Schita injectiei Magneti Mareli G5
Popescu eugen
Localitate: Voluntari Ilfov
Mesajde Popescu eugen » Joi 18-Ian-2007 12:25
Dupa indelungi cautari pt. manualul Haynes am avut marea surpriza sa constat ca G5ul monopunct nu este in acest manual . Rog cu mare insistenta daca-l are cineva sa mil trimita si mie . bx 1.6 tri
Mircea
Mesajde Mircea » Joi 06-Sep-2007 10:37
Eugen,
poate iti foloseste aceasta lista a pinilor de pe conector ECU.
Magneti Marelli G5
1. Control signal to ignition coil, cylinder 1 & 4
2. Control signal to idle speed correction valve
3. Engine speed signal to revolution counter
4. Diagnosis
5. Control signal to main relay
6. Control signal to AC relay
7. Power to throttle potentiometer
8. Not connected
9. Power to manifold air pressure sensor (MAP)
10. Not connected
11. Ground to sensor
12. Ground to sensor
13. Ground
14. Signal from crankshaft sensor
15. Status signal from automatic gear box
16. Ground
17. Ground
18. Control signal to injection valve(s)
19. Control signal to ignition coil, cylinder 2 & 3
20. Control signal to tank ventilation
21. Control signal to fuel pump relay
22. Control signal to engine control lamp
23. Not connected
24. Signal from coolant temperature sensor
25. Signal from throttle potentiometer
26. Signal from air temperature sensor
27. Signal from manifold air pressure sensor (MAP)
28. Diagnosis
29. Constant power from battery
30. Signal from lambda sensor
31. Ground to crankshaft sensor
32. Air conditioner (only certain models)
33. Air conditioner (only certain models)
34. Not connected
35. Power from main relay
Înapoi la “Electrica - BX”
    Total mesaje 187863
    Total subiecte 18687
