Citire coduri
Azrael
Citire coduri
Mesajde Azrael » Vin 11-Noi-2011 13:57
Am cumparat un cititor de coduri Autel MaxiScan MS300 (nou) in speranta ca o sa vad de ce mi s-a aprins becul din bord dar de fiecare data cind il incerc i-mi da Link error - nu poate citi. E cumva Xantia II incompatiibila cu OBD II ? Sau e ceva in neregula sau cu masina mea?
e.miron
Localitate: Comanesti, Bacau
Masina: Xantia 2.0 HDI110
Mesajde e.miron » Sâm 12-Noi-2011 01:58
Autel MaxiScan MS300 CAN OBD-II Scan Tool (Automotive)
I thought I had a bad unit with LINK ERROR on two different cars. You will never see the MAXISCAN MS300 display on the LCD, as described in the manual. Here are the real steps to follow:
1. With the ignition off plug it in. I immediately saw CAN OBD2 on the LCD.
2. Turn the ignition switch to the ON position. This is the position just before you crank the starter. Do not start the vehicle.
3. Then press the ENTER button on the reader which starts the scan.
4. Use the SCROLL button on the reader to view the results.
Note that just resetting the code will not let you pass inspection. The sensors have to return a ready/OK code for the emissions test. It takes driving several miles for the sensors to retest and get back to the ready/OK status.
Sper sa-ti fie de folos. Daca nu intelegi striga tare si iti traduc eu dar acum sunt obosit si ...somnic
Azrael
Mesajde Azrael » Sâm 12-Noi-2011 09:52
asta am incercat de la inceput - degeaba, tot Link Eror i-mi arata. Am incercat si toate celelalte posibilitati, nici un efect.
Azrael
Mesajde Azrael » Sâm 12-Noi-2011 14:01
Da, e de la masina:
- Despite having an OBD-II-type (16 pin) connector on the MK2, sadly no Xantia is OBD-II compatible -
Asta e, trebuie sa o duc la cineva cu Lexia.
Mesajde mbc » Sâm 12-Noi-2011 14:54
daca tot suntem la subiectul acesta, masina mea (c5 din 2005) este compatibila obd 2?
Ultima oară modificat Sâm 12-Noi-2011 14:57 de către mbc, modificat 1 dată în total.
e.miron
Mesajde e.miron » Sâm 12-Noi-2011 14:55
eu am luat un conector chinezesc ieftin, o clona dupa ELM327 si merge binisor. Pot vedea cam 10 parametri de motor si functionare. Pot citi codurile dar nu le pot sterge.
Standardul pt Xantia nu e OBD2 , e EOBD.
@ mbc - la Diesel, legislatia a impus standardizarea OBD2 la toate masinile de dupa 2002, asa incat sunt mari sanse sa fie full compatibil.
Mesajde mbc » Sâm 12-Noi-2011 14:57
eu am pe benzina :)
e.miron
Mesajde e.miron » Sâm 12-Noi-2011 15:05
Atunci e sigur compatibil pt ca standardizarea la benzina s-a facut de prin 1998.
Mesajde mbc » Sâm 12-Noi-2011 15:21
E bine de stiut, merci. Eu vroiam sa imi iau o "chestie" obd2 wireless ca sa o pot conecta (wireless) la telefonul mobil si sa imi arate diferiti parametri in diferite situatii, cred ca stii despre ce vorbesc.
e.miron
Mesajde e.miron » Dum 13-Noi-2011 03:43
wireless e pentru iPhone ca nu are bluetooth. Pt android bluetooth merge ok cu Torque iar pt symbian nu stiu cum se cheama aplicatia dar am citit ca merge un pic cu scartaituri. deh nu degeaba se duce nokia de rapa.
Mesajde mbc » Dum 13-Noi-2011 08:57
wireless = fara cablu acuma ce tehnologie foloseste e partea a doua. la bluetooth ma gandeam si eu. Nokia se duce de rapa? nu ai vazut ultimele anunturi? Nokia e back in business.
Azrael
Mesajde Azrael » Dum 13-Noi-2011 09:35
De fapt EOBD -ul (o varianta mai complicata de OBD2 si complet compatibila cu el) a devenit obligatoriu pe toate masinile europeene (prin lege) abia dupa 2001 la benzina si 2004 la motorina, iar Citroen a asteptat pina in ultimul moment sa le converteasca si nici atunci complet. Am citit ca C5-pe benzina nu au fost complet compatibile decit incepind cu 2008, cu a doua generatie. Pina la urma pentru masinile dinainte de 2008 singurul sistem sigur e Lexia. Asa ca masina lui mbc va merge, dar e aproape sigur ca nu o sa vada toate datele. Iar asta nu va fi influentata in nici un fel de ce cititor folosesti. Imprumuta si tu un cititor din-ala simplu cum am luat eu si verifica daca merge inainte sa bagi banii, ori o sa patesti ca mine.
Apropo, stie cineva ce cabluri ai nevoie pt Proxia si de unde as putea face rost de ele?
sergiuliku
Localitate: Turda, Cluj
Mesajde sergiuliku » Dum 13-Noi-2011 14:40
carei treaba cu Lexia, OBD etc etc... este ceva mufa la masina pt. conectare si verificare (tester)? au toata xantiile? daca da, unde se afla?
Azrael
Mesajde Azrael » Dum 13-Noi-2011 17:12
Toate masinile moderne au un sistem de autodiagnosticare. OBD2 este sistemul generic, creat de americani in '96. EOBD este un sistem mai evoluat, creat de europeeni incepind cu '01. Lexia (si diferitele variante) e un sistem facut strict pentru masinile PSA - doar partial compatibil cu OBD2 sau EOBD.
Ca sa accesezi sistemul iti trebuie un cititor specializat care se cupleaza intr-o mufa speciala - la Xantia2 e in bord, lunga sigurante.
sergiuliku
Mesajde sergiuliku » Dum 13-Noi-2011 17:46
si xantia mea? 1.9td '97? are mufa pt diagnosticare? sau unde ar trebui sa ma uit, tot langa sigurante?
    Total mesaje 187833
    Total subiecte 18673
    Cel mai nou membru oprean
