Salut !
Imi cer scuze daca postez unde nu trebuie...
Puteti sa imi spuneti ce dotari are masina dupa seria de sasiu ? Sau imi puteti recomanda un soft..site..etc ?
(VF7RDRHH4BL554694)
Toate cele bune,
Adi
Dotari C5
- Localitate: Pitesti
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
BOITIER TELEMATIQUE FARA MODUL TELEMATIC
TYPE D’HABILLAGE INTÉRIEUR PIELE CLAUDIA MATINAL L019 "XT"
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE METAL PALEA
FEUX INT. DIVERS ILUMINAT DE AMBIANTA SOFT
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
GARNISSAGE DE PORTE DECORATIUNE ANODIZATA SOFT
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA ELECTRICA SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) COTIERA MANUALA FATA
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LAMPES DE PROJECTEURS LAMPA CU DESCARCARE
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ DG4
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
NAPPE CHAUFFANTE SCAUN CU INCALZIRE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE REGLARE AUTOMATA A PROIECTOARELOR
PROJECTEUR DIRECTIONNEL CU PROIECTOR DIRECTIONAL
RÉCEPTEUR RADIO SISTEM RADIONAVIGATIE DE A 4-A GENERATIE "NG4"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORES LATÉRAUX TRANSPERANTE LATERALE CU COMANDA MANUALA
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
ADAPTATION GARNITURE MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
VOLANT VOLAN IMBRACAT IN PIELE NETEDA
VENTILATEUR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
Caracteristicile vehiculului
Linie de produs C5 (X7)
Nr. APV/PR 11446 CJ 1 0049
Data de Inceput de Garantie DDG 30.05.2008
OPB H4DA
NRE e2*2001/116*0360*00
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 (X7)
SILHOUETTE BERLINA 4 USI
FINITION MEDIE INALTA
MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE AUTOMATA 6 TREPTE
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE KTV - VOPSEA NEGRU PERLA NERA
TYPE D’HABILLAGE INTÉRIEUR TESATURA SANDERSON G027+OMNIREP F920 "XQ"
COULEUR DE GARNISSAGE "FX"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE AUTOMATA AM6C1
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 15 X 53
COUPLE TACHYMÈTRE FARA C T
STYLE ROUE ROATA BALTICA 17 INCI
EMBRAYAGE FARA AMBREIAJ
DIFFÉRENTIEL (BOITE) DIFERENTIAL 86
JANTE / PNEU DIMENSION ECHIPARE PNEU 17 INCI
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 225/55 R17 97W FARA INTARIRE
ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
BOITE DE VITESSES TYPE CUTIE DE VITEZE AUTOMATA AM6
Suspensie Directie Franare
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 20,5
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 24,5
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 180
SUSPENSION ACTIVE SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSION (TYPE ARCHITECTURE) SUSPENSIE HIDRAULICA
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC
ENJOLIVEUR ROUE (STYLE) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
SORTIE D’ÉCHAPPEMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
FEU D’ÉCLAIRAGE DE SEUIL LUMINI DE PRAG FATA
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
ESSUIE-VITRE AVANT MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
PARE-CHOCS BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
ROUE DE SECOURS ROATA CU JANTA TABLA + PNEU CARE NU ARE DIMENSIUNI STANDARD
RÉTROVISEUR EXTÉRIEUR (ASPECT GLACE) OGLINDA RETROVIZOR EXTERIOR FUMURIE
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR ASPECT CROMAT
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
VITRE (ASPECT) GEAM FUMURIU
Echipament de interior
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SUPORT LOMBAR MANUAL
PRIZA AUXILIARA PACK AUDIO FARA PRIZA AUXILIARA PACHET AUDIO
CLIMAT (TEMPERATURE AMBIANTE) TARI CU CLIMA RECE
EQUIPEMENT PLANCHE DE BORD DECORATIUNE LOME STRALUCITOR
FEUX INT. DIVERS ILUMINAT STANDARD + LUMINA DE CITIT RAND2
COMBINÉ (CARACTÉRISTIQUES) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
GARNISSAGE DE PORTE DECORATIUNE LOME GRI/TUNGSTEN
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT (FONCTIONNEMENT) FARA COTIERA FATA
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LECTEUR D’INFORMATIONS ROUTIÈRES CU SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ NIVEL C ECRAN MONOCROM
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
REHAUSSE ASSISE AVANT CONDUCTEUR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
TUNER-RADIO CU UN SINGUR TUNER RADIO
STORES LATÉRAUX FARA TRANSPERANTE LATERALE
ADAPTATION GARNITURE MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 160W
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
DÉMARREUR DEMAROR CLASA 6+
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
Marci de echipamente
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE DELPHI
Diverse
OPB H4DA
Informatii generale
MONOGRAMME C5
Electricitate
Diverse
OPB H4DA
Informatii generale
MONOGRAMME C5
Caracteristici vehicul
Alimentare motor
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
CYLINDRÉE 2000 CM3
RÉCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE 100 KW 320 NM
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FILTRU DE PARTICULE
Electricitate
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
ETIQUETTE FARA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
OPB H4DA
Informatii generale
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
CYLINDRÉE 2000 CM3
Electricitate
Diverse
ETIQUETTE FARA
ROULAGE DRUM CORECT
- Localitate: Ardeal
- Masina: Masina cu 4 roti
Re: Dotari C5
AdrianVintila scrie:Salut !
(VF7RDRHH4BL554694)
Toate cele bune,
Adi
Inteleg ca ai cumparat recent masina. Cu cati km ai cumparat-o? Daca poti sa-mi spui. Stiu cati km avea in momentul vanzarii in Franta si sunt curios daca au ramas sau s-a umblat la ei.
Total mesaje 187775
Total subiecte 18654
Total membri 11821
Cel mai nou membru Shraunrst
