Euro 2 sau Euro 3?
cbx
Mesajde cbx » Sâm 25-Apr-2009 20:37
Vehicle family XSARA II
AS RPO No 09156 CJ 2 0130
Guarantee Start Date 14/01/2002
Engine serial number 10 DYJM 3023345
Gearbox serial number 20 DL42 4166959
OPB A02P
NRE e2*98/14*0189*03
General information
Product type CAR
Commercial marque/Component type CITROEN
Silhouette 5 DOOR SALOON
Trim level MEDIUM MEDIUM
Engine TURBO DIESEL DW10TD
Transmission BVM5
Paint type METALLIC PAINTWORK
Body colour PAINT - MAURITIUS BLUE
Interior trim type "MM" CESIUM VELOUR
Upholstery colour "FZ"
Gearbox (Characteristics) BE4-5L MANUAL GEARBOX
Engine (Type) EW/DW
Other badge WITHOUT FULLER BADGE
Other badge, " Misc. " XSARA
Badge XSARA + HDI
Vehicle characteristics
Speedometer drive TACHO TORQUE 22X19
Fuel supply-Engine
Diesel filter water detector WITH DIESEL FILTER WATER DETECTOR
Cylinder block (Material) CRANKCASE CAST IRON
Fuel DIESEL FUEL
Emissions standard (engine) EEC 2000 DEPOLL (ENGINE)
Engine (Type) EW/DW
Oil cooler MNTG WATER/OIL EXCHANGER ON ENGINE
Cooling motor RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
Crankcase gas circuit heating W/O HEATER CASING GAS CIRCUIT
EOBD Self-Diagnosis System WITHOUT "EOBD" AUTO-DIAGNOSTIC
Vehicle Technical Depollution L4 VEHICLE TECHNICAL DEPOLLUTION
Fan 1 FAN 3 SPEEDS 420W
Injection associated variant SIEMENS ASSEMBLY
Hybrid engine WITHOUT ALTERNATOR-STARTER
Throttle housing (engine inlet air circuit) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
Gearbox-Driveshafts
Transmission BVM5
Final drive ratio REAR AXLE HYPOID GEARSET 19 X 70
Wheel style 15 INCH STEEL WHEEL
Clutch CABLE CLUTCH TAKING UP OF PLAY
Seal, wheel end WHEEL-SIDE JOINT DIAM 17 5
Seal, differential end AXLE-SIDE JOINT JB2A
Differential (Gearbox) DIFFERENTIAL 84
Tyre (Size, Type) 195X55X15 H TYRES
Wheel (Type) STEEL WHEELS
Gearbox Type GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
Rear anti-roll bar REAR ANTI-ROLL BAR DIAM 19
Front anti-roll bar FRONT ANTI-ROLL BAR DIAM 20
Service brake ELECTRONIC BRAKEFORCE DISTRIBUTION
Brake Type VENTILATED FRONT DISCS/REAR DISCS
Suspension NORMAL SUSPENSION
Dynamic Stability Control System WITHOUT ELECTRONIC STABILITY PROGRAM
Bodywork-Exterior fittings
Horns HORN STANDARD
Rear spoiler ASSEMBLY WITHOUT REAR SPOILER
Side mouldings (Type) BODY COLOUR LATERAL PROTECTORS
Wheel embellisher (Style) 15 INCH BACCARAT 2 STYLE - 8 OPENINGS
Additional shield (under engine) W/O ENGINE UNDERSHELDING
Ext. rearview mirror comp. function EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
Windscreen wiper INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI
Headlamp wiper W/O HEADLAMP WIPER
Front panel blank LARGE AIR ENTRANCE FRONT BUMPER PLUG
Outside temperature sensor WITH EXTERIOR TEMPERATURE SENSOR
Exterior rear view mirror (Driver side) HT EXT RRVW MIRROR EL INT CONTR
Exterior rear view mirror (Passenger side) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
Exterior accessories DOOR MIRROR AND HANDLES BODY COLOUR
