C5 diverse intrebari
pef73
- Localitate: Brasov
- Masina: Citroen C5 1.6 Hdi 80kw 2005
- 2: Ford Ka 1.3i 55kw 2005
C5 BERLINE 5PTES 1.8 i 16v 117 BVM 5
Linie de produs C5
Nr. APV/PR 08920 CJ 1 0486
Data de Inceput de Garantie DDG 31.08.2001
Numar de Serie al Motorului 10 LT05 0321101
Numar de Serie al Cutiei 20 DL29 3173741
OPB R00O
NRE e2*98/14*0215*00
Informatii generale
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5
SILHOUETTE BERLINE 5PTES
FINITION MOYENNE BASSE
MOTEUR INJECTION EW7J4
TRANSMISSION BVM5
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE EKQ - PEINTURE ROUGE LUCIFER
TYPE D’HABILLAGE INTĂRIEUR VELOURS CONSTELLATION "HW"
COULEUR DE GARNISSAGE "FT"
BOITE DE VITESSES (CARACTĂRISTIQUES) BVM BE4 J
MOTEUR (TYPE) MOTEUR TYPE EW/DW
Caracteristici vehicul
Este cumva cu volan pe dreapta ?
Linie de produs C5
OPB R00O
Informatii generale
LIGNE DE PRODUIT C5
TRANSMISSION BVM5
- urzica
- Localitate: Medgidia
ben80 scrie:Am vazut ca ati ajutat un coleg sa identifice masina si sa afle date despre ea dupa seria sasiu si as vrea daca se poate sa ma ajutati si pe mine (tot in romaneste) sa identific masina Citroen C5 cu Vin: VF7DC6FZB76062849 si daca imi sp[une cineva ce capacitate si ce tip este acest motor...atasez o poza...multumesc
Vehicle characteristics
Vehicle family C5
AS RPO No 08920 CJ 1 0486
Warranty Start Date 31/08/2001
Engine serial number 10 LT05 0321101
Gearbox serial number 20 DL29 3173741
OPB R00O
BER e2*98/14*0215*00
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY C5
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL MEDIUM - LOW
ENGINE INJECTION EW7J4
TRANSMISSION BVM5
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EKQ - PAINT - WICKED RED
INTERIOR TRIM TYPE "HW" CONSTELLATION VELOUR
UPHOLSTERY COLOUR "FT"
GEARBOX (CHARACTERISTICS) BE4 J MANUAL GEARBOX
ENGINE (TYPE) EW/DW
STEERING UNVARIABLE POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 22X18
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL LEAD FREE PETROL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
ENGINE (TYPE) EW/DW
OIL COOLER WITHOUT OIL-WATER DISTR CHAMB
COOLING MOTOR RADIATOR TH : 13 6 - 21 DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
DEVICE (ANTIPOLLUTION) "EGR" + "PULSAIR" AIR INJECTION
VEHICLE TECHNICAL DEPOLLUTION L4 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTER WITHOUT PARTICLE FILTER
FAN 1 FAN 500W
INJECTION ASSOCIATED VARIANT MOUNTING SAGEM
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT) MANUAL THROTTLE BODY (ENGINE AIR INTAKE)
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 19 X 79
WHEEL STYLE 15 INCH STEEL WHEEL
CLUTCH ASSISTED HYDRAULIC CLUTCH
SEAL, WHEEL END WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END AXLE-SIDE JOINT JB2A
TYRE (SIZE, TYPE) 195X65X15 H TYRES
WHEEL (TYPE) STEEL WHEELS
INFLATION PRESSURE LOSS INDICATOR WITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
TRACTION CONTROL WITHOUT ANTISLIPPING
STEERING TRAVEL STEERING MECHANISM TRAVEL 166
ACTIVE SUSPENSION WITHOUT HYDRACTIVE SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
Body fittings
SIDE MOULDINGS (TYPE) GREY DYED SIDELAMPS
SIDE MOULDINGS (DIMENSION) PLASTIC SIDE PROTECTORS
WHEEL EMBELLISHER (STYLE) 15 INCH 8-SPOKE CHENONCEAUX STYLE
SILL ILLUMINATION LAMP WITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTION EXT DOOR MIRROR WITHOUT ADDITIONAL FUNCTION
WINDSCREEN WIPER FRONT WIPER BLADE W/O RAIN SENSOR
REAR SCREEN WIPER REAR SCREEN WIPER
HEADLAMP WIPER W/O HEADLAMP WIPER
FRONT PANEL BLANK SEMI-CLOSED GRILLE + LH SIDE BLANK
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES MATT BLACK EXT HANDLE + DOOR MIRROR + GUSSET
SUN ROOF FIXED ROOF
BUMPER TRIM DYED BUMPER STRIP
WINDOW (TYPE) ATHERMAL WINDSCREEN
EXTERIOR STYLING PACK WITHOUT BODY COLOUR EXTERIOR LOOK PACK
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
REAR SEAT ARMREST WITHOUT REAR ARMREST
RADIO TELEPHONE RADIO TELEPHONE PRE-EQUIPMENT (AERIAL + CABLE)
SPEED GRADUATIONS GRADUATION MPH
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENT DASHBOARD WITHOUT WOOD OR ALUMINIUM DECOR
