verificare serie sasiu
Bodea
- de-abia inscris
- Localitate: CLUJ
- Masina: Citroen C4 b7 1.6 hdi
- 2: Vw Polo 6N2 1.4mpi
Re: verificare serie sasiu
Ma poate ajuta cineva si pe mine cu o verificare seria sasiu la un C4 B7 VIN: VF7NC9HR8AY578216?
Sunt curios de dotarile cu care a venit masina din fabrica pentru ca am scos si un raport dna si ceva nu se pupa.In raport imi zice ca are transmisie automata cand ea e manuala.
Multumesc anticipat
Multumesc anticipat
iulian.arg
- Localitate: Iasi
Caracteristicile vehiculului
Linie de produs C4 (B7)
Nr. APV/PR 12436 88 1 0384
Data de Inceput de Garantie DDG 18.04.2011
OPB 000P
NRE e2*2007/46*0040*03
P4A 9666874399
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C4 (B7)
TIP CAROSERIE BERLINA CU 5 USI
NIVEL DE ECHIPARE MEDIE MEDIE
MOTOR DIESEL TURBO DV6C
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
TIP ECHIPARE INTERIOARA TESATURA HERMITAGE G142 + TESATURA OMNI REPS "4X"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCE
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
Caracteristici vehicul
Alimentare motor
ALIMENTARE INJECTIE TURBO CU SCHIMBATOR DIRECT
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
OPTIMIZAREA CONSUMULUI VEHICULULUI OPTIMIZAT
MOTOR RACIRE RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DISPOZITIV (ANTIPOLUARE) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE CU FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 2 TURATII 140W AERO FARA PRIZA DE AER
RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 19 X 71
STIL ROATA (JANTA) ROATA CU JANTA DIN ALUMINIU 16 INCI EXCLUSIV STIL 2 ’BOSTON’
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 205/55 R16 91V FARA INTARIRE
ROTI MONTATE ROATA 7 INCI
ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
Suspensie Directie Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 25
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22
FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
RACIRE ULEI DE POMPA DE DIRECTIE FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
SUSPENSIE SUSPENSIE NORMALA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
PEDALIER (TIP) PEDALIER STANDARD
Caroserie Echipamente
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
AVERTIZOARE SISTEM DE AVERTIZARE ACORD
ANTENA ANTENA PAVILION + GPS + INTEGRATA
DEFLECTOR AERODINAMIC SPATE MONTARE CU DEFLECTOR DE AER
DECORATIUNE (VOPSEA) DECORATIUNE NEGRU STRALUCITOR
ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT LATERAL (DIMENSIUNE) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
LUMINA DE SEMNALIZARE BALIZAJ LATERAL
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
INEL DE FIXARE EXTERIOR (ADAUGAT) INEL ARIMARE EXTERIOARA VAPOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR PLIABIL ELECTRIC + DIODA/LED
APARATOARE DE NOROI APARATOARE DE NOROI STANDARD
ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORIZARE PE MOTOR ELEMENT DE IZOLARE FONICA SUB CAPOTA MOTOR + TABLIER
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CU INDICATOR DE NIVEL APA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
STERGATOR DE LUNETA (FUNCTIONARE) MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CU PORNIRE AUTOMATA
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARE DE PROTECTIE FATA + SPATE IN CULOAREA CAROSERIEI + INEL CROMAT
APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
PLACA DE INMATRICULARE FARA PLACUTA DE INMATRICULARE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA CU LUMINI DE VIRAJ
ROATA DE REZERVA FARA ROATA DE REZERVA
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE FARA ORNAMENTE
GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
GEAM LATERAL SPATE (NATURA) GEAM LATERAL SPATE FIX
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
PACHET LOOK EXTERIOR DECOR NEGRU STRĂLUCITOR (DDY06) + ORNAMENT GEAM CROMAT (DGV04) + GEAM FUMURIU + FUMURIU ÎNCHIS (DVD09)
PACHET RADIO / INFORMATII / COMUNICARE CU SET TELEFONIC MÂINI LIBERE (DDO01) + MyWay (DRCRN) + 1 PRIZĂ JACK + USB (DYM04)
ACCES SI PORNIRE CU MAINI LIBERE FARA SISTEM ACCES/PORNIRE MAINI LIBERE
Echipament de interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
