Jos taxele Sulfinei!
mars2k
Mesajde mars2k » Mie 24-Ian-2007 16:07
Paco, textul tau e f. frumos formulat, dar (sper sa nu te superi) esenta lui o inteleg ca "nu vrem taxa ca nu ne place".
Daca protestul nostru ajunge la vreun oficial UE in forma actuala, va zice:
"Uite niste romani care n-au chef sa plateasca niste taxe. Nimic nou!"
Poate ai putea sa te inpiri din textul de mai jos, la partea cu Articolul 90.
Daca vorbim pe limba lor vor intelege ca, cel putin, ne-am facut temele.
"The European Court of Justice (ECJ) has consistently held that a Member State is not prohibited from levying a vehicle tax such as one on the first registration of a vehicle in that Member State but provided that the tax is in conformity with Article 90 of the EC Treaty.
This means that a Member State must not impose any internal tax, directly or indirectly, on the products of other Member States of a kind in excess of that imposed directly or indirectly on similar domestic products.
The ECJ has declared that Article 90 requires a Member State to take an imported second-hand vehicle's actual depreciation into account in calculating registration tax.
Otherwise the tax imposed would exceed the residual tax incorporated in the value of similar second-hand motor vehicles already registered in the national territory (see ECJ cases Nunes Tadeu, C-345/93; Commission v Denmark, C-47/88; and Commission v Hellenic Republic, C-375/95)."
Later edit: (off topic)
Si motorul ala de la Honda e tot atat de Euro 5 cum sunt si cele 5 stele EuroNCAP pe care le-a "obtinut" Civic :twisted:
http://www.euroncap.com/images/results/ ... asheet.pdf
Euro 2005 inseamna Euro 4, nu Euro 5.
Ultima oară modificat Mie 24-Ian-2007 16:11 de către mars2k, modificat 1 dată în total.
razzwan
Localitate: Galati
Mesajde razzwan » Mie 24-Ian-2007 16:11
parerea mea este ca sa fie dati astia din functie ca altfel daca cumva va castiga procesul UE au spus ca va baga alta taxa asemanatoare asteia asa ca deacuma ii mai voteaza masa .... :x
paco
carcotas profesionist
Mesajde paco » Mie 24-Ian-2007 16:20
Textul meu nu era pt europeni, ci pentru cei dinauntru. Pe de alta parte, am mentionat si eu articolul 90, invocat in textul tau.
Stai linistit, europenii stiu care sunt motivele reale ale taxei lui Brent Valmar, cred ca e mai important sa facem pur si simplu galagie, sa se vada ca birurile ne omoara.
Partea tehnica e treaba lor de negociere cu hotii de la putere.
Am mai spus, puteti corija textul cum credeti, nu tin sa ramana in forma actuala, doar n-am sa-l semnez doar eu.
nicum
Masina: BX 16 RS
Mesajde nicum » Mie 24-Ian-2007 16:33
@paco: am citit acum textul. Sorry ca nu l-am vazut mai devreme. E ok, dar se mai pot aduce imbunatatiri.
Toata lumea cunoaste motivatiile reale ale lui BV & co, ecologia e un pretext mult prea lame.
Acum trebuie sa vedem cum facem ca a acest text sa ajunga in mass-media. khan poti sa faci ceva in sensul asta? Textul se poate pune si sub forma de petitie online, dar pentru un impact cu adevarat important, e important sa ajunga in presa, altfel e doar un alt strigat in neant. :evil:
alexd
Mesajde alexd » Mie 24-Ian-2007 17:00
am spus si repet: un comunicat de presa oficial nu il poate da khan sau wld sau paco sau nicum. Il da asociatia, prin fax, catre agentiile de presa. aici nu-ti trebuiesc pile sa bagi comunicatu in mapa redactorului sef. De la agentiile de presa il preiau pulicatiile. simplu. va dau eu comunicatul, chit ca nu am nici o pozitie oficiala in club.
textul este foarte bun, hotarat-va asupra lui, dar tineti minte ca nu este declaratia de independenta, este doar un text de protest....
Mesajde WLD » Mie 24-Ian-2007 17:24
Nicu zicea sa ne ajute khan ca lucreaza in presa. Dar nu e nevoie, e de-ajuns un fax sau chiar un mail.
O sa vad ce mai adaug si eu la text in seara asta, apoi il postez aici. Il trimit lui Alexd ca si document sa il trimita la agentiile de presa, daca tot s-a oferit :wink:
RETRAS LA PENSIE
Mesajde eugenro2001 » Mie 24-Ian-2007 17:25
Am auzit mai devreme la radio ca ministrul de finante a spus ca taxa de prima imatriculare se va mentine cel putin inca doua-trei luni urmand ca in urma discutiilor cu comisiile europene sa o transforme in taxa in functie de gradul de poluare cu un cuantum care sa fie in concordanta cu cerintele UE.
paco
Mesajde paco » Mie 24-Ian-2007 19:20
Trag si ei de timp.
Oricum, e bine sa ne manifestam.
Asteptam adaugirile lui WLD si sper ca textul sa fie preluat de vreo publicatie.
Daca nu, incercam prin pile!
Mesajde dj01fad » Mie 24-Ian-2007 22:22
cum adica sa o transforme in taxa in functie de gradul de poluare? adica o sa o platim si noi, cei care avem masinile deja inmatriculate?
Dan Popa
Mesajde Dan Popa » Mie 24-Ian-2007 23:46
Deci, cine semneaza si cum ?
paco
Mesajde paco » Joi 25-Ian-2007 06:40
Rabdare, Catalin zice ca vrea sa mai perie nitel textul.
Apoi semnam si-l trimitem la presa.
jgr1001
Localitate: Bucuresti / Fagaras
Mesajde jgr1001 » Joi 25-Ian-2007 08:41
Se pare ca Vladescu da inapoi cu taxa:
http://www.curentul.ro/curentul.php?num ... bart=50395
paco
Mesajde paco » Joi 25-Ian-2007 08:57
Normal, europenii nu se vor lasa prostiti de smecherii de la APIA.
Iata alta luare de pozitie:
http://www.hotnews.ro/articol_64064-Rep ... culare.htm
Noi sa ne continuam demersul nostru, victoria e a noastra!
Dan Popa
Mesajde Dan Popa » Joi 25-Ian-2007 09:30
Paco, esti profesionist ! Victoria este a lor de 17 ani, dar noi ne continuam protestul.
mars2k
Mesajde mars2k » Joi 25-Ian-2007 09:47
dj01fad scrie:cum adica sa o transforme in taxa in functie de gradul de poluare? adica o sa o platim si noi, cei care avem masinile deja inmatriculate?
Daca se transforma in taxa ecologica, da.
Dar asta se va intampla oricum dupa ce UE ajunge la consens in privinta taxei (unice) ecologice (estimarea actuala: 2009).
Înapoi la “Diverse”
    Total mesaje 187847
    Total subiecte 18678
    Total membri 11850
    Cel mai nou membru Blustery
