Problema la spalatoarele de faruri!!!!NEEDD HELP
- floreacioaca
- Localitate: Oradea
- Masina: Citroen C5 I Exclusive
- urzica
- Localitate: Medgidia
mitre scrie:eu nu stiu daca am. cum aflu daca sunt dar nu merg? mentionez ca la C5 II pe care il am are patratele pe bara. pun vin daca ajuta. VF7RCRHRG76707164 Merci mult.
Linie de produs C5 II
Nr. APV/PR 10523 CJ 1 0298
Data de Inceput de Garantie DDG 30.03.2006
Numar de Serie al Motorului 10 DYTJ 4122536
Numar de Serie al Cutiei 20 MB02 0318106
OPB A03Z
NRE e2*2001/116*0306*02
Informatii generale
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINE 5PTES
FINITION MOYENNE BASSE
MOTEUR DIESEL TURBO DW10BTED4 SANS FAP
TRANSMISSION BVM6
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE PEINTURE GRIS ALUMINIUM
TYPE D’HABILLAGE INTĂRIEUR VELOURS BOURBON SL
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTĂRISTIQUES) BVM ML6 CL
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLĂMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
MONOGRAMME C5
Caracteristici vehicul
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
COUPLE TACHYMÈTRE CT 22 X NO
Alimentare motor
DĂTECTEUR D’EAU FILTRE À GAZOLE AVEC DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DĂPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
MOTEUR REFROIDISSEMENT RADIATEUR EP:32 - 21 DM2 ALU BRASE
RĂCHAUFFAGE CIRCUIT GAZ CARTER RECHAUFFAGE CIRCUIT GAZ CARTER
VARIATION PUISSANCE (MOTEUR) PUISSANCE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT EGR
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
FILTRE À PARTICULE SANS FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 150W
VARIANTE ASSOCIĂE INJECTION SYSTEME INJECTION SIEMENS
FILTRE RĂSERVOIR FILTRE RESERVOIR INTERIEUR
Cutie de viteze Transmisie
TRANSMISSION BVM6
COUPLE RAPPORT CP 17 X 71
STYLE ROUE ROUE TOLE 16 POUCES
EMBRAYAGE EMBRAYAGE HYDRAULIQUE
JOINT COTĂ ROUE JOINT COTE ROUE AC 3300I
JOINT COTĂ PONT JOINT COTE PONT AAR 3300I
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X16 W
ROUE (TYPE) MONTAGE ROUE TOLE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE ML6C
Suspensie Directie Franare
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION HYDRACTIVE 3
CONTRĂLE DYNAMIQUE DE STABILITĂ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
Caroserie Echipamente
ENJOLIVEMENT LATĂRAL (ASPECT) PROTECTEURS LATERAUX TEINTE MASSE
ENJOLIVEMENT LATĂRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE
ENJOLIVEUR ROUE (STYLE) STYLE AZZANA 8 AJOURS 16 POUCES
FEU D’ĂCLAIRAGE DE SEUIL SANS FEU ECLAIRAGE DE SEUIL
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETRO EXT SANS FONCTION COMPLEMENTAIRE
ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS TEINTE MASSE
VITRE (TYPE) P-B ATHER+ACCOUS+REFL+LAT FEUILL+AR TREMPE
PACK LOOK EXTĂRIEUR SANS PACK LOOK EXTERIEUR
Echipament de interior
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE SANS ACCOUDOIR AR
CLIMAT (TEMPĂRATURE AMBIANTE) PAYS FROIDS
GRADUATION VITESSES GRADUATION EN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD DECOR ALU BRUNITO
GARNISSAGE VOLUME CHARGEMENT SANS TAPIS
RANGEMENT SOUS SIÈGE SANS RANGEMENT SOUS SIEGE
GARNISSAGE DE PORTE PANNEAU DE PORTE SANS DECOR BOIS
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) SANS STORE AR
REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE PASSAGER
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
ELĂMENTS DE GARNISSAGE INTĂRIEUR GARNISSAGE PIED CENTRAL + CUSTODE POLYPRO
ACCOUDOIR ASSISE AVANT MONTAGE SANS ACCOUDOIR AVANT
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
LECTEUR D’INFORMATIONS ROUTIÈRES SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR AFFICHEUR (MONTRE ET OU T°)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE SANS INDICATEUR NIVEAU HUILE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE SANS REGLAGE PROJECTEUR
RĂCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS RD4
RĂFRIGĂRATION REFRIGERATION AUTOMATIQUE
RĂGULATEUR DE VITESSES SANS REGULATION VITESSE
RĂTROVISEUR INTĂRIEUR RETROVISEUR INT JOUR - NUIT
RĂGULATION CLIMATISATION / TEMPĂRATURE REFRIGERATION AUTOMATIQUE MONO-ZONE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TUNER-RADIO MONO TUNER RADIO
DĂTECTION D’OBSTACLE SANS DETECTEUR OBSTACLE
AMPLI-ĂQUALISEUR SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT MOUSSE 4 BRAS
PACK AMBIANCE SANS PACK AMBIANCE
PACK RADIO / INFORMATION / COMMUNICATION RD4
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SANS MAINTIEN LOMBAIRE
Electricitate
ALTERNATEUR ALTERNATEUR CLASSE 18
BATTERIE BATTERIE L3 450
DĂMARREUR DEMARREUR CLASSE 6+
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
FRĂQUENCE RADIO FREQUENCE RADIO ASIE
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
COTĂ CIRCULATION CIRCULATION A DROITE
TRIANGLE DE PRĂSIGNALISATION CONDITIONNEMENT TRIANGLE PRESIGNALISATION[b]
Este fara spalare faruri.
