verificare serie sasiu
audiexp
- Localitate: Pitesti
- Masina: Citroen C5 Exclusive 2.0 HDi 163CP 120 kW
Re: verificare serie sasiu
da.. masina este un Citroen C4..
C4 (B7) - DS4 BERLINE 5PTES 1.6 HDI 115 (DV6C) BVMP 6 ( cu functie 'stop and start')
norishor
- Localitate: Campina / Bucuresti
- Masina: Citroen C2 VTS (de competitie)
- 2: Lexus CT200H (de familie)
Re: c4
Nanel scrie:Saut! Ma poate ajuta cineva cu o verificare vin?VF7NC9HR8BY596176 . ms frumos !
Caracteristicile vehiculului
Linie de produs C4 (B7) - DS4
Nr. APV/PR 12714 88 1 0445
Data de Inceput de Garantie DDG 15.09.2011
OPB 0005
NRE e2*2007/46*0040*07
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C4 (B7) - DS4
SILHOUETTE BERLINA CU 5 USI
FINITION MEDIE MEDIE
MOTEUR DIESEL TURBO DV6C
TRANSMISSION CUTIE DE VITEZE MANUALA PILOTATA 6 TREPTE STOP AND START
TYPE DE PEINTURE VOPSEA OPACA
COULEUR DE CAISSE EWP - VOPSEA ALBA BANQUISE
TYPE D’HABILLAGE INTÉRIEUR TESATURA HERMITAGE G142 + TESATURA OMNI REPS "4X"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA MCD
MOTEUR (TYPE) MOTOR TIP DV
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
Caracteristici vehicul
Alimentare motor
ALIMENTATION INJECTIE TURBO CU SCHIMBATOR DIRECT
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO5 (MOTOR)
CYLINDRÉE 1600 CM3
CATALYSEUR CATALIZATOR CU 3 COMPUSI IN FILTRE IMPREGNATE CU RODIU + PALADIU
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
OPTIMISATION DE CONSOMMATION DU VÉHICULE NARMAL
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE MOTOR 82 KW - 270 NM
DISPOSITIF (ANTIPOLLUTION) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO5
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 2 TURATII 140W AERO FARA PRIZA DE AER
RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
STOP AND START CU STOP AND START
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 19 X 71
STYLE ROUE ROATA ALUMINIU B71 17 INCI ’PHOENIX’
EMBRAYAGE FARA AMBREIAJ
DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/45 R17 91V NERANFORSAT
ROUES MONTÉES ROATA 7 INCI 1/2
ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA MC
Suspensie Directie Franare
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 25
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22
FREIN TYPE DISCURI FATA VENTILATE / DISCURI SPATE
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
SUSPENSION SUSPENSIE NORMALA
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
VARIANTE ASSOCIÉE FREIN ESP BOSCH 8 1
PÉDALIER (TYPE) PEDALIER STANDARD
Caroserie Echipamente
ATTACHE-REMORQUE FARA DISPOZITIV DE REMORCARE
AVERTISSEURS SISTEM DE AVERTIZARE ACORD
ANTENNE ANTENA PAVILION + GPS + INTEGRATA
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTARE CU DEFLECTOR DE AER
DÉCORATION (PEINTE) DECORATIUNE NEGRU STRALUCITOR
ENJOLIVEMENT LATÉRAL (ASPECT) FARA ELEMENTE DE PROTECTIE LATERALE
ENJOLIVEMENT LATÉRAL (DIMENSION) FARA ELEMENTE DE PROTECTIE LATERALE
ENJOLIVEUR ROUE (STYLE) FARA CAPAC DE ROATA
FEU DE SIGNALISATION BALIZAJ LATERAL
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
