Sa o stapanesti sanatos!
E fabricata in data de 19.01.2006
Vehicle family C3 II
AS RPO No 10664 CA 1 0541
Guarantee Start Date 20/02/2006
Engine serial number 10 FD90 1412610
Gearbox serial number 20 CQ41 0024620
OPB A0C1
NRE e2*2001/116*0317*02
General information
Product type CAR
Commercial marque/Component type CITROEN
Silhouette FIRM 5 DOOR SALOON
Trim level MEDIUM MEDIUM
Engine DV4TD TURBO DIESEL
Transmission BVM5
Paint type NON-METALLIC PAINT
Body colour BANQUISE WHITE PAINT
Interior trim type WARP AND WEFT ECLA + CREPO "UW"
Upholstery colour "FT"
Gearbox (Characteristics) BVM MA5 / O
Engine (Type) EV/DV
Other badge, " Misc. " NO ADDITIONAL BADGE
Vehicle characteristics
Speedometer drive CT 21 X NO
Fuel supply-Engine
Fuel DIESEL FUEL
Emissions standard (engine) ANTI DEPOLLUTION L5 (ENGINE)
Speed sensor signal MULTIFUNCTIONAL ACTIVE SENSOR
Engine (Type) EV/DV
Catalytic converter 2-COMPONENT CATALYSER 50 PPM LOWER PLATE
Oil cooler WITHOUT OIL-WATER DISTR CHAMB
Cooling motor RADIATEUR EP:27 - 16 DM2 ALU BRASE SS MEC
Crankcase gas circuit heating W/O HEATER CASING GAS CIRCUIT
EOBD Self-Diagnosis System "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
Device (Antipollution) "EGR" EXHAUST GAS RECYCLING
Vehicle Technical Depollution L5 VEHICLE TECHNICAL DEPOLLUTION
Particle filter WITHOUT PARTICLE FILTER
Fan 1 AERO 2-SPEED 90W FAN
Fuel Vapour retrieval WITHOUT PETROL VAPOUR RECUPERATION
Injection associated variant SIEMENS ASSEMBLY
Tank filter CITHOUT RESERVOIR FILTER
Stop and Start WITHOUT STOP AND START
Gearbox-Driveshafts
Transmission BVM5
Final drive ratio REAR AXLE HYPOID GEARSET 17 X 61
Wheel style 14 INCH STEEL WHEEL
Gearbox type (type approval) GEARBOX MA/5 0
Differential (Gearbox) DIFFERENTIAL 68
Rim/tyre size 14 INCH TYRE FITMENT
Tyre (Size, Type) 175X65X14 T TYRES
Wheels fitted 5,5" RIM ROAD WHEELS
Wheel (Type) STEEL WHEELS
Gearbox Type GEARBOX MA
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
Rear anti-roll bar REAR ANTI-ROLL BAR DIAM 23.5
Front anti-roll bar FRONT ANTI-ROLL BAR DIAM 19
Brake Type NON-VENTILATED FRONT DISCS/REAR DRUMS
Steering travel STEERING MECHANISM TRAVEL 72
Suspension NORMAL SUSPENSION
Dynamic Stability Control System WITHOUT ELECTRONIC STABILITY PROGRAM
Brake associated variant ABS TEVES MK70
Electric steering 60 AMPERES ELECTRIC STEERING
Pedal bracket (Type) PEDAL STANDARD
Bodywork-Exterior fittings
Towbar WITHOUT TOWBAR
Aerial SHORT ROOF AERIAL
Opening roof (Appearance) WITHOUT SUN ROOF
Side mouldings (Type) SIDE TRIM PROTECTION MATT
Side mouldings (Dimension) WITHOUT BODY SILL PROTECTORS
Wheel embellisher (Style) 14 INCH 14-SPOKE MILAN STYLE
Underbody shield PLASTIC PROTECTIO + FOAM UNDER ENGINE
Additional shield (under engine) W/O ENGINE UNDERSHELDING
Ext. rearview mirror comp. function EXT MIRROR MANUAL-FOLD BACK
Exhaust tailpipe trim W/O EXHAUST OUTLET EMBELLISHER
Windscreen wiper FRONT WIPER BLADE W/O RAIN SENSOR
Headlamp wiper W/O HEADLAMP WIPER
Front panel blank WITHOUT FRONT BUMPER PLUG
Rear tailgate glass FIXED TAILGATE WINDOW
Outside temperature sensor WITH EXTERIOR TEMPERATURE SENSOR
Bumper BODY COLOUR FRONT/REAR BUMPER
Luggage rack WITHOUT ROOF BARS
Front foglamp NO FRONT FOG LIGHTS
Exterior rear view mirror (Driver side) DRIV EXT RRVW MIRROR NON HEAT ELEC CONTR
Exterior rear view mirror (Passenger side) PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL
Spare wheel STEEL WHEEL + STANDARD TYRE
Exterior accessories NEUTRAL EXT HANDLE+FLAP TRIM+EXT RR VIEW MIRROR
Sun roof FIXED ROOF
Bumper trim DYED BUMPER STRIP
