebox light, electric seat control., electric window switch, telephone
Facia fusebox with 30 fuse locations - models from January 1998
F2 10 Coolant temperature warning system, diagnostic socket
F3 10 Hydractive suspension
F5 10 Daytime running lights relay, heater blower relay, heated seats relay, heated rear screen switch
F6 10 ABS, cruise control
F7 20 Horn reley, towbar
F8 - Shunt to fuse 23
F9 5 Right-hand sidelight, left-hand tail light
F11 20 Sunroof
F12 20 Rewersing lights, stop-light switch, instrument panel, air conditioning
F13 20 Heated seats
F14 20 Fuel injection ECU, air conditioning
F15 30 Instrument panel, diagnostic socket, body computer
F16 20 Cigarette lighter
F17 10 AL4 transmission ECU
F18 10 Rear foglight and warning light
F19 5 Sidelights
F20 40 Electric seats
F21 30 Heater blower
F22 5 Sunroof
F23 -
F24 20 Widscreen/tailgate wipers and washers, rain sensor
F25 10 Radio, digital clock, alarm LED, body computer, instrument panel, ambient temperature display
F27 30 Electric front windows
F28 15 Map reading ligght, flasher unit, rear wiper motor, exterior mirror control, automatic transmission selector illumination
F29 30 Heated rear window, heated mirrors
F30 15 Ambient temperature display, digital clock, instrument panel, electric window motors
Engine compartment fuses - models up to January 1998
F1 20 ABS
F2 10 Telephone
F3 30/40 Cooling fan
F4 Free
F5 5 Cooling fan
F6 30 Headlight wash timer, front foglights
F7 5 Fuel injection
F8 20 Hydractive suspension
F9 10 Fuel pump reley
F10 5 Headlight washers
F11 5 Oxygen sensor reley
F12 10 Left-hand headlight main beam
F13 10 Right-hand headlight main beam
F14 10 Left-hand headlight dipped beam
F15 10 Right-hand headlight dipped beam
Engine compartment fuses - models from January 1998
F1 20 ABS
F2 40 Air injection pump
F3 30 Cooling fan
F4 Free
F5 5 Cooling fan
F7 20 Fuel injection
F11 5 Oxygen sensor reley or cruise control
Bulbs
Type Wattage
Headlights
Main beam H1 55
Dipped beam H1 55
Front foglight H3 55
Front sidelights Push-fit 5
Direction indicator light Bayonet 21
Direction indicator side repeater Push-fit 5
Stop/tail light Bayonet 21/5
Rear foglight Bayonet 21
Reversing light Bayonet 21
Number plate light Push-fit 5
Interior lights Push-fit 5
Fuses locations may vary according to model. This list is valid in cars made during 1993-1998.
schema claxon:
ELECTRICAL SYSTEM
Color Rating (amps)
Orange 5
Red 10
Blue 15
Yellow 20
Clear or white 25
Green 30
F6 10 ABS
F11 30 Sunroof
F13 10 Tow bar
F11 20 Sunroof
F13 20 Heated seats
F19 5 Sidelights
F22 5 Sunroof
F23 -
F1 20 ABS
F2 10 Telephone
F4 Free
F5 5 Cooling fan
F7 5 Fuel injection
F1 20 ABS
F3 30 Cooling fan
F4 Free
F5 5 Cooling fan
Bulbs
Type Wattage
Headlights
Main beam H1 55
Dipped beam H1 55
