verificare serie sasiu
- Davos
- Masina: Citroen C4 Picasso 2.0 BlueHDI BVA
Re: verificare serie sasiu
Caracteristicile vehiculului VF7RWRHRJ9L536551
Linie de produs C5 (X7)
Nr. APV/PR 11902 CJ 1 0062
Data de Inceput de Garantie DDG 08.09.2009
OPB HBDA
NRE e2*2001/116*0360*07
P4A 9658463599
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C5 (X7)
TIP CAROSERIE BREAK 5 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EZR - VOPSEA GRI ALUMINIU
TIP ECHIPARE INTERIOARA CAPITONAJ PIELE ST CYR + PIELE "XS"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C1
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE EXCLUSIV
MONOGRAMA C5
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO 4 (MOTOR)
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATE DE PUTERE (MOTOR) PUTERE 100 KW 320 NM
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO4
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 160W
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 15 X 53
STIL ROATA (JANTA) ROATA BALTICA 17 INCI
AMBREIAJ FARA AMBREIAJ
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/55 R17 97W FARA INTARIRE
ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6
Suspensie Directie Franare
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 180
SUSPENSIE SUSPENSIE NORMALA
SUSPENSIE ACTIVA SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
Caroserie Echipamente
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
IESIRE DE ESAPAMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA RETROVIZOR EXTERIOR FUMURIE
ACCESORII EXTERIOARE MANER EXTERIOR ASPECT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
MODUL TELEMATIC FARA MODUL TELEMATIC
ALARMA ANTIFURT FARA ALARMA ANTIFURT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL PALEA
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA
GARNISAJ SPATIU DE INCARCARE COVORAS + BAGHETA SI MANER CROMAT
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE NEGRU ARGINT STRALUCITOR
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
CD FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DG4
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE PASAGERI FATA + SPATE
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROIECTOR DIRECTIONAL CU PROIECTOR DIRECTIONAL
RECEPTOR RADIO SISTEM RADIONAVIGATIE DE A 4-A GENERATIE "NG4"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 6+
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
OPB HBDA
P4A 9658463599
Informatii generale
MONOGRAMA C5
Alimentare motor
CARBURANT MOTORINA
CILINDREE 2000 CM3
AFISAJ AFISAJ DG4
Electricitate
Diverse
ETICHETA FARA
RULARE DRUM CORECT
zare
- Localitate: Oradea
- Masina: Citroen C5 III 2009, 2.0 100 Kw .Automata.
- 2: Peugeot 407
Multumesc Davos !
Stana Alexandru
- Masina: CITROEN DS4
- 2: Citroen c4
Salut! Imi poti verifica si mie urmatoarea serie se sasiu.
VF7NX9HR8BY630302
Multumesc frumos!
VF7NX9HR8BY630302
Multumesc frumos!
- Davos
Caracteristicile vehiculului VF7NX9HR8BY630302
Linie de produs DS 4
Nr. APV/PR 12772 88 1 0808
Data de Inceput de Garantie DDG 30.11.2011
OPB 000M
NRE e2*2007/46*0040*06
P4A 9666874399
Informatii generale
LINIE DE PRODUS DS 4
TIP CAROSERIE COUPE 3+2 USI
NIVEL DE ECHIPARE INALTA INALTA
MOTOR DIESEL TURBO DV6C
