problema de comunicare cu ECU la c5 2.0i
leautaandrei
- Localitate: Constanta
Am un C5 2.0i cu Ecu Magneti Marreli si nu porneste.Nu invarte motorul ci doar se aprind becurile din bord.ELectromotorul merge , baterie are.Diagnoza nu se poate conecta la ECU iar celelalte module citesc o eroare de comunicare cu ECU.MA puteti ajuta cu o schema electrica de la Ecu la Bsi sau ceva general de genul alimentare , K line, ignition...sper ca am fost destul de explicit.
Gringo
leautaandrei
leautaandrei
leautaandrei
- urzica
- Localitate: Medgidia
Caracteristicile vehiculului
Linie de produs C5 II
Nr. APV/PR 10985 CJ 1 0144
Data de Inceput de Garantie DDG 25.01.2007
OPB A044
NRE e2*2001/116*0304*01
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINA CU 5 USI
FINITION INALTA MEDIE
MOTEUR INJECTIE EW10A
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EXL - VOPSEA NEGRU OBSIDIAN
TYPE D’HABILLAGE INTĂRIEUR VELUR MOARA "FF"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTĂRISTIQUES) CUTIE DE VITEZE MANUALA BE4 J
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLĂMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
Alimentare motor
DĂTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT BENZINA FARA PLUMB
DĂPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
RĂCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
DISPOSITIF (ANTIPOLLUTION) FARA DISPOZITIV ANTIPOLUARE
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIĂE INJECTION SISTEM DE INJECTIE MAGNETI MARELLI
FILTRE RĂSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
JOINT COTĂ ROUE GARNITURA LATERALA DE ROATA DIAMETRU 17,5
JOINT COTĂ PONT GARNITURA LATERALA DE PUNTE JB2A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R16 W NERANFORSAT
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
Suspensie Directie Franare
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3
CONTRĂLE DYNAMIQUE DE STABILITĂ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ENJOLIVEMENT LATĂRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATĂRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ENJOLIVEUR ROUE (STYLE) STIL AZZANA 8 FANTE 16 INCI
FEU D’ĂCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
PACK LOOK EXTĂRIEUR PACHET LOOK EXTERIOR DUX03 DED16
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPĂRATURE AMBIANTE) TARI CU CLIMA RECE
GRADUATION VITESSES GRADATIE IN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE LAC NEGRU
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE DECORATIUNE LAC NEGRU
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ELĂMENTS DE GARNISSAGE INTĂRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN POLIPROPILENA
ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE FARA SISTEM DE REGLARE PROIECTOR
RĂCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RĂFRIGĂRATION SISTEM DE REFRIGERARE AUTOMATA
RĂGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RĂTROVISEUR INTĂRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
RĂGULATION CLIMATISATION / TEMPĂRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
TUNER-RADIO CU UN SINGUR TUNER RADIO
DĂTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
AMPLI-ĂQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
PACK RADIO / INFORMATION / COMMUNICATION RD4
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) FARA SPRIJIN LOMBAR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 12
BATTERIE BATERIE L3 450
DĂMARREUR DEMAROR CLASA 4
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRĂQUENCE RADIO FRECVENTA RADIO ASIA
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
COTĂ CIRCULATION CIRCULARE PE DREAPTA
TRIANGLE DE PRĂSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
OPB A044
Informatii generale
MONOGRAMME C5
Alimentare motor
Electricitate
Diverse
- urzica
http://www.fileshare.ro/e30983151
Descarca , dezarhiveaza, si priveste, vezi daca intelegi ceva, daca nu te pricepi mergi la un specialist](./images/smilies/eusa_wall.gif)
leautaandrei
paulsebastiant
leautaandrei
Total mesaje 187866
Total membri 11855
Cel mai nou membru Sepa13
