imbunatatire performante ..
Forum de discutii generale despre Citroen ZX. Numai ce nu se incadreaza in categoriile de mai jos.
DaCiaN
Localitate: Iasi, Romania
Mesajde DaCiaN » Mie 12-Mar-2008 22:14
am gasit acest paragraf pe net.. si ma gandeam poate ma ajutati sa inteleg si eu mai bine despre ce e vba. ..
Similar difficulties are encountered with the 1.8 Peugeot 306 the servo hose connects with just one branch of the two branch manifold and the PCV (positive crankcase ventilator or, more commonly called, the crankcase breather) can't be used because it's restricted at the throttle body end - solution: there is a blanked over vent precisely at he centre of the manifold in the perfect position.
Simply remove the rubber blanking plug get some 12mm hose and attach a 5cm piece to the vent with a jubilee clip then attach the Ecotek to this and use the rubber blanking plug to cover the exposed end of the Ecotek device with another jubilee clip - voila!
Bill's Peugeot (left) was much more responsive and on his annual trip to Devon a fill up that normally cost £30 was only £25 this time (same prices!) so he's saved about 15% on his fuel bill - oops sorry for the pun!
http://www.ecotekplc.com/images/30618.JPG
poate ma face careva sa inteleg mai bine.. de tradus am tradus eu .. dar nu prea am inteles mare lucru.. nu stiu termenii tehnici .
multumesc anticipat
p.s. e ceva legat de un power boost ce ar mari performantele masinii.. sau reactiile acesteia.. dar nu inteleg principiul de functionare..
btw.. intreb despre acest motor deoarece este identic ca al meu.. (aproape ).
Respectul se castiga, nu se impune ...
nicum
Masina: BX 16 RS
Mesajde nicum » Joi 13-Mar-2008 11:04
Cel mai bine ar fi sa dai tot threadul.
Nici eu nu inteleg prea bine. Fie a redus asistarea servo-directiei si in felul asta servo-directia suge mai putina putere, fie a intrerupt recircularea gazelor din carter si in felul asta amestecul e mai bun si deci motorul raspunde mai bine.
DaCiaN
Mesajde DaCiaN » Joi 13-Mar-2008 19:35
pai am dat linkul .. mai sus
am preluat de aici.. nu prea am inteles modul de functionare.. zic ca ar fi ceva reglaje la aer.. amestec carbiurant..? culmea e ca acest produs nu e numai pt astfel de motoare.. ci pt o gama ff mare de motoare .
nicum
Masina: BX 16 RS
Mesajde nicum » Vin 14-Mar-2008 12:48
Pai da link-ul complet... comentariile alea par desprinse de pe un forum.
DaCiaN
Mesajde DaCiaN » Vin 14-Mar-2008 12:50
omule.. am dat linkul.. e asa de greu sa te uiti pe un site?..
nu te descurci?:) ce link sa mai dau? .. de pe siteul respectiv am preluat. .. e vba despre produsul respectiv.. un simplu click si vezi produsul
marryuss
Localitate: bacau
Mesajde marryuss » Mie 26-Mar-2008 10:55
legat de imbunatatirea performantelor la zx.
Visez in continuare la un zx 16v. Intrebarea mea este: se poate monta pe un motor de 1.8 8v o chiuloasa de 1.8 16v? Intreb acest lucru ca eu trebuie sa imi fac rk la motor si daca tot il desfac....
alexd
Mesajde alexd » Mie 26-Mar-2008 11:58
dacian, de exemplu poti sa dai linkul asa :
http://www.ecotekplc.com/power_boost.htm
nu stiu daca asta e prostia care te intereseaza sau alta, de ce m-as obosi eu sa caut cand tu nu te obosesti sa dai un link coerent...
te mai si gonflezi de parca ai de a face cu niste prosti puturosi nedescurcareti care nu au altceva de facut pe forumu' asta decat sa caute cai verzi pe pereti pentru ca vrei tu sa stii la ce foloseste o aberatie.
DaCiaN
Mesajde DaCiaN » Joi 27-Mar-2008 20:24
am dat un simplu link si in caz ca cineva priceput se pricepe, ma lumineaza si pe mine.
oricum nu ai fost tu acela.
mersi si scuze daca te-ma jignit(ofensat) cu ceva.
se poate sterge topicul.
Înapoi la “Citroen ZX”
