verificare serie sasiu
Stana Alexandru
Masina: CITROEN DS4
2: Citroen c4
Re: verificare serie sasiu
Mesajde Stana Alexandru » Joi 16-Mai-2019 11:17
Sebid scrie:Rog si pentru mine, se poate VF7RD5FV8AL501309 ?
Multumesc anticipat :)
Caracteristicile vehiculului
Linie de produs C5 (X7)
Nr. APV/PR 12049 CJ 1 0390
Data de Inceput de Garantie DDG 30.11.2009
Numar de Serie al Motorului 10 FJAY 0671426
OPB H004
NRE e2*2001/116*0360*08
P4A 9665953399
Informatii generale
GEN DE PRODUS VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU CITROEN
LINIE DE PRODUS C5 (X7)
TIP CAROSERIE BERLINA 4 USI
NIVEL DE ECHIPARE SUPERIOARA JOASA PLUS
MOTOR INJECTIE EP6CDT
TRANSMISIE CUTIE DE VITEZE MANUALA6
TIP DE VOPSEA VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI EYP - VOPSEA GRI FULMINATOR
TIP ECHIPARE INTERIOARA PIELE CLAUDIA MISTRAL L019 "QR"
CULOARE GARNISAJ "FX"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA MCC
MOTOR (TIP) MOTOR TIP EP
MONOGRAMA COMPLEMENTARA, DIVERSE EXCLUSIV
MONOGRAMA C5
Caracteristici vehicul
DIRECTIE MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU FARA C T
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT FARA PLUMB 95 CALITATE A/B/E/E+
DEPOLUARE (MOTOR) DEPOLUARE MOTOR SUPERIOARA L6 EURO 5
ESAPAMENT TOBA DE ESAPAMENT LONGITUDINALA
CATALIZATOR CATALIZATOR IMPREGNAT SUB 10PPM
INCALZIRE CIRCUIT GAZE CARTER SISTEM DE INCALZIRE A CIRCUITULUI DE GAZE DIN CARTER
DISPOZITIV (ANTIPOLUARE) FARA DISPOZITIV ANTIPOLUARE
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO5
FILTRU DE PARTICULE FARA FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU DOUA TURATII 140W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE BOSCH
FITRU DE REZERVOR FILTRU REZERVOR INTERIOR
STOP AND START FARA SISTEM STOP AND START
Cutie de viteze Transmisie
CUPLU RAPORT RAPORT PUNTE 17 X 71
STIL ROATA (JANTA) ROATA BALTICA 17 INCI
AMBREIAJ AMBREIAJ HIDRAULIC
DIFERENTIAL (CUTIE) DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI ECHIPARE PNEU 17 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 225/55 R17 97W FARA INTARIRE
ROATA (TIP) ECHIPARE ROATA CU JANTA DIN ALIAJ 1
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP CUTIE DE VITEZE MANUALA MC
Suspensie Directie Franare
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 20,5
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 24,5
CURSA MECANISMULUI DE DIRECTIE CURSA MECANISM DE DIRECTIE 180
SUSPENSIE SUSPENSIE NORMALA
SUSPENSIE ACTIVA SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII CU SISTEM ESP
DIRECTIE (FUNCTIONARE) DIRECTIE ASISTATA ELECTROHIDRAULIC
Caroserie Echipamente
ORNAMENT LATERAL (ASPECT) ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) CAPAC CENTRAL DE ROATA BALTICA 17 INCI
IESIRE DE ESAPAMENT IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
SUPLIMENT DE PROTECTIE (SUB MOTOR) FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC
STERGATOR PARBRIZ MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR FARA MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA
ROATA DE REZERVA ROATA JANTA TABLA + PNEU STANDARD
RETROVIZOR EXTERIOR (ASPECT OGLINDA) OGLINDA DE RETROVIZOR EXTERIOR CROMATA ELECTROCHIMIC
ACCESORII EXTERIOARE MANER EXTERIOR ASPECT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON ACOPERIS FIX
ORNAMENT DE BARA DE PROTECTIE ORNAMENT CENTRAL SPATE CROMAT
GEAM (ASPECT) GEAM FUMURIU
GEAM (TIP) PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
Echipament de interior
ALARMA ANTIFURT FARA ALARMA ANTIFURT
COTIERA DE SCAUN SPATE CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA TEMPERATA
GRADARE VITEZE GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) VOLAN PE STANGA
INCALZIRE ADITIONALA FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD DECORATIUNE METAL PALEA
LUMINI INTERIOARE DIVERSE ILUMINAT DE AMBIANTA SOFT
GARNISAJ SPATIU DE INCARCARE FARA COVORAS
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA DECORATIUNE NEGRU ARGINT STRALUCITOR
DIFUZOR 4 DIFUZOARE FATA (2 TWEETERE + 2 FATA) + 2 DIFUZOARE SPATE
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) TRANSPERANT MANUAL SPATE
INALTARE SCAUN DE PASAGER FATA MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) COTIERA MANUALA FATA
CD FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR LAMPA CU HALOGEN
ACTIONARE GEAM SPATE MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ AFISAJ DEV
OGLINDA DE PARASOLAR OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN SCAUN FARA INCALZIRE
AIRBAG LATERAL FATA AIRBAG LATERAL FATA ZONA TORACE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU ILUMINAT ZONA PICIOARE CONDUCATOR + PASAGER FATA
PROTECTIE PASAGER SPATE FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA REGLARE AUTOMATA A PROIECTOARELOR
RECEPTOR RADIO SISTEM RADIONAVIGATIE CU MEMORIE FLASH "RNEG"
REFRIGERARE SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE FARA PLASA IN PORTBAGAJ
TUNER-RADIO TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTARE GARNITURA MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR FARA AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO 1 PRIZA RCA AUDIO
MODUL TELEMATIC FARA MODUL TELEMATIC
Electricitate
ALTERNATOR ALTERNATOR CLASA 15
BATERIE BATERIE L3 500
DEMAROR DEMAROR CLASA 3
ILUMINAT DEOSEBIT APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
Marci de echipamente
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE STANDARD
ATMOSFERA ATMOSFERA NORMALA
ETICHETA FARA
PARTEA DE CIRCULATIE CIRCULARE PE DREAPTA
ECHIPAMENT DE PRIM AJUTOR FARA ECHIPARE DE REZERVA
RULARE DRUM CORECT
zoly
Localitate: lugoj
Mesajde zoly » Mar 19-Noi-2019 15:43
ma ajutatisi pe mine va rog cu detalii despre C5 Turer Exclusiv 2010 HDI. cu seria
VF7RWRHF8AL524805. Mulțumesc!
