Ajutor! Citire VIN
urzica
Localitate: Medgidia
Mesajde urzica » Vin 16-Mai-2014 18:55
calin194 scrie:MĂŁ ajutati si pe mine cu date despre VIN?
VF7RCRFJC76673906
Vreau sĂŁ cumpĂŁr si eu aceastĂŁ masinĂŁ si nu stiu nimic despre Citroen C5.
VĂŁ multmesc!
aracteristicile vehiculului
Linie de produs C5 II
Nr. APV/PR 10360 CJ 1 0296
Data de Inceput de Garantie DDG 26.04.2005
OPB A044
NRE e2*2001/116*0304*01
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINA CU 5 USI
FINITION INALTA MEDIE
MOTEUR INJECTIE EW10A
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE KCW - VOPSEA SABLE DE LANGRUNE
TYPE D’HABILLAGE INTÉRIEUR VELUR MOARA "FF"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA BE4 J
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT BENZINA FARA PLUMB
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
DISPOSITIF (ANTIPOLLUTION) FARA DISPOZITIV ANTIPOLUARE
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE MAGNETI MARELLI
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
JOINT COTÉ ROUE GARNITURA LATERALA DE ROATA DIAMETRU 17,5
JOINT COTÉ PONT GARNITURA LATERALA DE PUNTE JB2A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215/55 R16 W NERANFORSAT
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
Suspensie Directie Franare
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ENJOLIVEUR ROUE (STYLE) STIL AZZANA 8 FANTE 16 INCI
FEU D’ÉCLAIRAGE DE SEUIL LUMINA PENTRU PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
PACK LOOK EXTÉRIEUR FARA PACHET LOOK EXTERIOR
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE LAC NEGRU
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE DECORATIUNE LAC NEGRU
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) TRANSPERANT MANUAL SPATE
REHAUSSE ASSISE AVANT PASSAGER SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ELÉMENTS DE GARNISSAGE INTÉRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN POLIPROPILENA
ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
ECLAIRAGE BAS HABITACLE ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE FARA SISTEM DE REGLARE PROIECTOR
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT CU PLASA IN PORTBAGAJ
TUNER-RADIO CU UN SINGUR TUNER RADIO
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
PACK RADIO / INFORMATION / COMMUNICATION RD4
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) FARA SPRIJIN LOMBAR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 12
BATTERIE BATERIE L3 450
DÉMARREUR DEMAROR CLASA 3
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
calin194
Localitate: stei
Masina: CITROEN c4
2: Ford Mondeo2
3: Tico
Mesajde calin194 » Sâm 17-Mai-2014 19:58
Mulțumesc mult!
zoli100
Localitate: drobeta turnu severin
Ajutor! Citire VIN
Mesajde zoli100 » Mie 18-Iun-2014 21:35
Salutare tuturor. De astazi sunt pe forum si de o luna posesorul unui c5 breack . As dori si eu si eu ajutorul vostru ptr citirea vin-ului masinii mele cu urmatoarele date : VF7DERHZB76299593. Va multumesc anticipat
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Joi 19-Iun-2014 07:49
Caracteristicile vehiculului
Linie de produs C5
Nr. APV/PR 09342 CJ 1 0665
Data de Inceput de Garantie DDG 05.07.2002
OPB R007
NRE e2*98/14*0220*01
Informatii generale
LIGNE DE PRODUIT C5
SILHOUETTE BREAK 5 USI
MOTEUR DIESEL TURBO DW10ATED FARA FILTRU DE PARTICULE
TYPE DE PEINTURE VOPSEA OPACA
COULEUR DE CAISSE KNC - VOPSEA ALBASTRU AMIRAL
TYPE D’HABILLAGE INTÉRIEUR VELUR RIZIERE "HZ"
COULEUR DE GARNISSAGE "FT"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML5C
Alimentare motor
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE CEE 2000 (MOTOR)
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 MBA
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL L4
VENTILATEUR 1 VENTILATOR 500W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
BOÎTIER PAPILLON (ADMISSION AIR MOTEUR) FARA MODUL CLAPETA (ADMISIE AER MOTOR)
COUPLE RAPPORT RAPORT PUNTE 6 X 65
STYLE ROUE ROATA DIN TABLA 15 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC CU COMANDA ASISTATA
JOINT COTÉ ROUE GARNITURA PE PARTEA ROTII DIAMETRU 20
JOINT COTÉ PONT GARNITURA PE PARTEA PUNTII JB3A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205X65X15 H
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA ML
ANTIPATINAGE FARA SISTEM ANTIPATINARE
COURSE MÉCANISME DE DIRECTION CURSA MECANISM DE DIRECTIE 148
CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
ENJOLIVEUR ROUE (STYLE) STIL CHAMBORD 14 FANTE 15 INCI
FEU D’ÉCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
PORTE-BAGAGES MONTARE CU BARE DE ACOPERIS
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS RETROVIZOR SI MANER EXTERIOR IN CULOAREA CAROSERIEI + GUSEU VOPSIT
PACK LOOK EXTÉRIEUR FARA PACHET LOOK EXTERIOR CULOARE CAROSERIE
RADIO-TÉLÉPHONE PREGATIRE PRELIMINARA PENTRU RADIO TELEFON (ANTENA + CABLU)
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD STANDARD
GARNISSAGE VOLUME CHARGEMENT COVORAS PORTBAGAJ DIN PVC + LATERALE DIN MOCHETA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
RÉGLAGE ASSISE AVANT CONDUCTEUR FARA SUPORT REGLARE LOMBARA CONDUCATOR
ELÉMENTS DE GARNISSAGE INTÉRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN TESATURA
ACCOUDOIR ASSISE AVANT MONTARE CU COTIERA FATA
BOITE DE RANGEMENT CU COMPARTIMENT DE DEPOZITARE
CD ROM POUR AUTO PC FARA CD ROM PENTRU AUTO-PC
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTION PASSAGER ARRIÈRE CU PROTECTIE PASAGER SPATE
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD3"
RÉGULATEUR DE VITESSES FARA SISTEM DE REGULARIZARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
PACK AMBIANCE FARA PACHET AMBIANTA
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
BATTERIE BATERIE L2 400
DÉMARREUR DEMAROR CLASA 5
Diverse
ROULAGE DRUM CORECT
BOÎTIER SERVITUDE BSI COMM 2000
TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
zoli100
Mesajde zoli100 » Vin 20-Iun-2014 13:45
avem a multumi !!!
zoli100
Re: Ajutor! Citire VIN
Mesajde zoli100 » Lun 25-Oct-2021 19:37
salutare tuturora.am revenit dupa mult timp cu un c5 2009. ma mai puteti ajuta cu descifrarea vin VF7RWRHF89L503853. MULTUMESC
Înapoi la “Citroen C5 I-II”
