C5 ll
Beemer
- Localitate: Gherla
Vehicle characteristics
Vehicle family C5 II
AS RPO No 11047 CJ 1 0032
Warranty Start Date 13/07/2007
OPB A03Y
BER e2*2001/116*0306*04
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5 II
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL MEDIUM HIGH
ENGINE DIESEL TURBO DW10BTED4 FAP
TRANSMISSION BVM6
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EZW - PAINT IRON GREY
INTERIOR TRIM TYPE SHOW "SM" CLOTH
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BVM ML6 CL
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE C5
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE CT 22 X NO
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
ENGINE (TYPE) EW/DW
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
COOLING MOTOR RADIATOR TH : 32 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE) STANDARD POWER
DEVICE (ANTIPOLLUTION) "EGR" EXHAUST GAS RECYCLING
VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER PARTICLE FILTER
FAN 1 ELECTRONIC FAN INTEGRAL CTRL 150W
INJECTION ASSOCIATED VARIANT SIEMENS ASSEMBLY
TANK FILTER RESERVOIR FILTER INTERIOR
Gearbox-Driveshafts
TRANSMISSION BVM6
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLE 16 INCH OLYMPOS WHEEL
CLUTCH HYDRAULIC CLUTCH
SEAL, WHEEL END SEAL WHEEL SIDE AC 3300I
SEAL, DIFFERENTIAL END SEAL ON DIFF SIDE AAR 3300I
TYRE (SIZE, TYPE) 215/55 R16 W NON REINFORCED TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 3
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE ML6C
Suspension-Steering-Brakes
SUSPENSION NORMAL SUSPENSION
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) ASSISTED ELECTROHYDRAULIC STEERING
Body fittings
SIDE MOULDINGS (TYPE) BODY COLOUR LATERAL PROTECTORS
SIDE MOULDINGS (DIMENSION) PLASTIC SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) OLYMPOS STYLE
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
REAR TAILGATE GLASS FIXED TAILGATE WINDOW
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
WINDOW (TYPE) ATHERMAL WINDSCREEN
EXTERIOR STYLING PACK BODY COLOUR EXTERIOR LOOK PACK
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITH REAR ARMREST
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT CUBIC MINIWEAVE DECOR
LOAD SPACE TRIM W/O MAT
UNDERSEAT STORAGE 2 UNDER SEAT STORAGE DRAWERS
DOOR TRIM CUBIC MINIWEAVE DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
INT. UPHOLSTERY ELEMENTS CLOTH B/C POST TRIM + POLYPRO QUARTER PANEL
FRONT SEAT ARMREST DRIVER ANT PASSENGER FRONT ARMREST
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DISPLAY DISPLAY (RADIO+CLOCK AND OR TEMP, CD)
COURTESY MIRROR DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT
OIL GAUGE TEMPERATURE RECEIVER
HEATING ELEMENT NON HEATED SEAT
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER WITHOUT HEADLAMP ADJUSTMENT
RADIO RECEIVER "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR OR SPEED LIMIT
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
AIR CON./TEMPERATURE REGULATION AUTOMATIC AIR CONDITIONNED BI-ZONE
LOAD SPACE STORAGE W/O BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE CENTRAL LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH
RADIO-INFORMATION-COMMUNICATION PACK RM4
SEAT LUMBAR SUPPORT (OPERATION) WITHOUT LUMBAR SUPPORT
Electrical
ALTERNATOR ALTERNATOR CLASS 18 180 AMP
BATTERY BATTERY L3 450
STARTER MOTOR STARTER MOTOR CLASS 6+
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
EMERGENCY WARNING TRIANGLE WARNING TRIANGLE CONDITIONNING
OPB A03Y
General information
PRODUCT TYPE CAR
TRANSMISSION BVM6
ENGINE (TYPE) EW/DW
BADGE C5
Fuel supply-Engine
FUEL DIESEL FUEL
ENGINE (TYPE) EW/DW
Gearbox-Driveshafts
TRANSMISSION BVM6
GEARBOX TYPE ML6C
Body fittings
SUN ROOF FIXED ROOF
Interior fittings
Electrical
Miscellaneous
