Ajutor! Citire VIN
mesersmith
Moderator - C5
Localitate: calarasi
Masina: C5 III
2: C5 II
3: Peugeot 308
Mesajde mesersmith » Mar 19-Feb-2013 00:56
Daca te intereseaza, iata si caracteristicile vehiculului:
Linie de produs C5 II
Nr. APV/PR 10335 CJ 1 0008
Data de Inceput de Garantie DDG 23.04.2005
OPB A047
NRE e2*2001/116*0305*02
Informatii generale
GENRE DE PRODUIT VEHICUL PARTICULAR
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINA CU 5 USI
FINITION INALTA MEDIE
MOTEUR DIESEL TURBO DV6TED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA5
TYPE DE PEINTURE VOPSEA METALIZATA LACUITA
COULEUR DE CAISSE EZR - VOPSEA GRI ALUMINIU
TYPE D’HABILLAGE INTÉRIEUR VELUR OTTI "PZ"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MECANICA BE4 L
MOTEUR (TYPE) MOTOR TIP EV/DV
MONOGRAMME COMPLÉMENTAIRE, DIVERS FARA MONOGRAMA SUPLIMENTARA
MONOGRAMME C5
Caracteristici vehicul
DIRECTION MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
COUPLE TACHYMÈTRE RAPORT TRANSMISIE 22 X NO
Alimentare motor
DÉTECTEUR D’EAU FILTRE À GAZOLE FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT MOTORINA
DÉPOLLUTION (MOTEUR) DEPOLUARE EURO 4 (MOTOR)
REFROIDISSEMENT D’HUILE SCHIMBATOR APA/ULEI MOTOR
MOTEUR REFROIDISSEMENT RADIATOR EP:27 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATION PUISSANCE (MOTEUR) PUTERE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULARE GAZE DE ESAPAMENT "EGR"
DÉPOLLUTION TECHNIQUE VÉHICULE DEPOLUARE TEHNICA VEHICUL EURO4
FILTRE À PARTICULE FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTE ASSOCIÉE INJECTION SISTEM DE INJECTIE BOSCH
FILTRE RÉSERVOIR FILTRU REZERVOR INTERIOR
Cutie de viteze Transmisie
COUPLE RAPPORT RAPORT PUNTE 17 X 71
STYLE ROUE ROATA CU JANTA DIN TABLA 16 INCI
EMBRAYAGE AMBREIAJ HIDRAULIC
JOINT COTÉ ROUE GARNITURA LATERALA DE ROATA DIAMETRU 17,5
JOINT COTÉ PONT GARNITURA LATERALA DE PUNTE JB2A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X16 W
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
BOITE DE VITESSES TYPE CUTIE DE VITEZE MANUALA BE4R
Suspensie Directie Franare
SUSPENSION SUSPENSIE NORMALA
SUSPENSION ACTIVE SUSPENSIE HIDRACTIVA 3
CONTRÔLE DYNAMIQUE DE STABILITÉ CU SISTEM ESP
DIRECTION (FONCTIONNEMENT) SISTEM DE DIRECTIE MECANICA ASISTATA
Caroserie Echipamente
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE COLORATE IN MASA
ENJOLIVEMENT LATÉRAL (DIMENSION) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC
ENJOLIVEUR ROUE (STYLE) STIL AZZANA 8 FANTE 16 INCI
FEU D’ÉCLAIRAGE DE SEUIL FARA LUMINA DE PRAG
COMPLÉMENT DE PROTECTION (SOUS MOTEUR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA FUNCTIE SUPLIMENTARA
ESSUIE-VITRE AVANT MECANISM STERGERE PARBRIZ CU SENZOR DE PLOAIE
ESSUIE-VITRE ARRIÈRE FARA MECANISM DE STERGERE LUNETA
ESSUIE-PROJECTEUR FARA MECANISM DE STERGERE PROIECTOR
OBTURATEUR FACE AVANT FARA OBTURATOR PARTE FRONTALA FATA
VITRE VOLET ARRIÈRE GEAM FIX DE CAPAC DE PORTBAGAJ
PORTE-BAGAGES MONTARE FARA USA SUPORT DE BAGAJE
PROJECTEUR ANTIBROUILLARD PROIECTOARE ANTI-CEATA
TOIT OUVRANT ACOPERIS FIX
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE COLORAT IN MASA