ANNEAU D’ARRIMAGE EXTÉRIEUR (RAPPORTÉ) INEL ARIMARE EXTERIOARA VAPOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR PLIABIL ELECTRIC + DIODA/LED
PARE-BOUE APARATOARE DE NOROI STANDARD
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORISATION COTÉ MOTEUR ELEMENT DE IZOLARE FONICA SUB CAPOTA MOTOR + TABLIER
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU INTERMITENTA CU CADENTA AUTOMATA + INDICATOR NIVEL DE APA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
ESSUIE-VITRE ARRIÈRE (FONCTIONNEMENT) MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CU PORNIRE AUTOMATA
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE PAVILLON CU GEAM DE PAVILION
PARE-CHOCS BARE DE PROTECTIE FATA + SPATE IN CULOAREA CAROSERIEI + INEL CROMAT
PARE-BOUE (BAVETTE) FARA APARATORI DE ROTI SPATE
PLAQUE POLICE FARA PLACUTA DE INMATRICULARE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA CU LUMINI DE VIRAJ
ROUE DE SECOURS ROATA TIP ROLA
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR IN CULOAREA CAROSERIEI
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
ENJOLIVEMENT PARE-CHOCS BARA DE PROTECTIE FARA ORNAMENTE
VITRE (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
VITRE CUSTODE (NATURE) GEAM LATERAL SPATE FIX
VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
APPUI-TÊTE AVANT TETIERA FATA ARTICULATA
ASSISE ARRIÈRE BANCHETA SPATE CU PERNA MONOBLOC SPATARE SEPARATE
DETECTION ANGLEMORT FARA SISTEM DE SUPRAVEGHERE UNGHI MORT
ACCOUDOIR ASSISE ARRIÈRE FARA COTIERA SPATE
CACHE-BAGAGES PANOU/MASUTA
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA TEMPERATA
CLIMATISEUR CU AEROTERMA
CONDAMNATION ENFANT SIGURANTA COPIL MANUALA USA SPATE
GRADUATION VITESSES GRADATIE IN KM/H
CONSOLE CONSOLA LUNGA
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECLAIRAGE DE COFFRE VOLUME CHARGEMENT COMANDA AUTOMATA ILUMINAT PORTBAGAJ + VOLUM DE INCARCARE + AMV
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD + PARTE INFERIOARA INJECTATA
FEUX INT. DIVERS LC FATA/SPATE CU LED-URI DE AMBIANTA FARA LUMINI DE AMBIANTA
GARNISSAGE VOLUME CHARGEMENT COVORAS PORTBAGAJ MOCHETA
RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
COMBINÉ (CARACTÉRISTIQUES) TABLOU DE BORD CU COROANA PERSONALIZABILA + MATRICE
GARNISSAGE DE PORTE DECORATIE ALUMINIU CALD SOFT
ANCRAGE SIÈGE ENFANT FARA SISTEM DE ANCORARE ISO PENTRU SCAUNE DE COPII SPATE
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 5,5 KG + CAPAC + PARTE LATERALA SUPERIOARA SPATE DE CAROSERIE
REHAUSSE ASSISE AVANT PASSAGER DISPOZITIV DE INALTARE PERNA PASAGER REGLARE PARALELA + AVANSARE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
RÉGLAGE ASSISE AVANT CONDUCTEUR SUPORT LOMBAR CONDUCATOR
RÉGLAGE ASSISE AVANT PASSAGER SUPORT LOMBAR PASAGER
ACCOUDOIR ASSISE AVANT COTIERA CENTRALA SCAUN FATA + REGLABILA
INDICATEUR DE TEMPÉRATURE EXTÉRIEURE INDICATOR TEMPERATURA EXTERIOARA
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE GEAM SPATE SECVENTIAL CU COMANDA ELECTRICA
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
