Buna tuturor
Vreau sa achizitionez si sa mi montez un modul bluethoot pentru deschiderea si inchiderea automata a usilor ( Bluetooth Keyless Entry ,http://www.smdevs.com/ro/order.php )
Ma intereseaza daca ma poate ajuta cineva si sa-mi spuna ce fel de inchide am pe masina ( c5 2003 ) vaccumetrica , etc .
<<Ground (negative) Trigger. Locking Systems are driven using a ground pulse that comes
from door or wireless key module. Initially the input is neutral (not connected) and when an
action is invoked, a short GND signal is sent on corresponding lock or unlock circuit.
+12V Positive Trigger. Similar with Ground Triggers, but uses a +12V pulse instead of
ground pulse.
Polarity Switch. Locking Systems are driven by switching polarity from GND to +12V (or
other way around) on the corresponding lock or unlock circuit.
Vacuum System. There is a selector valve in the driver's door which routes vacuum to one
circuit and simultaneously vents the other circuit to the atmosphere. The atmospheric pressure
entering the vented circuit acts against a diaphragm and moves the actuator to the
selected position. A vacuum reservoir is provided to allow several lock/unlock cycles while
the vacuum pump in not in operation.
Data Bus. Data messages are sent over an internal network, usually CAN or IEBus (AVCLan).
In order to have a functional system with BKES-L, additional components are required in
order to interface the regular relays with data bus endpoints.
Voltage Level. On the same wire, different levels of voltage, one for lock and another one
for unlock.>>>>>>>
Multumesc !!!!
inchidere certralizata
- taviciobanu
- Localitate: Tg-Jiu
inchidere cetralizata
Modulul inchide si deschide automat centralul in functie de deparatrea sau apropierea de masina prin bluethoot .Si nu coasta o avere 200 RON .
- taviciobanu
Andrei.
- Localitate: Bucharest
- Masina: Citroen C5 2.0 HDI 140 CP in pending
- 2: Lancia Musa 1.4 16v 95 CP
- 3: Dacia Logan 1.6 MPI 90 CP
Re: inchidere certralizata
Revin cu intrebare pe acest topic.
Ai instalat? Cum merge? Se monteaza greu ?