VITRE (TYPE) PARBRIZ CU IZOLARE TERMICA
PACK LOOK EXTÉRIEUR FARA PACHET LOOK EXTERIOR
Echipament de interior
ALARME ANTIVOL FARA ALARMA ANTIFURT
ACCOUDOIR ASSISE ARRIÈRE CU COTIERA SPATE
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA TEMPERATA
GRADUATION VITESSES GRADATIE IN KM/H
COTÉ DE CONDUITE (POSTE DE CONDUITE) VOLAN PE STANGA
CHAUFFAGE ADDITIONNEL FARA SISTEM DE INCALZIRE SUPLIMENTAR
EQUIPEMENT PLANCHE DE BORD DECORATIUNE SATIN ARGINTAT
GARNISSAGE VOLUME CHARGEMENT FARA COVORAS
RANGEMENT SOUS SIÈGE 1 SERTAR DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE PANOU DE USA FARA DECORATIUNE DIN LEMN
HAUT-PARLEUR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
COMMANDE D’AUTORADIO COMANDA SISTEM AUDIO LA DISTANTA
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA TRANSPERANT SPATE
REHAUSSE ASSISE AVANT PASSAGER FARA MECANISM DE INALTARE PERNA DE SEZUT PASAGER FATA
COMMANDE ASSISE AVANT CONDUCTEUR COMANDA MANUALA SCAUN CONDUCATOR
COMMANDE ASSISE AVANT PASSAGER COMANDA MANUALA SCAUN PASAGER FATA
ELÉMENTS DE GARNISSAGE INTÉRIEUR TAPITERIE STALP CENTRAL + PARTE LATERALA SUPERIOARA SPATE A CAROSERIEI DIN POLIPROPILENA
ACCOUDOIR ASSISE AVANT COTIERE FATA CONDUCATOR SI PASAGER
COMPACT DISQUE MONTARE COMPACT DISCURI
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE ECRAN MONOCROM
LAMPES DE PROJECTEURS LAMPA CU HALOGEN
LÈVE-VITRE ARRIÈRE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
LECTEUR D’INFORMATIONS ROUTIÈRES FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFFICHEUR AFISAJ (NAVIGATIE + RADIO + CEAS, T°,CD)
MIROIR DE COURTOISIE OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
INDICATEUR D’HUILE SENZOR TEMPERATURA
NAPPE CHAUFFANTE SCAUN FARA INCALZIRE
ECLAIRAGE BAS HABITACLE FARA ILUMINAT INFERIOR DE HABITACLU
PROTECTION PASSAGER ARRIÈRE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALISATION COUSSIN GONFLABLE DEZACTIVARE MANUALA AIRBAG
PROJECTEUR CORRECTEUR ASSIETTE FARA SISTEM DE REGLARE PROIECTOR
RÉCEPTEUR RADIO SISTEM RADIOTELEFON "RT3"
RÉFRIGÉRATION SISTEM DE REFRIGERARE AUTOMATA
RÉGULATEUR DE VITESSES SISTEM DE REGULARIZARE SI DE LIMITARE VITEZA
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
RÉGULATION CLIMATISATION / TEMPÉRATURE SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
RANGEMENT VOLUME CHARGEMENT FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DÉTECTION D’OBSTACLE FARA SISTEM DE DETECTARE OBSTACOLE
AMPLI-ÉQUALISEUR FARA AMPLIFICATOR EGALIZATOR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT CU SPUMA 4 BRATE
PACK AMBIANCE FARA PACHET AMBIANTA
PACK RADIO / INFORMATION / COMMUNICATION RT3 + SISTEM NAVIGATIE MONOCROM
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) FARA SPRIJIN LOMBAR
Electricitate
ALTERNATEUR ALTERNATOR CLASA 15
DÉMARREUR DEMAROR CLASA 5
ECLAIREMENT PARTICULIER APRINDERE AUTOMATA A LUMINILOR
FRÉQUENCE RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSFERA NORMALA
COTÉ CIRCULATION CIRCULARE PE DREAPTA
TRIANGLE DE PRÉSIGNALISATION FARA TRIUNGHI REFLECTORIZANT
Static
Localitate: Buftea
Mesajde Static » Mar 19-Feb-2013 04:35
Multumesc tuturor!