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
TIP ECHIPARE INTERIOARA PIELE CLAUDIA L019 + PIELE CLAUDIA MB L049 "3P"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCE
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
Alimentare motor
VARIANTA SOCIATA INJECTIE SISTEM INJECTIE SIEMENS
ALIMENTARE INJECTIE TURBO CU SCHIMBATOR DIRECT
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE EURO5 (MOTOR)
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR CU 3 COMPUSI IN FILTRE IMPREGNATE CU RODIU + PALADIU
RECIRE ULEI SCHIMBATOR APA/ULEI MOTOR
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
OPTIMIZAREA CONSUMULUI VEHICULULUI NARMAL
MOTOR RACIRE RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
VARIATE DE PUTERE (MOTOR) PUTERE MOTOR 82 KW - 270 NM
AUTODIAGNOSTICARE EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
DISPOZITIV (ANTIPOLUARE) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
VENTILATOR 1 VENTILATOR 2 TURATII 140W AERO FARA PRIZA DE AER
RECUPERARE VAPORI DE BENZINA FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
CUPLU RAPORT RAPORT PUNTE 19 X 74
STIL ROATA (JANTA) ROATA CU JANTA ALUMINIU B75 17 INCI STIL 2 ’CANBERRA’
AMBREIAJ AMBREIAJ HIDRAULIC
PNEURI (DIMENSIUNI, TIP) PNEU 215/55 R17 94V NERANFORSAT
ROTI MONTATE ROATA 7 INCI 1/2
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
VARIANTA ASOCIATA FRANA ESP BOSCH 8 1
PEDALIER (TIP) PEDALIER ALUMINIU
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 30
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23,5
FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
RACIRE ULEI DE POMPA DE DIRECTIE FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
PACHET LOOK EXTERIOR DECOR NEGRU STRĂLUCITOR + ELERON ÎN CULOAREA CAROSERIEI (DDY25) + ORNAMENT GEAM CROMAT (DGV04) + GEAM FUMURIU + FUMURIU ÎNCHIS (DVD09)
PACHET RADIO / INFORMATII / COMUNICARE CU SET TELEFONIC MÂINI LIBERE (DDO01) + eMyWay (DRCT6) + 1 PRIZĂ JACK + USB (DYM04)
ACCES SI PORNIRE CU MAINI LIBERE FARA SISTEM ACCES/PORNIRE MAINI LIBERE
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
AVERTIZOARE SISTEM DE AVERTIZARE ACORD
ANTENA ANTENA PAVILION + GPS + INTEGRATA
DEFLECTOR AERODINAMIC SPATE MONTARE CU DEFLECTOR DE AER
DECORATIUNE (VOPSEA) DECORATIUNE NEGRU STRALUCITOR + ELERON IN CULOAREA CAROSERIEI
ORNAMENT LATERAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT LATERAL (DIMENSIUNE) FARA ELEMENTE DE PROTECTIE LATERALE CU TREAPTA CROMATA
ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
LUMINA DE SEMNALIZARE BALIZAJ LATERAL + SEMNATURA LUMINOASA
INEL DE FIXARE EXTERIOR (ADAUGAT) INEL ARIMARE EXTERIOARA VAPOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR PLIABIL ELECTRIC + DIODA/LED
APARATOARE DE NOROI APARATOARE DE NOROI CU SPUMA
ORNAMENT DE CAP DE TEAVA DE ESAPAMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORIZARE PE MOTOR ELEMENTE DE IZOLARE SUB CAPOTA MOTOR + TABLIER + PARTE INFERIOARA DE CAROSERIE
STERGATOR PARBRIZ MECANISM STERGERE PARBRIZ CU INTERMITENTA CU CADENTA AUTOMATA + INDICATOR NIVEL DE APA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
STERGATOR DE LUNETA (FUNCTIONARE) MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CU PORNIRE AUTOMATA
OBTURATOR FATA FATA FARA OBTURATOR PARTE FRONTALA FATA
