C5 diverse intrebari
cornelioan
Mesajde cornelioan » Sâm 20-Aug-2011 12:12
Verifica contactele in fasunguri, daca sunt OK, inseamna ca becurile sunt proaste. Iar cu un voltmetru si motorul pornit+ consumatori verifica tensiunea de incarcare, 13.8V
Mesajde mesersmith » Lun 22-Aug-2011 01:06
tensiunea maxima de incarcare este 14.4V.
daca valoarea este mai mare decat asta sau este puternic oscilanta, va trebui sa verifici alternatorul.
Eugen Chiriac
Localitate: Galati
Mesajde Eugen Chiriac » Mar 23-Aug-2011 15:59
Va rog frumos,ma poate ajuta cineva sa/mi spuna ce are masina asta pe ea?
VF7DERHZE76237492
Va multumesc mult.
Mesajde mbc » Mar 23-Aug-2011 17:26
Vehicle characteristics
Vehicle family C5
AS RPO No 09227 CJ 1 0474
Warranty Start Date 26/07/2002
Engine serial number 10 DYBL 4007816
Gearbox serial number 20 TP94 0331411
OPB R005
BER e2*98/14*0220*01
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5
SILHOUETTE 5 DOOR ESTATE
TRIM LEVEL HIGH MEDIUM
ENGINE DW10ATED TURBO DIESEL
TRANSMISSION Auto gearbox AL4
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR KSD - PETITPRE GREEN PAINT
INTERIOR TRIM TYPE "HZ" RIZIERE VELOUR
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) Auto gearbox AL4
ENGINE (TYPE) EW/DW
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
ENGINE (TYPE) EW/DW
OIL COOLER MNTG EXCHANGER ON ENG & G/BOX
COOLING MOTOR RADIATOR TH : 27 - 21 DM2 MBA
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN 500W
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE)
Gearbox-Driveshafts
FINAL DRIVE RATIO CP 25 X 68
WHEEL STYLE 15 INCH STEEL WHEEL
CLUTCH WITHOUT CLUTCH
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
TYRE (SIZE, TYPE) 205X65X15 H TYRES
WHEEL (TYPE) STEEL WHEELS
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE Auto gearbox AL4
Suspension-Steering-Brakes
TRACTION CONTROL WITHOUT ANTISLIPPING
STEERING TRAVEL STEERING MECHANISM TRAVEL 148
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
Body fittings
SIDE MOULDINGS (TYPE) BODY COLOUR DYED SIDELAMPS
SIDE MOULDINGS (DIMENSION) PLASTIC SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) 15 INCH 14-SPOKE CHAMBORD STYLE
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER HEADLAMP WASHWIPE
FRONT PANEL BLANK SEMI-CLOSED GRILLE + OPEN BUMPER
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES BODY COLOR DOOR MIRRORS AND HANDLES+PAINTED GUSSET
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
WINDOW (TYPE) ATHERMAL WINDSCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITH REAR ARMREST
RADIO TELEPHONE RADIO TELEPHONE PRE-EQUIPMENT (AERIAL + CABLE)
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT DASHBOARD WITHOUT WOOD OR ALUMINIUM DECOR
LOAD SPACE TRIM REVERSIBLE BOOT CARPET
UNDERSEAT STORAGE 2 UNDER SEAT STORAGE DRAWERS
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT ADJUSTMENT PASSENGER SPACER
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT WITHOUT DRIVERS LUMBAR ADJUSTMENT
INT. UPHOLSTERY ELEMENTS INT TRIM PANELS WITH CLOTH
FRONT SEAT ARMREST FITTED WITH ARMREST
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN WITH SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
CD-ROM FOR CAR PC WITHOUT CD ROM FOR AUTO-PC
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGE TEMPERATURE RECEIVER
HEATING ELEMENT HEATED SEAT
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION WITH RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER WITHOUT HEADLAMP ADJUSTMENT
RADIO RECEIVER "RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
LOAD SPACE STORAGE WITH BOOT TIDY
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH
FAN 1 FAN 500W
AMBIENCE PACK WITHOUT AMBIANCE PACK
Electrical
ALTERNATOR ALTERNATOR 150 AMP
BATTERY BATTERY L3 450
STARTER MOTOR CLASS 6 STARTER MOTOR
SPECIAL LIGHTING DAYLIGHT RUNNING LIGHTS
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
EMERGENCY WARNING TRIANGLE WARNING TRIANGLE CONDITIONNING
Top of the page
Eugen Chiriac
Localitate: Galati
Mesajde Eugen Chiriac » Mar 23-Aug-2011 17:57
Multumesc mult ptr ajutor,sa inteleg ca norma de poluare este euro 4?
