verificare serie sasiu
Lotg
Localitate: Târgu Mureș
Masina: Citroen C1 1.0 68hp Sensodrive 2006
Re: verificare serie sasiu
Mesajde Lotg » Vin 17-Iun-2016 07:51
Multumesc pentru info.
Stie cineva ce inseamna asta?
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
Citroen C1 1.0 Sensodrive
Alberto123
Localitate: Constanta
Masina: Citroen c5 lll
Mesajde Alberto123 » Vin 17-Iun-2016 09:23
VF7RD9HL0CL519185 Daca ma puteti ajuta si pe mine , multumesc!
Citroen c5 lll 1.6 hdi 115 cp 2012
MARIAN
Localitate: Buzau
Masina: Xantia 1.9TD VSX
2: C5 2.0 HDI 110CP
Mesajde MARIAN » Vin 17-Iun-2016 10:38
Vehicle characteristics
Vehicle family C5 (X7)
AS RPO No 12987 CJ 1 0451
Warranty Start Date 07/06/2012
Engine serial number 10 JBEU 3029157
Gearbox serial number 20 DP50 6606237
OPB H00A
BER e2*2001/116*0360*19
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 (X7)
SILHOUETTE 4 DOOR SALOON
TRIM LEVEL MEDIUM - LOW
ENGINE DV6C TURBO DIESEL
TRANSMISSION BVM5
PAINT TYPE NON-METALLIC PAINT
BODY COLOUR EWP - BANQUISE WHITE PAINT
INTERIOR TRIM TYPE W&W RAFAELO G025+OMNIREPS F920 "XP"
UPHOLSTERY COLOUR "FX"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
ENGINE (TYPE) EV/DV
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE C5
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EMISSION CONTROL EURO 5 (ENGINE)
ENGINE (TYPE) EV/DV
CATALYTIC CONVERTER CATALYTIC CONVERTER LESS THAN 10PPM
LPG FUEL TANK FUEL TANK WITH LOCATING TAB
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECIRCULATION + EXCHANGER
VEHICLE TECHNICAL DEPOLLUTION TECHNICAL VEHICLE EMISSION CONTROL EURO 5
PARTICLE FILTER PARTICLE FILTER
FAN 1 DUAL-SPEED ELECTRONIC FAN 140W
INJECTION ASSOCIATED VARIANT SIEMENS ASSEMBLY
TANK FILTER RESERVOIR FILTER INTERIOR
STOP AND START WITHOUT STOP AND START
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO CP 17 X 73
WHEEL STYLE 16-INCH STEEL WHEEL
CLUTCH HYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX) DIFFERENTIAL 84
RIM/TYRE SIZE 16 INCH TYRE FITMENT
TYRE (SIZE, TYPE) TYRE 225/60 R16 V NON-REINFORCED
WHEEL (TYPE) STEEL WHEELS
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 20
FRONT ANTI-ROLL BAR FRONT ANTI ROLL BAR DIAM 24
STEERING TRAVEL TRAVEL MECHANISM STEERING 184
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
Body fittings
SIDE MOULDINGS (TYPE) LATERAL PROTECTOR MASS TINTED
SIDE MOULDINGS (DIMENSION) PLASTIC SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) LAPONIE TYPE 16 INCH
EXHAUST TAILPIPE NON CHROME PLATED EXHAUST TAIL PIPE
SILL ILLUMINATION LAMP FRONT SILL LIGHTING LIGHT
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COL BUMPER + SOLID COL PROT + SS GRILLE TRIM
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE) CLEAR EXTERIOR MIRROR GLASS
EXTERIOR ACCESSORIES CHROME EFFECT EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) WINDOW TINTED
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN+TOUGHENED RR SCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITHOUT REAR ARMREST
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT TUNGSTEN DECOR
MISC. INT. LAMPS STD LIGHTING WITHOUT R2 READING LIGHT
LOAD SPACE TRIM W/O MAT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 260 KM/H 160 M/H MONOCHROME MATRIX
DOOR TRIM TUNGSTEN DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
FRONT SEAT ARMREST (OPERATION) WITHOUT FRONT ARMREST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY MONOCHROME SCREEN LEVEL C DISPLAY
COURTESY MIRROR DRIV OCCULT+PASS OCCULT W/O LIGHT
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
RADIO RECEIVER AUDIO CD SYSTEM RDS "RD45" MP3
REFRIGERATION AUTOMATIC AIR CONDITIONING
DRIVER’S SEAT HEIGHT CONTROL DRIVER’S SEAT HEIGHT MANUAL ADJ
INTERIOR REAR VIEW MIRROR NON-ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED MONO-ZONE
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
LATERAL BLINDS WITHOUT SIDE BLINDS
TRIM ADAPTATION PLAST GAITER/KNOB+INSERT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL LEATHER STEER WHEEL 4 BRANCHS
SEAT LUMBAR SUPPORT (OPERATION) WITHOUT LUMBAR SUPPORT
AUDIO PACK AUXILIARY SOCKET 1 JACK SOCKET
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING FRONT DAYTIME LIGHTS
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LIGHTING OF LAMPS MANUAL SWITCHING ON OF LIGHTS
TELEMATIC UNIT WITHOUT TELEMATIC UNIT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
LABEL WITHOUT
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
