Model cutie de viteze Citroen Xsara Picasso 1.6HDi 92 CP
Alexandru`
Mesajde Alexandru` » Mie 10-Iun-2009 09:38
Stie cineva ce cutie de viteze este montata pe Xsara Picasso 1.6 HDi 92CP? Ma intereseaza pentru a afla corespondenta intre viteza si turatie, eu fiind in rodaj.
Am gasit niste grafice pe internet, dar nu sunt sigur ca pe Xsara Picasso e montata aceeasi cutie ca pe Peugeot 207.
Multumesc.
Alexandru`
Mesajde Alexandru` » Mar 16-Iun-2009 10:20
Pe varianta cu motor 2.0 HDi cutia se pare ca este: BE4-5L.
Am citat mai jos ce am gasit pe un forum ca fiind o identificare dupa VIN
Vehicle family XSARA PICASSO
AS RPO No 08555 FV 2 0237
Guarantee Start Date 26/05/2000
Engine serial number 10 DYBH 3003560
Gearbox serial number 20 DL64 1847894
OPB P000
NRE e2*98/14*0153*00
General information
Product type CAR
Commercial marque/Component type CITROEN
Silhouette FAMILY SALOON
Trim level LOW / HIGH
Engine TURBO DIESEL DW10TD
Transmission BVM5
Paint type METALLIC PAINTWORK
Body colour QUARTZ GREY PAINT
Interior trim type "HC" DALICAN VELOUR
Upholstery colour "FZ"
Gearbox (Characteristics) BE4-5L MANUAL GEARBOX
Engine (Type) EW/DW
Vehicle characteristics
Steering POWER STEERING
Speedometer drive TACHO TORQUE 22X18
Fuel supply-Engine
Diesel filter water detector WITHOUT DIESEL FILTER WATER DETECTOR
Cylinder block (Material) CRANKCASE CAST IRON
Fuel DIESEL FUEL
Emissions standard (engine) EEC 95 DEPOLL (ENGINE)
Engine (Type) EW/DW
Oil cooler MNTG WATER/OIL EXCHANGER ON ENGINE
Cooling motor RADIATOR EP:31 (CU)
Crankcase gas circuit heating W/O HEATER CASING GAS CIRCUIT
Power variation (Engine) STANDARD POWER
EOBD Self-Diagnosis System WITHOUT "EOBD" AUTO-DIAGNOSTIC
Device (Antipollution) "EGR" EXHAUST GAS RECYCLING
Vehicle Technical Depollution L3 VEHICLE TECHNICAL DEPOLLUTION
Particle filter WITHOUT PARTICLE FILTER
Fan 1 3-SPEED 400W FAN WITHOUT DYNA FLAPS
Injection associated variant MOUNTING BOSCH
Gearbox-Driveshafts
Transmission BVM5
Final drive ratio REAR AXLE HYPOID GEARSET 19 X 72
Wheel style 15 INCH STEEL WHEEL
Clutch CABLE CLUTCH TAKING UP OF PLAY
Seal, wheel end WHEEL-SIDE JOINT DIAM 17 5
Seal, differential end AXLE-SIDE JOINT JB2A
Differential (Gearbox) SUPERIOR GEARBOX DIFF
Tyre (Size, Type) 185X65X15 H TYRES
Wheel (Type) STEEL WHEELS
Gearbox Type GEARBOX BE4R
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
Rear anti-roll bar REAR ANTI-ROLL BAR DIAM 21
Front anti-roll bar FRONT ANTI-ROLL BAR DIAM 21
Suspension NORMAL SUSPENSION
Bodywork-Exterior fittings
Towbar WITHOUT TOWBAR
Wheel embellisher (Style) 15 INCH 7-SPOKE HENDAYE STYLE
Additional shield (under engine) W/O ENGINE UNDERSHELDING
Front panel blank LARGE BLANK (SMALL AIR INTAKE)
Luggage rack WITHOUT ROOF BARS
Front foglamp FRONT FOG LIGHTS
Exterior accessories NEUTRAL EXT HANDLES + SIDE STRIPS + DOOR MIRRORS
Sun roof FIXED ROOF
Bumper trim DYED BUMPER STRIP
Glass (Appearance) TINTED
Interior fittings
Speed graduations GRADUATION KMS/H
Console WITHOUT CONSOLE
Driving position LEFT HAND DRIVE
Additional heating WITHOUT ADDITIONNAL HEATING
Loudspeaker ASSEMBLY WITH 4 SPEAKERS + 2 TWEETERS
Radio controls REMOTE RADIO CONTROL
Front seat armrest DRIVER SEAT ARMREST
Compact Disc WITHOUT COMPACT DISC
Satellite Navigation System WITHOUT NAVIGATION SYSTEM
Rear window lift MAN CTRL REAR WINDOW LIFTER
Front lateral airbag DOUBLE FRONT LATERAL AIRBAG
Rear passenger protection W/O RR PASSENGER PROTECTION
Airbag Deactivation MANUAL AIRBAG DEACTIVATION
Radio receiver "RB2" RDS CASSETTE AUDIO SYSTEM
Air conditioning AUTOMATIC AIR CONDITIONING
Cruise control WITHOUT SPEED CONTROL
Electrical
Alternator ALTERNATOR 150 AMP
Battery BATTERY L2 400
Starter motor STARTER MOTOR CL 5
Special lighting WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
Country type (I)
Special specification STANDARD
Atmospheric conditions NORMAL ATMOSPHERE
    Total subiecte 18658
