verificare serie sasiu
kady28
Re: verificare serie sasiu
Mesajde kady28 » Lun 02-Apr-2018 19:22
SLY scrie:Salutare si bine v-am gasit.
O lista de dotari pentru VF7RWRHF89L529758 se poate va rog?
Masina am achizitionat-o sambata si as vrea sa o cunosc cat mai bine :).
Multumesc anticipat.
Caracteristicile vehiculului
Linie de produs C5 (X7)
Nr. APV/PR 11874 CJ 1 0017
Data de Inceput de Garantie DDG 04.06.2009
OPB HBDM
NRE e2*2001/116*0360*07
P4A 9666041099
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C5 (X7)
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
TIP ECHIPARE INTERIOARA CAPITONAJ PIELE ST CYR + PIELE "XS"
CULOARE GARNISAJ "FC"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE EXCLUSIV
MONOGRAMA C5
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 16 X 69
STIL ROATA (JANTA) ROATA BALTICA 17 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/55 R17 97W FARA INTARIRE
ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP ML6C
Suspensie Directie Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 180
SUSPENSIE SUSPENSIE NORMALA
SUSPENSIE ACTIVA SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
IESIRE DE ESAPAMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION CU GEAM DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA RETROVIZOR EXTERIOR FUMURIE
ACCESORII EXTERIOARE MANER EXTERIOR ASPECT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL PALEA
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA
GARNISAJ SPATIU DE INCARCARE COVORAS + BAGHETA SI MANER CROMAT
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE ANODIZATA SOFT
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
CD FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DG4
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE PASAGERI FATA + SPATE
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROIECTOR DIRECTIONAL CU PROIECTOR DIRECTIONAL
RECEPTOR RADIO SISTEM RADIONAVIGATIE DE A 4-A GENERATIE "NG4"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
MODUL TELEMATIC FARA MODUL TELEMATIC
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 5
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE DEPOLUARE SUPERIOARA
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
SLY
Masina: C5 Tourer Exclusive '09
Mesajde SLY » Mar 03-Apr-2018 07:07
Multumesc.
ovidiufao
Localitate: moldova noua
Mesajde ovidiufao » Sâm 14-Apr-2018 22:58
Puteti sa ma ajutati si pe mine cu niste detalii despre urmatoarea masina VF7RD9HZCAL533227?
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Mar 17-Apr-2018 10:08
Nr. APV/PR 12224 CJ 1 0552
Data de Inceput de Garantie DDG 24.06.2010
OPB H46M
NRE e2*2001/116*0360*13
P4A 9666083099
Informatii generale
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE MEDIE COBORATA
MOTOR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA5
TIP ECHIPARE INTERIOARA TESATURA RAFAELO G025+OMNIREPS F920 "XP"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MECANICA BE4 L
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA, DIVERSE AIRDREAM
MONOGRAMA C5
Alimentare motor
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO 4 (MOTOR)
VARIATE DE PUTERE (MOTOR) PUTERE 80 KW 240 NM
DISPOZITIV (ANTIPOLUARE) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
CUPLU RAPORT RAPORT PUNTE 17 X 71
STIL ROATA (JANTA) ROATA CU JANTA DIN TABLA 16 INCI
DIFERENTIAL (CUTIE) DIFERENTIAL 84
JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 215/60 R16 95H FARA INTARIRE
ROATA (TIP) MONTARE ROATA CU JANTA DIN TABLA
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA BE4R
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 184