Sun roof FIXED ROOF
Bumper trim BODY COLOUR BUMPER STRIP
Glass (Appearance) WITHOUT WINDOW
Window (Type) ATHERMAL WINDSCREEN
Exterior Styling Pack BODY COLOUR EXTERIOR LOOK PACK
Interior fittings
Anti-theft alarm WITHOUT THEFT PROTECTION ALARM
Rear seat SEPARATE FOLD BACK BENCH SEAT
Rear seat armrest WITHOUT REAR ARMREST
Rear seatbelt REAR 3-POINT 3 INERTIA REEL SEAT BELT
Speed graduations GRADUATION KMS/H
Driving position LEFT HAND DRIVE
Additional heating WITHOUT ADDITIONNAL HEATING
Dashboard equipment WITHOUT DECOR
Misc. int. lamps MAP READING LAMP
Instrument panel (Characteristics) 220 KM/H OR 140 MPH GRADUATION GREY/BLUE DIAL
Loudspeaker MOUNTING 4 FRONT LOUDSPEAKERS + 2 REAR
Radio controls REMOTE RADIO CONTROL
Pollen filter WITH POLLEN FILTER
Front passenger seat height control WITHOUT SPACER PASSENGER SIDE
Driver seat control DRIVERS FRT SEAT MANUAL CNTROL
Driver seat adjustment WITHOUT DRIVER'S LUMBER AND SIDE SUPPORTS
Front passenger seat adjustment WITHOUT PASSENGER'S SIDE AND LUMBAR SUPPORTS
Compact Disc WITHOUT COMPACT DISC
Satellite Navigation System WITHOUT NAVIGATION SYSTEM
CD-ROM for car PC WITHOUT CD ROM FOR AUTO-PC
Rear window lift MAN CTRL REAR WINDOW LIFTER
Driver's window lift SEQUENTIAL DRIVER'S ELECTRIC WINDOW
Passenger's window lift NON SEQUENTIAL FRONT PASSENGER'S ELECTRIC WINDOW
Display DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
Courtesy mirror DRIV OCCULT+PASS OCCULT W/O LIGHT
Oil gauge STD OIL LEVEL INDICATOR
Heating element NON HEATED SEAT
Front lateral airbag NO LATERAL AIR BAG
Rear passenger protection W/O RR PASSENGER PROTECTION
Passenger airbag PASSENGER AIRBAG
Electric window (Operation) DRIVER'S ANTI-PINCH + REAR MANUAL
On-board computer COMPUTER
Equipment Pack WITHOUT DRIVING SCHOOL EQUIPMENT PACK
Airbag Deactivation MANUAL AIRBAG DEACTIVATION
Front seat guard WITHOUT CAB PROTECTION PANEL
Storage (Driving Position) INJECTED LOWER GLOVE BOX
Radio receiver "RB2" RDS CASSETTE AUDIO SYSTEM
Air conditioning REGULAR AIR CONDITIONNING
Cruise control WITHOUT SPEED CONTROL
Driver's seat height control PARALLEL DRV HEIGHT ADJ
Carpet cover W/O CARPETMAT
Driver airbag DRIVERS AIR BAG
Load space storage W/O BOOT TIDY
Wear indicator W/O BRAKE WEAR WARNING LIGHT
Obstacle Detection System WITHOUT OBSTACLE DETECTOR
Locking control SIMPLE CENTRAL LOCKING
Steering wheel RUBBER STEERING WHEEL
Electrical
Alternator ALTERNATOR 150 AMP
Horns HORN STANDARD
Battery BATTERY L2 400
Starter motor CLASS 6 STARTER MOTOR
Special lighting WITHOUT PARTICULAR LIGHT
Cen. locking rem control frequency 433 92 MHZ HETERODYNE
Component manufacturers
Miscellaneous
Country type (CS)
Special specification STANDARD
Atmospheric conditions NORMAL ATMOSPHERE
Slave control unit ANC CONTROL BOX (BSI) COMM 2000
OMAT ARUSIN
Localitate: CAMPULUNG
Mesajde OMAT ARUSIN » Dum 26-Apr-2009 12:36
multumesc foarte mult acum pot sa imi invat masina,...cat de cat,cat ma descurc cu franceza.
