istoric masina
stelea
Localitate: Hunedoara
istoric masina
Mesajde stelea » Lun 31-Ian-2011 17:25
Buna ziua, sunt nou venit in club, zilele trecute am luat un citroen c5 din 2004, foarte reusita masina. Poate cineva sa ma ajute cu niste date ( istoric ) despre masina. Seria este VF7DCRHZB76440723 . Va multumesc .
danutz
Localitate: Falticeni-Suceava
2: Ex : C 5 I și C 5 II
3: Tel : 0745.81.83.40
Mesajde danutz » Lun 31-Ian-2011 17:48
Ia d-acilea ! Cred ca e cam tot.Apropo, astea sunt datele masinii.Pt istoric service poate te ajuta alt coleg, pt ca nu am acces.Bafta !
Linie de produs C5
Nr. APV/PR 09690 CJ 1 0658
Data de Inceput de Garantie DDG 10.03.2004
Numar de Serie al Motorului 10 DYPK 6011405
Numar de Serie al Cutiei 20 LM23 0223676
OPB R002
NRE e2*98/14*0220*03
Informatii generale
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5
SILHOUETTE BERLINE 5PTES
FINITION HAUTE MOYENNE
MOTEUR DIESEL TURBO DW10ATED SANS FAP
TRANSMISSION BVM5
TYPE DE PEINTURE PEINTURE OPAQUE
COULEUR DE CAISSE PEINTURE BLANC BANQUISE
TYPE D’HABILLAGE INTÉRIEUR VELOURS OTTI PZ
COULEUR DE GARNISSAGE "FC"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM ML5C
MOTEUR (TYPE) MOTEUR TYPE EW/DW
Caracteristici vehicul
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
MOTEUR REFROIDISSEMENT RADIATEUR EP:27 - 21 DM2 ALU BRASE
AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC EOBD
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT EGR
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
FILTRE À PARTICULE SANS FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR 3 VITESSES 500W
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
Cutie de viteze Transmisie
TRANSMISSION BVM5
COUPLE RAPPORT CP 16 X 65
STYLE ROUE ROUE TOLE 15 POUCES
EMBRAYAGE EMBR HYDRAULIQUE CDE ASSISTEE
JOINT COTÉ ROUE JOINT COTE ROUE DIAMETRE 20
JOINT COTÉ PONT JOINT COTE PONT JB3A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195X65X15 H
ROUE (TYPE) MONTAGE ROUE TOLE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE BVM ML
Suspensie Directie Franare
ANTIPATINAGE SANS ANTIPATINAGE
COURSE MÉCANISME DE DIRECTION COURSE MECANISME DIRECTION 166
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION HYDRACTIVE 3
CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE
ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE
ENJOLIVEUR ROUE (STYLE) STYLE CHAMBORD 14 AJOURS 15 POUCES
FEU D’ÉCLAIRAGE DE SEUIL SANS FEU ECLAIRAGE DE SEUIL
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT SANS FONCTION COMPLEMENTAIRE
ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS POIGNEES EXT + RETRO EXT COULEUR CAISSE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
VITRE (TYPE) PARE-BRISE ATHERMIQUE
PACK LOOK EXTÉRIEUR SANS PACK LOOK EXTERIEUR COULEUR CAISSE
Echipament de interior
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
RADIO-TÉLÉPHONE PRE-CONDITIONNEMENT RADIO TELEPHONE(ANTENNE+CABLE)
GRADUATION VITESSES GRADUATION EN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD STANDARD
GARNISSAGE VOLUME CHARGEMENT SANS TAPIS
RANGEMENT SOUS SIÈGE 2 TIROIRS DE RANGEMENT SOUS SIEGE
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) STORE AR MANUEL
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE AVANT
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RÉGLAGE ASSISE AVANT CONDUCTEUR SANS REGLAGE LOMBAIRE COND
ELÉMENTS DE GARNISSAGE INTÉRIEUR GARNISSAGE PIED CENTRAL + CUSTODE TISSU
ACCOUDOIR ASSISE AVANT ACCOUDOIRS AVANT CONDUCTEUR ET PASSAGER
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
CD ROM POUR AUTO PC SANS CD ROM POUR AUTO-PC
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPERATURE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE SANS REGLAGE PROJECTEUR
RÉCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS RD3
RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR - NUIT
RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT MOUSSE 4 BRAS
PACK AMBIANCE SANS PACK AMBIANCE
Electricitate
ALTERNATEUR ALTERNATEUR CLASSE 15
DÉMARREUR DEMARREUR CLASSE 5
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
BOÎTIER SERVITUDE BSI LIGHT COM 2000
TRIANGLE DE PRÉSIGNALISATION SANS TRIANGLE PRESIGNALISATION
stelea
Mesajde stelea » Lun 31-Ian-2011 19:11
Multumesc mult . O seara placuta
danutz
Mesajde danutz » Lun 31-Ian-2011 19:24
Cu placere.Asemenea si tie !
laci_troen
Localitate: oradea
Mesajde laci_troen » Vin 04-Feb-2011 21:08
Din pacate istoric sters ca la multele aduse din Franta, dac te intereseaza km posibil sa fie ceva informatii in jurnalul masinii dar asta cu Lexia
danutz
Mesajde danutz » Vin 04-Feb-2011 22:39
Istoricul NU se poate sterge daca service-ul a fost facut in reteaua Citroen.Daca nu, asta e...
C i t r o n e l
Localitate: psaclub.ro
Mesajde C i t r o n e l » Sâm 05-Feb-2011 01:49
Mai nou vad ca nu se mai poate afisa de pe server istoricul de garantie la masinile care au iesit din garantie.
danutz
Mesajde danutz » Sâm 05-Feb-2011 10:25
In cazul meu, mi-au zis la Citroen ce s-a lucrat pe le masina si pe la ce km (dar asta numai in Franta, de unde a fost adusa).Dupa aia, nimic pt ca nu cred ca cel care avut-o a facut service-ul in reteaua Citroen.Si nici masina mea nu mai era in garantie; posibil sa aiba doar reprezentantele acces la aceste date ? :roll: :roll: :roll:
C i t r o n e l
Mesajde C i t r o n e l » Sâm 05-Feb-2011 10:50
Eu despre accesul de reprezentanta vorbesc, de anul acesta NU se mai afiseaza istoricul la cele iesite din garantie.
p.s.
chiar daca ei spun ca s-a schimbat aplicatia de fapt s-au scos si informatile istorice.
Detaliile de contract sunt vizibile ca si pina acum dar NU si istoricul la cele iesite din garantie.
laci_troen
Localitate: oradea
Mesajde laci_troen » Sâm 05-Feb-2011 13:26
Nu de dragul de a ma contrazice, dar acum am intrat pe VIN-ul meu si se vede tot ce afost in garantie,sustin ca cele din Franta nu se vad (nu neaparat toate,nu am explicatie) dar am intalnit si pe Peugeot.Nici ale tale Lucian nu se vad.daca vrei iti trimit Vin -ul meu sa te convingi pe PM
C i t r o n e l
Mesajde C i t r o n e l » Sâm 05-Feb-2011 14:30
Ok poti sa-mi trimiti pe PM/email sa verific.
Deci unele merg altele nu merg. Nu cred ca e problema doar de cele din Franta deoarece eu am incercat si cu alte VIN-uri inclusiv din Ro, DE... probabil noua aplicatie are bug-uri sau baza de date a patit ceva.
Înapoi la “Citroen C5 I-II”
    Total mesaje 187823
    Total subiecte 18666
