Ce inseamna asta? Imi apar uneori, mai ales dimineat cand pornesc masina. Multumesc.
Mentionez ca e vb de o Xsara 1.9 hdi din 2004, cu 185mii de km.
Top up coolant engine level si Automatic lightning inactive
torpila999
- Localitate: Iasi
torpila999
- Localitate: Iasi
adrian_emil
- Localitate: Ploiesti
AUTOMATIC ILLUMINATION OF HAZARD WARNING LAMPS IN THE EVENT OF AN IMPACT
The BSI controls the hazard warning lamps when an impact is detected.
Functional description:
Action Illumination of hazard warning lamps.
IF condition the ignition is on
AND condition the impact detection input is activated (connected to + BAT).
The impact is detected by the inertia switch mounted on a rigid part of the vehicle's structure (mechanical switch).
The hazard warning lamps can be switched off after an impact by pressing the button.
Note: This function is not totally reliable. It depends on the size and type of the impact.
The fact that the hazard warning lamps have illuminated in the event of an impact should therefore not be communicated.
adrian_emil
Total mesaje 187855
Total subiecte 18682