pishcotzzika
Localitate: cluj napoca
salut
Mesajde pishcotzzika » Mar 12-Mai-2009 21:46
eu am un citroen xsara 2001 1.6 16v 110 cp ...in brief scrie euro 3 am intrat pe service si seria la motor ar fi asta 10 FX2F 1030997 in seria de sasiu am incorporat NFU care este pe lista euro 3....deci ar fii euro 3? multumesc anticipat
bmw324
Localitate: GALATI
buna seara
Mesajde bmw324 » Sâm 01-Ian-2011 18:14
am achizitionat si eu un citroen xsara din 27/0/2000 si as dori sa stiu si eu mai multe date despre ea euro serie sasiu VF7NONFZF36883596 AS DOR SA O INMATRICULEZ SI NU STIU CE EURO ESTE MULTUMESC ANTICIPAT
Mesajde khan » Sâm 01-Ian-2011 18:25
Ligne de produit XSARA
N°APV/PR 08548 CJ 2 0129
Date de DĂŠbut de Garantie 27/07/2000
NumĂŠro de SĂŠrie du Moteur 10 FX1Z 0762826
NumĂŠro de SĂŠrie de la BoĂŽte 20 CD67 0622529
OPB N01L
NRE e2*98/14*0105*03
Informations gĂŠnĂŠrales
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT XSARA
SILHOUETTE BERLINE 3PTES
FINITION NIVEAU VTR
MOTEUR INJECTION TU5JP 90CV
TRANSMISSION BVM5
TYPE D’HABILLAGE INTÉRIEUR TISSU ISERE + MOLLETON "HN"
COULEUR DE GARNISSAGE FZ
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MA RENFORCEE
MOTEUR (TYPE) MOTEUR TYPE TU/TUD
MONOGRAMME COMPLÉMENTAIRE 1,6 I
MONOGRAMME COMPLÉMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
MONOGRAMME MONOGRAMME XSARA
CaractĂŠristiques vĂŠhicule
FINITION NIVEAU VTR
DIRECTION DIRECTION ASSISTEE
COUPLE TACHYMÈTRE CT 21 X 18
Alimentation moteur
ALIMENTATION INJECTION PRIM
CARTER CYLINDRE (MATIÈRE) CARTER CYLINDRE FONTE
CARBURANT ESSENCE SANS PLOMB
DÉPOLLUTION (MOTEUR) DEPOL CEE 95 (MOTEUR)
PRÉFILTRE MONTAGE SANS PREFILTRE
REFROIDISSEMENT D’HUILE SANS ECHANGEUR EAU/HUILE
RÉSERVOIR DE CARBURANT GPL SANS RESERVOIR GPL
MOTEUR REFROIDISSEMENT RADIATEUR (23 TR)
RÉCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L3
VENTILATEUR 2 VENTILATEURS 2 VITESSES 120W
RÉCUPÉRATION DES VAPEURS D’ESSENCE RECUP VAPEUR ESS NON PILOTE
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION BOSCH
BoĂŽte de vitesses Transmission
TRANSMISSION BVM5
COUPLE RAPPORT CP 16 X 65
STYLE ROUE ROUE TOLE 14 POUCES
JOINT COTÉ ROUE JOINT COTE ROUE AC2000I
JOINT COTÉ PONT JOINT COTE PONT GI2000I
DIFFÉRENTIEL (BOITE) DIFFERENTIEL RENFORCE
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 185X65X14 T
ROUES MOTRICES 2 ROUES MOTRICES
ROUES MONTÉES ROUE 5 POUCES 1/2
ROUE (TYPE) MONTAGE ROUE TOLE
BOITE DE VITESSES TYPE BVM MA
Suspension Direction Freinage
ANTIBLOCAGE SANS ANTI-BLOCAGE ROUE
BARRE ANTIDÉVERS ARRIÈRE BARRE ANTI DEVERS AR DIAM 19
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 19
FREIN PRINCIPAL AVEC COMPENSATEUR INTEGRE
FREIN TYPE DISQUES AV VENTILES/TAMBOURS AR
SUSPENSION SUSPENSION NORMALE
Carrosserie Equipements
ATTACHE-REMORQUE SANS ATTACHE REMORQUE
AVERTISSEURS AVERTISSEUR STANDARD
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTAGE AVEC DEFLECTEUR AR