LÈVE-VITRE AVANT PASSAGER MECANISM DE ACTIONARE GEAM PASAGER FATA CU COMANDA SECVENTIALA
AFFICHEUR AFISAJ DG4
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
REPOSE-PIED CU SUPORT DE SPIJINIRE PICIOR CONDUCATOR + PASAGER
INDICATEUR D’HUILE SENZOR DE NIVEL DE ULEI
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE 3 TETIERE SPATE
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
ORDINATEUR DE BORD CU CALCULATOR DE BORD
PACK ÉQUIPEMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
COMMANDE INTÉRIEURE DE PORTE (ASPECT) PALETA USA ASPECT CROMAT + ORNAMENT COLORAT
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL FARA PROIECTOR DIRECTIONAL
PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
PARE-SOLEIL AVANT PARASOLAR CONDUCATOR + PASAGER FARA INSCRIPTIE
RANGEMENT (POSTE CONDUITE) COMPARTIMENT DEPOZITARE OBIECTE MARUNTE + PALETA NEAGRA
RÉCEPTEUR RADIO RADIOTELEFON CU AFISAJ DEPLASAT ’RT6’
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI LIMITARE VITEZA PROGRAMABIL
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR REGLAJ PARALEL + INAINTE
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RANGEMENT (AUTRES) COMPARTIMENT DE DEPOZITARE STANDARD + BUZUNARE PE SPATARELE SCAUNELOR FATA
SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
RANGEMENT VOLUME CHARGEMENT CHINGA LATERALA PORTBAGAJ + PLASA
TAPIS MOCHETA TESUTA DILOUR F550
TUNER-RADIO TUNER DUBLU RADIO
TÉMOIN DE NIVEAU DE LIQUIDE DE REFROIDISSEMENT FARA MARTOR LUMINOS PENTRU NIVEL LICHID DE RACIRE
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
ADAPTATION GARNITURE FARA ADAPTARE GARNITURA
SURTAPIS FARA COVORAS SUPLIMENTAR
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN PIELE DE CEA MAI BUNA CALITATE
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + USB
BOITIER TELEMATIQUE MODUL TELEMATICA AUTONOM
Electricitate
ALTERNATEUR ALTERNATOR ISTT5
BATTERIE BATERIE L3 760 ETANSA(L3 760 VRLA 760 EN AGM)
DÉMARREUR DEMAROR CLASA 5
ECLAIREMENT PARTICULIER LUMINI DE ZI FATA
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
MESURE CHARGE BATTERIE CU SISTEM DE MASURARE A NIVELULUI DE INCARCARE A BATERIEI
ALLUMAGE FEUX APRINDERE AUTOMATA LUMINI
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION SOCIETATI (OVSA)
ATMOSPHÈRE ATMOSFERA NORMALA
PLAQUE CONSTRUCTEUR PLACUTA CONSTRUCTOR UNIUNEA EUROPEANA + NRE
ETIQUETTE FARA ETICHETA
PRISE D’ÉCOUTE RADIO PRIZA DE ACCESORII DUBLA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
CHOCS LATÉRAUX USA CARE NU ESTE INTARITA
JEUX DE CLÉS 2 CHEI TELECOMANDA DE INALTA FRECVENTA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
SURVEILLANCE VITESSE FARA SISTEM DE MONITORIZARE VITEZA
PLAQUE HOMOLOGATION COMPLÉMENTAIRE FARA PLACUTA DE OMOLOGARE SUPLIMENTARA
Servicii Diagbox: Activari/dezactivari optiuni / Actualizari software / Telecodare cheie noua/Reparatii chei telecomanda PSA / Telecodare RD/RT CD/Mp3 / Diagnoza pre-achizitie auto
audiexp
norishor : poti să-mi spui, te rog, datele astea si despre Citroen-ul meu: VF7RDRHH89L571484
Mulțumesc!
Mulțumesc!