marianmarian
Localitate: cernavoda
Mesajde marianmarian » Mar 19-Feb-2013 20:11
nimeni nu a spus ce km are masina si ce interventii a avut in garantie sau ultima revizie in servis.
toti spun ce dotare are masina .
mai putin cred ca ii intereseaza pe cei ce cumpara o masina sa afle ce dotare are masina decat ce km a avut si probleme.
alex_andu77
Localitate: craiova
am si eu nevoie de o identificare VIN
Mesajde alex_andu77 » Vin 22-Feb-2013 13:56
VIN : VF7RCRHRH76826568
e2*2001/116*0306*04
va multumesc !
alex_andu77
Localitate: craiova
scuze de intarziere...
Mesajde alex_andu77 » Vin 22-Feb-2013 14:04
VF7RCRHRH76826568
MARIAN
Localitate: Buzau
Masina: Xantia 1.9TD VSX
2: C5 2.0 HDI 110CP
Mesajde MARIAN » Vin 22-Feb-2013 18:31
taviciobanu scrie:Da-ne te rog si noua adresa sitului , sper ca nu e secreta.
http://service.citroen.com
mesersmith
Moderator - C5
Masina: C5 III
2: C5 II
3: Peugeot 308
Re: scuze de intarziere...
Mesajde mesersmith » Vin 22-Feb-2013 23:23
alex_andu77 scrie:VF7RCRHRH76826568
Caracteristicile vehiculului
Nr. APV/PR 11175 CJ 1 0170
Data de Inceput de Garantie DDG 28.08.2007
OPB A03Y
NRE e2*2001/116*0306*05
Informatii generale
FINITION MEDIE INALTA
MOTEUR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISSION CUTIE DE VITEZE MANUALA6
TYPE D’HABILLAGE INTÉRIEUR TESATURA SHOW "SM"
BOITE DE VITESSES (CARACTÉRISTIQUES) CUTIE DE VITEZE MANUALA ML6 CL
MOTEUR (TYPE) MOTOR TIP EW/DW
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
MOTEUR REFROIDISSEMENT RADIATOR EP:32 - 21 DM2 ALUMINIU BRAZAT
RÉCHAUFFAGE CIRCUIT GAZ CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
VARIANTE ASSOCIÉE INJECTION SISTEM INJECTIE SIEMENS
STYLE ROUE ROATA OLYMPOS 16 INCI
JOINT COTÉ ROUE GARNITURA LATERALA DE ROATA AC 3300I
JOINT COTÉ PONT GARNITURA PE PARTEA PUNTII AAR 3300I
ROUE (TYPE) MONTARE ROATA ALIAJ 3
BOITE DE VITESSES TYPE ML6C
DIRECTION (FONCTIONNEMENT) DIRECTIE ASISTATA ELECTROHIDRAULIC
ENJOLIVEMENT LATÉRAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CULOAREA CAROSERIEI
ENJOLIVEUR ROUE (STYLE) TIP OLYMPOS
ENJOLIVEMENT PARE-CHOCS BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
PACK LOOK EXTÉRIEUR PACHET LOOK EXTERIOR IN CULOAREA CAROSERIEI
CLIMAT (TEMPÉRATURE AMBIANTE) TARI CU CLIMA RECE
EQUIPEMENT PLANCHE DE BORD DECORATIUNE CUBIC CU OCHIURI MICI