Alberto123
Mesajde Alberto123 » Vin 17-Iun-2016 21:48
In romana nici o sansa nu? :))
kyn
Localitate: Timisoara
Mesajde kyn » Sâm 18-Iun-2016 10:42
Romana
Caracteristicile vehiculului
Linie de produs C5 (X7)
Nr. APV/PR 12987 CJ 1 0451
Data de Inceput de Garantie DDG 07.06.2012
OPB H00A
NRE e2*2001/116*0360*19
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 (X7)
SILHOUETTE BERLINA 4 USI
FINITION MEDIE COBORATA
MOTEUR DIESEL TURBO DV6C
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA OPACA
COULEUR DE CAISSE EWP - VOPSEA ALBA BANQUISE
TYPE D’HABILLAGE INTÉRIEUR TESATURA RAFAELO G025+OMNIREPS F920 "XP"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
EVOLUTIE DEFINITIE TEHNICA GAMA VECHE
MOTEUR (TYPE) MOTOR TIP DV
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Caracteristici vehicul
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO5 (MOTOR)
ECHAPPEMENT TOBA DE ESAPAMENT LONGITUDINALA
CATALYSEUR CATALIZATOR IMPREGNAT SUB 10PPM
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
DISPOSITIF (ANTIPOLLUTION) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO5
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze Transmisie
COUPLE RAPPORT CP 17 X 73
COUPLE TACHYMÈTRE FARA C T
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
DIFFÉRENTIEL (BOITE) DIFERENTIAL 84
JANTE / PNEU DIMENSION MONTAJ PNEU 16 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/60 R16 98V NERANFORSAT
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
Suspensie Directie Franare
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 20
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 184
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE FARA SUSPENSIE HIDRACTIVA
SUSPENSION (TYPE ARCHITECTURE) SUSPENSIE METALICA
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC
ENJOLIVEUR ROUE (STYLE) TIP LAPONIA 16 INCI
SORTIE D’ÉCHAPPEMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
PARE-CHOCS BARA DE PROTECTIE CULOARE CAROSERIE + ELEMENT DE PROTECTIE COLORAT IN MASA + FARA ORNAMENT DE GRILA
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD FARA PROIECTOARE ANTICEATA
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) RETROVIZOR EXTERIOR CU OGLINDA NEATENUATA
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR ASPECT CROMAT
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (ASPECT) GEAM FUMURIU
VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE FARA COTIERA SPATE
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE TUNGSTEN
FEUX INT. DIVERS ILUMINAT STANDARD FARA LAMPA DE CITIT PENTRU RANDUL 2
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
GARNISSAGE DE PORTE DECORATIUNE TUNGSTEN
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) FARA COTIERA FATA
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ NIVEL C ECRAN MONOCROM
MIROIR DE COURTOISIE OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD45" MP3
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU O ZONA
RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
STORES LATÉRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE BURDUF/MANER MANETA + PLACUTA DIN MATERIAL PLASTIC
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) FARA SPRIJIN LOMBAR
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK
BOITIER TELEMATIQUE FARA MODUL TELEMATIC
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L2 400
DÉMARREUR DEMAROR CLASA 5
ECLAIREMENT PARTICULIER LUMINI DE ZI FATA
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
ALLUMAGE FEUX APRINDERE LUMINI MANUALA
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
ETIQUETTE FARA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
Citroen C5 Exclusive 2.0 163CP
Citroen DS5 2.0 163CP
cristian_bora
Localitate: CALAFAT
Masina: Citroen C5 Exclusive
2: nu
3: nu
Mesajde cristian_bora » Lun 20-Iun-2016 14:58
Buna ziua! Tocmai am achizitionat si eu un Citroen C5 Exclusive 2.0 Hdi 163 FAP din Franta. An de fabricatie 2012 august, km 150.091. Seria de identificare este VF7RDRHHACL526379. Ma puteti ajuta si pe mine cu detalii despre aceasta masina dupa seria de identificare. De asemenea, masina nu are carnet de intretinere, dar stiu ca francezii fac toate reviziile la timp si as dori sa stiu ce revizii se fac conform cartii de service. Nu gasesc nicaieri sa downloadez aceste informatii. Va multumesc!
kady28
Mesajde kady28 » Lun 20-Iun-2016 15:07
Cat a costata daca vreti sa ziceti?
