verificare serie masina
Eurofighter
Mesajde Eurofighter » Joi 22-Dec-2011 00:41
"inspirandu-ma" de pe celelalte threaduri ale forumului, este cineva dispus sa verifice o serie de C5?
VF7RDRHF89L511737
mai mult: ce service imi recomandati pentru verificarea masinii?
as vrea sa cumpar un C5, dar numai dupa verificari "minutioase"
imi puteti da unele sfaturi cu privire la achizitie?
multumesc!
hippo
Localitate: Timisoara
Mesajde hippo » Joi 22-Dec-2011 08:40
Eu am avut acces doar la datele pe care le poti citi mai jos. Poate ca cei care au cont pe http://service.citroen.com, la sectiunea cu plata, pot sa-ti dea mai multe detalii despre acel C5.
C5 (X7) BERLINE 4PTES 2.0 HDi 138 FAP BVM 6
Caracteristicile vehiculului
Linie de produs C5 (X7)
Nr. APV/PR 11768 CJ 1 0476
Data de Inceput de Garantie DDG 18.02.2009
Numar de Serie al Motorului 10 DYXH 4014854
Numar de Serie al Cutiei 20 MB25 0716104
OPB H4DM
NRE e2*2001/116*0360*04
Informatii generale
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 (X7)
SILHOUETTE BERLINE 4PTES
FINITION SUPERIEURE BASSE PLUS
MOTEUR DIESEL TURBO DW10BTED4 FAP
TRANSMISSION BVM6
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE KTV - PEINTURE NOIR PERLA NERA
TYPE D’HABILLAGE INTÉRIEUR C&T CUIR ST CYR + CUIR "XS"
COULEUR DE GARNISSAGE "FC"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM ML6 CL
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS EXCLUSIVE
MONOGRAMME C5
Caracteristici vehicul
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
COUPLE TACHYMÈTRE SANS C T
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 5(MOTEUR)
CATALYSEUR CATALYSEUR INF 10PPM
RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 5
FILTRE À PARTICULE FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 150W
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION DELPHI
FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
STOP AND START SANS STOP AND START
Cutie de viteze Transmisie
TRANSMISSION BVM6
COUPLE RAPPORT CP 16 X 69
STYLE ROUE ROUE BALTIQUE 17 POUCES
EMBRAYAGE EMBRAYAGE HYDRAULIQUE
DIFFÉRENTIEL (BOITE) DIFFERENTIEL 86
JANTE / PNEU DIMENSION MONTE PNEU 17 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/55 R17 W NON RENFORCE
ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE ML6C
Suspensie Directie Franare
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 20,5
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 24,5
COURSE MÉCANISME DE DIRECTION COURSE MECANISME DIRECTION 180
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION ACTIVE REGLAGE MANUEL
SUSPENSION (TYPE ARCHITECTURE) SUSPENSION HYDRAULIQUE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX CHROME
ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE + CHROME
ENJOLIVEUR ROUE (STYLE) CABOCHON BALTIQUE 17 POUCES
SORTIE D’ÉCHAPPEMENT SORTIE ECHAPPEMENT NON CHROMEE
FEU D’ÉCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL AVANT + ARRIERE
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE AVEC MEMOIRE
ESSUIE-VITRE AVANT EV AV INTER CAD AUTOMATIQUE 16 VIT
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
ESSUIE-PROJECTEUR ESSUIE-PROJECTEUR
VITRE PAVILLON SANS VITRE PAVILLON
PARE-CHOCS P/C CC + PROT CHROME + ENJO GRILLE CHROME
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) GLACE RETROVISEUR EXTERIEUR TEINTEE
ACCESSOIRES EXTÉRIEURS POIGNEE EXT ASPECT CHROMEE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS ENJOLIVEUR CENTRAL AR CHROME
VITRE (ASPECT) TEINTEE + SURTEINTEE
VITRE (TYPE) P-B FEUILLETE ACCOUSTIQUE + AR TREMPE
Echipament de interior
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
CLIMAT (TEMPÉRATURE AMBIANTE) PAYS TEMPERES
GRADUATION VITESSES GRADUATION EN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD DECOR METAL PALEA
FEUX INT. DIVERS ECLAIRAGE AMBIANCE
GARNISSAGE VOLUME CHARGEMENT SANS TAPIS
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 260 KM/H 160 M/H MATRICE COULEUR
GARNISSAGE DE PORTE DECOR ANODISE SOFT
HAUT-PARLEUR 4 HP AV (2TW+2HP) + 5 HP AR (2TW+2HP+1C BASSE)
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) STORE AR MANUEL
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE AVANT ARRIERE