TETIERA SPATE TETIERA SPATE REGLABILA
TETIERA FATA TETIERA FATA ARTICULATA
SCAUN SPATE BANCHETA SPATE CU PERNA MONOBLOC SPATARE SEPARATE
DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
COTIERA DE SCAUN SPATE FARA COTIERA SPATE
MASCARE BAGAJE PANOU/MASUTA
CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
CLIMATIZOR CU AEROTERMA
SIGURANTA COPII SIGURANTA COPIL MANUALA USA SPATE
GRADARE VITEZE GRADATIE IN KM/H
CONSOLA CONSOLA LUNGA
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
ILUMINAT DE PORTBAGAJ VOLUM INCARCARE COMANDA AUTOMATA ILUMINAT PORTBAGAJ + VOLUM DE INCARCARE + AMV
ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + PARTE INFERIOARA INJECTATA
LUMINI INTERIOARE DIVERSE LAMPA DE CITIT FATA/SPATE CU BECURI FARA LED DE AMBIANTA FARA LUMINI DE AMBIANTA
GARNISAJ SPATIU DE INCARCARE COVORAS PORTBAGAJ MOCHETA
DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD CU COROANA PERSONALIZABILA + MATRICE
CAPITONAJ DE USA DECORATIE ALUMINIU CALD SOFT
ANCORARE SCAUN PENTRU COPII FARA SISTEM DE ANCORARE ISO PENTRU SCAUNE DE COPII SPATE
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 5,5 KG + CAPAC + PARTE LATERALA SUPERIOARA SPATE DE CAROSERIE
INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR SUPORT LOMBAR CONDUCATOR
REGLARE SCAUN FATA DE PASAGER SUPORT LOMBAR PASAGER
COTIERA DE SCAUN FATA COTIERA CENTRALA PERNA FATA
INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU HALOGEN
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE GEAM SPATE SECVENTIAL CU COMANDA ELECTRICA
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFISAJ AFISAJ DG4
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
SUPORT DE PICIOR CU SUPORT DE SPIJINIRE PICIOR CONDUCATOR + PASAGER
INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
CALCULATOR DE BORD CU CALCULATOR DE BORD
PACHET ECHIPAMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
COMANDA INTERIOARA DE USA (ASPECT) PALETA USA ASPECT CROMAT + ORNAMENT COLORAT
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
PROTECTIE POST FATA FARA PROTECTIE POST FATA
PARASOLAR FATA PARASOLAR CONDUCATOR + PASAGER FARA INSCRIPTIE
DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE + PALETA NEAGRA
RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
REFRIGERARE SISTEM DE REFRIGERARE SIMPLA
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI LIMITARE VITEZA PROGRAMABIL
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR REGLAJ PARALEL + INAINTE
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
DEPOZITARE (ALTELE) COMPARTIMENT DE DEPOZITARE STANDARD + BUZUNARE PE SPATARELE SCAUNELOR FATA
COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
DEPOZITARE VOLUM DE INCARCARE CHINGA LATERALA PORTBAGAJ + PLASA
COVORADS DE PODEA MOCHETA TESUTA DILOUR F550
TUNER-RADIO TUNER DUBLU RADIO
MARTOR DE NIVEL DE LICHID DE RACIRE FARA MARTOR LUMINOS PENTRU NIVEL LICHID DE RACIRE
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE DECORATIUNE CROMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
MODUL TELEMATIC FARA MODUL TELEMATIC
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L3 720
DEMAROR DEMAROR CLASA 6
ILUMINAT DEOSEBIT LUMINI DE ZI FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
MASURA INCARCARII BATERIEI CU SISTEM DE MASURARE A NIVELULUI DE INCARCARE A BATERIEI
APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
MODIFICARE AN MODEL IN CURS INDICE MINOR "00"
ATMOSFERA ATMOSFERA NORMALA
PLACUTA CONSTRUCTORULUI PLACUTA CONSTRUCTOR UNIUNEA EUROPEANA + NRE
ETICHETA FARA ETICHETA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
SOC LATERAL USA CARE NU ESTE INTARITA
SET DE CHEI 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
RULARE DRUM CORECT
MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
PLACA DE OMOLOGARE COMPLEMENTARA FARA PLACUTA DE OMOLOGARE SUPLIMENTARA
OPB 000P
P4A 9666874399
Informatii generale
Alimentare motor
CARBURANT MOTORINA
CILINDREE 1600 CM3
AFISAJ AFISAJ DG4
Electricitate
Diverse
RULARE DRUM CORECT
dasyn7
- de-abia inscris
- Localitate: Oradea
- Masina: Citroen C3
Ma poate ajuta cineva cu o verificare a seriei de sasiu pt un C3: VF7SXHMRPKT537019.