Nr. APV/PR 13041 CJ 1 0078
Data de Inceput de Garantie DDG 30.07.2012
OPB H007
NRE e2*2001/116*0360*24
Informatii generale
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTEUR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE AUTOMATA 6 TREPTE
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EZR - VOPSEA GRI ALUMINIU
TYPE D’HABILLAGE INTÉRIEUR PIELE CLAUDIA MATINAL L019 "XT"
CULOARE GARNISAJ "FC"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C1
EVOLUTIE DEFINITIE TEHNICA ANIMATIE DE GAMA
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS EXCLUSIV
MONOGRAMA C5
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
CARBURANT MOTORINA
CYLINDRÉE 2000 CM3
RÉCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATE DE PUTERE (MOTOR) PUTERE 120 KW 340 NM
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC COMANDA INTEGRATA 220W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE DELPHI
CUPLU RAPORT RAPORT PUNTE 15 X 53
STIL ROATA (JANTA) ROATA EGEE 17 INCI
EMBRAYAGE FARA AMBREIAJ
DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/55 R17 97W FARA INTARIRE
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 20,5
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24,5
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 180
SUSPENSIE SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSION (TYPE ARCHITECTURE) SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
FEU D’ÉCLAIRAGE DE SEUIL BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROUE DE SECOURS FARA ROATA DE REZERVA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA RETROVIZOR EXTERIOR FUMURIE
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE ORNAMENT CENTRAL SPATE CROMAT
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
ALARMA ANTIFURT FARA ALARMA ANTIFURT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL LUCIANO
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA SOFT
GARNISAJ SPATIU DE INCARCARE FARA COVORAS
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
GARNISSAGE DE PORTE DECORATIUNE ANODIZATA SOFT
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DEV DE INALTA REZOLUTIE
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL CU PROIECTOR DIRECTIONAL
RECEPTOR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORES LATÉRAUX TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTATION GARNITURE MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
VOLANT VOLAN IMBRACAT IN PIELE NETEDA
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB + BLUETOOTH
MODUL TELEMATIC MODUL TELEMATICA AUTONOM
Electricitate
BATTERIE BATERIE L3 720 LDC(L3 720 70AH EF 720 EN)
DEMAROR DEMAROR CLASA 6+
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
ATMOSFERA ATMOSFERA NORMALA
ETIQUETTE FARA
ROULAGE DRUM CORECT
cristian_bora
Localitate: CALAFAT
2: nu
3: nu
Mesajde cristian_bora » Lun 20-Iun-2016 16:47
Sigur. De ce sa nu spun? Ca doar nu o fi vreun secret. Am dat 10.000 euro pe ea. Asta este masina: http://autovit.ro/anunt/citron-c5-ID7GgkrZ.html
Ce parere aveti?
Va multumesc mult pentru informatii!
Stima!
florindaniel
Localitate: ploiesti
Mesajde florindaniel » Lun 20-Iun-2016 20:51
Frumoasa domnule!
Cat mai putine evenimente neplacute!
kady28
Mesajde kady28 » Lun 20-Iun-2016 21:04
Da frumoasa, si eu am urmarit-o mult timp dar depasesea bugetul cu putin si nu vreau cu automata.
Drumuri bune si doar motorina sa ceara!
cristian_bora
Localitate: CALAFAT
2: nu
3: nu
Mesajde cristian_bora » Mar 21-Iun-2016 00:10
Va multumesc!
Cozma55
Masina: C5 III 2.0HDi, 163CP, Tourer, Exclusive, Automat
2: Ford Mondeo
Mesajde Cozma55 » Joi 23-Iun-2016 08:28
frumoasa masina, sa o stapaniti sanatosi si fara incidente.
sport mode cat mai des folosit, e o placere!
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Joi 23-Iun-2016 10:31
Sport la cutie sau la suspensie?
Cozma55
2: Ford Mondeo
Mesajde Cozma55 » Joi 23-Iun-2016 10:37
Cutie, suspensia sa fie cat mai confortabila. Mie asa imi place.
florindaniel
Mesajde florindaniel » Mie 06-Iul-2016 18:21
WF7RWRHH89L584525, ma putet ajuta cu detalii.
In romana.
Multumesc
Înapoi la “Citroen C5 III”
    Total mesaje 187841
    Total subiecte 18674
