Buna ziua,
Sunt interesat de un c4 grand, am luat vin-ul si am mers pe service.citroen, nu inteleg ce inseamna "TRIM LEVEL: MEDIUM MEDIUM". Vanzatorul sustine ca este exclusive. Din brosura din 2007, are dotari pe care le are Exclusite, dar *nu toate*. Sa fie mai degraba un VTR+ la care s-au araugat unele chestii?
Mai jos extras-ul de la vin:
Vehicle characteristics
Vehicle family C4 PICASSO
AS RPO No 11191 FV 2 0041
Warranty Start Date 10/07/2008
OPB K7KA
BER e2*2001/116*0345*01
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C4 PICASSO
SILHOUETTE ESTATE - LEISURE
TRIM LEVEL MEDIUM MEDIUM
ENGINE EW10A INJECTION
TRANSMISSION Auto gearbox AL4
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR KAQ - ANODISED YELLOW PAINT
INTERIOR TRIM TYPE QUANTA + MISTECO "TN" VELOUR
UPHOLSTERY COLOUR "FC"
GEARBOX (CHARACTERISTICS) Auto gearbox AL4
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE WITHOUT BADGE
SPEEDOMETER DRIVE W/O TACHO TORQUE
Fuel supply-Engine
FUEL SUPPLY INJECTION
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) ANTI DEPOLLUTION L5 (ENGINE)
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER
OIL COOLER MNTG EXCHANGER ON ENG & G/BOX
COOLING MOTOR RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION) WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTION L5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 200WAERO VARIABLE SPEED FAN
INJECTION ASSOCIATED VARIANT MOUNTING MAGNETI MARELLI
TANK FILTER RESERVOIR FILTER INTERIOR
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) MOTORISED THROTTLE BODY (ENG AIR INTAKE)
STOP AND START WITHOUT STOP AND START
Gearbox-Driveshafts
FINAL DRIVE RATIO CP 20 X 73
WHEEL STYLE 16 INCH BAIKAL WHEEL
CLUTCH WITHOUT CLUTCH
GEARBOX TYPE (TYPE APPROVAL) GEARBOX AL/4
DIFFERENTIAL (GEARBOX) W/O GEARBOX DIFF
TYRE (SIZE, TYPE) NON-REINFORCED 215/55 R16 93V TYRE
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE Auto gearbox AL4
Suspension-Steering-Brakes
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAMETER 22.5
SUSPENSION NORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE) METAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANT 8 1 BOSCH ESP
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORN STANDARD
AERIAL INTEGRAL AERIAL
FINISHER (SELF-ADHESIVE) DOOR FRAME REAR TRIM
REAR SPOILER FITTING WITH RR UPPER DEFLECTOR
SIDE MOULDINGS (TYPE) SOLID COLOUR + BODY COLOUR
SIDE MOULDINGS (DIMENSION) THIN SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) WITHOUT WHEEL CAP
SILL ILLUMINATION LAMP SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR
ENGINE BAY SOUNDPROOFING WITHOUT SOUND-PROOFING
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK WITHOUT FRONT BUMPER PLUG
ROOF GLASS WITHOUT ROOF WINDOW
REAR TAILGATE GLASS OPENING TAILGATE WINDOW
LUGGAGE RACK MOUNTING WITH ROOF BARS
FRONT FOGLAMP FRONT FOG LIGHTS
SPARE WHEEL EMERGENCY WHEEL
EXTERIOR ACCESSORIES BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CONVEX EXTERIOR MIRROR GLASS
SUN ROOF FIXED ROOF
BUMPER TRIM BODY COLOUR BUMPER STRIP
GLASS (APPEARANCE) TINTED + MOULDED RR WINDOW GLASS
REAR QUARTER WINDOW (TYPE) FIXED REAR QTR GLASS
WINDOW (TYPE) LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
FRONT HEAD RESTRAINT JOINTED FRONT HEADREST
