inchidere certralizata
sinis78
Localitate: romania
Mesajde sinis78 » Lun 01-Iun-2015 08:06
Buna tuturor
Vreau sa achizitionez si sa mi montez un modul bluethoot pentru deschiderea si inchiderea automata a usilor ( Bluetooth Keyless Entry ,http://www.smdevs.com/ro/order.php )
Ma intereseaza daca ma poate ajuta cineva si sa-mi spuna ce fel de inchide am pe masina ( c5 2003 ) vaccumetrica , etc .
<<Ground (negative) Trigger. Locking Systems are driven using a ground pulse that comes
from door or wireless key module. Initially the input is neutral (not connected) and when an
action is invoked, a short GND signal is sent on corresponding lock or unlock circuit.
 +12V Positive Trigger. Similar with Ground Triggers, but uses a +12V pulse instead of
ground pulse.
 Polarity Switch. Locking Systems are driven by switching polarity from GND to +12V (or
other way around) on the corresponding lock or unlock circuit.
 Vacuum System. There is a selector valve in the driver's door which routes vacuum to one
circuit and simultaneously vents the other circuit to the atmosphere. The atmospheric pressure
entering the vented circuit acts against a diaphragm and moves the actuator to the
selected position. A vacuum reservoir is provided to allow several lock/unlock cycles while
the vacuum pump in not in operation.
 Data Bus. Data messages are sent over an internal network, usually CAN or IEBus (AVCLan).
In order to have a functional system with BKES-L, additional components are required in
order to interface the regular relays with data bus endpoints.
 Voltage Level. On the same wire, different levels of voltage, one for lock and another one
for unlock.>>>>>>>
Multumesc !!!!
taviciobanu
Localitate: Tg-Jiu
2: Golf V 2004 1.4 16v benzina
Mesajde taviciobanu » Lun 01-Iun-2015 14:38
Hm, dar de ce ai da bani pe asa ceva, ti-ai pierdut cheia, sau...ca nu prea inteleg, ce face chestia asta?
Trust Me I’m An Engineer
sinis78
Localitate: romania
inchidere cetralizata
Mesajde sinis78 » Lun 01-Iun-2015 16:58
Modulul inchide si deschide automat centralul in functie de deparatrea sau apropierea de masina prin bluethoot .Si nu coasta o avere 200 RON .
taviciobanu
Localitate: Tg-Jiu
Mesajde taviciobanu » Mar 02-Iun-2015 08:45
Adica vrei sa deschizi masina automat de la 200 de metri?Esti sigur ca-i bine asa ceva?Sau nu pricep eu?
Andrei.
Localitate: Bucharest
Masina: Citroen C5 2.0 HDI 140 CP in pending
2: Lancia Musa 1.4 16v 95 CP
3: Dacia Logan 1.6 MPI 90 CP
Re: inchidere certralizata
Mesajde Andrei. » Mie 01-Noi-2017 16:30
Revin cu intrebare pe acest topic.
Ai instalat? Cum merge? Se monteaza greu ?
Înapoi la “Citroen C5 I-II”
    Total mesaje 187851
    Total subiecte 18681