Multumesc frumos!
Multumesc frumos!
Linie de produs C5 (X7)
Nr. APV/PR 12532 CJ 1 0600
Data de Inceput de Garantie DDG 25.03.2011
Numar de Serie al Motorului 10 DYYF 4030272
OPB H003
NRE e2*2001/116*0360*19
P4A 9666908899
Informatii generale
LINIE DE PRODUS C5 (X7)
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE INALTIME MEDIE PLUS
MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
TIP ECHIPARE INTERIOARA TESATURA BRISE + OMNI SERGE ’6M’
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA C5
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
CARBURANT MOTORINA CALITATE DA/DE/DE+
DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR SUPERIEUR L6 EURO 5
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 2000 CM3
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
VARIATE DE PUTERE (MOTOR) PUTERE 120 KW 340 NM
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
CUPLU RAPORT RAPORT PUNTE 17 X 71
STIL ROATA (JANTA) ROATA BALTICA 17 INCI
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/55 R17 97W FARA INTARIRE
CUTIE DE VITEZE TIP ML6C
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20,5
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 180
SUSPENSIE ACTIVA FARA SUSPENSIE HIDRACTIVA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE METALICA
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
IESIRE DE ESAPAMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG LUMINI DE PRAG FATA
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
RETROVIZOR EXTERIOR (ASPECT OGLINDA) RETROVIZOR EXTERIOR CU OGLINDA NEATENUATA
ACCESORII EXTERIOARE MANER EXTERIOR ASPECT CROMAT
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU CALD
LUMINI INTERIOARE DIVERSE ILUMINAT STANDARD + LUMINA DE CITIT RAND2
GARNISAJ SPATIU DE INCARCARE COVORAS PORTBAGAJ SI MANER CROMAT
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COTIERA DE SCAUN FATA (FUNCTIONARE) FARA COTIERA FATA
CD FARA MONTARE COMPACT DISC
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
AFISAJ AFISAJ DEV
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
RECEPTOR RADIO SISTEM RADIONAVIGATIE CU MEMORIE FLASH "RNEG"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA BURDUF/MANER MANETA + PLACUTA DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE DIN ALUMINIU CULOARE CALDA
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUPORT LOMBAR MANUAL
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE BATERIE L3 720 LDC(L3 720 70AH EF 720 EN)
DEMAROR DEMAROR CLASA 5
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SERIE SPECIALA TRANSVERS 2010
ETICHETA FARA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
OPB H003
P4A 9666908899
Informatii generale
MONOGRAMA C5
Alimentare motor
CILINDREE 2000 CM3
AFISAJ AFISAJ DEV
Electricitate
Diverse
ETICHETA FARA
RULARE DRUM CORECT
dasyn7
- de-abia inscris
Salut! am rezolvat. pt cine vrea sa verifice VIN, isi poate face cont aici: http://public.servicebox-parts.com/pages/index.jsp
poly
- Localitate: Craiova
- Masina: C5 Exclusive 163 Automat
- 2: Xantia Activa Hdi
Eu nu gasesc sectiunea cu caracteristicile masinii
Sent from my SM-T835 using Tapatalk
iulian.arg
- Localitate: Iasi
Incearca aici: http://service.citroen.com/
PatrickMC
- de-abia inscris
- Localitate: Cricau
- Masina: Citroen Jumper
Salutare tuturor, sunt nou pe acest grup si nou proprietar de autoutilitara Citroen Jumper sunt in cautarea istoricului, intreb si eu daca ma poate ajuta cu informatii despre istoricul masini cu seria VF7YDDMFC11477380 este vorba de un Jumper 3.0 . Va multumesc mult!
florindaniel
- Localitate: ploiesti
Mă puteti ajuta cu ceva detalii despre c5 cu seria:
VF7RWAHWTFL512061.
