[VAND] pompa injectie.
Tot ce este legat in mod direct de Citroen. Cititi cu atentie REGULILE publicate in header-ul sectiunii! Anunturile vor contine OBLIGATORIU o descriere cat mai detaliata a produsului, datele de contact si PRETUL. Nerespectarea acestor reguli duce la stergerea anuntului. ATENTIE: Discutiile Off-Topic vor fi sterse fara notificare prealabila.
cristisimi
Localitate: bacau
Mesajde cristisimi » Dum 24-Noi-2013 14:41
pompa injectie. cod XUD 203.pret 300 ron negociabil...pompa am vrut sa o pun la mine pe masina dar difera,..
marianmarian
Localitate: cernavoda
Mesajde marianmarian » Lun 25-Noi-2013 19:24
pune si tu de pe ce masina provine si marca?
Catalin Radu
Localitate: Ploiesti
Mesajde Catalin Radu » Lun 25-Noi-2013 20:11
Ia d-aci mariane:
The XUD was available with either SOHC 8-valve or 12-valve heads. It was mainly applied transversally in front wheel drive vehicles, tilted by 30°. However, some applications in non-PSA vehicles had the engine installed longitudinally, with rear-wheel drive. The XUD is built in Citroen's plant in TrÊmery, near Metz.[1]
Displacement ranges between 1,769 and 2,138 cc, and all XU diesel engines have a stroke of either 88 mm (3.5 in) or 92 mm (3.6 in). The former was shared with the XU9. Bore sizes range from 80 mm (3.1 in) to 86 mm (3.4 in), some of which are shared with other XU engines.
Upon its release the engine was noted as one of the best diesel engines (for cars and light vans) in the world with its high power output and refinement it made all other diesel engines seem agricultural.[1] It was also particularly light, with a ready-to-run XUD9 weighing 157 kg (346 lb), 15% less than a comparable diesel of the previous generation.[1] However, if the cooling system is neglected or improperly bled after filling - needing a raised filling level because the expansion tank is not the highest point in the system - the engine has a tendency to blow its head gasket. A simple solution is to use a plastic soft drink bottle with the bottom removed, fitted with a rubber O ring seal on the flange at the cap end for filling. Because radiators (typical life 100,000 miles), generally have only just sufficient cooling capacity when new, in order to help get the engine to operating temperature quickly, silting causes significant problems. Coolant changes to maintain corrosion inhibitors (and stop silting) are critical on this engine. Nonetheless due to the high volume of cars manufactured with this engine spare parts are plentiful and well priced.
Eeeiii ?
cristisimi
Localitate: bacau
Mesajde cristisimi » Lun 25-Noi-2013 20:30
pai pompa de injectie este de citroen xantia de 1.9 am vrut sa o pun pe masina mea,citroen xantia de 1,9 td dhx din 98.dar eu pe masina am alt tip de pompa,...
cristisimi
Localitate: bacau
Mesajde cristisimi » Lun 25-Noi-2013 20:35
adica ce pe care o am pe masina este cu ceva electric in plus fata de aia din poza,.
Înapoi la “Vanzari/Cumparari/Schimburi”
    Total mesaje 187855
    Total subiecte 18701
    Total membri 11859
    Cel mai nou membru Kongyawen