BARA DE PROTECTIE BARA DE PROTECTIE FATA + SPATE STANDARD IN CULOAREA CAROSERIEI + ORNAMENT CROMAT
APARATOARE DE NOROI (BAVETA) FARA APARATORI DE ROTI SPATE
PLACA DE INMATRICULARE FARA PLACUTA DE INMATRICULARE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA CU LUMINI DE VIRAJ
ROATA DE REZERVA ROATA TIP ROLA
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI
ORNAMENT DE BARA DE PROTECTIE BARA DE PROTECTIE FARA ORNAMENTE
GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
GEAM LATERAL SPATE (NATURA) FARA GEAM FIX LATERAL SPATE
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
MODUL TELEMATIC MODUL TELEMATICA AUTONOM
TETIERA SPATE TETIERA SPATE REGLABILA
TETIERA FATA TETIERA FATA ARTICULATA
SCAUN SPATE BANCHETA SPATE CU PERNA MONOBLOC SPATARE SEPARATE
DETECTARE UNGHI MORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
MASCARE BAGAJE PANOU/MASUTA
CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMATIZOR CU AEROTERMA
SIGURANTA COPII SIGURANTA COPIL MANUALA USA SPATE
CONSOLA CONSOLA LUNGA
ILUMINAT DE PORTBAGAJ VOLUM INCARCARE COMANDA AUTOMATA ILUMINAT PORTBAGAJ + VOLUM DE INCARCARE + AMV
ECHIPAMENT PLANSA DE BORD PLANSA DE BORD STANDARD + PARTE INFERIOARA INJECTATA
LUMINI INTERIOARE DIVERSE LUMINI PENTRU CITIT HARTA FATA/SPATE CU LED-URI FARA LED DE AMBIANTA CU LUMINI PENTRU ILUMINAT AMBIENTAL
GARNISAJ SPATIU DE INCARCARE COVORAS PORTBAGAJ MOCHETA
DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD CU COROANA PERSONALIZATA + CONTUR CROMAT
CAPITONAJ DE USA DECORATIUNE MOLDING 2
ANCORARE SCAUN PENTRU COPII FARA SISTEM DE ANCORARE ISO PENTRU SCAUNE DE COPII SPATE
COMANDA DE SISTEM AUDIO COMANDA SISTEM AUDIO LA DISTANTA
INSONORIZARE HABITACLU ELEMENT DE IZOLARE FONICA TABLIER 5,5KG + VOL + PARTE SUPERIOARA LATERALA SPATE DE CAROSERIE + PASAJ DE ROATA
INALTARE SCAUN DE PASAGER FATA DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR REGLARE ELECTROPNEUMATICA A SUPORTULUI LOMBAR AL CONDUCATORULUI
REGLARE SCAUN FATA DE PASAGER REGLARE ELECTROPNEUMATICA SUPORT LOMBAR PASAGER
COTIERA DE SCAUN FATA COTIERA CENTRALA SCAUN FATA + REGLABILA
INDICATOR DE TEMPERATURA EXTERIOARA INDICATOR TEMPERATURA EXTERIOARA
BECURI DE PROIECTOR LAMPA CU HALOGEN
ACTIONARE GEAM SPATE FARA MECANISM DE ACTIONARE GEAM SPATE
ACTIONARE GEAM FATA PASAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFISAJ AFISAJ DG4
OGLINDA DE PARASOLAR OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
SUPORT DE PICIOR SUPORT SPRIJIN PICIOR STANG CONDUCATOR DIN ALUMINIU
INDICATOR DE ULEI SENZOR DE NIVEL DE ULEI
MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
CALCULATOR DE BORD CU CALCULATOR DE BORD
PACHET ECHIPAMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
COMANDA INTERIOARA DE USA (ASPECT) PALETA USA CROMATA + ORNAMENT NEUTRU
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROIECTOR DIRECTIONAL FARA PROIECTOR DIRECTIONAL
PROTECTIE POST FATA FARA PROTECTIE POST FATA
PARASOLAR FATA PARASOLAR CONDUCATOR + PASAGER FARA INSCRIPTIE
DEPOZITARE (POST DE CONDUCERE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE + PALETA CROMATA
RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI LIMITARE VITEZA PROGRAMABIL
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR REGLAJ PARALEL + INAINTE