RANGEMENT SOUS SIÈGE 2 SERTARE DE DEPOZITARE SUB SCAUN
GARNISSAGE DE PORTE DECORATIUNE CUBIC CU OCHIURI MICI
COMPACT DISQUE FARA MONTARE COMPACT DISC
SYSTÈME DE NAVIGATION FARA SISTEM DE NAVIGARE
AFFICHEUR AFISAJ (RADIO + CEAS + SI SAU T°,CD)
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
PACK RADIO / INFORMATION / COMMUNICATION RM4
Electricitate
ALTERNATEUR ALTERNATOR CLASA 18
BATTERIE BATERIE L3 450
DÉMARREUR DEMAROR CLASA 6+
Diverse
TRIANGLE DE PRÉSIGNALISATION PREGATIRE PENTRU TRIUNGHI DE PRESEMNALIZARE
macphisto
Localitate: Petrosani
cumparare C5
Mesajde macphisto » Mie 08-Mai-2013 14:16
Buna
Am gasit si eu un C5 1.6 hdi FAP de vanzare. 2006 iunie, inscrisa in RO in 2010, al doilea proprietar. Pretul e bun, dar ii apare mesajul ala cu Deppolution System Faultry si becul galben aprins de la motor. In zona mea nu are nimeni Lexia, asa ca apelez la ajutorul vostru. Din ce am citit pe forum ar fi aditivul Eolys, se poate cumpara si completa/repara? Dupa ce o iau daca e sa o cumpar as da o fuga la fam. Stan sa o revizeze de la A la Z. VIN-ul este VF7RC9HZC76739062.
Mersi
Andrei
urzica
Localitate: Medgidia
Re: cumparare C5
Mesajde urzica » Mie 08-Mai-2013 22:38
macphisto scrie:Buna
Mersi
Andrei
Nr. APV/PR 10690 CJ 1 0153
Data de Inceput de Garantie DDG 17.03.2006
OPB A047
Informatii generale
FINITION INALTIME MEDIE PLUS
COULEUR DE CAISSE EYT - VOPSEA GRI ORAGEUX
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
DISPOSITIF (ANTIPOLLUTION) RECICLARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
STYLE ROUE ROATA HUNGARO 16 INCI
ROUE (TYPE) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATOR PIERDERE PRESIUNE PNEURI
ENJOLIVEUR ROUE (STYLE) TIP HUNGARO
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR RABATABIL ELECTRIC FARA MEMORIE
RÉCEPTEUR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4"
RÉTROVISEUR INTÉRIEUR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
TUNER-RADIO CU UN SINGUR TUNER RADIO
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
PACK RADIO / INFORMATION / COMMUNICATION RD4
Electricitate
Diverse
macphisto
Mesajde macphisto » Mie 08-Mai-2013 23:10
multumesc
cris1sz
Localitate: Baia Mare
Masina: Citroen C4, 1.6HDI, 90HP
Mesajde cris1sz » Sâm 14-Dec-2013 16:44
Ma puteti ajuta si pe mine pentru decodarea urmatorului VIN: VF7LC9HXC9Y598828 ?