Xantia 2.0 HDI 80 Kw 1999
C5 Turer Exclusiv 2010 Hidroactiva
Yamaha TDM 850
kady28
Mesajde kady28 » Vin 22-Noi-2019 23:01
zoly scrie:Salut,
Nr. APV/PR 12184 CJ 1 0538
Data de Inceput de Garantie DDG 15.10.2010
Numar de Serie al Motorului 10 DYXH 4077884
OPB HBDM
NRE e2*2001/116*0360*09
P4A 9666041099
Informatii generale
TIP CAROSERIE BREAK 5 USI
MOTOR DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
CULOAREA CAROSERIEI KTV - VOPSEA NEGRU PERLA NERA
TIP ECHIPARE INTERIOARA CAPITONAJ PIELE ST CYR + PIELE "XS"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6 CL
MOTOR (TIP) MOTOR TIP EW/DW
MONOGRAMA C5
Alimentare motor
CARBURANT MOTORINA CALITATE DA/DE/DE+
CILINDREE 2000 CM3
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR"
FILTRU DE PARTICULE CU FILTRU DE PARTICULE
VENTILATOR 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 150W
VARIANTA SOCIATA INJECTIE SISTEM DE INJECTIE DELPHI
CUPLU RAPORT RAPORT PUNTE 16 X 69
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE FARA INDICATOR PENTRU PIERDERE PRESIUNE DIN PNEURI
CUTIE DE VITEZE TIP ML6C
BARA ANTIRULIU SPATE BARA ANTIRULIU SPATE DIAMETRU 21
STERGATOR DE LUNETA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR MECANISM DE STERGERE PROIECTOR
PORTBAGAJ MONTARE CU BARE DE PORTBAGAJ LONGITUDINALE
ORNAMENT DE BARA DE PROTECTIE BANDOU DE BARA DE PROTECTIE CULOAREA CAROSERIEI
CLIMA (TEMPERATURA AMBIANTA) TARI CU CLIMA RECE
GARNISAJ SPATIU DE INCARCARE COVORAS + BAGHETA SI MANER CROMAT
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) FARA TRANSPERANT SPATE
BECURI DE PROIECTOR LAMPA CU DESCARCARE
AFISAJ AFISAJ DEV
FOLIE INCALZIRE SCAUN SCAUN CU INCALZIRE
PROTECTIE PASAGER SPATE CU PROTECTIE PASAGER SPATE
PROIECTOR DIRECTIONAL CU PROIECTOR DIRECTIONAL
ADAPTARE GARNITURA MANER MANETA DE VITEZE DIN TEP + BURDUF DE PROTECTIE DIN PIELE
Electricitate
ALTERNATOR ALTERNATOR CLASA 18
BATERIE BATERIE L3 450
DEMAROR DEMAROR CLASA 6+
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE DEPOLUARE SUPERIOARA
ETICHETA FARA
RULARE DRUM CORECT
Palici Dan
Localitate: Barlad
Masina: Citroen C5 III 2.0 HDI 136 cai 2009
2: Audi A4 B7
3: Audi A4 B7
Mesajde Palici Dan » Mie 11-Dec-2019 13:52
Buna ziua,
Ma ajutati si pe mine va rog cu detalii despre C5 III Exclusiv 2009 HDI. cu seria
VF7RDRHRJ9L508656. Mulțumesc mult!