DEPOZITARE (ALTELE) COMPARTIMENT DE DEPOZITARE STANDARD + BUZUNARE PE SPATARELE SCAUNELOR FATA
COVORAS DE PODEA (ASPECT) COVORAS SUPLIMENTAR MOCHETA 1
DEPOZITARE VOLUM DE INCARCARE CHINGA LATERALA PORTBAGAJ + PLASA
COVORADS DE PODEA MOCHETA TESUTA DILOUR F550
MARTOR DE NIVEL DE LICHID DE RACIRE FARA MARTOR LUMINOS PENTRU NIVEL LICHID DE RACIRE
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
ADAPTARE GARNITURA MANER ALUMINIU + BURDUF PIELE CLUB
COVORAS DE PODEA COVORASE SUPLIMENTARE FATA + SPATE
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN PIELE DE CEA MAI BUNA CALITATE
Electricitate
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L2 640
DEMAROR DEMAROR CLASA 5
ILUMINAT DEOSEBIT LUMINI DE ZI FATA
MASURA INCARCARII BATERIEI CU SISTEM DE MASURARE A NIVELULUI DE INCARCARE A BATERIEI
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SOCIETATI (OVSA)
MODIFICARE AN MODEL IN CURS INDICE MINOR "00"
PLACUTA CONSTRUCTORULUI PLACUTA CONSTRUCTOR UNIUNEA EUROPEANA + NRE
ETICHETA FARA ETICHETA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII 220V + ACCESORIU DUBLU
SOC LATERAL USA CARE NU ESTE INTARITA
SET DE CHEI 2 CHEI TELECOMANDA DE INALTA FRECVENTA
RULARE DRUM CORECT
MONITORIZARE VITEZA FARA SISTEM DE MONITORIZARE VITEZA
PLACA DE OMOLOGARE COMPLEMENTARA FARA PLACUTA DE OMOLOGARE SUPLIMENTARA
OPB 000M
P4A 9666874399
Informatii generale
Alimentare motor
CARBURANT MOTORINA
CILINDREE 1600 CM3
AFISAJ AFISAJ DG4
Electricitate
Diverse
RULARE DRUM CORECT
norishor
- Localitate: Campina / Bucuresti
- Masina: Citroen C2 VTS (de competitie)
- 2: Lexus CT200H (de familie)
Stana Alexandru scrie:Salut! Imi poti verifica si mie urmatoarea serie se sasiu.
VF7NX9HR8BY630302
Multumesc frumos!
Pe langa ce a scris colegul DAVOS, intreaba la reprezentanta de campania de rechemare pentru probleme la capota. Ai o campanie activa!
Servicii Diagbox: Activari/dezactivari optiuni / Actualizari software / Telecodare cheie noua/Reparatii chei telecomanda PSA / Telecodare RD/RT CD/Mp3 / Diagnoza pre-achizitie auto
Stana Alexandru
- 2: Citroen c4
Multumesc DAVOS.
La ce problema te referi la capota?
Stana Alexandru
- 2: Citroen c4
Vreau sa va mai intreb ceva, am un obd II l-am pus pe masina astazi si am avut urmatoarele doua erori P0263 si P0269, dar nu erau permanente, le-am putut sterge, iar dupa vre-o 4 5 km am pus iar obd-ul si erorile nu au mai aparut. Ce ar putea fi?
norishor
@Alexandru: intrebi la reprezentanta care e treaba cu capota.
Stana Alexandru
- 2: Citroen c4
@norishor: ai putea fi putin mai explicit despre ce este vorba te rog, nu prea am timp sa merg in reprezentanta prea curand. Multumesc anticipat, o seara frumoasa!
startz
- Localitate: boldesti-scaeni
- Masina: toyota yaris mk1
- 2: urmeaza un citroen
Salutare!
Sunt nou pe aici.
Pentru ca s-a marit putin familia si nu mai e de ajuns un yaris in doua usi si nici loganul maica-mii, intentionez sa cumpar un c4 picasso/ grand picasso.
Am gasit ceva,am vazut, imi place dar niste informatii in plus nu strica.
Asadar, va rog, daca se poate ceva informatii pentru VIN: VF73AAHXTDJ891014
Va multumesc mult!
Sunt nou pe aici.
Va multumesc mult!
norishor
startz scrie:Salutare!
Sunt nou pe aici.
Va multumesc mult!
Salutare!