norishor
VF7RDRHH89L571484
Linie de produs C5 (X7)
Nr. APV/PR 12054 CJ 1 0373
Data de Inceput de Garantie DDG 24.11.2009
OPB H002
NRE e2*2001/116*0360*10
Informatii generale
LIGNE DE PRODUIT C5 (X7)
SILHOUETTE BERLINA 4 USI
FINITION SUPERIOARA JOASA PLUS
MOTEUR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EYP - VOPSEA GRI FULMINATOR
TYPE D’HABILLAGE INTÉRIEUR PIELE CLAUDIA MATINAL L019 "XT"
COULEUR DE GARNISSAGE "FC"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS EXCLUSIV
MONOGRAMME C5
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE FARA C T
Alimentare motor
CARBURANT MOTORINA
ECHAPPEMENT TOBA DE ESAPAMENT LONGITUDINALA
CYLINDRÉE 2000 CM3
CATALYSEUR CATALIZATOR IMPREGNAT SUB 10PPM
VARIATION PUISSANCE (MOTEUR) PUTERE 120 KW 340 NM
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
VENTILATEUR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE DELPHI
STOP AND START FARA SISTEM STOP AND START
COUPLE RAPPORT RAPORT PUNTE 16 X 69
STYLE ROUE ROATA BALTICA 17 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/55 R17 97W FARA INTARIRE
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
BOITE DE VITESSES TYPE ML6C
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 20,5
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24,5
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 180
SUSPENSION ACTIVE SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSION (TYPE ARCHITECTURE) SUSPENSIE HIDRAULICA
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ENJOLIVEUR ROUE (STYLE) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
SORTIE D’ÉCHAPPEMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
FEU D’ÉCLAIRAGE DE SEUIL BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
ESSUIE-VITRE AVANT MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR MECANISM DE STERGERE PROIECTOR
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
PARE-CHOCS BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
ROUE DE SECOURS FARA ROATA DE REZERVA
RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) OGLINDA RETROVIZOR EXTERIOR FUMURIE
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR ASPECT CROMAT
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS ORNAMENT CENTRAL SPATE CROMAT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
EQUIPEMENT PLANCHE DE BORD DECORATIUNE METAL PALEA
FEUX INT. DIVERS ILUMINAT DE AMBIANTA SOFT
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
GARNISSAGE DE PORTE DECORATIUNE ANODIZATA SOFT
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) COTIERA MANUALA FATA
COMPACT DISQUE FARA MONTARE COMPACT DISC
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL CU PROIECTOR DIRECTIONAL
RÉCEPTEUR RADIO SISTEM RADIONAVIGATIE DE A 4-A GENERATIE "NG4"
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORES LATÉRAUX TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTATION GARNITURE MANER LEVIER DE VITEZE + BURDUF PIELE
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
BOITIER TELEMATIQUE FARA MODUL TELEMATIC
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA + LUMINI DIURNE FATA
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ETIQUETTE FARA
EQUIPEMENT DE SECOURS RECIPIENT SUB PRESIUNE REPARARE PNEU
ROULAGE DRUM CORECT
OPB H002
Informatii generale
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
CYLINDRÉE 2000 CM3
Electricitate
Diverse
ETIQUETTE FARA
ROULAGE DRUM CORECT
audiexp
Mulțumesc frumos!
Salut norishor îmi poți spune si mie datele la mașina cu vin-ul vf7rd9hzc54014866! Mulțumesc.
Citro, citro citro
- kady28
Caracteristicile vehiculului vf7rd9hzc54014866
Nr. APV/PR 11473 CJ 1 0120
Data de Inceput de Garantie DDG 17.06.2008
OPB H46M
NRE e2*2001/116*0360*00
Informatii generale
FINITION INALTA INALTA
MOTEUR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA5
COULEUR DE CAISSE KPK - VOPSEA ALBASTRU MAURITIUS
TYPE D’HABILLAGE INTÉRIEUR TESATURA RUBENS G026+OMNISERGE F915 "XR"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
VARIATION PUISSANCE (MOTEUR) PUTERE 80 KW 240 NM
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
COUPLE RAPPORT CP 17 X 73
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
DIFFÉRENTIEL (BOITE) DIFERENTIAL 84
JANTE / PNEU DIMENSION MONTAJ PNEU 16 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/60 R16 98V NERANFORSAT
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 184
SUSPENSION ACTIVE FARA SUSPENSIE HIDRACTIVA
SUSPENSION (TYPE ARCHITECTURE) SUSPENSIE METALICA
DIRECTION (FONCTIONNEMENT) SISTEM DE DIRECTIE MECANICA ASISTATA
ENJOLIVEUR ROUE (STYLE) TIP LAPONIA 16 INCI
FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (ASPECT) FUMURIU + FUMURIU INCHIS
EQUIPEMENT PLANCHE DE BORD DECORATIUNE MOLDING EVREST
FEUX INT. DIVERS ILUMINAT STANDARD + LUMINA DE CITIT RAND2
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) FARA COTIERA FATA
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
AFFICHEUR AFISAJ NIVEL C ECRAN MONOCROM
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
STORES LATÉRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE MOLDING
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SUPORT LOMBAR MANUAL
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE BATERIE L2 400
Diverse
ETIQUETTE FARA
ROULAGE DRUM CORECT
OPB H46M
Informatii generale
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
Electricitate
Diverse
ETIQUETTE FARA
ROULAGE DRUM CORECT
Ristian
- Localitate: Constanta
- Masina: Citroen C3 2011
Salut! Mi-am cumparat si eu un Citroen C3 din 2011 si am vazut ca tu poTi verifica VIN-ul. Al meu este VF7SC8HR0BA543353. Iti multumesc anticipat!!!