Mulțumesc
VF7RWAHWTFL512061.
Mulțumesc
moisina
- de-abia inscris
- Masina: Citroen c4
Ma puteți ajuta și pe mine cu ceva detalii pentru un C4 Coupe cu seria :VF7LA9HZH74567273
Mulțumesc! [img]https://uploads.tapatalk-cdn.com/20190409/9d0c39ae68c2c35ef1eb6a2080a8ba7a.jpg[/img]
Trimis de pe al meu VTR-L09 folosind Tapatalk
norishor
- Localitate: Campina / Bucuresti
- Masina: Citroen C2 VTS (de competitie)
- 2: Lexus CT200H (de familie)
moisina scrie:Ma puteți ajuta și pe mine cu ceva detalii pentru un C4 Coupe cu seria :VF7LA9HZH74567273
Mulțumesc!
Linie de produs C4
Nr. APV/PR 10944 88 1 0185
Data de Inceput de Garantie DDG 31.10.2006
Numar de Serie al Motorului 10 JB60 3105542
OPB I3DP
NRE e2*2001/116*0302*03
Informatii generale
LINIE DE PRODUS C4
TIP CAROSERIE BERLINA 3 USI
NIVEL DE ECHIPARE EXCLUSIV VTS
MOTOR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE
CULOAREA CAROSERIEI EZW - VOPSEA GRI FER
TIP ECHIPARE INTERIOARA ACCESORIU PLASA 3D XRAY + ALCANTARA "ST"
CULOARE GARNISAJ "FZ"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCD
MONOGRAMA COMPLEMENTARA, DIVERSE VTS
Alimentare motor
BLOC CILINDRI (MATERIAL) BLOC CILINDRI ALUMINIU
DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR EURO 4
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR CU 2 COMPUSI IN FILTRE IMPREGNATE CU PLATINA
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR 2 TURATII 130W AERO
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
STIL ROATA (JANTA) ROATA RESOLFEN 17 INCI
TIP DE CUTIE DE VITEZE (OMOLOGARE) CUTIE DE VITEZE TIP MCD
DIFERENTIAL (CUTIE) DIFERENTIAL 77
PNEURI (DIMENSIUNI, TIP) PNEU 205/50 R17 89W NERANFORSAT
ROTI MONTATE ROATA 6 INCI 1/2
ROATA (TIP) MONTARE ROATA ALIAJ 2
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 27
COLOANA DE DIRECTIE COLOANA DE DIRECTIE CU REGLARE MANUALA
PEDALIER (TIP) PEDALIER ALUMINIU
ANTENA ANTENA + GPS + GSM
DEFLECTOR AERODINAMIC SPATE MONTARE CU DEFLECTOR DE AER LA MIJLOCUL CAPACULUI
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) STIL TROMPA
LUMINA DE MERS INAPOI CU 2 LUMINI PENTRU MERSUL INAPOI
ETANSEITATE AERODINAMICA FARA GARNITURA DE CAPOTA MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
INSONORIZARE PE MOTOR IZOLARE FONICA LA CAPOTA
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
LUNETA (GEAM DE CAPAC DE PORTBAGAJ) GEAM FIX DE CAPAC DE PORTBAGAJ
BARA DE PROTECTIE BARA DE PROTECTIE FATA SPORT IN CULOAREA CAROSERIEI GRILA BARA DE PROTECTIE SPATE STANDARD IN CULOAREA CAROSERIEI
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
ROATA DE REZERVA ROATA CU JANTA TABLA + PNEU CU DIMENSIUNE NESTANDARDIZATA
ACCESORII EXTERIOARE MANER EXTERIOR + COMANDA SPATE + SUPORT + RETROVIZOR IN CULOAREA CAROSERIEI
GEAM (ASPECT) FUMURIU + FUMURIU INCHIS IN SPATE
GEAM (TIP) PARBRIZ IZOLAT TERMIC SI CU STRAT REFLECTORIZANT + GEAMURI LATERALE SI SPATE SECURIZATE
ACCES SI PORNIRE CU MAINI LIBERE FARA ACCCES SI PORNIRE MAINI LIBERE