iulian.arg
Localitate: Iasi
Mesajde iulian.arg » Vin 13-Dec-2019 19:36
Linie de produs --> C5 (X7)
Nr. APV/PR --> 11762 CJ 1 0451
Data de Inceput de Garantie DDG --> 09.02.2009
Numar de Serie al Motorului --> 10 DYXG 4005073
OPB --> H4DA
NRE --> e2*2001/116*0360*04
P4A --> 9658463599
Informatii generale
GEN DE PRODUS --> VEHICUL PARTICULAR
MARCA COMERCIALA, TIP SUBANSAMBLU --> CITROEN
LINIE DE PRODUS --> C5 (X7)
TIP CAROSERIE --> BERLINA 4 USI
NIVEL DE ECHIPARE --> SUPERIOARA JOASA PLUS
MOTOR --> DIESEL TURBO DW10BTED4 FILTRU DE PARTICULE
TRANSMISIE --> CUTIE DE VITEZE AUTOMATA 6 TREPTE
TIP DE VOPSEA --> VOPSEA METALIZATA LACUITA
CULOAREA CAROSERIEI --> KGM - VOPSEA SUROIT
TIP ECHIPARE INTERIOARA --> PIELE CLAUDIA MATINAL L019 "XT"
CULOARE GARNISAJ --> "FC"
CUTIE DE VITEZE (CARACTERISTICI) --> CUTIE DE VITEZE AUTOMATA AM6C1
MOTOR (TIP) --> MOTOR TIP EW/DW
MONOGRAMA COMPLEMENTARA, DIVERSE --> EXCLUSIV
MONOGRAMA --> C5
DIRECTIE --> MECANISM DE DIRECTIE ASISTATA CARE NU ESTE VARIABILA
CUPLU DE TAHOMETRU --> FARA C T
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA --> FARA SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CARBURANT --> MOTORINA CALITATE DA/DE/DE+
DEPOLUARE (MOTOR) --> DEPOLUARE MOTOR EURO 4
ESAPAMENT --> TOBA DE ESAPAMENT LONGITUDINALA
CILINDREE --> 2000 CM3
CATALIZATOR --> CATALIZATOR IMPREGNAT SUB 10PPM
INCALZIRE CIRCUIT GAZE CARTER --> FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
VARIATE DE PUTERE (MOTOR) --> PUTERE 100 KW 320 NM
DISPOZITIV (ANTIPOLUARE) --> RECIRCULARE GAZE DE ESAPAMENT "EGR"
DEPOLUARE TEHNICA VEHICUL --> DEPOLUARE TEHNICA VEHICUL EURO4
FILTRU DE PARTICULE --> CU FILTRU DE PARTICULE
VENTILATOR --> 1 VENTILATOR ELECTRONIC CU COMANDA INTEGRATA 160W
VARIANTA SOCIATA INJECTIE --> SISTEM DE INJECTIE DELPHI
FITRU DE REZERVOR --> FILTRU REZERVOR INTERIOR
STOP AND START --> FARA SISTEM STOP AND START
CUPLU RAPORT --> RAPORT PUNTE 15 X 53
STIL ROATA (JANTA) --> ROATA ATLANTIQUE 18 INCI
AMBREIAJ --> FARA AMBREIAJ
DIFERENTIAL (CUTIE) --> DIFERENTIAL 86
JANTA / PNEU DIMENSIUNI --> ECHIPARE CU PNEURI DE 18 INCI
PNEURI (DIMENSIUNI, TIP) --> PNEU 245/45 R18 100W RANFORSAT
ROATA (TIP) --> MONTARE ROATA ALIAJ 3
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE --> INDICATOR PIERDERE PRESIUNE PNEURI
CUTIE DE VITEZE TIP --> CUTIE DE VITEZE AUTOMATA AM6
BARA ANTIRULIU SPATE --> BARA ANTIRULIU SPATE DIAMETRU 20,5
ANTIRULIU FATA --> BARA ANTIRULIU FATA DIAMETRU 24,5
CURSA MECANISMULUI DE DIRECTIE --> CURSA MECANISM DE DIRECTIE 180
SUSPENSIE --> SUSPENSIE NORMALA
SUSPENSIE ACTIVA --> SUSPENSIE ACTIVA CU REGLARE MANUALA
SUSPENSIE (TIP ARHITECTURA) --> SUSPENSIE HIDRAULICA
CONTROL DINAMIC AL STABILITATII --> CU SISTEM ESP
DIRECTIE (FUNCTIONARE) --> DIRECTIE ASISTATA ELECTROHIDRAULIC
ORNAMENT LATERAL (ASPECT) --> ELEMENTE DE PROTECTIE LATERALE CROMATE
ORNAMENT LATERAL (DIMENSIUNE) --> ELEMENTE DE PROTECTIE LATERALE DIN MATERIAL PLASTIC + CROMATE
ORNAMENT DE ROATA (STIL) --> CAPAC CENTRAL DE ROATA ATLANTIC 18 INCI
IESIRE DE ESAPAMENT --> IESIRE TEAVA DE ESAPAMENT CARE NU ESTE CROMATA
LUMINA DE PRAG --> BLOC OPTIC PENTRU ILUMINAT PRAG FATA + SPATE
SUPLIMENT DE PROTECTIE (SUB MOTOR) --> FARA PROTECTIE SUPLIMENTARA SUB MOTOR
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR --> RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
STERGATOR PARBRIZ --> MECANISM DE STERGERE PARBRIZ CU INTERMITENTA CADENTA AUTOMATA 16 CADENTE
STERGATOR DE LUNETA --> FARA MECANISM DE STERGERE LUNETA
STERGATOR DE PROIECTOR --> MECANISM DE STERGERE PROIECTOR
GEAM DE PAVILION --> FARA ELEMENT VITRAT DE PAVILION
BARA DE PROTECTIE --> BARA DE PROTECTIE IN CULOAREA CAROSERIEI + ELEMENT DE PROTECTIE CROMAT + ORNAMENT GLILA CROMAT
PORTBAGAJ --> MONTARE FARA USA SUPORT DE BAGAJE
PROIECTOR ANTICEATA --> PROIECTOARE ANTI-CEATA
ROATA DE REZERVA --> FARA ROATA DE REZERVA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) --> OGLINDA DE RETROVIZOR EXTERIOR CROMATA ELECTROCHIMIC
ACCESORII EXTERIOARE --> MANER EXTERIOR ASPECT CROMAT
RETROVIZOR EXTERIOR (RAZA ZONA CONDUCATOR) --> OGLINDA BOMBATA LA RETROVIZORUL EXTERIOR
