Istoric
rastelistu
- Localitate: ro bv
Re: Istoric
VF7RCRHRH76818968
Linie de produs C5 II
Nr. APV/PR 11126 CJ 1 0189
Data de Inceput de Garantie DDG 29.08.2007
Numar de Serie al Motorului 10 DYVD 4066623
Numar de Serie al Cutiei 20 MB17 0543969
OPB A03Y
NRE e2*2001/116*0306*04
Informatii generale
GENRE DE PRODUIT VEHICULE PARTICULIER
MARQUE COMMERCIALE, TYPE ORGANE CITROEN
LIGNE DE PRODUIT C5 II
SILHOUETTE BERLINE 5PTES
FINITION MOYENNE HAUTE
MOTEUR DIESEL TURBO DW10BTED4 FAP
TRANSMISSION BVM6
TYPE DE PEINTURE PEINTURE METALLISEE VERNIE
COULEUR DE CAISSE PEINTURE NOCCIOLA
TYPE D'HABILLAGE INTĂRIEUR TISSU SHOW SM
COULEUR DE GARNISSAGE "FY"
BOITE DE VITESSES (CARACTĂRISTIQUES) BVM ML6 CL
MOTEUR (TYPE) MOTEUR TYPE EW/DW
MONOGRAMME COMPLĂMENTAIRE, DIVERS SANS MONOGRAMME COMPLEMENTAIRE
MONOGRAMME C5
Caracteristici vehicul
DIRECTION DIRECTION ASSISTANCE NON VARIABLE
COUPLE TACHYMÈTRE CT 22 X NO
Alimentare motor
DĂTECTEUR D'EAU FILTRE À GAZOLE SANS DETECTEUR EAU FILTRE GASOIL
CARBURANT GAZOLE
DĂPOLLUTION (MOTEUR) DEPOLLUTION EURO 4(MOTEUR)
REFROIDISSEMENT D'HUILE ECHANGEUR EAU/HUILE MOTEUR
MOTEUR REFROIDISSEMENT RADIATEUR EP:32 - 21 DM2 ALU BRASE
RĂCHAUFFAGE CIRCUIT GAZ CARTER RECHAUFFAGE CIRCUIT GAZ CARTER
VARIATION PUISSANCE (MOTEUR) PUISSANCE STANDARD
DISPOSITIF (ANTIPOLLUTION) RECIRCULATION GAZ ECHAPPEMENT EGR
DĂPOLLUTION TECHNIQUE VĂHICULE DEPOLLUTION TECHNIQUE VEHICULE EURO 4
FILTRE À PARTICULE FILTRE A PARTICULES
VENTILATEUR 1 VENTILATEUR ELECTRONIQUE CDE INTEGREE 150W
VARIANTE ASSOCIĂE INJECTION SYSTEME INJECTION SIEMENS
FILTRE RĂSERVOIR FILTRE RESERVOIR INTERIEUR
Cutie de viteze Transmisie
TRANSMISSION BVM6
COUPLE RAPPORT CP 17 X 71
STYLE ROUE ROUE OLYMPOS 16 POUCES
EMBRAYAGE EMBRAYAGE HYDRAULIQUE
JOINT COTĂ ROUE JOINT COTE ROUE AC 3300I
JOINT COTĂ PONT JOINT COTE PONT AAR 3300I
PNEUMATIQUE (DIMENSIONS, TYPE) PNEU 215X55X16 W
ROUE (TYPE) MONTAGE ROUE ALLIAGE 3
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE SANS INDICATEUR PERTE PRESSION GONFLAGE
BOITE DE VITESSES TYPE ML6C
Suspensie Directie Franare
SUSPENSION SUSPENSION NORMALE
SUSPENSION ACTIVE SUSPENSION HYDRACTIVE 3
CONTRĂLE DYNAMIQUE DE STABILITĂ AVEC SYSTEME ESP
DIRECTION (FONCTIONNEMENT) DIRECTION ELECTRO HYDRAULIQUE ASSISTEE
Caroserie Echipamente
ENJOLIVEMENT LATĂRAL (ASPECT) PROTECTEURS LATERAUX COULEUR CAISSE
ENJOLIVEMENT LATĂRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE
ENJOLIVEUR ROUE (STYLE) TYPE OLYMPOS
FEU D'ĂCLAIRAGE DE SEUIL SANS FEU ECLAIRAGE DE SEUIL
COMPLĂMENT DE PROTECTION (SOUS MOTEUR) SANS PROTECTION COMPLEMENTAIRE SOUS MOTEUR
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETRO EXT SANS FONCTION COMPLEMENTAIRE
