Top up coolant engine level si Automatic lightning inactive
torpila999
Localitate: Iasi
Mesajde torpila999 » Lun 24-Noi-2008 11:45
Ce inseamna asta? Imi apar uneori, mai ales dimineat cand pornesc masina. Multumesc.
Mentionez ca e vb de o Xsara 1.9 hdi din 2004, cu 185mii de km.
cbx
Mesajde cbx » Lun 24-Noi-2008 12:41
completeaza lichid racire motor
iluminare automata inactiva
torpila999
Localitate: Iasi
Mesajde torpila999 » Lun 24-Noi-2008 12:44
Banuiam ceva cu lichidul de racire, dar aia cu iluminarea de la ce poate sa fie? Multumesc.
adrian_emil
Localitate: Ploiesti
Mesajde adrian_emil » Lun 24-Noi-2008 14:09
AUTOMATIC ILLUMINATION OF HAZARD WARNING LAMPS IN THE EVENT OF AN IMPACT
The BSI controls the hazard warning lamps when an impact is detected.
Functional description:
Action Illumination of hazard warning lamps.
IF condition the ignition is on
AND condition the impact detection input is activated (connected to + BAT).
The impact is detected by the inertia switch mounted on a rigid part of the vehicle's structure (mechanical switch).
The hazard warning lamps can be switched off after an impact by pressing the button.
Note: This function is not totally reliable. It depends on the size and type of the impact.
The fact that the hazard warning lamps have illuminated in the event of an impact should therefore not be communicated.
bogdan78
Mesajde bogdan78 » Lun 24-Noi-2008 17:38
tare, asa inveti o gramada de lucruri. asta cu luminile este acelas lucru cu aprinderea avariilor in caz de frana brusca?
adrian_emil
Mesajde adrian_emil » Sâm 29-Noi-2008 18:36
aprinderea avariilor in caz de frana brusca cred ca e altceva ... descrierea de mai sus este pt aprinderea avariilor in caz de tamponare cu conditia activarii senzorului (de tip mecanic) aflat in partea dreapta fatza a caroseriei
Înapoi la “Electrica - Xsara”
    Total mesaje 187855
    Total subiecte 18682