TRAPA DE PLAFON --> TRAPA DE PLAFON CU COMANDA ASISTATA SECVENTIALA + SISTEM ANTIPRINDERE
ORNAMENT DE BARA DE PROTECTIE --> ORNAMENT CENTRAL SPATE CROMAT
GEAM (ASPECT) --> FUMURIU + FUMURIU INCHIS
GEAM (TIP) --> PARBRIZ STRATIFICAT CU IZOLARE FONICA + SPATE SECURIZAT
ALARMA ANTIFURT --> ALARMA PENTRU VOLUM + PERMETRU - STANDARD
COTIERA DE SCAUN SPATE --> CU COTIERA SPATE
CLIMA (TEMPERATURA AMBIANTA) --> TARI CU CLIMA TEMPERATA
GRADARE VITEZE --> GRADATIE IN KM/H
PARTE CONDUCERE (POST DE CONDUCERE) --> VOLAN PE STANGA
INCALZIRE ADITIONALA --> FARA SISTEM DE INCALZIRE SUPLIMENTAR
ECHIPAMENT PLANSA DE BORD --> DECORATIUNE METAL PALEA
LUMINI INTERIOARE DIVERSE --> ILUMINAT DE AMBIANTA
GARNISAJ SPATIU DE INCARCARE --> FARA COVORAS
TABLOU DE BORD (CARACTERISTICI) --> GRADATIE 260 KM/H 160 M/H MATRICE COLOR
CAPITONAJ DE USA --> DECORATIUNE ANODIZATA SOFT
DIFUZOR --> 4 DIFUZOARE FATA (2 TWEETERE + 2 DIFUZOARE) + 5 DIFUZOARE SPATE (2 TWEETERE + 2 DIFUZOARE + 1 SUBWOOFER)
IZOLATIE (TRANSPERANT, PARASOLAR LATERAL, TRAPA DE PLAFON) --> TRANSPERANT MANUAL SPATE
INALTARE SCAUN DE PASAGER FATA --> MECANISM DE INALTARE SCAUN PASAGER CU REGLARE FATA SPATE
COMANDA DE SCAUN FATA DE CONDUCATOR --> COMANDA SCAUN CU MEMORIE CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER --> COMANDA ELECTRICA SCAUN PASAGER FATA
COTIERA DE SCAUN FATA (FUNCTIONARE) --> COTIERA MANUALA FATA
CD --> FARA MONTARE COMPACT DISC
SISTEM DE NAVIGATIE --> CU SISTEM DE NAVIGATIE CU ECRAN COLOR
BECURI DE PROIECTOR --> LAMPA CU DESCARCARE
ACTIONARE GEAM SPATE --> MECANISM DE ACTIONARE ELECTRICA GEAM SPATE CU COMANDA SECVENTIALA + BLOCARE
CITITOR DE INFORMATII RUTIERE --> FARA SISTEM DE SUPRAVEGHERE TRAIECTORIE LATERALA
AFISAJ --> AFISAJ (NAVIGATIE+VIDEO+RADIO+CEAS,T°,CD)
OGLINDA DE PARASOLAR --> OGLINDA CONDUCATOR + PASAGER ILUMINATA CU CAPAC
FOLIE INCALZIRE SCAUN --> SCAUN CU INCALZIRE
AIRBAG LATERAL FATA --> AIRBAG LATERAL ZONA TORACE FATA + SPATE + AIRBAG CORTINA
ILUMINAT JOS HABITACLU --> ILUMINAT ZONA PICIOARE PASAGERI FATA + SPATE
PROTECTIE PASAGER SPATE --> FARA ELEMET DE PROTECTIE PASAGER SPATE
NEUTRALIZARE AIRBAG --> DEZACTIVARE MANUALA AIRBAG
PROIECTOR CORECTIE VERTICALA --> REGLARE AUTOMATA A PROIECTOARELOR
PROIECTOR DIRECTIONAL --> CU PROIECTOR DIRECTIONAL
RECEPTOR RADIO --> SISTEM RADIOTELEFON "RT4"
REFRIGERARE --> SISTEM DE REFRIGERARE AUTOMATA
INALTARE SCAUN FATA DE CONDUCATOR --> SISTEM DE INALTARE PERNA SCAUN CONDUCATOR CU REGLARE ELECTRICA
RETROVIZOR INTERIOR --> RETROVIZOR INTERIOR CROMAT ELECTROCHIMIC CU POZITII ZI-NOAPTE
REGULATOR CLIMATIZARE / TEMPERATURA --> SISTEM DE REFRIGERARE AUTOMATA CU DOUA ZONE
DEPOZITARE VOLUM DE INCARCARE --> FARA PLASA IN PORTBAGAJ
TUNER-RADIO --> TUNER DUBLU RADIO
DETECTAREA OBSTACOLULUI --> SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE
STORURI LATERALE --> TRANSPERANTE LATERALE CU COMANDA MANUALA
ADAPTARE GARNITURA --> MANER LEVIER DE VITEZE + BURDUF PIELE
AMPLIFICATOR-EGALIZATOR --> CU AMPLIFICATOR EGALIZATOR
FRECVENTA RADIO --> FRECVENTA RADIO EUROPA OCCIDENTALA
COMANDA DE BLOCARE --> BLOCARE PRIN SUPRA INCHIDERE
VOLANT --> VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE METAL
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) --> SUSTINERE ZONA LOMBARA AUTOMATA
PRIZA AUXILIARA PACK AUDIO --> 1 PRIZA RCA AUDIO
MODUL TELEMATIC --> FARA MODUL TELEMATIC
Electricitate
ALTERNATOR --> ALTERNATOR CLASA 18
BATERIE --> BATERIE L3 500
DEMAROR --> DEMAROR CLASA 6+
ILUMINAT DEOSEBIT --> APRINDERE AUTOMATA + LUMINI DIURNE FATA
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI --> FRECVENTA TELECOMANDA DE BLOCARE 433,92 MHZ HETERODINA
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE --> STANDARD
ATMOSFERA --> ATMOSFERA NORMALA
ETICHETA --> FARA
PARTEA DE CIRCULATIE --> CIRCULARE PE DREAPTA
ECHIPAMENT DE PRIM AJUTOR --> RECIPIENT SUB PRESIUNE REPARARE PNEU
RULARE --> DRUM CORECT
Ordy
Masina: Citroen C4
Mesajde Ordy » Joi 16-Ian-2020 14:12
Va rog, puteti sa ma ajutati cu detalii pentru un Citroen C4 Picasso cu seria de sasiu VF73DBHZMFJ789460 ? Multumesc mult.