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE
ENJOLIVEUR ROUE (STYLE) STYLE SAINT MALO 14 POUCES
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETRO EXT SANS FONCTION COMPLEMENTAIRE
INSONORISATION COTÉ MOTEUR INSONO TABLIER + CAPOT MOTEUR
ESSUIE-VITRE AVANT EV AV INTERM SS INDIC NIV EAU
ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT OBTURATEUR FACE AV GRANDE ENTREE AIR
PARE-CHOCS PARE-CHOCS AV+AR STANDARD COULEUR CAISSE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
PROJECTEUR SPÉCIAL (DOUBLE-OPTIQUE) PROJECTEUR SIMPLE PARABOLE
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR NON CHAUFFANT CDE MANUELLE
RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER NON CHAUFFANT CDE ELECTRIQUE
ACCESSOIRES EXTÉRIEURS POIGNEES EXT NEUTRE+RETRO EXT COUL CAISSE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
VITRE (ASPECT) TEINTEE
Equipement intĂŠrieur
ALARME ANTIVOL SANS ALARME ANTIVOL
APPUI-TÊTE ARRIÈRE APPUI TETE AR REGLABLE
APPUI-TÊTE AVANT APPUI-TETE AV ARTICULE
ASSISE ARRIÈRE BANQUETTE SEPAREE RABATTABLE
ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
CEINTURE DE SÉCURITÉ AVANT CEINTURE PYROTECHNIQUE AVEC ALARME
GRADUATION VITESSES GRADUATION EN KM/H
COMPTE-TOURS COMPTE-TOURS A AIGUILLE
CONDITIONNEMENT RADIO ALIMENT ANTENNE RECEPTEUR HP AV/AR TWEETER
COTÉ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
COMMANDE À DISTANCE MONTAGE CDE A DISTANCE
EQUIPEMENT PLANCHE DE BORD SANS DECOR CUBIC
FEUX INT. DIVERS SANS LECTEUR DE CARTE
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 220 KM/H OU 140 M/H CADRAN BLANC
COMPTE-TOURS (PRISE INFORMATIONS) COMPTE-TOURS INFO CALCULATEUR
HAUT-PARLEUR SANS HAUT-PARLEURS
COMMANDE D’AUTORADIO SANS CDE AUTO-RADIO A DISTANCE
REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE COTE PASSAGER
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
RÉGLAGE ASSISE AVANT CONDUCTEUR SANS MAINTIENS LOMBAIRE ET LATERAL CONDUCTEUR
RÉGLAGE ASSISE AVANT PASSAGER SANS MAINTIEN LATERAL FIXE PASSAGER
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
LÈVE-VITRE ARRIÈRE SANS LEVE VITRE AR
LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE ELECTRIQUE
LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE ELECTRIQUE
MONTRE MONTRE NUMERIQUE
MIROIR DE COURTOISIE CONDUCT+PASSAGER OCCULT SANS ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR NIVEAU HUILE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
SAC GONFLABLE LATÉRAL AVANT SAC GONFLABLE LATERAL AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
SAC GONFLABLE PASSAGER SAC GONFLABLE COTE PASSAGER
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PLAFONNIER CDE PTES AV - PLAFONNIER AV+AR
PROTECTION POSTE AVANT SANS GRILLE DE SEPARATION
RANGEMENT (POSTE CONDUITE) V/P INFERIEUR INJECTE
RÉCEPTEUR RADIO SANS AUTO-RADIO
RÉFRIGÉRATION REFRIGERATION REGULEE
REHAUSSE ASSISE AVANT CONDUCTEUR REHAUSSE CONDUCTEUR REGLAGE PARALLELE