Linie de produs C4 PICASSO / C4 SPACETOURER (B78)
Nr. APV/PR 13574 FV 2 0476
Data de Inceput de Garantie DDG 02.06.2014
OPB 003G
NRE e2*2007/46*0356*04
P4A 9802806199
Informatii generale
LINIE DE PRODUS C4 PICASSO / C4 SPACETOURER (B78)
TIP CAROSERIE BREAK TIMP LIBER
NIVEL DE ECHIPARE INALTA MEDIE
MOTOR DIESEL DW10FD FAP 110KW
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE TIP STOP AND START
TIP DE VOPSEA PLAT STANDARD
CULOAREA CAROSERIEI EXY - VOPSEA NEGRU ONIX
TIP ECHIPARE INTERIOARA TAPITERIE PANZA ONDULICE "8M"
CULOARE GARNISAJ "FC"
MONOGRAMA BLUE HDI
DIRECTIE SISTEM DE DIRECTIE VARIABILA ASISTATA
CUPLU DE TAHOMETRU FARA RAPORT TAHOMETRU
Alimentare motor
ALIMENTARE INJECTIE TURBO DIRECTA CU SCHIMBATOR
CARBURANT MOTORINA
DEPOLUARE (MOTOR) DEPOLUARE (MOTOR) EURO 6.1
CILINDREE 2000 CM3
CATALIZATOR CATALIZATOR CU MAI PUTIN DE 50PPM
OPTIMIZAREA CONSUMULUI VEHICULULUI OPTIMIZARE CONSUM DE CARBURANT NORMAL
MOTOR RACIRE RADIATOR EP28 28DM2 ALUMINIU BRAZAT
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA EURO6
VENTILATOR 1 VENTILATOR 2 TREPTE DE TURATIE 140W AERO VOLET DYNAMIQUE
LANT DE TRACTIUNE HIBRIDA FARA LANT DE TRACTIUNE HIBRID
STOP AND START CUA STOP AND START ALTERNATOR DEMAROR
STIL ROATA (JANTA) JANTA EOLE 18"
JANTA / PNEU DIMENSIUNI ECHIPARE CU PNEURI DE 18 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/45 R18 95V RANFORSAT
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE DETECTARE PNEU DEZUMFLAT INDIRECT FARA LOCALIZARE
CUTIE DE VITEZE TIP CUTIE DE VITEZE TIP AM6 3
BARA ANTIRULIU SPATE RIGIDITATE 30000 NM/RAD
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 23 TUBULARA
UNGHI VOLAN CU SENZOR DE UNGHI VOLAN
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE METALICA
DIRECTIE (FUNCTIONARE) SISTEM DE DIRECTIE ASISTATA ELECTRIC
PROTECTIE SUB CAROSERIE FARA ELEMENT DE PROTECTIE SUB CAROSERIE
ETANSEITATE AERODINAMICA ETANSARE AERODINAMICA USA FATA SI SPATE
INSONORIZARE PE MOTOR ELEMENTE DE IZOLARE FONICA TABLIER + CAPOTA + PASAJ DE ROATA + GRUP MOTOPROPULSOR SISTEM CLIMATIZARE
STERGATOR PARBRIZ INTERMITENT CU 2 CADENTE + CADENTA AUTOMATA
BARA DE PROTECTIE BARA DE PROTECTIE FATA IN CULOAREA CAROSERIEI + INEL CROMAT SI BARA DE PROTECTIE SPATE IN CULOAREA CAROSERIEI
ROATA DE REZERVA FARA ROATA DE REZERVA
ACCESORII EXTERIOARE MANER EXTERIOR NEGRU + INEL CROMAT
GEAM (TIP) PARBRIZ DIN STICLA STRATIFICATA IZOLATA TERMIC + IZOLATA ACUSTIC + SPATE DIN STICLA SECURIZATA
ACCES SI PORNIRE CU MAINI LIBERE ACCES FATA + PORTBAGAJ + PORNIRE MAINI LIBERE
SCAUN SUPLIMENTAR 2 SCAUNE SEPARATE SUPLIMENTARE
DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
MASCARE BAGAJE PANOU MASCARE BAGAJE + RULOU
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
COMANDA DE VITEZE COMANDA VITEZA PE VOLAN
CONSOLA CU CONSOLA AMOVIBILA