Davos
Masina: Citroen C4 Picasso 2.0 BlueHDI BVA
Mesajde Davos » Vin 17-Ian-2020 11:42
@Ordy VF73DBHZMFJ789460
Linie de produs C4 PICASSO / C4 SPACETOURER (B78)
Nr. APV/PR 14176 FV 2 0429
Data de Inceput de Garantie DDG 25.09.2015
Numar de Serie al Motorului 10 JBGY 0024140
OPB 0059
NRE e2*2007/46*0356*09
P4A 9807589399
Informatii generale
LINIE DE PRODUS C4 PICASSO / C4 SPACETOURER (B78)
TIP CAROSERIE BERLINA FAMILIALA
NIVEL DE ECHIPARE INALT JOS PLUS
MOTOR DIESEL TURBO DV6FC FAP 88KW
TRANSMISIE CUTIE DE VITEZE MANUALA 6 TREPTE TIP STOP AND START
TIP DE VOPSEA PLAT STANDARD
CULOAREA CAROSERIEI EWP - VOPSEA ALBA BANQUISE
TIP ECHIPARE INTERIOARA TAPITERIE PANZA ONDULICE "8M"
CULOARE GARNISAJ "FR"
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE MANUALA ML6CV
EVOLUTIE DEFINITIE TEHNICA GAMA INITIALA
MOTOR (TIP) MOTOR TIP DV
MONOGRAMA BLUE HDI
DIRECTIE SISTEM DE DIRECTIE VARIABILA ASISTATA
CUPLU DE TAHOMETRU FARA RAPORT TAHOMETRU
Alimentare motor
ALIMENTARE INJECTIE TURBO DIRECTA CU SCHIMBATOR
DEPOLUARE (MOTOR) DEPOLUARE MOTOR EURO 6.1
PRIZA VITEZE (INFORMATII SENZOR) SENZOR ROTI FATA NESEMNALIZAT SPATE SEMNALIZAT
CILINDREE 1600 CM3
CATALIZATOR CATALIZATOR CU MAI PUTIN DE 50PPM
REZERVOR DE CARBURANT REZERVOR CARBURANT CU ELEMENT DE INDEXARE
MOTOR RACIRE RADIATOR 28DM2-18F1
AUTODIAGNOSTICARE EOBD SISTEM DE AUTODIAGNOSTICARE "EOBD"
DISPOZITIV (ANTIPOLUARE) RECIRCULARE GAZE DE ESAPAMENT "EGR" + SCHIMBATOR
DEPOLUARE TEHNICA VEHICUL DEPOLUARE TEHNICA VEHICUL EURO 6.1
VENTILATOR 1 VENTILATOR 2 TURATII 95W AERO
LANT DE TRACTIUNE CHAINE DE TRACTION THERMIQUE
STOP AND START CU STOP AND START DEMAROR
CUPLU RAPORT RAPORT PUNTE 17 X 65
STIL ROATA (JANTA) JANTA NOTOS 16"
JANTA / PNEU DIMENSIUNI MONTAJ PNEU 16 INCI
PNEURI (DIMENSIUNI, TIP) PNEU 205/60 R16 92H FARA INTARIRE
INDICATOR DE PIERDERE A PRESIUNII DE UMFLARE DETECTARE PNEU DEZUMFLAT INDIRECT FARA LOCALIZARE
BARA ANTIRULIU SPATE RIGIDITATE 30000 NM/RAD
ANTIRULIU FATA BARA ANTIRULIU FATA DIAMETRU 22 TUBULARA
FRANA TIP DISCURI FATA VENTILATE / DISCURI SPATE
UNGHI VOLAN CU SENZOR DE UNGHI VOLAN
SUSPENSIE SUSPENSIE COBORATA
SUSPENSIE (TIP ARHITECTURA) SUSPENSIE METALICA
DIRECTIE (FUNCTIONARE) DIRECTIE ELECTRICA ASISTATA DUBLU PINION LOW POWER
DISPOZITIV DE REMORCARE FARA DISPOZITIV DE REMORCARE
AVERTIZOARE SISTEM DE AVERTIZARE STANDARD
ANTENA ANTENA PAVILION + GPS + INTEGRATA
ORNAMENT LATERAL (DIMENSIUNE) FARA ELEMENTE DE PROTECTIE LATERALE
ORNAMENT DE ROATA (STIL) FARA CAPAC DE ROATA
PROTECTIE SUB CAROSERIE DEFLECTOR SUB PLANSEU FATA
LUMINA DE SEMNALIZARE BALIZAJ LATERAL
ETANSEITATE AERODINAMICA ETANSARE AERODINAMICA USA FATA SI SPATE