REAR SEAT 3 SEPARATE REAR SEATS (3 SLIDING)
SUPPLEMENTARY SEAT 2 PLACES SUPPLEMENT SEPAR SEATS
REAR SEAT ARMREST WITHOUT REAR ARMREST
LUGGAGE COVER SCREEN
REAR SEATBELT REAR 3-POINT 3 INERTIA REEL SEAT BELT
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITH AUTO RECIRCULATION HEATER MATRIX
CHILD LOCK ELECTRIC REAR CHILD LOCK
SPEED GRADUATIONS GRADUATION KMS/H
RADIO EQUIPMENT FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER
DRIVING POSITION LEFT HAND DRIVE
REMOTE CONTROL HEADLAMP ILLUMINATION WITH PLIP
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
BOOT AND LOAD SPACE LIGHTING BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL
DASHBOARD EQUIPMENT STD FASCIA PANEL EQUIPMENT + PAINTED UPPER VP
INT. TRIM AND EQUIPMENT VARIATION STANDARD INTERIOR EQUIPMENT DRESSING
MISC. INT. LAMPS MAP READING LAMP
WORK TABLE WITH WORK TABLE
UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
DOOR TRIM DOOR TRIM PAD WITHOUT DECOR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) MANUAL REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT PASSENGER TILTING BACK
FRONT SEAT ARMREST DRIVER ANT PASSENGER FRONT ARMREST
COMPACT DISC MOUNTING COMPACT DISC
STOWAGE BIN WITH COOLED STORAGE BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING
TRAFFIC INFORMATION READER WITHOUT LATERAL TRAJECTORY MONITORING
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
SUPPLEMENTARY SEAT SEATBELT SUPPLY SEAT - INERTIA-REEL BELT
FITTING REAR HEAD RESTRAINT MOUNT 3 REAR HEAD-REST
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG THORAX SIDE + CURTAIN AIRBAG
PASSENGER AIRBAG PASSENGER AIRBAG
ELECTRIC WINDOW (OPERATION) DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH
ADDITIONAL AIR CONDITIONING WITH ADDITIONAL AIR CONDITIONING
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
RADIO RECEIVER "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION AUTOMATIC AIR CONDITIONING
INTERIOR REAR VIEW MIRROR NON-ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
LOAD SPACE STORAGE WITH BOOT TIDY
TUNER RADIO DUAL RADIO TUNER
INTERIOR PROTECTION WITH INTERIOR PROTECTION
OBSTACLE DETECTION SYSTEM REAR RADAR OBSTACLE SENSOR
LATERAL BLINDS SIDE BLINDS "ROW 2"
TRIM ADAPTATION WITHOUT MOULDING ADAPTATION
FLOOR MAT W/O CARPETMAT
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL SIMPLE + AUTOMATIC CENTRAL LOCKING
STEERING WHEEL STANDING STEERING WHEEL
DRIVER’S KNEE AIRBAG DRIVER’S KNEE AIRBAG
REAR VIDEO SCREEN WITHOUT REAR VIDEO SCREEN
CHILD OBSERVATION INTERIOR MIRROR INTERIOR CHILD MONITORING MIRROR
SUPPLEMENTARY HEATER WITHOUT ADDITIONAL HEATING
Electrical
ALTERNATOR ALTERNATOR 120 AMP
HORNS HORN STANDARD
BATTERY BATTERY L3 500
STARTER MOTOR STARTER MOTOR CL 4
SPECIAL LIGHTING AUTOMATIC HEADLAMP ILLUMINATION
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
MULTIPLEXING MULTIPLEXING ASSEMBLY CAN CAN
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET WITH ACCESSORIES SOCKET
TRAFFIC SIDE DRIVING ON THE RIGHT-HAND SIDE
SIDE IMPACTS DOOR WITHOUT REINFORCEMENT
SET OF KEYS 1 HF PLIP KEY + 1 SINGLE MAIN KEY
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
SLAVE CONTROL UNIT BSI + COM FIXED HUB STEERING WHEEL
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
Nelamurire VIN
Total subiecte 18658