mihai ham
Localitate: Valcea
Mesajde mihai ham » Sâm 14-Dec-2013 17:28
Linie de produs C4
Nr. APV/PR 12085 88 1 0222
Data de Inceput de Garantie DDG 11.01.2010
OPB I00G
NRE e2*2001/116*0302*17
Informatii generale
LIGNE DE PRODUIT C4
FINITION SX VTR
MOTEUR DIESEL TURBO DV6ATED4
COULEUR DE CAISSE KGN - VOPSEA BOURRASQUE
TYPE D’HABILLAGE INTÉRIEUR VELUR LITUS G070+MISTECO2 F930 "2B"
COULEUR DE GARNISSAGE "FZ"
FINITION SX VTR
Alimentare motor
ALIMENTATION INJECTIE TURBO CU SCHIMBATOR DIRECT
CARTER CYLINDRE (MATIÈRE) BLOC CILINDRI ALUMINIU
CARBURANT MOTORINA
CYLINDRÉE 1600 CM3
CATALYSEUR CATALIZATOR CU MAI PUTIN DE 50PPM
MOTEUR REFROIDISSEMENT RADIATOR 21,3DM2 18MBAS
AUTODIAGNOSTIC EOBD AUTODIAGNOSTICARE "EOBD" FARA ACCELEROMETRU
FILTRE À PARTICULE FARA FILTRU DE PARTICULE
VENTILATEUR 1 VENTILATOR 2 TURATII 130W AERO
RÉCUPÉRATION DES VAPEURS D’ESSENCE FARA SISTEM DE RECUPERARE VAPORI DE BENZINA
COUPLE RAPPORT CP 19 X 72
DIFFÉRENTIEL (BOITE) DIFERENTIAL 84
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 205/55 R16 V CARE NU ESTE INTARIT
ROUES MONTÉES ROATA 6 INCI 1/2
ROUE (TYPE) MONTARE ROATA CU JANTA DIN TABLA NIVEL 2
BARRE ANTIDÉVERS ARRIÈRE BARA ANTIRULIU SPATE DIAMETRU 27
COLONNE DIRECTION COLOANA DE DIRECTIE CU REGLARE MANUALA
ANTIDÉVERS AVANT BARA ANTIRULIU FATA DIAMETRU 22,5
REFROIDISSEMENT D’HUILE POMPE DE DIRECTION FARA SISTEM DE RACIRE ULEI DE POMPA DE DIRECTIE
CONTRÔLE DYNAMIQUE DE STABILITÉ FARA SISTEM ESP
VARIANTE ASSOCIÉE FREIN ABS BOSCH 8 1
PÉDALIER (TYPE) PEDALIER STANDARD
AVERTISSEURS SISTEM DE AVERTIZARE STANDARD
ANTENNE ANTENA + GPS + GSM
DÉFLECTEUR AÉRODYNAMIQUE ARRIÈRE MONTARE CU DEFLECTOR SPATE IN PARTEA SUPERIOARA A CAPACULUI DE PORTBAGAJ
DÉCORATION (PEINTE) DECORATIUNE COLORATA IN MASA
ENJOLIVEMENT LATÉRAL (DIMENSION) FARA ELEMENTE DE PROTECTIE LATERALE
FEU DE RECUL CU 1 LUMINA PENTRU MERS INAPOI
ETANCHÉITÉ AÉRODYNAMIQUE FARA GARNITURA DE CAPOTA MOTOR
FONCTION COMPLÉMENTAIRE RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR CU PLIERE MANUALA
ENJOLIVEUR DE SORTIE D’ÉCHAPPEMENT FARA ORNAMENT PE IESIREA TEVII DE ESAPAMENT
INSONORISATION COTÉ MOTEUR IZOLARE FONICA LA CAPOTA
ESSUIE-VITRE ARRIÈRE MECANISM DE STERGERE LUNETA
VITRE PAVILLON FARA ELEMENT VITRAT DE PAVILION
PARE-CHOCS BARA DE PROTECTIE FATA/SPATE STANDARD CULOARE CAROSERIE + ORNAMENT DE PROIECTOR DE CEATA CARE NU ESTE CROMAT
PARE-BOUE (BAVETTE) FARA APARATORI DE ROTI SPATE
PLAQUE POLICE FARA PLACUTA DE INMATRICULARE