FUNCTIE COMPLEMENTARA DE RETROVIZOR EXTERIOR RETROVIZOR EXTERIOR RABATABIL ELECTRIC CU MEMORIE
INSONORIZARE PE MOTOR ELEMENTE DE IZOLARE FONICA TABLIER + CAPOTA + PASAJ DE ROATA + GRUP MOTOPROPULSOR SISTEM CLIMATIZARE
STERGATOR PARBRIZ INTERMITENT CU 2 CADENTE + CADENTA AUTOMATA
OBTURATOR FATA FATA MODUL INTRARE AER PILOTAT
GEAM DE PAVILION CU GEAM DE PAVILION
BARA DE PROTECTIE BARA DE PROTECTIE FATA IN CULOAREA CAROSERIEI + INEL CROMAT SI BARA DE PROTECTIE SPATE IN CULOAREA CAROSERIEI
PLACA DE INMATRICULARE FARA PLACUTA DE INMATRICULARE
PROIECTOR ANTICEATA PROIECTOARE ANTI-CEATA CU LUMINI DE VIRAJ
ASISTARE VIZUALA PANORAMICA FARA SISTEM DE ASISTARE VIZUALA PANORAMICA
ROATA DE REZERVA ROATA DE REZERVA TIP ROLA
ACCESORII EXTERIOARE MANER EXTERIOR NEGRU + INEL CROMAT
GEAM (ASPECT) GEAM FUMURIU + FUMURIU INCHIS
GEAM (TIP) PARBRIZ DIN STICLA STRATIFICATA IZOLATA TERMIC + IZOLATA ACUSTIC + SPATE DIN STICLA SECURIZATA
ACCES SI PORNIRE CU MAINI LIBERE ACCES FATA + PORTBAGAJ + PORNIRE MAINI LIBERE
TETIERA SPATE TETIERA SPATE REGLABILA
SCAUN SUPLIMENTAR FARA PERNA DE SEZUT SUPLIMENTARA
DETECTARE UNGHI MORT CU SUSITEM DE SUPRAVEGHERE UNGHI MORT
MASCARE BAGAJE PANOU + MASCA BAGAJE
CENTURA DE SIGURANTA SPATE CENTURI DE SIGURANTA SPATE CU 3 RETRACTOARE IN 3 PUNCTE + MARTOR LUMINOS DE CUPLARE
CENTURA DE SIGURANTA FATA CENTURA DE SIGURANTA PIROTEHNICA DUBLA CU ALARMA
CLIMATIZOR CU AEROTERMA
COMANDA DE VITEZE COMANDA DE VITEZE LA PODEA
CONSOLA CONSOLA LUNGA + COMPARTIMENT DE DEPOZITARE
EXTRACTOR DE AER FARA EXTRACTOR DE AER
MIRROR LINK FARA OGLINDA LINK
ILUMINAT COMPARTIMENT DEPOZITARE CU LUMINA IN TORPEDOU
ILUMINAT DE PORTBAGAJ VOLUM INCARCARE COMANDA AUTOMATA ILUMINAT PORTBAGAJ + VOLUM DE INCARCARE + AMV
ECHIPAMENT PLANSA DE BORD DECORATIUNE PLANSA DE BORD INTENSIVE
VARIATIE DE ECHIPARE INTERIOARA ECHIPARE INTERIOARA STOFA
LUMINI INTERIOARE DIVERSE ILUMINAT CU LED-URI
MASUTA DE LUCRU CU MASA DE LUCRU
GARNISAJ SPATIU DE INCARCARE COVORAS PORTBAGAJ MOCHETA
DEPOZITARE SUB SCAUN 2 SERTARE DE DEPOZITARE SUB SCAUN
TABLOU DE BORD (CARACTERISTICI) TABLOU DE BORD DIGITAL CU 29 MARTORI LUMINOSI
CAPITONAJ DE USA DECORATIUNE LAC MAT
VENTILATOR ADITIONAL FARA VENTILATOR SUPLIMENTAR
INSONORIZARE HABITACLU IZOLARE FONOCA TABLIER + TUNEL VARF DE GAMA
INALTARE SCAUN DE PASAGER FATA SISTEM INALTARE PERNA SCAUN PASAGER REGLAJ INAINTE
COMANDA DE SCAUN FATA DE CONDUCATOR COMANDA MANUALA SCAUN CONDUCATOR
COMANDA DE SCAUN FATA DE PASAGER COMANDA MANUALA SCAUN PASAGER FATA
REGLARE PERNA DE SEZUT FATA CONDUCATOR PERNA DE SEZUT CONDUCATOR CU REGLARE SPATAR CU INCLINARE
REGLARE SCAUN FATA DE PASAGER SPATAR SCAUN PASAGER CARE SE POATE INCLINA