RANGEMENT (AUTRES) VIDE POCHE AR CONSOLE SANS COUVERCLE
SURTAPIS (ASPECT) SANS SURTAPIS
SAC GONFLABLE CONDUCTEUR SAC GONFLABLE COTE CONDUCTEUR
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TAPIS MOQUETTE DILOURS F330
TÉMOIN D’USURE SANS TEMOIN USURE PLAQUETTE FREIN
INDICATEUR DE TEMPÉRATURE EXTÉRIEURE (GRADUATION) SANS INDICATEUR TEMP EXT
CONTACT TRANSPONDEUR
INDICATEUR DE TEMPÉRATURE D’EAU INDICAT TEMP EAU+TEMOIN ROUGE
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT MOUSSE
ElectricitĂŠ
ALTERNATEUR ALTERNATEUR CLASSE 8
BATTERIE BATTERIE L1 250
DÉMARREUR DEMARREUR CLASSE 2
ECLAIREMENT PARTICULIER SANS ECLAIRAGE PARTICULIER
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION 433,92 MHZ HETERODYNE
Marques d'ĂŠquipements
Divers
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
ADAPTATION ARMEMENT SANS ADAPTATION ARMEMENT
PRISE D’ÉCOUTE RADIO SANS PRISE ACCESSOIRES
BOÎTIER SERVITUDE BOITIER DE SERVITUDE (BSI)
seria e gresita, in loc de O e 0
bmw324
Localitate: GALATI
sal
Mesajde bmw324 » Sâm 01-Ian-2011 19:36
multumesc mult pentru informatii dar o inca intrebare ca n ma pricep este euro3 sau euro 2? multumesc anticipat
Mesajde khan » Mie 05-Ian-2011 12:03
pai eu stiu ca asta DEPOL CEE 95 inseamna euro2
usatii83
Localitate: Chisinau
Re: euro 2 sau euro 3
Mesajde usatii83 » Joi 06-Ian-2011 17:46
OMAT ARUSIN scrie:Buna,am vazut ca se poate afla detaliile masinii .Te rog Khan vrei sa imi cauti si mie ?Am incercat la adresa pe care ai postato dar nu am cont la ei.Daca vrei sa ma ajuti iti dau datele.Tipul n1rhyb xsara, nr. de identificare estevf7n1rhyb73504042 si nr. de omologare abct2x1111t13e3/2001. Toate sunt majuscule, dar nu imi permite regulamentul sa folosesc atat de multe.Multumesc.
Linie de produs XSARA II
Nr. APV/PR 09156 CJ 2 0130
Data de Inceput de Garantie DDG 14.01.2002
Numar de Serie al Motorului 10 DYJM 3023345
Numar de Serie al Cutiei 20 DL42 4166959
OPB A02P
Informatii generale
LIGNE DE PRODUIT XSARA II
SILHOUETTE BERLINE 5PTES
FINITION MOYENNE MOYENNE
MOTEUR DIESEL TURBO DW10TD
TRANSMISSION BVM5
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE PEINTURE BLEU MAURITIUS
TYPE D’HABILLAGE INTÉRIEUR VELOURS CESIUM MM
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM BE4 L
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLÉMENTAIRE SANS MONOGRAMME COMPLEMENTAIRE
MONOGRAMME COMPLÉMENTAIRE, DIVERS XSARA
MONOGRAMME XSARA + HDI
Caracteristici vehicul
COUPLE TACHYMÈTRE CT 22 X 19
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE AVEC DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DÉPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
MOTEUR REFROIDISSEMENT RADIATEUR EP:27 - 21 DM2 ALU BRASE
AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC EOBD
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
VENTILATEUR 1 VENTILATEUR 3 VITESSES 420W