SUSPENSIE ACTIVA FARA SUSPENSIE HIDRACTIVA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE METALICA
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ORNAMENT DE ROATA (STIL) TIP LAPONIA 16 INCI
LUMINA DE PRAG LUMINI DE PRAG FATA
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE CULOARE CAROSERIE + ELEMENT DE PROTECTIE COLORAT IN MASA + FARA ORNAMENT DE GRILA
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA FARA PROIECTOARE ANTICEATA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) RETROVIZOR EXTERIOR CU OGLINDA NEATENUATA
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI
COTIERA DE SCAUN SPATE FARA COTIERA SPATE
ECHIPAMENT PLANSA DE BORD DECORATIUNE TUNGSTEN
LUMINI INTERIOARE DIVERSE ILUMINAT STANDARD FARA LAMPA DE CITIT PENTRU RANDUL 2
GARNISAJ SPATIU DE INCARCARE FARA COVORAS
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
CAPITONAJ DE USA DECORATIUNE TUNGSTEN
INALTARE SCAUN DE PASAGER FATA FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) FARA COTIERA FATA
SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
BECURI DE PROIECTOR LAMPA CU HALOGEN
AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU O ZONA
TUNER-RADIO CU UN SINGUR TUNER RADIO
DETECTAREA OBSTACOLULUI FARA SISTEM DE DETECTARE OBSTACOLE
ADAPTARE GARNITURA BURDUF/MANER MANETA + PLACUTA DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) FARA SPRIJIN LOMBAR
PRIZA AUXILIARA PACK AUDIO FARA PRIZA AUXILIARA PACHET AUDIO
Electricitate
BATERIE BATERIE L2 400
ILUMINAT DEOSEBIT LUMINI DE ZI FATA
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE DEPOLUARE STIMULARE FISCALA
ETICHETA FARA
RULARE DRUM CORECT
subdread
Masina: Citroen C5 2013 2.0HDI 163CP
Mesajde subdread » Mie 18-Apr-2018 12:50
Hello , ma poate ajuta cineva cu VF7RDRHH4DL506487 . Merci.
Mike60
Localitate: Surrey
Masina: Citroen C3 Picasso Exclusive, 2014
2: Punto Sporting, 2001
3: Renault Scenic 2, 2007
Mesajde Mike60 » Joi 26-Apr-2018 22:41
Buna seara
Achizitionand un Citroen C3 Picasso as dori sa stiu si eu daca a avut incidente si cu ce a iesit pe poarta fabricii.
Sunt multumit de ea dar doresc sa aflu mai multe informatii.
Se poate modifica afisajul sa-mi indice cantitatea de combustibil consumata in l pentru 100 de km ?
Acum am varianta numarul de mile la un galon !
VIN : VF7SH9HP4ET527399
Multumesc anticipat
Cu stima
Mihai
fiki
Localitate: medgidia
Masina: c 5 2004 raposata ...
2: c 5 x7 2008 exclusiv
verificare vin
Mesajde fiki » Dum 22-Iul-2018 18:05
buna seara colegi o verificare la un vin as vrea si eu ma poate ajuta cineva? vf7rwrhrh54076506
cazy2vd
Localitate: arad
Mesajde cazy2vd » Lun 23-Iul-2018 22:17
Salut ! As avea si eu nevoie, pentru o eventuala achizitie, daca ma poate ajuta cineva, de o verificare la un c5 2008, vin: VF7RDRHRH54066300
Multumesc mult!
I0nut
Masina: Subaru Forester 2.5 XT AT
2: Citroen C5 III 2.2 HDI MT
Mesajde I0nut » Lun 06-Aug-2018 22:01
Buna seara,
Intentionez sa achizitionez un C5 III si as dori sa obtin cu ajutorul forumului ceva informatii despre masina, mai ales legate de numarul de kilometri, intrari in service, ...
Sper cu ajutorul vostru sa devin membru posesor de Citroen si sa ne depanam povestile legate de masini la intalniri asa cum o fac si pe forumul Subaru cu colegii de acolo, de cateva ori pe an.
Astfel, VF7RW4HTH9L551329 si multumesc anticipat.
I0nut
Mesajde I0nut » Vin 10-Aug-2018 20:21
L'am luat si sunt incantat !
astigelu
Masina: Citroen C5 2.0hdi, 163CP, 2010, Automat, H3+
Mesajde astigelu » Dum 26-Aug-2018 11:52
Buna ziua,
Si eu tocmai am devenit posesorul unui C5 2,0 HDI, 163 CP, 2010. As dori daca se poate detaliile de fabricatie si caracteristici la vin: VF7RWRHHAAL573555. Multumesc.