RABATERE SCAUN FATA DE PASAGER FARA RABATERE PERNA DE SEZUT DE SCAUN PASAGER FATA
COTIERA DE SCAUN FATA COTIERE FATA CONDUCATOR SI PASAGER
CASETA DE DEPOZITARE TRAPE IN PODEA
AFISAJ ECRAN DIGITAL SENSIBIL LA ATINGERE + DIAGONALA 12" DFT
MONTARE TETIERA SPATE MONTARE 3 TETIERE SPATE
AIRBAG LATERAL FATA AIRBAG LATERAL ZONA TORACE + AIRBAG CORTINA
ACTIONARE GEAM ELECTRICA (FUNCTIONARE) FUNCTIE ANTIPRINDERE PE PARTEA CONDUCATORULUI + PASAGERILOR FATA/SPATE
PLAFONIERA COMANDA USI FATA + SPATE PLAFONIERA FATA
PROIECTOR CORECTIE VERTICALA REGLARE MANUALA DE LA DISTANTA A PROIECTOARELOR
RECEPTOR RADIO SISTEM AUDIO ANALOG SMEG
REGULATOR DE VITEZA SISTEM DE REGULARIZARE SI LIMITARE VITEZA PROGRAMABIL
RETROVIZOR INTERIOR RETROVIZOR INTERIOR CU REGLARE PENTRU ZI - NOAPTE
DEPOZITARE (ALTELE) BUZUNAR DIN PLASA PE SPATARUL SCAUNULUI
COVORAS DE PODEA (ASPECT) COVORAS SUPLIMENTAR MOCHETA 1
AIRBAG DE CONDUCATOR AIRBAG LATERAL CONDUCATOR
DETECTAREA OBSTACOLULUI SISTEM DE DETECTARE OBSTACOLE CU RADAR FATA SPATE + CAMERA VIDEO SPATE + PARCARE AUTOMATA
STORURI LATERALE FARA TRANSPERANTE LATERALE
ADAPTARE GARNITURA MANER TEP + PLACUTA CROMATA + BURDUF TEP CU CUSATURA
COVORAS DE PODEA COVORASE SUPLIMENTARE FATA + SPATE
COMANDA DE BLOCARE BLOCARE PRIN SIMPLA INCHIDERE + AUTOMATA
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE
VARIANTA ASOCIATA SCAUN VARIANTA ASOCIATA PERNA DE SEZUT INALTA
AIRBAG DE GENUNCHI CONDUCATOR FARA AIRBAG PENTRU GENUNCHI CONDUCATOR
ECRAN VIDEO SPATE FARA ECRAN VIDEO IN SPATE
RETROVIZOR INTERIOR SUPRAVEGHERE COPII FARA RETROVIZOR INTERIOR PENTRU SUPRAVEGHERE COPIL
PRIZA AUXILIARA PACK AUDIO 1 PRIZA JACK + 2 USB
Electricitate
BATERIE BATERIE L3 760 VRLA2 EN AGM
DEMAROR STTD
ILUMINAT DEOSEBIT LUMINA DIURNA FATA (LATERAL DREAPTA)
FRECVENTA TELECOMANDA BLOCARE DESCHIDERI 433,92 MHZ SUPER HETERODINA
MULTIPLEXARE ARHITECTURA ELECTRICA FULL
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE SOCIETATI (OVSA)
PLACUTA CONSTRUCTORULUI PLACUTA CONSTRUCTOR UNIUNEA EUROPEANA + NRE
ETICHETA FARA ETICHETA
CONECTOR DE ASCULTARE SISTEM AUDIO PRIZA ACCESORII 220V TRIPLA
SOC LATERAL USA CARE NU ESTE INTARITA
LICHID REFRIGERANT LICHID DE REFRIGERARE 1234 YF
RULARE DRUM CORECT
Ordy
Masina: Citroen C4
Mesajde Ordy » Sâm 18-Ian-2020 08:19
Mersi mult!
Ordy
Masina: Citroen C4
Mesajde Ordy » Sâm 18-Ian-2020 08:23
Din pacate, insa, am aflat ca masina s-a vandut....
Davos
Mesajde Davos » Sâm 18-Ian-2020 13:51
N-a fost să fie, aceasta avea cutie manuală, să eviți cutiile de viteze robotizate (pilotate), cele automate cu convertizor sunt foarte fiabile.
Le recunoști ușor, au poziția "P", cele robotizate nu au această poziție.
Toate cele bune și succes.