BRICHETA BRICHETA FATA
SCAUN SPATE PERNA SEPARABILA RABATABILA + SPATAR SEPARABIL RABATABIL
CENTURA DE SIGURANTA SPATE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
SIGURANTA COPII FARA SISTEM DE BLOCARE USA PENTRU COPIL
TUROMETRU TUROMETRU DIGITAL
ECHIPAMENT PLANSA DE BORD PLANSA DE BORD METALIZATA KURTZ FATADA INFERIOARA + SUPORT CREOIN VOPSITE
LUMINI INTERIOARE DIVERSE PLAFONIERA FATA 3 POZITII
TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD DIGITAL CU FATADA GRI LION
CAPITONAJ DE USA TAPITERIE USA DECORATIUNE CROM SATINAT
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 6 KG
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA PERDEA IMPOTRIVA SOARELUI
INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
REGLARE SCAUN FATA DE PASAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATERE SCAUN FATA DE CONDUCATOR CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN CONDUCATOR
RABATERE SCAUN FATA DE PASAGER CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN PASAGER FATA
CD MONTARE COMPACT DISCURI
CASETA DE DEPOZITARE FARA CONTAINER DE DEPOZITARE
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE FARA MECANISM DE ACTIONARE GEAM SPATE
AFISAJ AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
AIRBAG DE PASAGER AIRBAG LATERAL PASAGER
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR CU INCALZIRE
COMANDA INTERIOARA DE USA (ASPECT) COMANDA INTERIOARA USA ASPECT SOFT MISTRAL
PLANSEU SPATE INCARCARE FARA PLANSEU SPATE DE INCARCARE
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PARASOLAR FATA PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT DE DEPOZITARE LATERAL CU INCHIDERE + OCHELARI
RECEPTOR RADIO SISTEM RADIOTELEFON "RT3"
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
INALTARE SCAUN FATA DE CONDUCATOR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
COVORAS DE PODEA (ASPECT) COVORAS SUPLIMENTAR TUFTE F470 CU SNUR TEP V072
AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
DEPOZITARE VOLUM DE INCARCARE CU PLASA + COMPARTIMENT DE DEPOZITARE AMOVIBIL IN PORTBAGAJ
PROTECTIE INTERIOARA FARA PROTECTIE INTERIOARA
ADAPTARE GARNITURA MANER MANETA DE VITEZA CU INSERTIE CROMATA
COVORAS DE PODEA CU COVORAS SUPLIMENTAR
VOLANT VOLAN SPORT
RETROVIZOR INTERIOR SUPRAVEGHERE COPII FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
Electricitate
BATERIE BATERIE L3 450
ILUMINAT DEOSEBIT APRINDERE AUTOMATA A LUMINILOR
MULTIPLEXARE MONTARE RETEA MULTIPLEXATA CAN CAN
Diverse
RULARE DRUM CORECT
MODUL ELECTRONIC (BOÎTIER SERVITUDE) BSI + COMANDA VOLAN BUTUC FIX
TRIUNGHI DE PRESEMNALIZARE FARA TRIUNGHI REFLECTORIZANT
Servicii Diagbox: Activari/dezactivari optiuni / Actualizari software / Telecodare cheie noua/Reparatii chei telecomanda PSA / Telecodare RD/RT CD/Mp3 / Diagnoza pre-achizitie auto
norishor
florindaniel scrie:Mă puteti ajuta cu ceva detalii despre c5 cu seria:
VF7RWAHWTFL512061.