ROUE DE SECOURS ROATA JANTA TABLA + PNEU STANDARD
ACCESSOIRES EXTÉRIEURS MANER EXTERIOR + COMANDA SPATE + SUPORT + RETROVIZOR IN CULOAREA CAROSERIEI
RÉTROVISEUR EXTÉRIEUR (RAYON COTÉ CONDUCTEUR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
VITRE (ASPECT) FUMURIU + FUMURIU INCHIS IN SPATE
VITRE (TYPE) PARBRIZ STRATIFICAT CU IZOLARE FONICA + GEAMURI LATERALE & SPATE SECURIT
ACCÈS ET DÉMARRAGE MAINS LIBRES FARA ACCCES SI PORNIRE MAINI LIBERE
ALLUME-CIGARE FARA BROCHETA
APPUI-TÊTE ARRIÈRE TETIERA SPATE REGLABILA
APPUI-TÊTE AVANT TETIERA FATA REGLABILA
ASSISE ARRIÈRE PERNA SEPARABILA RABATABILA + SPATAR SEPARABIL RABATABIL
ACCOUDOIR ASSISE ARRIÈRE FARA COTIERA SPATE
CEINTURE DE SÉCURITÉ ARRIÈRE CENTURA DE SIGURANTA SPATE 3 RETRACTARE 3 PUNCTE
CEINTURE DE SÉCURITÉ AVANT CENTURA DE SIGURANTA PIROTEHNICA CU ALARMA
CONDAMNATION ENFANT SIGURANTA COPIL MANUALA USA SPATE
COMPTE-TOURS TUROMETRU DIGITAL INTEGRAT
CHAUFFAGE ADDITIONNEL SISTEM DE INCALZIRE SUPLIMENTARA AUTOMATA
EQUIPEMENT PLANCHE DE BORD PLANSA DE BORD METALIZATA KURTZ FATADA INFERIOARA + SUPORT CREOIN VOPSITE
FEUX INT. DIVERS PLAFONIERA FATA 3 POZITII
GARNISSAGE DE PORTE PANOU DE USA FARA DECORATIUNE CROM SATINAT
INSONORISATION HABITACLE ELEMENT DE IZOLARE FONICA TABLIER 6 KG
ISOLATION (RIDEAU, PARE-SOLEIL LATÉRAL, TOIT OUVRANT) FARA PERDEA IMPOTRIVA SOARELUI
RÉGLAGE ASSISE AVANT CONDUCTEUR FARA SUPORTURI LOMBARE SI LATERALE CONDUCATOR
RÉGLAGE ASSISE AVANT PASSAGER FARA SUPORTURI LOMBARE SI LATERALE PASAGER
RABATTEMENT ASSISE AVANT CONDUCTEUR SCAUN CONDUCATOR FARA SISTEM DE RABATERE PERNA DE SEZUT
RABATTEMENT ASSISE AVANT PASSAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
ACCOUDOIR ASSISE AVANT MONTARE FARA COTIERA FATA
SYSTÈME DE NAVIGATION CU SISTEM DE NAVIGATIE CU ECRAN COLOR
LÈVE-VITRE ARRIÈRE MECANISM ACTIONARE GEAMURI SPATE CU COMANDA MANUALA
AFFICHEUR AFISAJ DEV
MIROIR DE COURTOISIE OGLINDA PARASOLAR CONDUCATOR + PASAGER CU CAPAC FARA LUMINA
INDICATEUR D’HUILE SENZOR DE NIVEL DE ULEI
MONTAGE APPUI-TÊTE ARRIÈRE MONTARE 3 TETIERE SPATE
SAC GONFLABLE LATÉRAL AVANT AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
SAC GONFLABLE PASSAGER AIRBAG LATERAL PASAGER
LÈVE-VITRE ÉLECTRIQUE (FONCTIONNEMENT) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERULUI
PACK ÉQUIPEMENT FARA PACHET ECHIPAMENT PENTRU VEHICUL DE SCOALA AUTO
RÉTROVISEUR EXTÉRIEUR RETROVIZOR EXTERIOR FARA INCALZIRE
COMMANDE INTÉRIEURE DE PORTE (ASPECT) COMANDA INTERIOARA DE USA CU ASPECT NEUTRU
