[DEZMEMBREZ] Citroen Jumper II 2.2 HDI si 2.8 HDI an 2004
Tot ce este legat in mod direct de Citroen. Cititi cu atentie REGULILE publicate in header-ul sectiunii! Anunturile vor contine OBLIGATORIU o descriere cat mai detaliata a produsului, datele de contact si PRETUL. Nerespectarea acestor reguli duce la stergerea anuntului. ATENTIE: Discutiile Off-Topic vor fi sterse fara notificare prealabila.
constantadezmembrari
Localitate: constanta
Mesajde constantadezmembrari » Vin 25-Ian-2013 00:25
Dezmembrez Citroen Jumper. II 2.2 HDI si 2.8 HDI an fab 2002-2006, 2.8 HDI (JTD) tip SOFIM 8140.43S 93 KW (127 CP) si 2.2 HDI 77kw (104cp) tip 4HY (DW12UTED), de marfa si 8+1 locuri, cutie de viteze 5+1 trepte, (echivalent Fiat DUCATO si Citroen Jumper), cu ABS, Servo directie, Airbag, A/C, geamuri electrice, inchidere centralizata, jante tabla R15 si R16, CD Player OEM.
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capotaportbagaj/haion, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa inalta presiune, rampa injectoare, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompaservo directie, brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbagsofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
Emil Paunas
Localitate: TARGOVISTE, DB
Mesajde Emil Paunas » Lun 28-Ian-2013 15:15
Masini cu piese de aur :? ........... Nu recomand
Înapoi la “Vanzari/Cumparari/Schimburi”
Utilizatori ce ce navighează pe acest forum: Google [Bot] și 5 vizitatori
    Total mesaje 187829
    Total membri 11848
    Cel mai nou membru calfianu