Window (Type) NON ATHERMAL WINDSCREEN
Interior fittings
Anti-theft alarm WITHOUT THEFT PROTECTION ALARM
Rear head restraint WITHOUT REAR HEADREST
Front head restraint JOINTED FRONT HEADREST
Rear seat WITHOUT REAR SEAT POSITION
Luggage cover PARCEL SHELF + LUGGAGE COVER + SCREEN
Rear seatbelt WITHOUT REAR SAFETY BELT
Front seatbelt PYROTECHNIC SEAT BELT WITH ALARM
Climate (Ambient temp) TEMPERATE COUNTRIES
Child lock MANUAL REAR CHILD LOCK
Speed graduations GRADUATION KMS/H
Grab handles HANDLE FR PASS + HOOK
Radio equipment FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
Driving position LEFT HAND DRIVE
Remote control REMOTE CONTROL ASSEMBLY
Air extractor IMPROVED AIR EXTRACTOR
Dashboard equipment STANDARD FASCIA PANEL + SOLID COLOUR CONTROL PANEL
Misc. int. lamps MAP READING LAMP
Work table WITHOUT WORK TABLE
Load space trim PVC BOOT MAT+CARPET SIDES
Underseat storage WITHOUT UNDER SEAT STORAGE
Instrument panel (Characteristics) DIGITAL INSTRUMENT PANEL NEUTRAL FRONT PANEL
Loudspeaker 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
Radio controls REMOTE RADIO CONTROL
Pollen filter WITH POLLEN FILTER
Passenger compartment soundproofing 5KG BULKHEAD SOUNDPROOFING
Front passenger seat height control WITHOUT SPACER PASSENGER SIDE
Driver seat adjustment RECLINING DRIVER'S SEAT BACK
Front seat armrest ASSEMBLY WITHOUT FRONT ELBOW REST
Compact Disc WITHOUT COMPACT DISC
Satellite Navigation System WITHOUT NAVIGATION SYSTEM
Rear window lift MAN CTRL REAR WINDOW LIFTER
Driver's window lift SEQUENTIAL DRIVER'S ELECTRIC WINDOW
Passenger's window lift STD ELEC CONTROL FRONT PASSENGER ELECTRIC WINDOW
Display DISPAY (RADIO+CLOCK+AND OR T°, CD) WITHOUT MEMORY
Clock NUMERIC CLOCK
Courtesy mirror DRIV OCCULT+PASS OCCULT W/O LIGHT
Oil gauge STD OIL LEVEL INDICATOR
Fitting rear head restraint WITHOUT REAR HEAD-REST
Heating element NON HEATED SEAT
Front lateral airbag SINGLE FRONT SIDE AIRBAG
Passenger airbag PASSENGER AIRBAG
On-board computer COMPUTER
Equipment Pack WITHOUT DRIVING SCHOOL EQUIPMENT PACK
Exterior rear view mirror (Heated) NON HEATED DOOR MIRROR
Airbag Deactivation MANUAL AIRBAG DEACTIVATION
Interior door control (Appearance) CHROME FINISH INSIDE DOOR HANDLE
Front seat guard WITHOUT CAB PROTECTION PANEL
Storage (Driving Position) LOWER STORAGE COMPARTMENT WITHOUT LOCK
Radio receiver "RD4" RDS COMPACT DISC AUDIO SYSTEM
Air conditioning SINGLE AIR CONDITIONING
Cruise control WITHOUT SPEED CONTROL
Driver's seat height control PARALLEL DRV HEIGHT ADJ
Storage (others) W/O OTHER SETTING BOXES
Driver airbag DRIVERS AIR BAG
Load space storage W/O BOOT TIDY
Exterior temperature (Scale) EXT TEMP INDICATOR CELSIUS
Obstacle Detection System WITHOUT OBSTACLE DETECTOR
Trim adaptation GEAR LEVER KNOB PLASTIC+CHROME INSERT
Locking control SIMPLE CENTRAL LOCKING
Steering wheel RUBBER STEERING WHEEL
Child observation interior mirror WITHOUT INTERIOR CHILD MONITORING MIRROR
Electrical
Alternator ALTERNATOR 150 AMP
Battery BATTERY L2 400
Starter motor STARTER MOTOR CL 4
Special lighting WITHOUT PARTICULAR LIGHT
Multiplexing MULTIPLEXING ASSEMBLY CAN CAN
Component manufacturers
Miscellaneous
Country type (F)
Special specification CLUB
Atmospheric conditions NORMAL ATMOSPHERE
Radio headphone socket WITHOUT ACCESSORIES SOCKET
Traffic side RIGHT HAND DRIVE
Side impacts DOOR WITHOUT REINFORCEMENT
Set of keys 1 HF PLIP KEY+1 SECONDARY
Emergency equipment W/O HELP EQUIPMENT
Surface conditions GOOD TERRAIN
Speed monitoring PROGRAMMED OVERSPEED WARNING
Emergency warning triangle WITHOUT WARNING TRIANGLE
Informatie