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV A MEMOIRE CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV ELECT PASSAGER
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) ACCOUDOIR AV MANUEL
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION AVEC SYSTEME NAVIGATION ECRAN COULEUR
LAMPES DE PROJECTEURS LAMPE A DECHARGE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
LECTEUR D’INFORMATIONS ROUTIÈRES SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR AFFICHEUR (NAVIGATION+VIDEO+RADIO+MONTRE,T°,CD)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX AV + RIDEAU
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS PASS AV + AR
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
PROJECTEUR DIRECTIONNEL AVEC PROJECTEUR DIRECTIONNEL
RÉCEPTEUR RADIO SYSTEME RADIOTELEPHONE "RT4"
RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE ELECTRIQUE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RÉGULATION CLIMATISATION / TEMPÉRATURE REFRIGERATION AUTOMATIQUE BI-ZONE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TUNER-RADIO BI TUNER RADIO
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AVANT ARRIERE
STORES LATÉRAUX STORES LATERAUX COMMANDE MANUELLE
ADAPTATION GARNITURE POMMEAU LEVIER VITESSE+SOUFFLET CUIR
AMPLI-ÉQUALISEUR AVEC AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT CUIR 4 BRAS DECOR METAL
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN LOMBAIRE AUTOMATIQUE
PRIZA AUXILIARA PACK AUDIO 1 PRISE RCA AUDIO
Electricitate
ALTERNATEUR ALTERNATEUR CLASSE 18
BATTERIE BATTERIE L3 450
DÉMARREUR DEMARREUR CLASSE 5
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE + FEUX DIURNES AV
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
BOITIER TELEMATIQUE SANS BOITIER TELEMATIQUE
Marci de echipamente
Diverse
ATMOSPHÈRE ATMOSPHERE NORMALE
COTÉ CIRCULATION CIRCULATION A DROITE
EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS
ROULAGE BONNE ROUTE
Eurofighter
Mesajde Eurofighter » Joi 22-Dec-2011 15:27
multumesc mult, hippo!
ce inseamna urmatoarele caracteristici?
stie cineva?
multumesc!
Mesajde mbc » Joi 22-Dec-2011 17:02
suspensie normala, nu Hydractive 3 plus
suspensie activa dar fara mod automat sport / confort
suspensie hidrapneumatica (respectiv nu suspensie clasica, de tabla)
Eurofighter
Mesajde Eurofighter » Joi 22-Dec-2011 17:35
merci!
Eurofighter
Mesajde Eurofighter » Joi 22-Dec-2011 18:48
care este diferenta dintre suspensia normala si H3+, respectiv dintre suspensia activa cu mod automat si cea fara modul automat?
hippo
Mesajde hippo » Joi 22-Dec-2011 19:28
@Eurofighter, nu pot decat sa ma bucur ca ti-au fost de folos datele despre C5.
Sa auzim numai de bine! :lol:
C i t r o n e l
Localitate: psaclub.ro
Mesajde C i t r o n e l » Joi 22-Dec-2011 19:50
C5-III din ce stiu eu nu se comercializeaza decat cu H3+ sau supensie de tabla, fara alte variante de suspensie hidraulica.
H3 vs H3+
- H3 nu are modul sport/confort ca si H3+
- H3 are mai putine sfere decat H3+ ( pe fata doar 2 fata de 3 la H3+ pe spate doar 2... )
H3+ pana la 60km ora este in mod confort ( daca nu este selectat sport ) apoi acesta este decuplat - sferele confort dezactivate.
Eurofighter
Mesajde Eurofighter » Joi 22-Dec-2011 20:18
hm
deja nu mai stiu ce sa cred despre masina asta :P
cum pot observa daca are H3+ sau altceva?
sper sa ajung maine la un test drive, si poate imi fac un cadou de Craciun :)
Mesajde mesersmith » Joi 22-Dec-2011 21:44
Pai tocmai ce ti-a raspuns colegul Citronel.
Uita-te intre scaune daca intre cele doua butoane de ridicare, ai si un al treile buton pe care scrie SPORT.
Daca-l ai, ai H3+, daca nu, ai H3 simplu.
Eurofighter
Mesajde Eurofighter » Vin 23-Dec-2011 00:44
aha!
merci
e vorba despre acest buton, da?
ce ma mai deranjeaza la el, este unul din butoanele de pe volan care este tocit;
nu este doar vopseaua putin uzata, ci tot butonul e dus
se poate intampla asta in 70000 km? eu cred ca nu
sa fie un semn ca masina are mai multi kilometri decat sunt afisati?
butonul respectiv este Set+
Eurofighter
Mesajde Eurofighter » Vin 23-Dec-2011 10:37
a luat-o altcineva...
fara cadou de Craciun anul asta :(
Eurofighter
Mesajde Eurofighter » Joi 15-Mar-2012 16:45
salut,
poate cineva sa verifice seria urmatoare?
