Coduri eroare senzor turbina - 1.6HDI
mike.omega
Localitate: Constanta
Masina: Daewoo Nubira II 1.6 GPL
2: Citroen C4 1.6 HDI
3: Citroen C3 1.1i
Mesajde mike.omega » Sâm 15-Oct-2011 21:11
Salutare!
Fiindca am primit de la cineva un dispozitiv de citire a datelor prin bluetooth si cateva programele gratis/demo am zis sa vad si eu ce coduri de eroare prezinta C4. Motorul in general nu mai dezvolta aceeasi putere care inainte.
Codurile de eroare sunt :
P0299 - For SID 803; Check vacuum supply to controller solenoid, they have been known to leak vacuum.
I have seen an EDC16C3 system with a recked turbo.
P2566 - Turbocharger Boost Control Position Sensor Circuit Intermittent
P2563 - For SID 803; Check for turbo control vacuum supply, possibly too weak. Look at other solenoid valves for vacuum leakage. (Stable 750mb vacuum with engine running).
P2562 - For SID 803; Check for turbo control vacuum supply, possibly too weak. Look at other solenoid valves for vacuum leakage. (Stable 750mb vacuum with engine running).
Explicatiile le-am gasit cu google.
Pareri? Opinii?
Multumesc
claus4you
Mesajde claus4you » Dum 16-Oct-2011 08:42
P0299
Supraalimentare slabĂŁ turbo/compresor de supraalimentare; Sau:; Sistem admisie de aer, scurgere detectatĂŁ
restu nu stiu sa-ti zic
eu :D
mike.omega
3: Citroen C3 1.1i
Mesajde mike.omega » Lun 23-Ian-2012 21:38
Problema s-a rezolvat la service (fosta reprezentanta Citroen) prin schimbarea unui senzor si verificat parametrii motorului la drum. Cost: 180 ron. Cat si pentru ce, nu stiu, n-am fost eu cu masina la service.
Înapoi la “Probleme C4”
    Total mesaje 187842
    Total subiecte 18674
