verificare serie sasiu
kady28
Re: verificare serie sasiu
Mesajde kady28 » Mie 06-Iul-2016 21:30
florindaniel scrie:WF7RWRHH89L584525, ma putet ajuta cu detalii.
In romana.
Multumesc
Banuiesc ca incepe cu V si nu cu W.
Linie de produs C5 (X7)
Nr. APV/PR 12113 CJ 1 0515
Data de Inceput de Garantie DDG 18.02.2010
OPB H003
NRE e2*2001/116*0360*10
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C5 (X7)
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI KTH - VOPSEA GRI THORIUM
TIP ECHIPARE INTERIOARA PIELE CLAUDIA MATINAL L019 "XT"
CULOARE GARNISAJ "FC"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE EXCLUSIV
MONOGRAMA C5
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATE DE PUTERE (MOTOR) PUTERE 120 KW 340 NM
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 16 X 69
STIL ROATA (JANTA) ROATA BALTICA 17 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/55 R17 97W FARA INTARIRE
ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP ML6C
Suspensie Directie Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 180
SUSPENSIE SUSPENSIE NORMALA
SUSPENSIE ACTIVA SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
IESIRE DE ESAPAMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION CU GEAM DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA DE RETROVIZOR EXTERIOR CROMATA ELECTROCHIMIC
ACCESORII EXTERIOARE MANER EXTERIOR ASPECT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL PALEA
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA SOFT
GARNISAJ SPATIU DE INCARCARE COVORAS + BAGHETA SI MANER CROMAT
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE ANODIZATA SOFT
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
CD FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE CU SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DG4
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROIECTOR DIRECTIONAL CU PROIECTOR DIRECTIONAL
RECEPTOR RADIO SISTEM RADIONAVIGATIE DE A 4-A GENERATIE "NG4"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR CU AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
MODUL TELEMATIC FARA MODUL TELEMATIC
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 6+
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
florindaniel
Localitate: ploiesti
Mesajde florindaniel » Mie 06-Iul-2016 22:01
E cu V.
Multumesc.
ovybd
Localitate: Carei
3: Citroen C2 1.4HDi 90cp
Mesajde ovybd » Joi 07-Iul-2016 08:18
@kady28 - Poti sa imi dai si mie datele pentru VF7RDRHHAAL511224 in romana?
Arian
Masina: Citroen C5 Exclusive (2010): 2.0hdi 163CP
Mesajde Arian » Joi 07-Iul-2016 08:32
Pare ok din caracteristici, ce ai interesant, sistem audio, scaun incalzit, xenon, suspensie, navigatia buna
C5 (X7) BERLINA 4 USI 2.0 HDi 163 FAP (DW10CTED4) CUTIE DE VITEZE AUTOMATA 6 TREPTE
Caracteristicile vehiculului
Nr. APV/PR 12135 CJ 1 0201
Data de Inceput de Garantie DDG 02.04.2010
OPB H007
NRE e2*2001/116*0360*11
Informatii generale
TIP CAROSERIE BERLINA 4 USI
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
TIP ECHIPARE INTERIOARA CAPITONAJ PIELE ST CYR + PIELE "XS"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C1
MONOGRAMA C5
Alimentare motor
CARBURANT MOTORINA
CILINDREE 2000 CM3
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VENTILATOR 1 VENTILATOR ELECTRONIC COMANDA INTEGRATA 220W
CUPLU RAPORT RAPORT PUNTE 15 X 53
AMBREIAJ FARA AMBREIAJ
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20,5
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
ORNAMENT DE BARA DE PROTECTIE ORNAMENT CENTRAL SPATE CROMAT
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GARNISAJ SPATIU DE INCARCARE FARA COVORAS
CAPITONAJ DE USA DECORATIUNE NEGRU ARGINT STRALUCITOR
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DG4
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
Electricitate
BATERIE BATERIE L3 500
Diverse
ETICHETA FARA
RULARE DRUM CORECT
Ex: Citroen C4 Coupe 2006: 1.6i 16V, 109CP (VTR) Gri Iceland
New: Citroen C5 Exclusive 2010: 2.0hdi 163CP Blue BOURRASQUE
Filtru Particule Anulat + Stage 2 by Doc (OBDTUNING) la 196CP/144kW/400Nm
ovybd
Localitate: Carei
Mesajde ovybd » Joi 07-Iul-2016 11:34
Arian scrie:Pare ok din caracteristici, ce ai interesant, sistem audio, scaun incalzit, xenon, suspensie, navigatia buna
Multumesc frumos, detin masina de un an, dar am zis sa vad ce are si inca nu am observat :)
sabinpop
Localitate: TarguJiu
Masina: Citroen C5 2.0 Hdi 2006 Exclusive
2: Citroen C5 2.2 Hdi 2012 "Serie noire"
Mesajde sabinpop » Mar 19-Iul-2016 12:46
Se poate o verificare si pentru urmatoarea serie vf7rd4hlabl561241 ? Multumesc
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Mar 19-Iul-2016 16:37
Un reminder.