VF7RDRHF854098542
multumesc
exclu20
Localitate: Oltenita
Mesajde exclu20 » Lun 19-Mar-2012 08:43
intra pe http://service.citroen.com/ creeaza-ti un cont si poti verifica singur seria masinii ( cum a iesit din fabrica )
Detalii despre istoric, km. revizii numai la reprezentanta.
Mesajde mbc » Lun 19-Mar-2012 09:25
de pe service citroen:
Vehicle characteristics
Vehicle family C5 (X7)
AS RPO No 11707 CJ 1 0083
Warranty Start Date 16/12/2008
OPB H4DM
BER e2*2001/116*0360*04
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 (X7)
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL UPPER LOW PLUS
ENGINE DIESEL TURBO DW10BTED4
TRANSMISSION BVM6
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR KTV - BLACK PEARL PAINT
INTERIOR TRIM TYPE W&W LEATHER ST CYR + LEATHER "XS"
UPHOLSTERY COLOUR "FC"
GEARBOX (CHARACTERISTICS) BVM ML6 CL
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " EXCLUSIVE
BADGE C5
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EMISSION CONTROL EURO 5 (ENGINE)
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER CATALYTIC CONVERTER LESS THAN 10PPM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER PARTICLE FILTER
FAN 1 ELECTRONIC FAN INTEGRAL CTRL 150W
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITHOUT STOP AND START
Gearbox-Driveshafts
TRANSMISSION BVM6
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 16 X 69
WHEEL STYLE WHEEL BALTIQUE 17 INCH
CLUTCH HYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 86
RIM/TYRE SIZE 17 INCH TYRE FITMENT
TYRE (SIZE, TYPE) TYRE 225/55 R17 W NON-REINFORCED
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR TYRE DEFLECTION INDICATOR
GEARBOX TYPE ML6C
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20.5
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24,5
STEERING TRAVEL 180 STEERING MECHANISM TRAVEL
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION ACTIVE SUSPENSION MANUAL ADJUSTMENT
SUSPENSION (ARCHITECTURE TYPE) HYDRAULIC SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
Body fittings
SIDE MOULDINGS (TYPE) CHROME SIDE PROTECTORS
SIDE MOULDINGS (DIMENSION) PLASTIC + CHROME SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) WHEEL TRIM BALTIQUE 17 INCH
EXHAUST TAILPIPE NON CHROME PLATED EXHAUST TAIL PIPE
SILL ILLUMINATION LAMP SILL LIGHT FRONT AND REAR
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR
WINDSCREEN WIPER FRONT WIPER AUTO SPEED 16 SPEED
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER HEADLAMP WASHWIPE
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COL BUMPER + CHROME PROT + CHROME GRILLE TRIM
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE) TINTED EXT REAR VIEW MIRROR
EXTERIOR ACCESSORIES CHROME EFFECT EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM CHROMED REAR CENTRAL TRIM
GLASS (APPEARANCE) TINTED + OVER-TINTED
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITH REAR ARMREST
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT PALEA METAL DECOR
MISC. INT. LAMPS AMBIENT LIGHTING
LOAD SPACE TRIM W/O MAT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 260 KM/H 160 M/H COLOUR MATRIX
DOOR TRIM SOFT ANODISED DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT REAR ADJUSTMENT SPACER
DRIVER SEAT CONTROL MEMORY CTRL DRIVERS FRONT SEAT
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT ELEC CNTRL
FRONT SEAT ARMREST (OPERATION) FRONT ARMREST MANUAL
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS DISCHARGE BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY MONOCHROME SCREEN LEVEL C DISPLAY
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING FRONT PASSENGER AND REAR FOOTWELL ILLUMINATION
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
DIRECTIONAL HEADLAMP WITH DIRECTIONAL LIGHTS
RADIO RECEIVER "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS WITHOUT SIDE BLINDS
TRIM ADAPTATION LEATHER GEAR LEVER KNOB + LEATHER GAITER
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL 4 BRANCH LEATHER STEER WHEEL DECOR METAL
SEAT LUMBAR SUPPORT (OPERATION) AUTOMATIC LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET 1 AUDIO RCA SOCKET
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L3 450
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING AUTOMATIC LIGHTING + FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Component manufacturers
Miscellaneous
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
LABEL WITHOUT
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
Înapoi la “Citroen C5 III”
    Total mesaje 187794
    Total subiecte 18658
    Total membri 11825
    Cel mai nou membru FHV
