PROBLEME CUTIE AUTOMATA C3!!!!!!!!!!!!!!!! HELP!!!!!!!!!!!!!
CARLO81
Localitate: CONSTANTA
Mesajde CARLO81 » Lun 19-Iul-2010 08:24
BUNA ZIUA, POSED UN C3 1.4 I DIN 2003 CU CUTIE AUTOMATA 4 TREPTE. PROBLEMA ESTE CA ATUNCI CAND MOTORUL ESTE LA INCEPUT DE TRASEU ADICA CAND ESTE MAI RECE, LA TRECEREA DIN TREAPTA 3 IN TREPTA 4 SE BLOCHEAZA IN TREAPTA 3. "D" ADICA DRIVE SE TRENSFORMA INTRO "-" IMI DA SEMNAL ACUSTIC DE EROARE SI MI SE APRIND MARTORII DE SPORT SI ZAPADA. DACA O SCOT PE MANUAL NU REACTIONEAZA DE NICI UN FEL NU VREA SA SCHIMBE VITEZELE DELOC. AM CONSTATAT CA RAMANE BLOCATA IN VITEZA 3, PENTRU CA A INCETINIT SI AM PLECAT DIN NOU, ACESTA PLEACA SUBTURATA SI CAND AJUNG LA VITEZA IN CARE NORMAL SE SCHIMBA IN TREAPTA 4 ACESTA RAMANE TURATA SI NU SCHIMBA. AM OPRIT MASINA PE DREAPTA, AM OPRIT MOTORUL, L-AM REPORNIT AM PLECAT DIN NOU, SI NU IMI MAI APARE PROBLEMA PANA DE EXEMPLU A DOUA ZI CAND PLEC CU EA DIN NOU LA DRUM.
- AM FOST LA ATS BUCURESTI SI MI-AU SPUS SA SCHIMB BATERIA CA NU MAI ARE AMPERAJUL NECESAR SI CA CUTIA AUTOMATA ISI IA NECESARUL DE FUNCTIONARE DIN BATERIE. AM SCHIMBAT BATERIA SI ACESTA PROBLEMA REAPARE.
- AM FOST LA UN SERVICE DIN CONSTANTA ACESTIA MI-AU REFACUT NIVELUL LA ULEI LA CUTIE, TOT DEGEABA
- MI-A MAI SPUS CINEVA CA TREBUIE "RESOFTAT" CALCULATORUL
ASTEPT CEVA SFATURI CA NU IMI POT EXPLICA CE POATE AVEA SI DE CE SE INTAMPLA DOAR LA INCEPUT DE TRASEU, DUPA O PERIOADA DE MERS NU MAI APARE PROBLEMA PE TOT RESTUL ZILEI.
Mesajde khan » Mie 21-Iul-2010 11:37
renunta la CAPS te rog!!!
iliescu sorin
Localitate: Constanta
Masina: C 5 Break 2,0 . hidramata, an 2004
2: CX 2,0 Break. an 1989
3: Xsara 1,4 i , an 2002
Cutie hidramata
Mesajde iliescu sorin » Mie 21-Iul-2010 13:21
Cum intri in Lazu pe dreapta visavis de service Peugeot pe dreapta este o curte cu un mic service + magazin piese auto. La service ( fara firma ) il cauti pe Mircea .
CARLO81
Re: Cutie hidramata
Mesajde CARLO81 » Joi 22-Iul-2010 14:34
iliescu sorin scrie:Cum intri in Lazu pe dreapta visavis de service Peugeot pe dreapta este o curte cu un mic service + magazin piese auto. La service ( fara firma ) il cauti pe Mircea .
Ok, mersi mult!!! O sa il caut neaparat!!! Sper sa imi fie de ajutor ca nu stiu ce sa-i mai fac!!!
iliescu sorin
C3
Mesajde iliescu sorin » Joi 22-Iul-2010 14:55
Eu la el am facut o cutie zf de A8 , care nu primea nici o comanda pe D si una de XM 3L V6 .
CARLO81
Re: C3
Mesajde CARLO81 » Vin 23-Iul-2010 14:49
iliescu sorin scrie:Eu la el am facut o cutie zf de A8 , care nu primea nici o comanda pe D si una de XM 3L V6 .
Un numar de telefon ceva se poate?!
r0b3rt92
Mesajde r0b3rt92 » Mar 07-Apr-2015 12:40
Salut, am o problema identica cu a ta (carlo), acelasi tip de motorizare al masinii, acelasi an. Te rog daca poti sa ma anunti si pe mine daca ai rezolvat pana la urma ceva, eu am fost la nenumarate service-uri si nicio rezolvare.
Zahar
Masina: Citroen c3 2003 1.4i cutie AL4
Mesajde Zahar » Joi 16-Apr-2015 21:39
Si eu am aceeasi problema.. Doar ca mie imi face asa si cand e motorul cald. Mi-a resoftat cutia de doua ori, problema a reapărut dupa o saptamana de fiecare data. Sunt efectiv disperat.. Tot 2003, tot 1.4 I
    Total mesaje 187843