Davos
Masina: Citroen C4 Picasso 2.0 BlueHDI BVA
Mesajde Davos » Dum 26-Aug-2018 17:15
Caractéristiques du véhicule VF7RWRHHAAL573555
Ligne de produit C5 (X7)
N°APV/PR 12415 CJ 1 0484
Date de Début de Garantie 29/12/2010
OPB H006
NRE e2*2001/116*0360*18
P4A 9665460399
Informations générales
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 (X7)
SILHOUETTE BREAK 5PTES
FINITION SUPERIEURE BASSE PLUS
MOTEUR DIESEL TURBO DW10CTED4 FAP
TRANSMISSION BVA 6 RAPPORTS
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE KTV - PEINTURE NOIR PERLA NERA
TYPE D’HABILLAGE INTÉRIEUR C&T CUIR ST CYR + CUIR "XS"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVA AM6C1
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
MONOGRAMME C5
Caractéristiques véhicule
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
COUPLE TACHYMÈTRE SANS C T
Alimentation moteur
DÉTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DÉPOLLUTION (MOTEUR) DEPOLLUTION EURO 5(MOTEUR)
ECHAPPEMENT SILENCIEUX AR LONGITUDINAL
CYLINDRÉE 2000 CM3
CATALYSEUR CATALYSEUR INF 10PPM
RÉCHAUFFAGE CIRCUIT GAZ CARTER RECHAUFFAGE CIRCUIT GAZ CARTER
VARIATION PUISSANCE (MOTEUR) PUISSANCE 120 KW 340 NM
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 5
FILTRE À PARTICULE FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 220W
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION DELPHI
FILTRE RÉSERVOIR FILTRE RESERVOIR INTERIEUR
STOP AND START SANS STOP AND START
Boîte de vitesses Transmission
COUPLE RAPPORT CP 15 X 53
STYLE ROUE ROUE ATLANTIQUE 18 POUCES
EMBRAYAGE SANS EMBRAYAGE
DIFFÉRENTIEL (BOITE) DIFFERENTIEL 86
JANTE / PNEU DIMENSION MONTE PNEU 18 POUCES
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 245/45 R18 100W RENFORCE
ROUE (TYPE) MONTAGE ROUE ALLIAGE 3
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE BVA AM6
Suspension Direction Freinage
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 21
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 24,5
COURSE MÉCANISME DE DIRECTION COURSE MECANISME DIRECTION 180
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION ACTIVE REGLAGE MANUEL
SUSPENSION (TYPE ARCHITECTURE) SUSPENSION HYDRAULIQUE
CONTRÔLE DYNAMIQUE DE STABILITÉ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
Carrosserie Equipements
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX CHROME
ENJOLIVEMENT LATÉRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE + CHROME
ENJOLIVEUR ROUE (STYLE) CABOCHON ATLANTIQUE 18 POUCES
SORTIE D’ÉCHAPPEMENT SORTIE ECHAPPEMENT NON CHROMEE
FEU D’ÉCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL AVANT + ARRIERE
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT RABATTABLE ELECTRIQUE
ESSUIE-VITRE AVANT EV AV INTER CAD AUTOMATIQUE 16 VIT
ESSUIE-VITRE ARRIÈRE ESSUIE-VITRE AR
ESSUIE-PROJECTEUR ESSUIE-PROJECTEUR
VITRE PAVILLON SANS VITRE PAVILLON
PARE-CHOCS P/C CC + PROT CHROME + ENJO GRILLE CHROME
PORTE-BAGAGES MONTAGE AVEC BARRES DE TOIT LONGITUDINALES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
ROUE DE SECOURS ROUE TOLE REDUITE + PNEU STANDARD
RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) GLACE RETROVISEUR EXTERIEUR ELECTROCHROME
ACCESSOIRES EXTÉRIEURS POIGNEE EXT ASPECT CHROMEE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) GLACE RETRO EXT BOMBE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
VITRE (ASPECT) VITRE SURTEINTEE
