Dupa ce pornesc motorul mi se aprinde ABS in bord si apare ABS/esr defaillant iar pe tester apare eroare : u1213 invalid data recieved from abs control module
U1205 no comuniction with steering wheel angle senzor si u2005 triggering ( vehicle speed receipt anormaly ) . Care sa fie problema ? Sa fie doar o banala siguranta ? Care e siguranta pt abs ???
[url=https://postimg.org/image/ap3ajsbtv/][img]https://s13.postimg.org/ap3ajsbtv/image.jpg[/img][/url]
PS: problema a apărut cam la 1 zi dupa ce am pus cauciucurile de iarna
Problema abs