Trimis de pe al meu SM-G935F folosind Tapatalk
Vasia71
Masina: Citroen C5
Mesajde Vasia71 » Mie 29-Ian-2020 12:36
Buna tuturor. O rugaminte am: as avea nevoie de caracteristicile unui C5 cu seria VF7RDRHHABL555235 pe care il detin. Multumesc anticipat! O zi frumoasa. :)
Davos
Mesajde Davos » Mie 29-Ian-2020 19:30
@Vasia71
Nr. APV/PR 12777 CJ 1 0288
Data de Inceput de Garantie DDG 30.11.2011
Numar de Serie al Motorului 10 DYZD 4000680
OPB H007
NRE e2*2001/116*0360*21
P4A 9691198699
Informatii generale
NIVEL DE ECHIPARE MEDIE INALTA
MOTOR DIESEL TURBO DW10CTED4 FILTRU DE PARTICULE
TRANSMISIE CUTIE DE VITEZE AUTOMATA 6 TREPTE
CUTIE DE VITEZE (CARACTERISTICI) CUTIE DE VITEZE AUTOMATA AM6C1
MONOGRAMA COMPLEMENTARA, DIVERSE FARA MONOGRAMA SUPLIMENTARA
MONOGRAMA C5
Alimentare motor
DETECTOR DE APA IN FILTRUL DE MOTORINA CU SISTEM DE DETECTARE APA IN FILTRUL DE MOTORINA
CILINDREE 2000 CM3
VARIATE DE PUTERE (MOTOR) PUTERE 120 KW 340 NM
VENTILATOR 1 VENTILATOR ELECTRONIC COMANDA INTEGRATA 220W
CUPLU RAPORT RAPORT PUNTE 15 X 53
AMBREIAJ FARA AMBREIAJ
CUTIE DE VITEZE TIP CUTIE DE VITEZE AUTOMATA AM6 NORMA EURO5
LUMINA DE PRAG LUMINI DE PRAG FATA
RETROVIZOR EXTERIOR (ASPECT OGLINDA) RETROVIZOR EXTERIOR CU OGLINDA NEATENUATA
ECHIPAMENT PLANSA DE BORD DECORATIUNE ALUMINIU CALD
LUMINI INTERIOARE DIVERSE ILUMINAT STANDARD + LUMINA DE CITIT RAND2
TABLOU DE BORD (CARACTERISTICI) GRADATIE 260 KM/H 160 M/H MATRICE MONOCROMA
CAPITONAJ DE USA DECORATIE ALUMINIU CALD SOFT
SISTEM DE NAVIGATIE FARA SISTEM DE NAVIGARE
AFISAJ AFISAJ NIVEL C ECRAN MONOCROM
ILUMINAT JOS HABITACLU FARA ILUMINAT INFERIOR DE HABITACLU
RECEPTOR RADIO SISTEM AUDIO COMPACT DISC RDS "RD4/MP3"
INALTARE SCAUN FATA DE CONDUCATOR SISTEM DE INALTARE PERNA CONDUCATOR REGLARE MANUALA
ADAPTARE GARNITURA MANER MANETA PIELE + BURDUF DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE CU 4 BRATE DIN ALUMINIU CULOARE CALDA
SPRIJIN LOMBAR DE SCAUN (FUNCTIONARE) SUPORT LOMBAR MANUAL
PRIZA AUXILIARA PACK AUDIO 1 PRIZA USB
Electricitate
BATERIE BATERIE L3 720 LDC(L3 720 70AH EF 720 EN)
ILUMINAT DEOSEBIT LUMINI DE ZI FATA
APRINDERE LUMINI EXTERIOARE APRINDERE AUTOMATA LUMINI
Diverse
ETICHETA FARA
RULARE DRUM CORECT
Vasia71
Masina: Citroen C5
Mesajde Vasia71 » Mie 29-Ian-2020 23:21
@Davos
Multumesc mult! Toate cele bune!
THUNDER77
Localitate: Pitesti
Mesajde THUNDER77 » Mar 04-Feb-2020 10:26
Salutare! O verificare va rog, multumesc frumos.
VF7RDRHF8AL546135
Nu sunt un tip agitat sau violent , doar ca simt nevoia sa crap cate un cap in fiecare zi.....
norishor
Localitate: Campina / Bucuresti
Masina: Citroen C2 VTS (de competitie)
2: Toyota Prius Gen II (de familie)
Mesajde norishor » Mar 04-Feb-2020 10:29
THUNDER77 scrie:Salutare! O verificare va rog, multumesc frumos.
VF7RDRHF8AL546135
Nr. APV/PR 12287 CJ 1 0485
Data de Inceput de Garantie DDG 15.07.2010
Numar de Serie al Motorului 10 DYXH 4091532
OPB H4DM
NRE e2*2001/116*0360*12
P4A 9666041099
Informatii generale
NIVEL DE ECHIPARE INALTIME MEDIE PLUS
TIP ECHIPARE INTERIOARA TESATURA STCYR G028+OMNISERGE F915’5E’
MONOGRAMA C5
Alimentare motor
CILINDREE 2000 CM3
INCALZIRE CIRCUIT GAZE CARTER FARA SISTEM DE INCALZIRE CIRCUIT DE GAZE CARTER
STIL ROATA (JANTA) ROATA PERSIQUE 17 INCI
ROATA (TIP) MONTARE ROATA ALIAJ 2
SUSPENSIE ACTIVA FARA SUSPENSIE HIDRACTIVA
ORNAMENT DE ROATA (STIL) CAPAC CEDNTRAL DE ROATA PERSIQUE 17 INCI
ACCESORII EXTERIOARE MANER EXTERIOR IN CULOAREA CAROSERIEI
ECHIPAMENT PLANSA DE BORD DECORATIUNE MOLDING EVREST
COTIERA DE SCAUN FATA (FUNCTIONARE) FARA COTIERA FATA
AFISAJ AFISAJ DEV
ADAPTARE GARNITURA BURDUF/MANER MANETA + PLACUTA DIN MATERIAL PLASTIC
VOLANT VOLAN IMBRACAT IN PIELE 4 BRATE DECORATIUNE MOLDING
Electricitate
DEMAROR DEMAROR CLASA 5
APRINDERE LUMINI EXTERIOARE APRINDERE LUMINI MANUALA
Diverse
CRITERIU FACTORI, CLIENTELA CONCEPTIE ANIVERSARA
ETICHETA FARA
RULARE DRUM CORECT
Servicii Diagbox: Activari/dezactivari optiuni / Actualizari software / Telecodare cheie noua/Reparatii chei telecomanda PSA / Telecodare RD/RT CD/Mp3 / Diagnoza pre-achizitie auto
Înapoi la “Citroen C5 III”
    Total mesaje 187751
    Total subiecte 18612
    Posts per day: 24
    Users per day: 2
    Total membri 11707
    Cel mai nou membru AdnanS2024