VITRE (TYPE) P-B FEUILLETE ACCOUSTIQUE + AR TREMPE
Equipement intérieur
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
CLIMAT (TEMPERATURE AMBIANTE) PAYS FROIDS
GRADUATION VITESSES GRADUATION EN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD DECOR METAL PALEA
FEUX INT. DIVERS ECLAIRAGE AMBIANCE SOFT
GARNISSAGE VOLUME CHARGEMENT TAPIS+BGT ET POIGNEE CHROME
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 260 KM/H 160 M/H MATRICE COULEUR
GARNISSAGE DE PORTE DECOR NOIR ARGENT BRILLANT
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) SANS STORE AR
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE AVANT ARRIERE
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV A MEMOIRE CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV ELECT PASSAGER
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) ACCOUDOIR AV MANUEL
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION AVEC SYSTEME NAVIGATION ECRAN COULEUR
LAMPES DE PROJECTEURS LAMPE A DECHARGE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
LECTEUR D’INFORMATIONS ROUTIÈRES SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR AFFICHEUR DEV
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL THORAX AV + RIDEAU
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE REGLAGE AUTOMATIQUE PROJECTEURS
PROJECTEUR DIRECTIONNEL AVEC PROJECTEUR DIRECTIONNEL
RÉCEPTEUR RADIO SYSTEME RADIO NAV MEMOIRE FLASH "RNEG"
RÉFRIGÉRATION REFRIGERATION AUTOMATIQUE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE ELECTRIQUE
RÉTROVISEUR INTÉRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RÉGULATION CLIMATISATION / TEMPÉRATURE REFRIGERATION AUTOMATIQUE BI-ZONE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TUNER-RADIO BI TUNER RADIO
DÉTECTION D’OBSTACLE DETECTEUR OBSTACLE RADAR AVANT ARRIERE
STORES LATÉRAUX STORES LATERAUX COMMANDE MANUELLE
ADAPTATION GARNITURE POMMEAU LEVIER VITESSE+SOUFFLET CUIR
AMPLI-ÉQUALISEUR SANS AMPLI EQUALISEUR
FRÉQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT CUIR 4 BRAS DECOR METAL
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) MAINTIEN LOMBAIRE AUTOMATIQUE
PRISE AUXILIAIRE PACK AUDIO 1 PRISE RCA AUDIO
BOITIER TELEMATIQUE BOITIER TELEMATIQUE AUTONOME
Electricité
ALTERNATEUR ALTERNATEUR CLASSE 18
BATTERIE BATTERIE L3 500
DÉMARREUR DEMARREUR CLASSE 6+
ECLAIREMENT PARTICULIER FEUX DIURNE AV
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FREQUENCE TELECDE CONDA 433,92 MHZ HETERODYNE
ALLUMAGE FEUX ALLUMAGE FEUX AUTOMATIQUE
Marques d'équipements
Divers
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
ETIQUETTE SANS
COTÉ CIRCULATION CIRCULATION A DROITE
EQUIPEMENT DE SECOURS SANS EQUIPEMENT SECOURS
ROULAGE BONNE ROUTE
astigelu
Mesajde astigelu » Dum 26-Aug-2018 17:53
Multumesc inca odata! Am incercat si o traducere pe Translate la Google, o da cam ciudat, dar e ok, daca e cumva si varianta in lb. romana ar fi super! Am vazut mai sus pusa la cineva.
Davos
Mesajde Davos » Dum 26-Aug-2018 17:58
Ti-am trimis mesaj, nu mai pot edita.
zare
Localitate: Oradea
Masina: Citroen C5 III 2009, 2.0 100 Kw .Automata.
2: Peugeot 407
Mesajde zare » Mie 05-Sep-2018 15:36
Salutare,imi puteti da si mie o descriere a acestei masini:VF7RWRHRJ9L536551 ,multumesc .
Înapoi la “Citroen C5 III”
    Total mesaje 187847
    Total subiecte 18678
    Total membri 11850
    Cel mai nou membru Blustery