Poate verifica oricine orice serie pe http://service.citroen.com/ cu o simpla inscriere care dureaza cel mult un minut. E mai rapid decat postarea unui mesaj pe forum si asteptatul raspunsului.
iulian.arg
Localitate: Iasi
sabinpop scrie:Se poate o verificare si pentru urmatoarea serie vf7rd4hlabl561241 ? Multumesc
Cred ca a ami cerut cineva verificare pentru seria asta.
Nr. APV/PR 12805 CJ 1 0184
Data de Inceput de Garantie DDG 06.02.2012
OPB H00E
NRE e2*2001/116*0360*19
Informatii generale
MOTOR DIESEL TURBO DW12C FILTRU DE PARTICULE
TIP DE VOPSEA LAC MAT
CULOAREA CAROSERIEI EXE - VOPSEA NEGRU PERLA NERA SATINAT
TIP ECHIPARE INTERIOARA PIELE INTEGRALA MV145 "QS"
CULOARE GARNISAJ "FE"
EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
MONOGRAMA C5
Alimentare motor
CARBURANT MOTORINA
ESAPAMENT TOBA DE ESAPAMENT TRANSVERSALA
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
VENTILATOR 2 VENTILATOARE ELECTRONICE CU COMANDA INTEGRATA 300W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
STIL ROATA (JANTA) ADRIATICA GRI HEPHAIS 19"
JANTA / PNEU DIMENSIUNI MONTARE PNEU 19 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 245/40 R19 98Y RANFORSAT
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 25
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL ROATA ADRIATICA 19 INCI
IESIRE DE ESAPAMENT IESIRE ESAPAMENT CROMATA
ROATA DE REZERVA ROATA TIP ROLA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) RETROVIZOR EXTERIOR CU OGLINDA NEATENUATA
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
AFISAJ AFISAJ DG4
ADAPTARE GARNITURA MANER + BURDUF PIELE INTEGRAL
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
VOLANT VOLAN IMBRACAT IN PIELE NETEDA
Electricitate
BATERIE BATERIE L3 760 ETANSA(L3 760 VRLA 760 EN AGM)
ILUMINAT DEOSEBIT LUMINI DE ZI FATA
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE MECCANO 1
ETICHETA FARA
RULARE DRUM CORECT
sabinpop
Mesajde sabinpop » Mie 20-Iul-2016 08:02
Multumesc
Ionutz Braila
Localitate: Braila
Masina: Opel vectra b
Mesajde Ionutz Braila » Mar 26-Iul-2016 09:31
Ma poate ajuta cineva cu informatii legate de acest VIN, cel mai mult ma intereseaza nr de km, dar daca doriti sa.mi dati si restul de informatii as fi recunoscator ( in lb romana, asta daca nu include o munca in plus) VF7RDRHF8AL517956!!
Va multumesc !!
I like CITROËN C5 III
**créative technolgie**
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Mie 27-Iul-2016 07:58
Acces la kilometri poti avea doar pe baza unui abonament destul de scump pe care, pare-se, nu-l mai are nimeni din cei care activeaza pe forum.
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Mie 27-Iul-2016 07:59
Nr. APV/PR 12155 CJ 1 0454
Data de Inceput de Garantie DDG 05.03.2010
OPB H4DM
NRE e2*2001/116*0360*09
Informatii generale
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TIP DE VOPSEA VOPSEA OPACA
CULOAREA CAROSERIEI EWP - VOPSEA ALBA BANQUISE
MONOGRAMA C5
Alimentare motor
CARBURANT MOTORINA
CILINDREE 2000 CM3
VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
ROATA DE REZERVA FARA ROATA DE REZERVA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA RETROVIZOR EXTERIOR FUMURIE
AFISAJ AFISAJ DG4
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN TEP + BURDUF DE PROTECTIE DIN PIELE
Electricitate
DEMAROR DEMAROR CLASA 5
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE DEPOLUARE SUPERIOARA
ETICHETA FARA
ECHIPAMENT DE PRIM AJUTOR RECIPIENT SUB PRESIUNE REPARARE PNEU
RULARE DRUM CORECT
Ionutz Braila
Localitate: Braila
Mesajde Ionutz Braila » Mie 27-Iul-2016 13:40
Multumesc baieti !!
SergiuMan
Localitate: Cluj
Masina: Opel Astra
Mesajde SergiuMan » Joi 28-Iul-2016 00:42
Salut.
Referitor la subiect - sunt si eu pe cale sa cumpar un C5 zilele astea. La reprezentanta nu au gasit nici pentru mine nici o intrare. Am insa istoricul de la firma de leasing (ALD AUTOMOTIVE). Mi s-a spus ca s-ar putea ca firma de leasing sa nu fi facut reviziile in reprezentata Citroen si atunci sa nu fie disponibile. Cat de "in siguranta" sa ma simt? :)
Eventual daca puteti arunca o privire la datele pentru:
VF7RDRHH8AL556334
Multumesc mult.
robby1703
Localitate: Iasi
Masina: Vw Passat B5.5
Mesajde robby1703 » Mie 03-Aug-2016 13:25
Ma puteti ajuta si pe mine cu o verificare pentru seria VF7RDRHF89L573859? Multumesc
Înapoi la “Citroen C5 III”
    Total mesaje 187832
    Total subiecte 18674
    Total membri 11847