Mesajde mbc » Mar 23-Aug-2011 18:26
Euro 3 . A mea e euro4 si zice L5 VEHICLE TECHNICAL DEPOLLUTION
Eugen Chiriac
Localitate: Galati
Mesajde Eugen Chiriac » Mar 23-Aug-2011 18:32
am inteles ...multumesc mult
mitre
Localitate: Oradea
Mesajde mitre » Sâm 10-Sep-2011 23:57
Am facut in august cam 5600 km si ieri cand veneam spre casa am alimentat din Macedonia si am avut surpriza ca dupa vreo 10 km sa apara eroarea Antipolution system faulty si sa se aprinda martorul din bord. Masina merge la fel ca inainte si nu da semne ca ar avea vreo problema. Am mai patit asa cand am luat-o si din gresala am bagat benzina. Am scos atunci benzina si am pus motorina si dupa 10 km s-a stins martorul si nu a mai aparut. Sa vad cand se termina motorina ca mai am doar un sfert de rezervor dar totusi ce ar putea fi oare? Merci
mitre
Localitate: Oradea
Mesajde mitre » Dum 11-Sep-2011 00:30
Am uitat sa spun ca am schimbat distributia si uleiul de cca 8000 km si totul este ok. nivel ulei si mesaj la pornire. nu sunt zgomote suspecte.
mitre
Localitate: Oradea
Mesajde mitre » Dum 11-Sep-2011 01:13
Intre timp am mai cautat pe forum si vad ca este posibil sa fie fie motorina proasta, debitmetru de aer si ceva conducte sau FAP dar asta iese din discutie ca nu are masina asa ceva.
mitre
Localitate: Oradea
Mesajde mitre » Joi 15-Sep-2011 20:07
Mai am vreo 10l de motorina. Maine cred ca alimentez. Care este cea mai buna motorina pe piata?
Eugen Chiriac
Localitate: Galati
Mesajde Eugen Chiriac » Vin 16-Sep-2011 14:31
Eu de doi ani de zile pun numai de la rompetrol,vara efix/ul si iarna cea mai scumpa,nu mai stiu cum se numeste.Eu las masina din septembrie pana in decembrie intr/o curte la un prieten ca plec in Italia si cand ma intorc inainte de Craciun vreau sa spun ca porneste ca si cum as fi lasat/o ieri.De aceea spun ca eu personal sunt multumit de motorina de la rompetrol.Chiar am schimbat filtru de motorina luna trecuta ,aveam facuti peste 10 000 de km cu el .Cand mi l/au dat mecanicii jos au spus ca arata foarte bine si l/as mai fi putut folosi,dar totusi l/am schimbat.
mitre
Localitate: Oradea
Mesajde mitre » Lun 19-Sep-2011 20:41
Am facut plinul si nu a disparut eroarea. Deasemenea am luat jos bateria si tot nmic. Se pare ca Lexia scrie pe ea. Sa vedem ce zice si apoi cer sfaturi. Nu am constatat comportament diferit desi am mers cca 1000 km de cand a aparut problema.
mitre
Localitate: Oradea
Mesajde mitre » Lun 07-Noi-2011 22:46
Nu a disparut eroarea. poate daca o sterg doar. am mai facut cev km si masina merge bine. a inceput sa nu mai apara decat rar eroarea de airbag si centura. dar a aparut si prima defectiune mecanica. cand am mers sa schimb cauciucurile am descoperit pe stanga un furtun rupt de la returul de hidraulic. trebuie sa merg sa vad ce si cum la service. voi aveti idee daca este periculos ca eu nu am observat sa curga. este doar umezit. poate aveti si un pret si de unde sa il comand ca cica vine numai pe original.
merci
mitre
Localitate: Oradea
Mesajde mitre » Mie 16-Noi-2011 20:25
am gasit pe original la reprezentanta 35 ron
Înapoi la “Citroen C5 I-II”
    Total mesaje 187823
    Total subiecte 18666