VARIANTE ASSOCIÉE INJECTION SYSTEME INJECTION SIEMENS
MOTEUR HYBRIDE SANS ALTERNO-DEMARREUR
BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
Cutie de viteze Transmisie
TRANSMISSION BVM5
COUPLE RAPPORT CP 19 X 70
STYLE ROUE ROUE TOLE 15 POUCES
EMBRAYAGE EMBRAYAGE CABLE RATTRAPAGE JEU
JOINT COTÉ ROUE JOINT COTE ROUE DIAMETRE 17,5
JOINT COTÉ PONT JOINT COTE PONT JB2A
DIFFÉRENTIEL (BOITE) DIFFERENTIEL 84
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195X55X15 H
BOITE DE VITESSES TYPE BVM BE4R
Suspensie Directie Franare
ANTIBLOCAGE ANTI-BLOCAGE ROUE
ANTIDÉVERS AVANT BARRE ANTI DEVERS AV DIAM 20
FREIN PRINCIPAL REPARTITION ELECTRONIQUE FREINAGE
FREIN TYPE DISQUES AV VENTILES/DISQUES AR
CONTRÔLE DYNAMIQUE DE STABILITÉ SANS SYSTEME ESP
Caroserie Echipamente
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTAGE SANS DEFLECTEUR AR
ENJOLIVEMENT LATÉRAL (ASPECT) PROTECTEURS LATERAUX COULEUR CAISSE
ENJOLIVEUR ROUE (STYLE) STYLE BACCARAT 2 - 8 AJOURS 15 POUCES
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
SONDE TEMPÉRATURE EXTÉRIEURE AVEC SONDE TEMPERATURE EXT
RÉTROVISEUR EXTÉRIEUR (COTÉ CONDUCTEUR) RETRO EXT CONDUCTEUR CHAUFFANT CDE ELECTRIQUE
RÉTROVISEUR EXTÉRIEUR (COTÉ PASSAGER) RETRO EXT PASSAGER CHAUFFANT CDE ELECTRIQUE
ACCESSOIRES EXTÉRIEURS RETRO ET POIGNEE EXT COULEUR CAISSE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
VITRE (ASPECT) SANS VITRE
VITRE (TYPE) PARE-BRISE ATHERMIQUE
PACK LOOK EXTÉRIEUR PACK LOOK EXTERIEUR COULEUR CAISSE
Echipament de interior
CEINTURE DE SÉCURITÉ ARRIÈRE CEINT SECU AR 3 ENROULEURS 3 PTS
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
FEUX INT. DIVERS LECTEUR DE CARTE
COMBINÉ (CARACTÉRISTIQUES) GRADUATION 220 KM/H OU 140 M/H CADRAN GRIS/BLEU
HAUT-PARLEUR MONTAGE 4 HAUT-PARLEURS AV + 2 AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
FILTRE À POLLEN AVEC FILTRE A POLLEN
RÉGLAGE ASSISE AVANT PASSAGER SANS MAINTIENS LOMBAIRE ET LATERAL PASSAGER
CD ROM POUR AUTO PC SANS CD ROM POUR AUTO-PC
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR CDE MANUELLE
LÈVE-VITRE AVANT CONDUCTEUR LEVE-VITRE AV CONDUCTEUR CDE SEQUENTIELLE
LÈVE-VITRE AVANT PASSAGER LEVE-VITRE AV PASSAGER CDE ELECTR NON SEQUENTIELLE
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE SANS ECLAIRAGE
SAC GONFLABLE LATÉRAL AVANT SANS SAC GONFLABLE LATERAL AV
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) ANTI PINCEMENT CONDUCTEUR+PASSAGER ELECT+AR MANUEL
ORDINATEUR DE BORD AVEC ORDINATEUR DE BORD
PACK ÉQUIPEMENT SANS PACK EQUIPEMENT AUTO-ECOLE
PROTECTION POSTE AVANT SANS PROTECTION POSTE AV
RÉCEPTEUR RADIO SYSTEME AUDIO CASSETTE RDS RB2
RÉGULATEUR DE VITESSES SANS REGULATION VITESSE
DÉTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
Electricitate
ALTERNATEUR ALTERNATEUR CLASSE 15
BATTERIE BATTERIE L2 400
DÉMARREUR DEMARREUR CLASSE 6
Marci de echipamente
Diverse
BOÎTIER SERVITUDE BOITIER DE SERVITUDE (BSI) COMM 2000