ESSUIE-VITRE AVANT ESSUIE-VITRE AV AVEC CAPTEUR DE PLUIE
ESSUIE-VITRE ARRIÈRE SANS ESSUIE-VITRE AR
ESSUIE-PROJECTEUR SANS ESSUIE-PROJECTEUR
OBTURATEUR FACE AVANT SANS OBTURATEUR FACE AV
VITRE VOLET ARRIÈRE VITRE VOLET AR FIXE
PORTE-BAGAGES MONTAGE SANS PORTE BAGAGES
PROJECTEUR ANTIBROUILLARD PROJECTEURS ANTI BROUILLARD
TOIT OUVRANT TOIT FIXE
ENJOLIVEMENT PARE-CHOCS BANDEAU DE PARE-CHOCS COULEUR CAISSE
VITRE (TYPE) PARE-BRISE ATHERMIQUE
PACK LOOK EXTĂRIEUR PACK LOOK EXTERIEUR COULEUR CAISSE
Echipament de interior
ALARME ANTIVOL SANS ALARME ANTIVOL
ACCOUDOIR ASSISE ARRIÈRE AVEC ACCOUDOIR AR
CLIMAT (TEMPĂRATURE AMBIANTE) PAYS FROIDS
GRADUATION VITESSES GRADUATION EN KM/H
COTĂ DE CONDUITE (POSTE DE CONDUITE) CONDUITE A GAUCHE
CHAUFFAGE ADDITIONNEL SANS CHAUFFAGE ADDITIONNEL
EQUIPEMENT PLANCHE DE BORD DECOR CUBIC MINIMAILLE
GARNISSAGE VOLUME CHARGEMENT SANS TAPIS
RANGEMENT SOUS SIÈGE 2 TIROIRS DE RANGEMENT SOUS SIEGE
GARNISSAGE DE PORTE DECOR CUBIC MINIMAILLE
HAUT-PARLEUR 4 HP AV (2 TW + 2 AV) + 2 HP AR
COMMANDE D'AUTORADIO CDE AUTO-RADIO A DISTANCE
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) SANS STORE AR
REHAUSSE ASSISE AVANT PASSAGER SANS REHAUSSE PASSAGER
COMMANDE ASSISE AVANT CONDUCTEUR CDE SIEGE AV MANUEL CONDUCTEUR
COMMANDE ASSISE AVANT PASSAGER CDE SIEGE AV MANUEL PASSAGER
ELĂMENTS DE GARNISSAGE INTĂRIEUR GARNISSAGE PIED CENTRAL TISSU + CUSTODE POLYPRO
ACCOUDOIR ASSISE AVANT ACCOUDOIRS AVANT CONDUCTEUR ET PASSAGER
COMPACT DISQUE SANS MONTAGE COMPACT DISQUE
SYSTÈME DE NAVIGATION SANS SYSTEME NAVIGATION
LAMPES DE PROJECTEURS LAMPE HALOGENE
LÈVE-VITRE ARRIÈRE LEVE-VITRE AR ELECT CDE SEQUENT + CONDAMNAT
LECTEUR D'INFORMATIONS ROUTIÈRES SANS SURVEILLANCE TRAJECTOIRE LATERALE
AFFICHEUR AFFICHEUR (RADIO+MONTRE+ET OU T°,CD)
MIROIR DE COURTOISIE CONDUCTEUR+PASSAGER OCCULTABLE AVEC ECLAIRAGE
INDICATEUR D'HUILE RECEPTEUR TEMPERATURE
NAPPE CHAUFFANTE SIEGE NON CHAUFFANT
ECLAIRAGE BAS HABITACLE SANS ECLAIRAGE BAS HABITACLE
PROTECTION PASSAGER ARRIÈRE SANS PROTECTION PASSAGER AR
NEUTRALISATION COUSSIN GONFLABLE NEUTRALISATION MANUELLE COUSSIN GONFLABLE
PROJECTEUR CORRECTEUR ASSIETTE SANS REGLAGE PROJECTEUR
RĂCEPTEUR RADIO SYSTEME AUDIO COMPACT DISC RDS RD4/MP3
RĂFRIGĂRATION REFRIGERATION AUTOMATIQUE
RĂGULATEUR DE VITESSES REGULATEUR ET LIMITEUR VITESSE
RĂTROVISEUR INTĂRIEUR RETROVISEUR INT JOUR - NUIT
RĂGULATION CLIMATISATION / TEMPĂRATURE REFRIGERATION AUTOMATIQUE BI-ZONE
RANGEMENT VOLUME CHARGEMENT SANS FILET DANS COFFRE
TUNER-RADIO BI TUNER RADIO
DĂTECTION D'OBSTACLE SANS DETECTEUR OBSTACLE
AMPLI-ĂQUALISEUR SANS AMPLI EQUALISEUR
COMMANDE VERROUILLAGE VERROUILLAGE SIMPLE CONDAMNATION
VOLANT VOLANT MOUSSE 4 BRAS