LOAD SPACE TRIM NON REVERSIBLE BOOT CARPET
UNDERSEAT STORAGE WITHOUT UNDER SEAT STORAGE
LOUDSPEAKER MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLS REMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF) WITHOUT REAR BLIND
FRONT PASSENGER SEAT HEIGHT CONTROL WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL PASSENGER FRT SEAT MANUAL CNTR
DRIVER SEAT ADJUSTMENT WITHOUT DRIVERS LUMBAR ADJUSTMENT
INT. UPHOLSTERY ELEMENTS INT TRIM PANELS WITHOUT CLOTH
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
COMPACT DISC WITHOUT COMPACT DISC
STOWAGE BIN WITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEM WITHOUT NAVIGATION SYSTEM
HEADLAMP BULBS HALOGEN BULB
REAR WINDOW LIFT MAN CTRL REAR WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
COURTESY MIRROR DRIVER’S CONCEALABLE + PASS WITHOUT LIGHT
OIL GAUGE OIL LEVEL WARNING INDICATOR
HEATING ELEMENT NON HEATED SEAT
FOOTWELL LIGHTING WITHOUT DOOR SILL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER WITHOUT HEADLAMP ADJUSTMENT
RADIO RECEIVER "RD2" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATION SINGLE AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
INTERIOR REAR VIEW MIRROR DAY -NIGHT INNER REAR MIRROR
LOAD SPACE STORAGE W/O BOOT TIDY
OBSTACLE DETECTION SYSTEM WITHOUT OBSTACLE DETECTOR
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
LOCKING CONTROL CENTRAL DEAD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL 4 BRANCH
FAN 1 FAN 500W
AMBIENCE PACK WITHOUT AMBIANCE PACK
Electrical
ALTERNATOR ALTERNATOR 90 AMP
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 3
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION DEPOLLUTION INFERIOR
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
EMERGENCY WARNING TRIANGLE WITHOUT WARNING TRIANGLE
primul incident. dau aseara cu spatele si lovesc o tabla cu capota spate a portbagajului. arata ca in imagini. la reprezentanta 560 ornamentul 20600 capota nevopsita si fara geam. se poate repara oare? gasesc ornament mai ieftin? merci
[url=http://postimage.org/image/hcw8gghw/][img]http://s3.postimage.org/hcw8gghw/DSCN0383.jpg[/img][/url]
[url=http://postimage.org/image/hcxvzszo/][img]http://s3.postimage.org/hcxvzszo/DSCN0384.jpg[/img][/url]
danutz
- 2: Ex : C 5 I și C 5 II
- 3: Tel : 0745.81.83.40
Ia d-aci !!!
Ligne de produit C5
N°APV/PR 09717 CJ 1 0365
Date de DĂŠbut de Garantie 12/08/2003
NumĂŠro de SĂŠrie du Moteur 10 DYPK 6016573
NumĂŠro de SĂŠrie de la BoĂŽte 20 LM23 0236381
OPB R002
NRE e2*98/14*0220*03
Informations gĂŠnĂŠrales
LIGNE DE PRODUIT C5
FINITION HAUTE MOYENNE
MOTEUR DIESEL TURBO DW10ATED SANS FAP
TRANSMISSION BVM5
COULEUR DE CAISSE EYL - PEINTURE GRIS ICELAND
TYPE D’HABILLAGE INTĂRIEUR VELOURS MOARA "FF"
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTĂRISTIQUES) BVM ML5C
CaractĂŠristiques vĂŠhicule
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
Alimentation moteur
DĂTECTEUR D’EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DĂPOLLUTION (MOTEUR) DEPOL CEE 2000 (MOTEUR)
REFROIDISSEMENT D’HUILE ECHANGEUR EAU/HUILE MOTEUR
MOTEUR REFROIDISSEMENT RADIATEUR EP:27 - 21 DM2 ALU BRASE
AUTODIAGNOSTIC EOBD SANS AUTO-DIAGNOSTIC "EOBD"
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT "EGR"
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLLUTION TECHNIQUE VEHICULE L4
FILTRE À PARTICULE SANS FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR 3 VITESSES 500W
VARIANTE ASSOCIĂE INJECTION SYSTEME INJECTION BOSCH
BOĂTIER PAPILLON (ADMISSION AIR MOTEUR) SANS BOITIER PAPILLON(ADMISSION AIR MOTEUR)
BoĂŽte de vitesses Transmission
TRANSMISSION BVM5
COUPLE RAPPORT CP 16 X 65
STYLE ROUE ROUE ALLIAGE SILVERSTONE 15 POUCES
EMBRAYAGE EMBR HYDRAULIQUE CDE ASSISTEE
JOINT COTĂ ROUE JOINT COTE ROUE DIAMETRE 20
JOINT COTĂ PONT JOINT COTE PONT JB3A
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 195X65X15 H
ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE BVM ML
Suspension Direction Freinage
ANTIPATINAGE SANS ANTIPATINAGE
COURSE MĂCANISME DE DIRECTION COURSE MECANISME DIRECTION 166
