BUNA ZIUA, POSED UN C3 1.4 I DIN 2003 CU CUTIE AUTOMATA 4 TREPTE. PROBLEMA ESTE CA ATUNCI CAND MOTORUL ESTE LA INCEPUT DE TRASEU ADICA CAND ESTE MAI RECE, LA TRECEREA DIN TREAPTA 3 IN TREPTA 4 SE BLOCHEAZA IN TREAPTA 3. "D" ADICA DRIVE SE TRENSFORMA INTRO "-" IMI DA SEMNAL ACUSTIC DE EROARE SI MI SE APRIND MARTORII DE SPORT SI ZAPADA. DACA O SCOT PE MANUAL NU REACTIONEAZA DE NICI UN FEL NU VREA SA SCHIMBE VITEZELE DELOC. AM CONSTATAT CA RAMANE BLOCATA IN VITEZA 3, PENTRU CA A INCETINIT SI AM PLECAT DIN NOU, ACESTA PLEACA SUBTURATA SI CAND AJUNG LA VITEZA IN CARE NORMAL SE SCHIMBA IN TREAPTA 4 ACESTA RAMANE TURATA SI NU SCHIMBA. AM OPRIT MASINA PE DREAPTA, AM OPRIT MOTORUL, L-AM REPORNIT AM PLECAT DIN NOU, SI NU IMI MAI APARE PROBLEMA PANA DE EXEMPLU A DOUA ZI CAND PLEC CU EA DIN NOU LA DRUM.
- AM FOST LA ATS BUCURESTI SI MI-AU SPUS SA SCHIMB BATERIA CA NU MAI ARE AMPERAJUL NECESAR SI CA CUTIA AUTOMATA ISI IA NECESARUL DE FUNCTIONARE DIN BATERIE. AM SCHIMBAT BATERIA SI ACESTA PROBLEMA REAPARE.
- AM FOST LA UN SERVICE DIN CONSTANTA ACESTIA MI-AU REFACUT NIVELUL LA ULEI LA CUTIE, TOT DEGEABA
- MI-A MAI SPUS CINEVA CA TREBUIE "RESOFTAT" CALCULATORUL
ASTEPT CEVA SFATURI CA NU IMI POT EXPLICA CE POATE AVEA SI DE CE SE INTAMPLA DOAR LA INCEPUT DE TRASEU, DUPA O PERIOADA DE MERS NU MAI APARE PROBLEMA PE TOT RESTUL ZILEI.
PROBLEME CUTIE AUTOMATA C3!!!!!!!!!!!!!!!! HELP!!!!!!!!!!!!!
renunta la CAPS te rog!!!
iliescu sorin
- Localitate: Constanta
- Masina: C 5 Break 2,0 . hidramata, an 2004
- 2: CX 2,0 Break. an 1989
- 3: Xsara 1,4 i , an 2002
Cutie hidramata
Cum intri in Lazu pe dreapta visavis de service Peugeot pe dreapta este o curte cu un mic service + magazin piese auto. La service ( fara firma ) il cauti pe Mircea .
Re: Cutie hidramata
iliescu sorin scrie:Cum intri in Lazu pe dreapta visavis de service Peugeot pe dreapta este o curte cu un mic service + magazin piese auto. La service ( fara firma ) il cauti pe Mircea .
Ok, mersi mult!!! O sa il caut neaparat!!! Sper sa imi fie de ajutor ca nu stiu ce sa-i mai fac!!!
iliescu sorin
C3
Eu la el am facut o cutie zf de A8 , care nu primea nici o comanda pe D si una de XM 3L V6 .
Total mesaje 187829
Cel mai nou membru RyaVikuain