EXTRACTOR DE AER FARA EXTRACTOR DE AER
ILUMINAT COMPARTIMENT DEPOZITARE CU LUMINA IN TORPEDOU
ECHIPAMENT PLANSA DE BORD DECORATIUNE PLANSA DE BORD INTENSIVE
VARIATIE DE ECHIPARE INTERIOARA ECHIPARE INTERIOARA STOFA
LUMINI INTERIOARE DIVERSE ILUMINAT CU LED-URI
MASUTA DE LUCRU CU MASA DE LUCRU
TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD DIGITAL CU 29 MARTORI LUMINOSI
CAPITONAJ DE USA DECORATIUNE LAC MAT
VENTILATOR ADITIONAL CU VENTILATOR SUPLIMENTAR
INSONORIZARE HABITACLU IZOLARE FONOCA TABLIER + TUNEL VARF DE GAMA
INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
REGLARE PERNA DE SEZUT FATA CONDUCATOR PERNA DE SEZUT CONDUCATOR CU REGLARE SPATAR CU INCLINARE
REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
RABATERE SCAUN FATA DE PASAGER CU SISTEM DE RABATERE PERNA DE SEZUT SCAUN PASAGER FATA
COTIERA DE SCAUN FATA COTIERE FATA CONDUCATOR SI PASAGER
CD MONTARE COMPACT DISCURI
CASETA DE DEPOZITARE TRAPE IN PODEA
AFISAJ ECRAN DIGITAL SENSIBIL LA ATINGERE + DIAGONALA 12" DFT
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
PLAFONIERA COMENZI USI FATA + SPATE PLAFONIERE FATA + SPATE
RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
DEPOZITARE (ALTELE) BUZUNAR DIN PLASA PE SPATARUL SCAUNULUI
COVORAS DE PODEA (ASPECT) FARA COVORAS SUPLIMENTAR
AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE + PARCARE AUTOMATA
STORURI LATERALE TRANSPERANTE LATERALE CU COMANDA MANUALA
COVORAS DE PODEA FARA COVORAS SUPLIMENTAR
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
VARIANTA ASOCIATA SCAUN VARIANTA ASOCIATA PERNA DE SEZUT INALTA
AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
RETROVIZOR INTERIOR SUPRAVEGHERE COPII RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
Electricitate
ALTERNATOR ALTERNATOR ISTT52
BATERIE BATERIE L3 760 VRLA2 EN AGM
ILUMINAT DEOSEBIT LUMINA DIURNA FATA (LATERAL DREAPTA)
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI 433,92 MHZ SUPER HETERODINA
MULTIPLEXARE ARHITECTURA ELECTRICA FULL
Diverse
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII TRIPLA
LICHID REFRIGERANT LICHID DE REFRIGERARE 1234 YF
ECHIPAMENT DE PRIM AJUTOR KIT REPARARE PROVIZORIE PNEU
RULARE DRUM CORECT
startz
@norishor
Mulțumesc mult!
Ma intriga o chestie: tapițerie interioara pânză ondulice "8m".
Am văzut mașina și scaunele sunt din piele și într-adevăr sunt neincalzite, cam ciudat.
Mulțumesc mult!
dumi
- Localitate: Bucharest
- Masina: Citroen C5 2011 163cp
Bună seara.
Îmi puteți da și mie caracteristicile unui C5 x7 cu seria VF7RDRHHABL527870?
Mulțumesc
P. S. @norishor dacă le poți secționa ca mai sus, ți-aș fi recunoscător
Mulțumesc
dumi
Nu ma poate ajuta și pe mine cineva cu caracteristicile în limba română?
dumi
Am rezolvat. Mulțumesc tuturor pentru ajutor.
Total mesaje 187841
Total subiecte 18674