Mulțumesc
Nr. APV/PR 14245 CJ 1 0315
Data de Inceput de Garantie DDG 26.11.2015
Numar de Serie al Motorului 10 DYZL 4031192
OPB H00P
NRE e2*2001/116*0360*34
P4A 9809238899
Informatii generale
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR DIESEL DW10FC FAP 132KW
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE TIP STOP AND START
TIP ECHIPARE INTERIOARA PIELE INTEGRALA MV145 "QS"
CULOARE GARNISAJ "FE"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C
EVOLUTIE DEFINITIE TEHNICA ANIMATIE GAMA
MONOGRAMA COMPLEMENTARA, DIVERSE BLUE HDI
MONOGRAMA C5 CROSSTOURER
Alimentare motor
DEPOLUARE (MOTOR) DEPOLLUTION MOTEUR EURO 6.1
CILINDREE 2000 CM3
DEPOLUARE TEHNICA VEHICUL DEPOLLUTION TECHNIQUE VEHICULE EURO 6.1
STOP AND START CU STOP AND START
CUPLU RAPORT RAPORT PUNTE 15 X 53
STIL ROATA (JANTA) JANTA STIL CASPIENNE 18"
AMBREIAJ FARA AMBREIAJ
JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 245/45 R18 100W RANFORSAT
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE DE PRESIUNE UMFLARE NORMA ECE 64.02
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO6
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21,5
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 25
SUSPENSIE ACTIVA SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE HIDRAULICA
IESIRE DE ESAPAMENT IESIRE ESAPAMENT CROMATA
LUMINA DE PRAG BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
GEAM DE PAVILION CU GEAM DE PAVILION
MIRROR LINK CU OGLINDA LINK
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL LUCIANO
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA SOFT
GARNISAJ SPATIU DE INCARCARE COVORAS + BAGHETA SI MANER CROMAT
CAPITONAJ DE USA DECORATIUNE NEGRU ARGINT STRALUCITOR
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
AFISAJ AFISAJ ECRAN DEV HR TACTIL
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROIECTOR DIRECTIONAL CU PROIECTOR DIRECTIONAL
WIFI CU WIFI
RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE
STORURI LATERALE TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTARE GARNITURA MANER + BURDUF PIELE INTEGRAL
VOLANT VOLAN IMBRACAT IN PIELE NETEDA
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB + BLUETOOTH
MODUL TELEMATIC MODUL TELEMATIC AUTONOM VERSIUNE 2.0
Electricitate
ALTERNATOR ALTERNATOR ISTT52
BATERIE BATERIE L3 760 VRLA2 EN AGM
DEMAROR DEMAROR CLASA 6+
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE MECCANO 22
ETICHETA FARA
RULARE DRUM CORECT
vasileisip
- de-abia inscris
- Localitate: Cluj-Napoca
- Masina: citroen c5 II
- 2: golf 4
ma ajutatisi pe mine va rog cu detalii despre C5 cu seria VF7RDRHF89L568814?
Multumesc
Multumesc
Rog si pentru mine, se poate VF7RD5FV8AL501309 ?
Multumesc anticipat
Multumesc anticipat
Stana Alexandru
- Masina: CITROEN DS4
- 2: Citroen c4
vasileisip scrie:Salut,
Multumesc
Nr. APV/PR 12042 CJ 1 0552
Data de Inceput de Garantie DDG 18.02.2010
Numar de Serie al Motorului 10 DYXH 4057148
OPB H4DM
NRE e2*2001/116*0360*07
P4A 9666041099
Informatii generale
TIP CAROSERIE BERLINA 4 USI
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
CULOAREA CAROSERIEI KGN - VOPSEA BOURRASQUE
TIP ECHIPARE INTERIOARA TESATURA STCYR G028+OMNISERGE F915’5E’
MONOGRAMA C5
Alimentare motor
DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
CILINDREE 2000 CM3
VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
CUPLU RAPORT RAPORT PUNTE 16 X 69
STIL ROATA (JANTA) ROATA PERSIQUE 17 INCI
ORNAMENT DE ROATA (STIL) CAPAC CEDNTRAL DE ROATA PERSIQUE 17 INCI
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
ECHIPAMENT PLANSA DE BORD DECORATIUNE MOLDING EVREST
GARNISAJ SPATIU DE INCARCARE FARA COVORAS
AFISAJ AFISAJ DEV
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE MOLDING
Electricitate
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE ANIVERSARA
ETICHETA FARA
RULARE DRUM CORECT
Total mesaje 187865
Total membri 11854