PLANCHER ARRIÈRE CHARGE FARA PLANSEU SPATE DE INCARCARE
PROJECTEUR CORRECTEUR ASSIETTE REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
PROTECTION POSTE AVANT FARA PROTECTIE POST FATA
PARE-SOLEIL AVANT PARTE LATERALA CONDUCATOR + PASAGER FARA INSCRIPTIONARE
RANGEMENT (POSTE CONDUITE) COMPARTIMENT DE DEPOZITARE LATERAL, INCHIS FARA SUPORT PENTRU OCHELARI
RÉCEPTEUR RADIO SISTEM RADIONAVIGATIE CU MEMORIE FLASH "RNEG"
REHAUSSE ASSISE AVANT CONDUCTEUR RIDICARE SCAUN CONDUCATOR REGLARE PARALELA
SURTAPIS (ASPECT) FARA COVORAS SUPLIMENTAR
SAC GONFLABLE CONDUCTEUR AIRBAG LATERAL CONDUCATOR
TAPIS MOCHETA TESUTA DILOUR F550
DÉTECTION D’OBSTACLE SISTEM DE DETECTARE OBSTACOL CU RADAR SPATE
ADAPTATION GARNITURE BURDUF + MANER PIELE PLACUTA CROMATA
SURTAPIS FARA COVORAS SUPLIMENTAR
COMMANDE VERROUILLAGE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN SPUMA CU 2 BRATE
RÉTROVISEUR INTÉRIEUR SURVEILLANCE ENFANT FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
PRIZA AUXILIARA PACK AUDIO FARA PRIZA AUXILIARA PACHET AUDIO
Electricitate
BATTERIE BATERIE L2 400
DÉMARREUR DEMAROR CLASA 4
FRÉQUENCE TÉLÉCOMMANDE DE CONDAMNATION FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
MULTIPLEXAGE MONTARE RETEA MULTIPLEXATA CAN CAN
BOITIER TELEMATIQUE FARA MODUL TELEMATIC
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION SOCIETATE (OVSA)
PRISE D’ÉCOUTE RADIO PRIZA ACCESORII
CHOCS LATÉRAUX USA CARE NU ESTE INTARITA
JEUX DE CLÉS 1 CHEIE TELECOMANDA INALTA FRECVENTA + 1 CHEIE PRINCIPALA UNICA
EQUIPEMENT DE SECOURS FARA ECHIPARE DE REZERVA
ROULAGE DRUM CORECT
BOÎTIER SERVITUDE BSI EVOLUTION
urzica
Mesajde urzica » Sâm 14-Dec-2013 23:47
Static scrie:Salutare tuturor,
Va rog sa ma ajutati cu un VIN: VF7RC9HZC76666401
As vrea sa cumpar masina si nu strica o mica identificare.
Va multumesc anticipat!
Stima,
Adrian
OPB A047
Informatii generale
MONOGRAMME C5
Alimentare motor
CARBURANT MOTORINA
Electricitate
Diverse
marianmarian
Mesajde marianmarian » Dum 15-Dec-2013 10:59
fratilor de ce nu spuneti ce problem a avut masina si km si ultima revizie
cred ca asta ii intereseaza pe cumparatorii
calin194
Localitate: stei
Masina: CITROEN c4
2: Ford Mondeo2
3: Tico
Mesajde calin194 » Vin 16-Mai-2014 09:27
MĂŁ ajutati si pe mine cu date despre VIN?
VF7RCRFJC76673906
Vreau sĂŁ cumpĂŁr si eu aceastĂŁ masinĂŁ si nu stiu nimic despre Citroen C5.
VĂŁ multmesc!
Înapoi la “Citroen C5 I-II”