PACK RADIO / INFORMATION / COMMUNICATION RM4
MAINTIEN LOMBAIRE ASSISE (FONCTIONNEMENT) SANS MAINTIEN LOMBAIRE
Electricitate
ALTERNATEUR ALTERNATEUR CLASSE 18
BATTERIE BATTERIE L3 450
DĂMARREUR DEMARREUR CLASSE 6+
ECLAIREMENT PARTICULIER ALLUMAGE AUTOMATIQUE FEUX
FRĂQUENCE RADIO FREQUENCE RADIO EUROPE OCCIDENTALE
Marci de echipamente
Diverse
CRITÈRE VARIANCE, CLIENTÈLE CONCEPTION STANDARD
ATMOSPHÈRE ATMOSPHERE NORMALE
COTĂ CIRCULATION CIRCULATION A DROITE
TRIANGLE DE PRĂSIGNALISATION CONDITIONNEMENT TRIANGLE PRESIGNALISATION
OPB A03Y
Informatii generale
TRANSMISSION BVM6
MONOGRAMME C5
Alimentare motor
CARBURANT GAZOLE
TRANSMISSION BVM6
Electricitate
Diverse
rastelistu
- Localitate: ro bv
vf7rcrhrh76755241
Nr. APV/PR 10760 CJ 1 0209
Data de Inceput de Garantie DDG 07.08.2006
Numar de Serie al Motorului 10 DYVD 4024729
Numar de Serie al Cutiei 20 MB17 0431688
OPB A03Y
Informatii generale
FINITION HAUTE MOYENNE PLUS
TRANSMISSION BVM6
COULEUR DE CAISSE PEINTURE GRIS FER
TYPE D'HABILLAGE INTĂRIEUR VELOURS MOARA "FF"
MONOGRAMME C5
Alimentare motor
CARBURANT GAZOLE
RĂCHAUFFAGE CIRCUIT GAZ CARTER SANS RECHAUFFAGE CIRCUIT GAZ CARTER
TRANSMISSION BVM6
STYLE ROUE ROUE HUNGARO 16 POUCES
ROUE (TYPE) MONTAGE ROUE ALLIAGE 1
INDICATEUR DE PERTE DE PRESSION DE GONFLAGE INDICATEUR PERTE PRESSION GONFLAGE
ENJOLIVEMENT LATĂRAL (DIMENSION) PROTECTEURS LATERAUX PLASTIQUE + CHROME
ENJOLIVEUR ROUE (STYLE) TYPE HUNGARO
FEU D'ĂCLAIRAGE DE SEUIL FEU ECLAIRAGE DE SEUIL
FONCTION COMPLĂMENTAIRE RĂTROVISEUR EXTĂRIEUR RETRO EXT RABATTABLE ELECTRIQUE SANS MEMOIRE
CLIMAT (TEMPĂRATURE AMBIANTE) PAYS TEMPERES
EQUIPEMENT PLANCHE DE BORD DECOR LAQUE NOIRE
RANGEMENT SOUS SIÈGE 1 TIROIR DE RANGEMENT SOUS SIEGE
GARNISSAGE DE PORTE DECOR LAQUE NOIRE
ISOLATION (RIDEAU, PARE-SOLEIL LATĂRAL, TOIT OUVRANT) STORE AR MANUEL
COMPACT DISQUE MONTAGE COMPACT DISQUES
ECLAIRAGE BAS HABITACLE ECLAIRAGE CAVE A PIEDS COND + PASS AV
RĂTROVISEUR INTĂRIEUR RETROVISEUR INT JOUR-NUIT ELECTROCHROME
RANGEMENT VOLUME CHARGEMENT AVEC FILET DANS COFFRE
TUNER-RADIO MONO TUNER RADIO
DĂTECTION D'OBSTACLE DETECTEUR OBSTACLE RADAR AVANT ARRIERE
PACK RADIO / INFORMATION / COMMUNICATION RD4
Electricitate
Diverse
OPB A03Y
Informatii generale
TRANSMISSION BVM6
MONOGRAMME C5
Alimentare motor
CARBURANT GAZOLE
TRANSMISSION BVM6
Electricitate
Diverse
- urzica
- Localitate: Medgidia
Re: Istoric
rastelistu scrie:VF7RCRHRH76818968
Multumesc pentru informatie dar ma interesa mai mult istoricul de repararii care au fost facute si inregistrate macar in perioada garantiei.
OPB A03Y
Informatii generale
TRANSMISSION BVM6
MONOGRAMME C5
Alimentare motor
CARBURANT GAZOLE
TRANSMISSION BVM6
Electricitate
Diverse