norishor
Linie de produs C3 (A51)
Nr. APV/PR 12573 CA 2 0260
Data de Inceput de Garantie DDG 30.04.2011
OPB L00E
NRE e2*2007/46*0003*09
Informatii generale
LIGNE DE PRODUIT C3 (A51)
SILHOUETTE BERLINA COMERCIALA 5 USI
MOTEUR DIESEL TURBO DV4C
TYPE D’HABILLAGE INTÉRIEUR TESATURA SI URZEAZA FYBER G111 + OMNI F942 ’3M’
COULEUR DE GARNISSAGE "FZ"
BOITE DE VITESSES (CARACTÉRISTIQUES) BVM MA5 / O
COUPLE TACHYMÈTRE CUPLU TAHOMETRU 21 X NO
Alimentare motor
ALIMENTATION INJECTIE "PRIM"
CARBURANT MOTORINA
CATALYSEUR CATALIZATOR 2 COMPUSI IMPREGNATI CU PLATINA SUB 50 PPM
REFROIDISSEMENT D’HUILE FARA SCHIMBATOR APA/ULEI
REZERVOR DE CARBURANT REZERVOR CARBURANT FARA ELEMENT DE INDEXARE
OPTIMISATION DE CONSOMMATION DU VÉHICULE CONSUM CARBURANT OPTIMIZARE
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 16 DM2 ALUMINIU BRAZAT FARA MEC
AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
VENTILATEUR 1 VENTILATOR 2 TURATII 100W AERO
FILTRE RÉSERVOIR FARA FILTRU REZERVOR
COUPLE RAPPORT RAPORT CUPLU 16 X 63
STYLE ROUE JANTA TABLA 6 J15 4-23
DIFFÉRENTIEL (BOITE) DIFERENTIAL 77
JANTE / PNEU DIMENSION MONTAJ PNEU 15 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 185/65 R15 88T NERANFORSAT
ROUES MONTÉES ROATA 6 INCI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA MA
ANTIBLOCAGE ANTIBLOCARE ROATA
BARRE ANTIDÉVERS ARRIÈRE FARA BARA ANTIRULIU SPATE
FREIN TYPE DISCURI FATA VENTILATE / TAMBURE SPATE
CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
VARIANTE ASSOCIÉE FREIN ABS TEVES MK70
ANTENNE ANTENA SCURTA PAVILION
DÉCORATION (ADHÉSIVE) ORNAMENT SPATE DE INCADRARE NEGRU MAT
ENJOLIVEMENT LATÉRAL (DIMENSION) TREAPTA DIN MATERIAL PLASTIC
ENJOLIVEUR ROUE (STYLE) CAPAC DE ROATA WHALETAIL 15"
PROTECTION SOUS CAISSE ELEMENT DE PROTECTIE DIN MATERIAL PLASTIC + ELEMENT DIN SPUMA SUB MOTOR
FEU DE RECUL CU 1 LUMINA PENTRU MERS INAPOI
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT CU ORNAMENT LA IESIRE ESAPAMENT
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ FARA SENZOR DE PLOAIE
TOIT OUVRANT FARA TRAPA DE PLAFON
ENJOLIVEMENT PARE-CHOCS BARA DE PROTECTIE FARA BANDOU
VITRE (TYPE) PARBRIZ STRATIFICAT + LUNETA SECURIZATA
ALLUME-CIGARE FARA BROCHETA
APPUI-TÊTE ARRIÈRE FARA TETIERA SPATE
APPUI-TÊTE AVANT TETIERA FATA REGLABILA
ASSISE ARRIÈRE FARA PERNA DE SEZUT SPATE
CACHE-BAGAGES PANOU + MASCARE BAGAJE + RULOU
CEINTURE DE SÉCURITÉ ARRIÈRE FARA CENTURA DE SIGURANTA SPATE
CEINTURE DE SÉCURITÉ AVANT RETRACTOR CU ALARMA LA CUPLARE CENTURA CONDUCATOR
CLIMATISEUR SISTEM DE CLIMATIZARE CU ADMISIA AERULUI MOTORIZATA