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION HYDRACTIVE 3
CONTRĂLE DYNAMIQUE DE STABILITĂ SANS SYSTEME ESP
Carrosserie Equipements
ENJOLIVEMENT LATĂRAL (ASPECT) PROTECTEURS LATERAUX COULEUR CAISSE
ENJOLIVEMENT LATĂRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE + CHROME
ENJOLIVEUR ROUE (STYLE) SANS ENJOLIVEUR DE ROUE
FEU D’ĂCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RABATTEMENT ELECTRIQUE COND + PAS + MARCHE AR
ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
ROUE DE SECOURS ROUE TOLE + PNEU STANDARD
ACCESSOIRES EXTĂRIEURS POIGNEES EXT + RETRO EXT COULEUR CAISSE
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
VITRE (TYPE) PARE-BRISE ATHERMIQUE
Equipement intĂŠrieur
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
RADIO-TĂLĂPHONE PRE-CONDITIONNEMENT RADIO TELEPHONE(ANTENNE+CABLE)
GRADUATION VITESSES GRADUATION EN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD PLANCHE DE BORD FACADE DECOR BOIS
GARNISSAGE VOLUME CHARGEMENT SANS TAPIS
RANGEMENT SOUS SIÈGE 1 TIROIR DE RANGEMENT SOUS SIEGE
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D’AUTORADIO CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) STORE AR MANUEL
REHAUSSE ASSISE AVANT PASSAGER REHAUSSE PASSAGER REGLAGE AVANT
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
RĂGLAGE ASSISE AVANT CONDUCTEUR SANS REGLAGE LOMBAIRE COND
ELĂMENTS DE GARNISSAGE INTĂRIEUR GARNISSAGE PIED CENTRAL + CUSTODE TISSU
ACCOUDOIR ASSISE AVANT ACCOUDOIRS AVANT CONDUCTEUR ET PASSAGER
COMPACT DISQUE MONTAGE COMPACT DISQUES
BOITE DE RANGEMENT SANS BOITE DE RANGEMENT
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
CD ROM POUR AUTO PC SANS CD ROM POUR AUTO-PC
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D’HUILE RECEPTEUR TEMPERATURE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE SANS REGLAGE PROJECTEUR
RĂCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS "RD3"
RĂFRIGĂRATION REFRIGERATION AUTOMATIQUE
RĂGULATEUR DE VITESSES SANS REGULATION VITESSE
RĂTROVISEUR INTĂRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
DĂTECTION D’OBSTACLE DETECTEUR OBSTACLE
AMPLI-ĂQUALISEUR SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT CUIR 4 BRAS
PACK AMBIANCE PACK AMBIANCE DECOR BOIS
ElectricitĂŠ
ALTERNATEUR ALTERNATEUR CLASSE 15
DĂMARREUR DEMARREUR CLASSE 5
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
FRĂQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
Marques d'ĂŠquipements
Divers
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
BOĂTIER SERVITUDE BSI LIGHT COM 2000
TRIANGLE DE PRĂSIGNALISATION SANS TRIANGLE PRESIGNALISATION
Fii FERICIT , caci NU ai Fap !
Restul, sper ca-ti dai seama la ce se refera, pt ca numai asa am gasit.Numai bine !
Ligne de produit C5
OPB R002
LIGNE DE PRODUIT C5
TRANSMISSION BVM5
Alimentation moteur
CARBURANT GAZOLE
TRANSMISSION BVM5
ElectricitĂŠ
Divers
inainte de a rasuci cheia in contact pana la poz accesorii, tine apasat butonul de langa turometru.
cu el apasat, pui cheia pe accesorii si il tii in continuare pana cand pe afisajul mic numararea ajunge la zero.
eliberezi butonul, dai cheia pe zero si apoi o pui din nou si o sa-ti afiseze noua valoare.
am luat azi urmatoarele pentru prima revizie mai consistenta :
1. ulei total 5 l,
2. filtru aer unix
3. filtru polen 4f
4. filtru ulei champion
5. pompa apa airtext
6. 2 role ipd
7. curea distributie gates
Totul la 675 ron. Ce parere aveti? am facut o alegere buna? pretul este bun? cam cat va costa manopera aproximativ?
Merci
1. ulei total 5 l,
2. filtru aer unix
3. filtru polen 4f
6. 2 role ipd
Merci
Depinde de foarte multi factori. Cum ar fi:pret, echipare, stare generala (optica+tehnica), motorizare(ar fi "parfum" sa coincida cu cea pe care o ai deja), etc.etc.etc.
Ar putea fi, in principiu, o treaba extrem de buna, cu conditia principala sa ai si un loc unde sa o "stochezi", fara sa deranjezi pe nimeni (daca toate celelalte sunt indeplinite, evident).
Am fost de ajutor?
Am fost de ajutor?
Total mesaje 187823
Total subiecte 18666
Total membri 11844
Cel mai nou membru profiart