ECLAIRAGE RANGEMENT ILUMINAT TORPEDOU
EQUIPEMENT PLANCHE DE BORD BANDOU GRI LION
FEUX INT. DIVERS FARA LAMPA DE CITIT HARTA
GARNISSAGE VOLUME CHARGEMENT COVORAS PORTBAGAJ DIN PVC + LATERALE DIN MOCHETA
RANGEMENT SOUS SIÈGE FARA COMPARTIMENT DE DEPOZITARE SUB SCAUN
COMBINÉ (CARACTÉRISTIQUES) 210 KM/H 130 M/H FUNDAL NEGRU ILUMINAT PERMANENT ALB
ANCRAGE SIÈGE ENFANT CU SISTEM DE ANCORARE ISO PENTRU SCAUNE COPII IN SPATE
FILTRE À POLLEN CU FILTRU DE POLEN
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
ACCOUDOIR ASSISE AVANT MONTARE FARA COTIERA FATA
CONSOLE PLAFOND FARA CONSOLA PLAFON
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
TAPIS HABITACLE COVORAS HABITACLU FATA
LÈVE-VITRE AVANT CONDUCTEUR MECANISM ACTIONARE GEAM CONDUCATOR CU COMANDA SECVENTIALA
LÈVE-VITRE AVANT PASSAGER MECANISM ACTIONARE GEAM FATA PASAGER COMANDA ELECTRICA CARE NU ESTE SECVENTIALA
AFFICHEUR AFISAJ (RADIO + CEAS, T°,CD)
MIROIR DE COURTOISIE PARASOLAR CONDUCATOR + PASAGER FARA LUMINA
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE FARA TETIERE SPATE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL FATA SIMPLU
RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA INCALZIRE
PLAFONNIER COMANDA LA DISTANTA A USILOR + PLAFONIEREI FATA
PLANCHER ARRIÈRE CHARGE PLANSEU DE INCARCARE SPATE, FIX, TRANSFORMABIL
RÉFRIGÉRATION SISTEM DE REFRIGERARE SIMPLA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE CU OGLINDA CARE NU ESTE CROMATA ELECTROCHIMIC
RANGEMENT (AUTRES) BUZUNAR PE SPATARUL SCAUNULUI COMPLET
TUNER-RADIO CU UN SINGUR TUNER RADIO
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
ADAPTATION GARNITURE MANER MANETA DE VITEZE DIN MATERIAL PLASTIC + PLACUTA CROMATA
SAC GONFLABLE GENOUX CONDUCTEUR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
Electricitate
DÉMARREUR DEMAROR CLASA 4
ECLAIREMENT PARTICULIER FARA ILUMINAT SPECIAL
ALLUMAGE FEUX APRINDERE LUMINI MANUALA
Diverse
PRISE D’ÉCOUTE RADIO PRIZA ACCESORII SIMPLA
JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
ROULAGE DRUM CORECT
BOÎTIER SERVITUDE BSI + COM 2005 INEL CU 4 POZITII
TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
OPB L00E
Informatii generale
Alimentare motor
CARBURANT MOTORINA
Electricitate
Diverse
ROULAGE DRUM CORECT
Ristian
Multumesc frumos!!!
Ristian
Asta inseamna ca a fost utilitara??? ca nu a avut banchete spate???
norishor
exact asta inseamna:
SILHOUETTE BERLINA COMERCIALA 5 USI (cu accent pe comerciala)
Ristian
mda
nasol....
Total mesaje 187828
Total subiecte 18669
Total membri 11845
